-vodafone-
15.12.2005 23:11:38
Kellame minu Abit IS7 + P4 2.0Ghz + 256mb Pc2700 Infineon |
Kõigepealt mainin ära, et olen algaja OC fänn ja OC esimest korda.Niisiis vaadake oma silmadega yle.
Field Value
CPU Properties
CPU Type Intel Pentium 4
CPU Alias Northwood, A80532
CPU Stepping B0
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 2.00GHz
CPUID Revision 00000F24h
CPU Speed
CPU Clock 2601.1 MHz (original:2000MHz, overclock: 30%)
CPU Multiplier 20.0x
CPU FSB 130.1 MHz (original: 100 MHz, overclock: 30%)
Memory Bus 173.4 MHz
DRAM:FSB Ratio 4:3
CPU Cache
L1 Trace Cache 12K Instructions
L1 Data Cache
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
Motherboard Properties
Motherboard ID 03/30/2005-i865PE-W83627-6A79AA1BC-24
Motherboard Name Abit IS7-G (5 PCI, 1 AGP, 4 DDR DIMM, Audio, Gigabit LAN, IEEE-1394)
Chipset Properties
Motherboard Chipset Intel Springdale i865PE
Memory Timings 2.5-3-3-7 (CL-RCD-RP-RAS)
PAT Enabled
SPD Memory Modules
DIMM1: Infineon 64D32300GU6B 256 MB PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz)
Temp on tavaliselt ~37* ja SuperPI ajal kuskil ~48*
Mis arvate? Mida võiksin muuta/sättida. Hetkel siis 2,6Ghz ja stabiilne.
1.(Mälu timingud pole meeles)
Taktsagedusel 2000Mhz olid tulemused testides: (Everest Ultimate)
CPU Queen - 1159
CPU ZLib - 8376
Mem read - 2031
Mem latency- 125.1
SuperPI 1M - -
2. (2-2-2-5)
Taktsagedusel 2400Mhz olid tulemused:
CPU Queen - 1392
CPU ZLib - 10134
Mem read - 2449
Mem latency- 106,5
SuperPI 1M - 1,05
3.(2.5-3-3-7)
Taktsagedusel 2600Mhz olid tulemused:
CPU Queen - 1508
CPU ZLib - 10883
Mem read - 2667
Mem latency- 94,5
SuperPI 1M - 1,01
4.(2.5-3-3-7)
Taktsagedusel 2700Mhz olid tulemused:
CPU Queen - 1578
CPU ZLib - restart
Mem read - -
Mem latency- -
SuperPI 1M - -
Miks masin 2700MHz peal testides restardi tegi? Toide on 400W Q-Tec kas sinna ongi see koer maetud?
Tean mälu on kuid hetkel pole midagi muud võtta kuid otsin/ostan PC3200 pulga 512mb siis. Kas mälu vahetamine annab midagi juurde, ma mõtlen just OC vallas.Mis vahe selle mäluga on?
Kommentaarid: 244 loe/lisa |
216 |
Riivo
16.12.2005 22:30:22
mälu piirini on veel aega. proovi prosele volte juurde anda
Kommentaarid: 233 loe/lisa |
221 |
-vodafone-
16.12.2005 22:34:15
riivo21 kirjutas: |
mälu piirini on veel aega. proovi prosele volte juurde anda |
Kas see võib aidata?Oletad või tead. v juurde keeramine annab stabiilsust- et ei tee restarti we.
216 |
Riivo
16.12.2005 22:47:21
-vodafone- kirjutas: |
riivo21 kirjutas: |
Kas see võib aidata?Oletad või tead. v juurde keeramine annab stabiilsust- et ei tee restarti we. |
see ei pruugi küll 100%'liselt aidata aga tasuks proovida. pane algul võimalikult vähe juurde
221 |
-vodafone-
16.12.2005 22:48:17
riivo21 kirjutas: |
riivo21 kirjutas: |
see ei pruugi küll 100%'liselt aidata aga tasuks proovida. pane algul võimalikult vähe juurde |
ikka jah.Proovin, kui mälu ära ostan PC3200
216 |
Riivo
16.12.2005 22:53:54
mälu vaheatmine ei anna sulle midagi juurde, sest...
su arvuti fsb on defaultis 100
praegu (klokituna) on 133
praegused mälud on 166
pc3200 mälud on 200
221 |
-vodafone-
16.12.2005 22:57:30
riivo21 kirjutas: |
pc3200 mälud on 200 |
Miks mu arvuti fsb siis deafaultis on 100 IS7??
