MMX-Power
22.09.2005 20:27:38
Skoor 2837, Arvuti on profiilis.
see pole kellatud masinaga, millagi kellan ja siis panen siia ka
_________________ Minu Blogi |
| Kommentaarid: 37 loe/lisa |
33 |
Draco
21.01.2006 00:26:20
PCmark Score : 4199
CPU Score : 3603
Memory Score : 4318
Graphic Score : 4785
HDD Score : 6446
_________________ Purgatory Judgement |
| Kommentaarid: 12 loe/lisa |
12 |
purexpure
| Kommentaarid: 58 loe/lisa |
47 |
Uranus
28.01.2006 02:27:40
PC mark score: 3458
CPU score: 3807
Memory score: 3794
Graphics score: 2681
HDD score: 4428
Gooseman
01.04.2006 23:35:11
| 7554
| Kommentaarid: 10 loe/lisa |
10 |
DonNiger
02.04.2006 01:17:12
4852 p
CPU 4620
MEM 4758
GPU 4310
HDD 5931
P 4 @3.8 GHz
116 |
Gooseman
29.04.2006 20:56:11
3D Mark05 score 8310
CPU score 5024
10 |
Anti
05.05.2006 17:43:49
| Gooseman kirjutas: |
CPU score 5024 |
siin me testime PCMARK05 skoore mitte 3DMark05 skoore
240 |
ivar111
06.05.2007 18:11:58
[hwbot] ivar111 - 7579 - Intel Core 2 6300 @ 3010MHz 4x512MB @ DDR860 CL4.4.4.12 7800GT 591/1291MHz [/hwbot]
Pilt
edit: väike uuendus: 10417p .
| Kommentaarid: 97 loe/lisa |
86 |
weedstone
125 |
windsurfer
| Kommentaarid: 42 loe/lisa |
39 |
Marguzzz
| Kommentaarid: 96 loe/lisa |
92 |
jann5
13.02.2008 08:44:27
ASUS M2N32-SLI deluxe wifi ATX AM2 2xPCI-E16x nForce590,
AMD Athlon 64 X2 6000+
4xDDR2 DIMM 512 DDR800
WD Caviar SE/250GB SATA300 7200rpm 16MB,
MSI GeForce 8800 GT 512MB OverClocked ,
Chieftec 500W,
Acer 22 tolli 5 ms ,
Win vista home premium
7145p
_________________ kui kuuled et arvuti mätsutab siis tea et ta sööb su cd-d |
DonNiger
21.09.2009 10:08:13
Upitame seda teemat ka. Uued kiired kettad väljas, see test enamasti mõeldud neile
12390p: Celeron 430@4,08Ghz, 4GB 453Mhz, 9800GTX+ 800/1150
Global ranking: 499
116 |
Flavius
14.08.2010 22:30:54
Lenovo ThinkPad T400
Protsessor: Intel C2D P8600 2.4GHz
Videokaart: Intel 4500MHD
Mälu: 2x2GB 1066MHz CL7
SSD: Crucial C300 64GB
OS: Windows 7 64bit
PCMark05: 5424p
HDD: 26150p
Core i5 750 @ 3200MHz
2x2GB 1600MHz CL7
HD5850 @ 775/1125
Crucial C300 128GB
Windows 7 64bit
PCMark05: 14541p
HDD: 30313p
118 |
Martin_S
Team Estonia
| Kommentaarid: 95 loe/lisa |
86 |
pohmakas,
käed värisevad
07.11.2010 20:08:20
Täitsa kena
| Kommentaarid: 167 loe/lisa |
138 |
Jaan
07.11.2010 21:56:30
xp startup on ilus- mis see on?
(kui i-ram, siis peaaegu ilus )
123 |
Martin_S
Team Estonia
07.11.2010 22:10:14
See on lihtsalt ssd, I-ram teeb 119 umbes
Crucial RealSSD C300 64GB
86 |
DonNiger
07.11.2010 23:29:22
| Martin_S kirjutas: |
Crucial RealSSD C300 64GB |
Minu ramdisk tegi 209 mb/s Natuke piiratud, sest 220 max lubatud - ketas ise suudam kusagil 230 mb/s
116 |
kaidtor
OC GURU
18.11.2010 22:30:42
e |
Minu poolt ka siis paar tulemust
I3 540@4795Mhz Jahutus Õhk
21663p
I7 980X@5251Mhz Jahutus SS
27248p
136 |
DonNiger
19.11.2010 09:37:49
kaidtor,
116 |
Jaan
19.11.2010 10:54:21
Üldiselt on i-RAM aeg läbi- hea SSD-ga saab paremaid tulemusi.
Näiteks i-RAM vs OCZ Agility 2:
XP startup-109/155MB/s
HDD General Usage- 94/103MB/s- SSD on selgelt kiirem.
Kiiremate SSD-ga on vaja lausa piirata XP startup testi (hwbot piir on 220MB/s)
Videokaardi puhul sobib HD5870 alternativiks uuem HD6870- enam-vähem sama hea.
Üks tulemus kah:
http://hwbot.org/community/submission/1079922_jaan_pcmark_2005_phenom_ii_x4_925_18038_marks
123 |
DonNiger
19.11.2010 13:08:40
I-Ram on jah juba mõnda aega ajalugu.
kaidtor mingi kamm sul HDD general usage - kuidagi ärmiselt madal. PCI-E ketas peaks palju enamaks suuteline olema. Mäletan, et mu ramdiskil oli sama kala, et jäi sinna 100 mb/s kanti kuid katsetades tõusis sinna 170 mb/s juurde. Indexing service välja / alloc. unit size oli vist 64K ja mingid serviced on veel vaja välja lülitada. Päris kinni XP'd keerata ei tohi, 3D ja SPi OS'se kasutada ei saa (nagunii ei saa). W7 kohta ei oska öelda aga seda testi peaks nagunii XP's laskma.
116 |
kaidtor
OC GURU
21.11.2010 18:20:11
Tegin ka väikse paranduse I3 540-ga
22252p
136 |
DonNiger
21.11.2010 18:30:47
kaidtor, ei taha kuidagi avada seda pilti...
116 |
kaidtor
OC GURU
136 |
Martin_S
Team Estonia
19.11.2011 11:38:08
Parandasin oma tulemust:
31686 3DMarks
Konf pildil.
Mõned alatestid nigelad, peab 5870ga ka proovima.
Enne kui Kaido tuleb, on see tiimi parim tulemus
86 |
kaidtor
OC GURU
19.11.2011 12:26:33
Martin_S, Kas SSD-ed olid raid 0-is.
Aga jah tahaks täna ikka tunduvalt suuremat numbrid näha aga eks pastab kuda lähed siiski lootust on
_________________ Teostan autode värvimis- ja keretöid! |
136 |
DonNiger
19.11.2011 13:27:34
Kas XP startup piirang enam ei kehti?
116 |
Martin_S
Team Estonia
19.11.2011 13:50:38
Kehtib, 220
86 |
DonNiger
19.11.2011 14:13:15
Sorry jah, millegipärast arvasin, et 120
116 |
kaidtor
OC GURU
136 |
onni
Martin_S
Team Estonia
23.07.2012 07:55:18
40345 PCMarks
Eesti WR
86 |
Evil
Hull
25.07.2012 15:24:54
Enam vähem.
Proset jahutas vesi?
Edit: tundub, et SS hoopis.
202 |
Martin_S
Team Estonia
25.07.2012 19:32:45
SS jah
Enam vähem tõesti, aga võrreldes väljamaa 80K skooridega on nagu täpe
86 |
