-vodafone-
14.01.2006 01:28:24
UDMA2>UDMA5 |
Field Value
ATA Device Properties
Model ID WDC WD400LB-07DNA0
Serial Number WD-WMADY1044838
Revision 77.07W77
Parameters 77545 cylinders, 16 heads, 63 sectors per track, 600 bytes per sector
LBA Sectors 78165360
Buffer 2 MB (Dual Ported, Read Ahead)
Multiple Sectors 16
ECC Bytes 74
Max. PIO Transfer Mode PIO 4
Max. UDMA Transfer Mode UDMA 5 (ATA-100)
Active UDMA Transfer Mode UDMA 2 (ATA-33)
Unformatted Capacity 44727 MB
ATA Device Features
SMART Supported
Security Mode Supported
Power Management Supported
Advanced Power Management Not Supported
Write Cache Supported
Host Protected Area Supported
Power-Up In Standby Not Supported
Automatic Acoustic Management Supported
48-bit LBA Supported
Device Configuration Overlay Supported
Field Value
Model ID QUANTUM FIREBALLlct08 04
Serial Number 691931390508
Revision A05.0X00
Parameters 8912 cylinders, 15 heads, 63 sectors per track, 512 bytes per sector
LBA Sectors 8421840
Buffer 418 KB (Dual Ported, Read Ahead)
Multiple Sectors 16
ECC Bytes 4
Max. UDMA Transfer Mode UDMA 4 (ATA-66)
Unformatted Capacity 4112 MB
ATA Device Features
SMART Supported
Automatic Acoustic Management Not Supported
48-bit LBA Not Supported
Device Configuration Overlay Not Supported
ATA Device Physical Info
Manufacturer Quantum
Hard Disk Family Fireball lct
Family Code Name Eagle
Form Factor 3.5"
Formatted Capacity 4340.5 million bytes
Disks 1
Recording Surfaces 1
Physical Dimensions 146.1 x 101.6 x 25.4 mm
Max. Weight 580 g
Average Rotational Latency 5.56 ms
Rotational Speed 5400 RPM
Max. Internal Data Rate 257 Mbit/s
Average Seek 9.5 ms
Track-To-Track Seek 2 ms
Full Seek 18 ms
Interface Ultra-ATA/66
Buffer-to-Host Data Rate 66.6 MB/s
Buffer Size 512 KB
Spin-Up Time 8 sec
Kaskettad saab panna vähemalt UDMA4 pealtööle?
Kommentaarid: 244 loe/lisa |
216 |
Ho Ho
14.01.2006 01:41:20
Peaks saama vist küll.
Millise juhtme kljes nad sul on? Kas vana 40 kiuga rim või uuem 80'ga?
Kommentaarid: 106 loe/lisa |
86 |
-vodafone-
14.01.2006 01:42:57
Vana 40 peaks olema ikka
216 |
Ho Ho
86 |
HacaX
15.01.2006 09:11:11
Lisaks kaablile on vaja ka kiibistikupoolset tuge sellisele kiirusele (ehk teisisõnu: kui mingi enneveeuputuseaegne PII siis ei saagi tõenäoliselt suuremat kiirust, hoolimata sellest et ketas ise on rohkemaks võimeline). Ja kui ketas juhtub mõne aeglase seadmega (CD-ROM näiteks) sama IDE kanali peal olema siis võib kah olla et rohkemat ei venita välja.
Kommentaarid: 24 loe/lisa |
22 |
-vodafone-
15.01.2006 14:15:24
HacaX, masin on mul profiilis. Just PII ei ole
216 |
lisa lemmikuks |