216 |
Riivo
16.12.2005 23:12:37
see oleneb protsessorist. aga vaatasin su arvuti confi uuesti ja tähelepanelikumalt läbi ja pean vabandama. sul on dram:fsb ratio 4:3 seega on pc3200 mäludest kasu küll. kasu suht väike aga olemas siiski
221 |
-vodafone-
16.12.2005 23:17:31
riivo21 kirjutas: |
see oleneb protsessorist. aga vaatasin su arvuti confi uuesti ja tähelepanelikumalt läbi ja pean vabandama. sul on dram:fsb ratio 4:3 seega on pc3200 mäludest kasu küll. kasu suht väike aga olemas siiski |
Ostma pean niivõi naa kuna mälu hetkel võetud perearvutist Tahaks ikka 2.8Ghz kätte saada, temp kh suht madal.
216 |
Riivo
16.12.2005 23:20:33
kas proovisid volte juurde anda? mälule võid ka natukene lisapinget anda. kuigi esimese korraga ei tasuks liiale minna
221 |
-vodafone-
16.12.2005 23:23:02
riivo21 kirjutas: |
kas proovisid volte juurde anda? mälule võid ka natukene lisapinget anda. kuigi esimese korraga ei tasuks liiale minna |
Ei ole veel proovind. Ostan omale mälu ära ja siis saan kasti omavaldusse ja hakkan piire otsima. Hetkel on risk suur, et kui midagi nihu läheb siis kannatab ka pere selle all.
Aga ei tea palju selline prose on läinud mõndadel õhuga?
216 |
neoman
17.12.2005 12:47:41
Sa võiksid vaadata kas BIOS is on selline asi nagu PCI/AGP lock 66/33 mhz peaksid need olema . Või fixed .
Kommentaarid: 78 loe/lisa |
-vodafone-
17.12.2005 20:59:58
neoman kirjutas: |
Sa võiksid vaadata kas BIOS is on selline asi nagu PCI/AGP lock 66/33 mhz peaksid need olema . Või fixed . |
on selline asi olemas. Mis sellest siis? 66/33 on
216 |
Riivo
17.12.2005 21:16:42
kui ei oleks, siis võib see ka klokkimist takistada
221 |
neoman
18.12.2005 00:36:56
mitte ei või vaid takistab päris kindlalt.
-vodafone-
19.12.2005 17:22:40
neoman kirjutas: |
uurisin, seda 66/33 muuta ei saa on hall ja seal ennem seda 66/33 mhz on kirjas mingi fixed. Kui hakkan fsb muutma siis muutuvad selle järel ka need 66/33
NT:
algul on 100/66/33
kui muudan siis 120/64/35 nt ma neid arve täpselt ei tea aga kui panen 133 siis on nagu korra 133/66/33
Panin siis BIOS´est fsb 133 (20x133) sain taktsageduseks 2672.8 MHz (original 2000 MHz, overclock: 34%)
CPU Clock 2672.6 MHz (original 2000 MHz, overclock: 34%)
CPU FSB 133.6 MHz (original: 100 MHz, overclock: 34%)
Memory Bus 178.2 MHz
DRAM:FSB Ratio 4:3
Memory Timings 2-3-3-6 (CL-RCD-RP-RAS)
PAT Enabled
Prose nagu ikka 1,4v
Testides olid tulemused:
(Taktsagedusel 2672.6Mhz)
CPU Queen - 1554
CPU ZLib - 11161
Mem read - 2719
Mem latency- 93.3
SuperPI 1M - 59sec
SuperPI 2M lahendamisel ei tõusnud prose temp kõrgemale kui 49C* (2663rpm) ja PWM oli 45C* (toitekas vist?)
No ikka väga kylm prose on 2.0@2.7Ghz temp on tavaliselt 36C* Super PI 2M lahendamisel tõuseb max 49C*
216 |
neoman
20.12.2005 17:21:40
Northwoodid on jah jahedad. Samas prescu on sama hea kui saun
-vodafone-
21.12.2005 17:01:24
CPU Clock 2410.3 MHz (original: 2000 MHz, overclock: 21%)
CPU FSB 120.5 MHz (original: 100 MHz, overclock: 21%)
Memory Bus 160.7 MHz
DRAM:FSB Ratio 4:3
Chipset Properties
SPD Memory Modules
Memory Timings 2-3-3-6 (CL-RCD-RP-RAS) kuid (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz) näitab ju , et @ 133 MHz peaks mälu jooksma kuid jookseb 160.7 MHz
Miks see nii on?
Prose temp hetkel 29C* 8)
216 |
Riivo
22.12.2005 11:44:09
Miks see nii on? |
sellepärast et sa oled mälu klokkinud. timingud ja sagedus ei ole otseses seoses. sulgudes on märgitud default andmed
221 |
