JediMihkel
27.11.2005 14:30:46
ma selle raido antud jutule eriti pihta ei saand et miks palutakse kõik serverid kinni panna kas selle üldise pira pärast või mille pärast?
Kommentaarid: 42 loe/lisa |
38 |
RvN
27.11.2005 14:54:55
selleks on päris mitu põhjust:
näiteks pole ikka veel built-in anti-cheat programmi, mistõttu on cheatereid pea võimatu avastada
samuti on väga low-fps kohti palju, mis oleks updatega vaja ära fixida
jne
Kommentaarid: 43 loe/lisa |
42 |
j22lind
27.11.2005 14:56:44
Raidomarek kirjutas: |
jama värk rahvas ...
Call of Duty 2 server boycott?
It looks like the Call of Duty 2 community is very pissed off with the developer - Infinity Ward and are planning a boycott by "mass server shutdowns of all Call of Duty games at a time of our choosing" (thanks Alistair Russell)
The statement should include the following:
1. When will you include an Anti-Cheat system for COD2?
2. When you you release your 1st patch for COD2?
3. What will it include?
4. What other plans have you for the support of the Call of Duty Games?
5. What will you do to ensure this situation does not arise again?
Failure to comply with this very simple request will result in the following action:
We will actively encourage ALL Clans, Leagues, Ladders, Players, Admins and server providers to enforce a series of 24hr mass server shutdowns of all Call of duty games at a time of our choosing.
Don't take this lightly, word spreads, people won't buy a broken toy. This has never been done before and do you really want to go down as the first and only companies to have it's client/fan base take such drastic measures in order to simply be given some regular information about a product, the choice is yours alone.
WE WILL NOT BE IGNORED ANY LONGER. |
hehe, päris hea Ma just olin vaadanud The Rocki ja siis lugesin seda postitust, milline kokkusattumus.
Kommentaarid: 5 loe/lisa |
lightbluefox
27.11.2005 15:02:58
ühesõnaga Infinity Yards ütles et neil on rull otsas ja ei viitsi enam call of duty 2ga tegelda. Mäng on ju tegelikult nn beeta. No kes tahaks mängu kus näed täpselt kuhu granaat kukub, näed kus vaenlased on, lõppematu helf jne. Täitsa arusaadav värk.
Mõtlen et võtan tna vist cod 1 peale...orikaid keeysid nigu muda
Kommentaarid: 45 loe/lisa |
44 |
JediMihkel
28.11.2005 16:55:23
aa et kui koode tead saad petta nagu ve.
ma küll kedagi näinud ei ole
ja naad ikkagi ei saa ju kõiki servusid kinni panna need arvutit es ses ümber maailma ju.
Beta mismoodi. aga see võiks küll teistmoodi olla et sa ei näe kui grana su juurde kukub et seda hoiatus värki ei hakka plinkima
38 |
Smoking
28.11.2005 18:26:46
JediMihkel kirjutas: |
Beta mismoodi. aga see võiks küll teistmoodi olla et sa ei näe kui grana su juurde kukub et seda hoiatus värki ei hakka plinkima |
Mitte mingil juhul ei saa koodidega petta vähemalt usun, et teil ei ole nii halb süsteem.
Kommentaarid: 360 loe/lisa |
298 |
Sarin
28.11.2005 20:12:54
kinni nad seda mängi ei pane.
lihtsalt ei tohi.
ma olen kindel et varsti on updated ja värgid.
mina kardan, et sellest mängust saab üks vägagi populaarne teamide mäng.
Kommentaarid: 7 loe/lisa |
lightbluefox
28.11.2005 21:37:30
kes chiitidest rääkis?
Kui keegi laseb sinu kuuldeulatuses niisama või kellelegi pihta, näidatakse ju kohe laskja asukoht kaardil ära. Mine aint kohale ja realiseeri kill.
Mäng on üldse mingitele newcomeritele tehtud, vähemalt tundub
MPs on ka skilliga tüüpe väga vähe, enamus sellised low-med skilliga, servus 1ks saada pole just teab mis probleem...
44 |
One
28.11.2005 22:34:24
ffs, mohaas/codis oli kah alguses nii, et näitas killeri asukoha ära ja hea seegi, fakin kämperi kari okse
kui mängutegijad on teinud sellise mängu siis see ka on selline..
mitte, et mingid lamedad fleimarid kes mohaa ja codi oma "reaalsus" patchidega ära sittusid vinguvad
ja siis infinity ward peab hüppama...
ahvikari raisk
huvitav kas 2ms ajal ütlesid kah osad vandid, et ära pumpa kasuta ja sõimasid sind n00biks
kui ise vastu ei saanud? vaevalt küll
ja ärge tulge vinguma, et ma ei tea millest räägin, tean küll, olin mõlemas mängus suht tipus
Kommentaarid: 1009 loe/lisa |
728 |
Le Inc
28.11.2005 22:44:17
COD2 SP on küll suhteliselt "reaalsuse" lähedane mäng. Lihtsalt kargamise asemel tuleb sihik ette võtta ja rahulikult lasta. Pähe lask on kohe surmav .. mida sa veel tahad? Samas see nö. lõputu elu on tegelikult suhteliselt asjalik, igatahes parem kui mööda kaarti ringi joosta ja elupakikesi otsida.
