uus teema   vasta Raud »  Protsessorid »  AMD Athlon(tm) XP 2600+ Barton ABI oleks vaja ? märgi kõik teemad loetuks
Taimps
Taimps
sõnum 11.12.2005 20:02:45 AMD Athlon(tm) XP 2600+ Barton ABI oleks vaja ? vasta tsitaadiga
profiilist näha masina andmeid. Pusisin natukene ja tekkis paar küsimust, et miks ma ei saa panna FSB-d 200 peale ja et kuidas ma saaksin rami dualis tööle?
Siin siis tulemused mis ma hetkel välja pusisin:
1.
Number of CPUs 1
Name AMD Athlon XP
Code name Barton
Specification AMD Athlon(tm) XP 3000+
Family/Model/Stepping 6A0
Extended Family/Model 7/A
Package Socket A
Technology 0.13µ
Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
Clock Speed 2149.1 MHz
Clock multiplier x11.5
Front Side Bus Frequency 186.9 MHz
Bus Speed 373.8 MHz
P-Rating 3000+
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2149.1 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Northbridge nVidia nForce2 Ultra 400 rev. C1
Southbridge nVidia nForce2 MCP rev. A4
Graphic Interface AGP
AGP Revision 3.0
AGP Transfert Rate 8x
AGP SBA supported, enabled
AGP Aperture 128 MBytes
Memory Type DDR
Memory Size 512 MBytes
Memory Frequency 186.9 MHz (1:1)
CAS# 3.0
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 8
DIMM #2
General
Memory type DDR-SDRAM
Manufacturer (ID) (0000000000000000)
Size 256 MBytes
Max bandwidth PC3200 (200 MHz)
Part number
Manufacturing date Week 00/Year 00
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 200
CAS# 2.5
RAS# to CAS# delay 3
RAS# Precharge 3
TRAS# 8
DIMM #3
General
Size 256 MBytes
Part number
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 133 166 200
CAS# 2.0 2.5 3.0
RAS# to CAS# delay 2 3 3
RAS# Precharge 2 3 3
TRAS# 6 7 8
BIOS #1
vendor Phoenix Technologies, LTD
version 6.00 PG
date 10/17/2003
CPU #1
manufacturer AMD
model AMD Athlon(tm) XP
clock speed 2140.0MHz
FSB speed 186.0MHz
multiplier 11.5x
Memory Module #1
designation A0
Memory Module #2
designation A1
size 256MBytes (single bank)
Memory Module #3
designation A2
Memory Device #1
designation A0
format DIMM
type unknown
speed 65MHz
Memory Device #2
designation A1
format DIMM
type unknown
size 256MBytes
speed 65MHz
Memory Device #3
designation A2
format DIMM
type unknown
size 256MBytes
speed 65MHz
2.
SiSoftware Sandra
Mainboard
Manufacturer : Pronix (Epox)
MP Support : No
Model : nVidia-nForce
System BIOS : 10/17/2003-nVidia-nForce-6A61BPACC-00
Chipset : nVidia nForce2 ICP
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Maximum Installable Memory : 1GB
Bank0/1 - A0 : Empty
Bank2/3 - A1 : DIMM 256MB
Bank4/5 - A2 : DIMM 256MB
Chipset 1
Model : Nvidia Corp nForce2 AGP Controller
Bus(es) : ISA AGP PCI USB FireWire/1394 i2c/SMBus
Front Side Bus Speed : 2x 187MHz (374MHz data rate)
Width : 64-bit
Logical/Chipset 1 Memory Banks
Power Save Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 2 : 256MB 8x(32Mx8) DDR-SDRAM PC3200U-2533-600 (CL2.5 up to 200MHz) (CL2 up to 167MHz)
Memory Module 3 : 256MB 8x(32Mx8) DDR-SDRAM PC3200U (CL0 up to 200MHz) (CL429496729.1 up to 167MHz) (CL429496728.6 up to 34MHz)
Environment Monitor 1
Model : Winbond W83627HF ISA
Version : 2.01
Mainboard Specific Support : No
Temperature Sensor(s)
CPU Temperature : 39.0°C / 102.2°F
Power / Aux Temperature : 18.0°C / 64.4°F
Cooling Device(s)
Auto Fan Speed Control : No
Chassis Fan Speed : 1758rpm
CPU Fan Speed : 2482rpm
Power / Aux Fan Speed : 2519rpm
Voltage Sensor(s)
CPU Voltage : 1.63V
Aux Voltage : 1.58V
+3.3V Voltage : 2.85V
+5V Voltage : 5.08V
+12V Voltage : 11.80V
-12V Voltage : -7.18V
-5V Voltage : -5.05V
Standby Voltage : 4.82V
Battery Voltage : 3.06V
The Power of Dreams
allar4
allar4
