cbr
12.01.2006 16:13:12
Täna lasti siis 1.5 ametlikult välja.
Here's what's new in Thunderbird 1.5:
* Automated update to streamline product upgrades. Notification of an update is more prominent, and updates to Thunderbird may now be half a megabyte or smaller. Updating extensions has also improved.
* Sort address autocomplete results by how often you send e-mail to each recipient.
* Spell check as you type.
* Saved Search Folders can now search across multiple accounts.
* Built in phishing detector to help protect users against email scams.
* Podcasting and other RSS Improvements.
* Deleting attachments from messages.
* Integration with server side spam filtering.
* Reply and forward actions for message filters.
* Kerberos Authentication.
* Auto save as draft for mail composition.
* Message aging.
* Filters for Global Inbox.
* Improvements to product usability including redesigned options interface, and SMTP server management.
* Many security enhancements. |
http://www.mozilla.com/thunderbird/
| Kommentaarid: 48 loe/lisa |
39 |
muku
12.01.2006 17:39:30
on see siis version 1.5 (20051201) ehk viimane RC?
Viimane RC ütleb, et no updates available...
taimpsfm
14.01.2006 04:14:07
| muku kirjutas: |
Viimane RC ütleb, et no updates available... |
Viimane RC on RC2 ehk siis 1.5 final. Ei peagi uuendusi leidma.
Kes tahavad Thunderbirdiga kirja koostamisel eesti keele spellerit kasutada,
kiigaku siia: http://taimar.pri.ee/artiklid/thunderspell/ 8)
_________________ Taimar.ee — Jälgi mind Twitteris! |
| Kommentaarid: 8 loe/lisa |
Tint
14.01.2006 05:40:45
Selle eest küll suur tänu
| Kommentaarid: 34 loe/lisa |
31 |
namstoop
15.01.2006 20:14:24
Mul igatahes 1.5 korralikult tööle ei hakanud. Panin vana tagasi. Tundus, et mingi jama tekkist graafilise poolega just, aken oli kuvatud osaliselt ja meile ka ei näidanud, kuigi olid olemas. Ainult päis oli näha. Proovisin nii puhast installi, kui vanale selga laskmist.
| Kommentaarid: 72 loe/lisa |
63 |
muku
15.01.2006 20:22:44
| namstoop kirjutas: |
| Mul igatahes 1.5 korralikult tööle ei hakanud. Panin vana tagasi. Tundus, et mingi jama tekkist graafilise poolega just, aken oli kuvatud osaliselt ja meile ka ei näidanud, kuigi olid olemas. Ainult päis oli näha. Proovisin nii puhast installi, kui vanale selga laskmist. |
väga huvitav - saada raport thunderbirdi meeskonnale, siis parandavad selle ka ära...
TT
13.02.2006 17:35:20
See probleem on enamsti seotud Pluginate(extensions)
Kõige lihtsam katse, võta extensions kaust enda profiilist maha(enne muidugi tee kogu kaustast koopia) ja proovi kas uus läheb käima!
_________________ Things ThaT You own end up Owning you! |
| Kommentaarid: 312 loe/lisa |
274 |
namstoop
13.02.2006 18:10:54
TT, tänks män, nüüd töötab! Mul polnud enam meeleski, et thunderbirdile tõepoolest ka paar extensionit oli peale läinud.
ja taimpsfm'ile spelleri eest kah
63 |
taimpsfm
ainars
09.03.2006 17:55:43
mul selline jama et ma ei saa thunderbirdiga kirja ära saata. Kirju lugeda saan kuid saata ei saa. mul elioni ühendus ja outgoing severi nimeks panin siis mail.elion.ee, kuid ei midagi ja mis ma sinna peaks siis panema.
kas mail.neti.ee(sellega viskas kah ette et ei saa saata)
| Kommentaarid: 22 loe/lisa |
22 |
namstoop
09.03.2006 17:59:21
ainars, mul ei ole küll elioni ühendus, aga kas mail.hot.ee (või isegi mail.neti.ee?) vms ei peaks olema? Kunagi ma ühel töökaaslasel aitasin nagu asja paika sättida, ja mäletan miskit sellist nagu.
63 |
marqs
| Kommentaarid: 28 loe/lisa |
ainars
10.03.2006 00:48:06
Ei tea, mis kala oli.
igaljuhul sain asja käima kui panin outgoing severi mail.neti.ee asemele mail.hot.ee
suured tänud!
22 |
muri666
03.05.2006 10:08:31
| kas thunderbirdi kuidagi väikeseks ei saaks teha, et ikoon oleks ainult kella juues?
| Kommentaarid: 41 loe/lisa |
39 |
taimpsfm
deppar
17.08.2006 15:16:58
Olen praegu läpakaga Rootsis, kasutan erinevaid wifi võrke, mis peaks olema outgoing serveri aadress, et kirjad ära saaks saata?