sõnum 11.12.2005 21:25:41 vasta tsitaadiga
Tõsta prose volti icon_exclaim.gif Kui ma ei eksi, siis sellel prosel def volt 1.65 kõik oleneb ka sinu toitekast, et kas see vastu peab! Prosele võid julgesti 0,1 volti juurde anda! Aga arvan, et so toitekas jääb nõrgaks, sest praegused näidud on küll VÄGA paigast ära icon_lol.gif
Kommentaarid: 39 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 36
Taimps
Taimps
sõnum 12.12.2005 02:05:25 vasta tsitaadiga
timmisin ja proovisin siin ja sain järgmise tulemuse:
Number of CPUs 1
Name AMD Athlon XP
Code name Barton
Specification AMD Athlon(tm) XP 2600+
Package Socket A
Technology 0.13µ
Clock Speed 1930.7 MHz
Front Side Bus Frequency 167.9 MHz
Bus Speed 335.8 MHz
P-Rating 2600+
L2 Speed 1930.7 MHz (Full)
L2 Location On Chip
AGP Revision 3.0
Memory Type DDR
Memory Frequency 201.5 MHz (5:6)
CAS# 3.0
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 8
DIMM #1
General
Size 256 MBytes
Part number
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
CAS# 2.0 2.5 3.0
TRAS# 6 7 8
DIMM #2
General
Size 256 MBytes
Part number
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 200
CAS# 2.5
RAS# Precharge 3
TRAS# 8
The Power of Dreams
Oioi
sõnum 13.12.2005 02:37:30 vasta tsitaadiga
Taimps kirjutas:
Taimps kirjutas:
Mis kõige selle pika timmimise ja proovimise point siis nüüdsesks olema peaks icon_rolleyes.gif
Kommentaarid: 262 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 236
allar4
allar4
sõnum 13.12.2005 08:46:19 vasta tsitaadiga
Oioi kirjutas:
Taimps kirjutas:
Taimps kirjutas:
antikondor
antikondor
sõnum 15.12.2005 13:02:37 vasta tsitaadiga
Mis kuradi asi on 2600+ barton?
Olen jah muusika suhtes elitaarne sitapea
000 WHILE hangover
001 drink beer
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 45
Oioi
sõnum 15.12.2005 13:22:51 vasta tsitaadiga
Antikrist kirjutas:
(miks see jutt ikka muidu protsessorite foorumis tolkneb icon_razz1.gif )
dexter666
dexter666
sõnum 15.12.2005 13:52:55 vasta tsitaadiga
soovitaks toiteka välja vahetada, sest toite pinged on liiga madalad hetkel. Siis kui see tehtud hakka prosele biosist vaikselt volti juurde lisama, proovi väikeste sammudega. Nii 0,25v sammudena, pinget tõstad seni kuni arvuti on stabiilne. Et mälud duali panna tuleb neid ümber tõsta, paned mälud esimesse ja teisse pessa. Nii, et mälud jäävad emaplaadil kahte esimesse parempoolsesse slotti. Üks mälu on eraldi seisvas pesas ja teine kohe sellele järgnevas.
Kommentaarid: 93 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 85
antikondor
antikondor
sõnum 15.12.2005 14:48:19 vasta tsitaadiga
Oioi kirjutas:
Antikrist kirjutas:
Irw, sedant küll, mul endal kah bartoni corega prose, kui ma pole varem 2600+ designatsioonist kuulnud.
000 WHILE hangover
001 drink beer
olc
olc
sõnum 15.12.2005 14:51:29 vasta tsitaadiga
Antikrist kirjutas:
Oioi kirjutas:
Antikrist kirjutas:
Irw, sedant küll, mul endal kah bartoni corega prose, kui ma pole varem 2600+ deignatsioonist kuulnud.
2600+ on täiesti olemas. 1910MHz peaks takt olema, ehk 11.5x166
Kui need 12V ja 3.3V seal õiged on siis on küll mingi lahja toide taga.
Kommentaarid: 141 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 129
käbi
sõnum 15.12.2005 14:52:56 vasta tsitaadiga
dexter666 kirjutas:
0,25 ei ole väike samm, enamusel pigem maximum
0,05 oleks väike
Elof
Elof
sõnum 15.12.2005 15:00:25 vasta tsitaadiga
olc kirjutas:
Antikrist kirjutas:
Oioi kirjutas:
Antikrist kirjutas:
Enne oleks loomulikult mõte need voldid ka manuaalselt üle mõõta testriga.
Emaplaadi andurid kipuvad väga tihti ropult valetama.
Olen ainult 1 emaplaati kohanud, mis enam-vähem täpselt suutis volte mõõta.