_________________ seda ma kartsingi... |
marqs
17.08.2006 18:04:35
selle konkreetse võrgu või teenusepakkuja smtp, võõrast võrgust sind üldiselt ligi ei lasta. kui need võrgud on avalikuks kasutamiseks, siis võib ka kogu smtp liiklus (port 25) blokeeritud olla. viisakamates kohtades võiks vastavat infot jagada kohalik teenindaja.
1 variant on kasutada tls'iga smtp.gmail.com:587 , aga see ei lase sind ilma Autentimata ligi ja seega vaja gmaili kontot.
muidugi saatja aadressi ei saa ka enda suva järgi seada.
läbi tele2 vpni ( https://wifi.tele2.ee/ ) saaks ehk smpt.tele2.ee'le ka ligi, kuid kahjuks on väljaspool tele2 loetletud levialasid selle teenuse tarbimine kasutamistingmustega vastuolus.
_________________ 0xDEAD
0xBEEF |
muhv
18.08.2006 08:45:07
| muri666 kirjutas: |
| kas thunderbirdi kuidagi väikeseks ei saaks teha, et ikoon oleks ainult kella juues? |
Veel selle kirjale vastuseks, et 1 hea proge suvalise proge tray-sse minimeerimiseks vajadusel on TrayIt!.
Kui hoiad all Ctrl nuppu, samal ajal hiirega akna minimeerimisel, minimeeritaksegi ta system tray-sse Hea lihtne ja käepärane proge!
_________________ * Tarkus on relv mida ei tohi anda lolli kätte!
* Kõige hullem on vägisi targaks tehtud loll!
* Pole olemas lollikindlaid asju, kuna lollid on kõige leidlikumad! |
| Kommentaarid: 7 loe/lisa |
deppar
18.08.2006 11:18:23
| marqs kirjutas: |
läbi tele2 vpni ( https://wifi.tele2.ee/ ) saaks ehk smpt.tele2.ee'le ka ligi, kuid kahjuks on väljaspool tele2 loetletud levialasid selle teenuse tarbimine kasutamistingmustega vastuolus. |
selge siis, eks saadan oma kirjad veebist
marqs
19.08.2006 21:22:47
deppar, mu eelnev gmaili jutt oli saatja aadressi suhtes vähe mööda - nüüd oli põhjust gmailis ringi klõpsida ning seal saab
seaded -> konto
alt aadresse lisada. infoks on öeldud:
Kasuta Gmaili oma teistelt e-posti aadressidelt saatmiseks
How do I customize the 'From:' address on outgoing mail?
If you'd like your outgoing Gmail messages to display another one of your email addresses in the 'From:' field (instead of your Gmail address), just follow these easy steps /../ |
ainult 1 pisike mh.. kiiks? nimelt kiri saab lisaks from'ile kaasa "Sender:" välja. näiteks thunderbird näitab mulle midagi sellist:
Subject: blablabla
Sender: GmailiKontole SeatudNimi
Date: 20:54
To: margus
opera mail seda Senderit nii ei eksponeeri.
aga lihtsalt teadmiseks, gmaili smtpd kasutades jäävad kõik saadetud kirjad ka gmaili kasutadesse. kellele mugav viis kirjade varundamiseks, kellele vesi paranoiaveskile.
0xBEEF |
indre
23.08.2006 12:07:05
| Probleem selline, et läppar liigub pidevalt kahe ühenduse vahel - starman ja elion. Panen küll kaks SMTP serverit sisse, aga vahelduva eduga ei kipu ta maile ikkagi saatma. Proovisin ka seda plugini, kus sai nende smpt serverite vahel plõksida, kui ka see ei aidanud. Mida teha?
| Kommentaarid: 17 loe/lisa |
16 |
muri666
07.10.2006 01:00:49
| kas thunderbirdiga kõiki maile kõvakettale korraga salvestada ei saaks kuidagi?
39 |
taimpsfm
07.10.2006 14:06:55
| muri666 kirjutas: |
| kas thunderbirdiga kõiki maile kõvakettale korraga salvestada ei saaks kuidagi? |
Äkki avaldad, kus need mailid sul on? :)
muri666
07.10.2006 21:52:24
| taimpsfm kirjutas: |
| muri666 kirjutas: |
Äkki avaldad, kus need mailid sul on?  |
eks need vist mingil kujul kõvakettal ka , muidu on hoti serveris. Tahaks need nagu ühte doc või txt faili salvestada korraga.
39 |
ZHarp
13.02.2007 15:55:56
| Kas Thunderbird's on võimalik printida lehti välja ilma saaja aadressita? Sellest pole lugu kui saajaid on 1-5, aga mitmed kirjad on saadetud kuni paarisajale inimesele ja esimesed kaks väljaprinditud lehte koosnevad siis ainult saaja aadressidest. Ainsa lahendusena olen leidnud valikud ...Edit As New ja siis printima panna. Küllaltki ebamugav.
| Kommentaarid: 61 loe/lisa |
56 |