Kommentaarid: 56 loe/lisa |
54 |
One
28.11.2005 23:07:14
imho on samuti see taastuv energia suht asjalik.. tuleb ekraanile, et get cover ja tõmbad kõrvale, et varsti uuesti üritada..
ja kellele liiga kerge siis tõstku raskustaset.
728 |
lightbluefox
29.11.2005 00:35:18
MP on ikka asi mis raha sisse toob, SP teed 2, 3 võibolla isegi 8 korda läbi ja siis on kopp ees. ja kui Mp on igav jääbki karp riiulile...
44 |
Fhlouz
29.11.2005 01:02:41
haha ja tahate öelda et COD 2-le ei tule mingit official patchi ega anti-cheat asja??? no siis jääb küll asi ostmata!!! cod 1 foreva m8
_________________ Wordpress/Woocommerce kodulehed/epoed. |
Kommentaarid: 3 loe/lisa |
marcor1
29.11.2005 12:39:36
Mäng oli hea kuid "koridoris jooksmine" - muutus lõpuks tüütuks.
Mängisin "tavalise" raskusega ja kasutades tossupomme ning jookse&valang kõhtu taktikat muutus asi kohati suht läbuks.
Häiris vastaste taastekkimine - seega polnud mõtet neid kõiki killida - piisas elusalt teatud punkti jõudmisest. Alles oma tiimi saabumisel lakkas vastaste vool.
Positiivne:mugav elusüsteem; õhustik ja tempo; vaenlaste relvade üles korjamine(pole laskemoona probleeme)
Negatiivne: koridori süsteem; lühidus; eluhoidmisest ja hoolsast sihtimisest pole kasu - oluline on elusalt punkti "x" jõuda
OT: kas midagi SWAT 3-e taolist on ka veel ilmunud?
Kommentaarid: 68 loe/lisa |
62 |
der hammer
29.11.2005 15:59:25
marcor1 kirjutas: |
OT: kas midagi SWAT 3-e taolist on ka veel ilmunud? |
SWAT 4 on
_________________ Tere. |
Kommentaarid: 148 loe/lisa |
130 |
RvN
29.11.2005 18:33:52
Fhlouz kirjutas: |
haha ja tahate öelda et COD 2-le ei tule mingit official patchi ega anti-cheat asja??? no siis jääb küll asi ostmata!!! cod 1 foreva m8 |
keegi on asjast väga valesti aru saanud
see tuleb igal juhul, cod1'l tuli neid patche ka päris mitu
probleemiks siis praegu see, et noliferid pole väga kannatlikud, pmst on mäng alla kuu vana euroopas kui juba mingit lärmi tõstetakse, like WTF?
42 |
lightbluefox
29.11.2005 18:55:36
lärm on täitsa põhjendatud
44 |
Thinkie
01.12.2005 20:57:12
Lõpuks siis PS2 versioon käes ning jah, PS2 ei ole PC Kõik on kuidagi viivega minuarust. Ja see pudiga mängimine... ei noh andke andeks. Tellisin PS2 klaveri aga kahtlen sügavalt, et COD seda lubab. Igatahes selle vibraatorpuldiga ei saa mingist korralikust snaiperdamisest juttugi olla.
Muide PS2 versioonis on med-packid alles.
One
10.12.2005 22:31:06
norm peli 2048x1536 reso ja 4x AA kõik max mängust aga DX7 render ja lippab nagu kuld
just kõmmutasin natukene, tõeliselt hea mäng
728 |
lightbluefox
10.12.2005 23:26:57
huvi pärast küsin WW, kuidas on mõnes MP rahvarohkemas serveris kui reso on 1024x768 ja graff low- med?
44 |
kuul
10.12.2005 23:32:07
Mängu kohta siis et üks kõvemaid SP mänge mida mänginud olen, BF2 peaks ka veel ära proovima siis ehk saab teise elamuse veel, kuid SP versioon on sigamõnus, eriti need suured lahingud, kus pead lihtsalt käristama, linnas tormama jne, MP versiooni ei saa mängida(eks arvake ise miks:D) nii et sellekohta kommentaare pole
Kommentaarid: 20 loe/lisa |
20 |
One
10.12.2005 23:35:15
huvi pärast küsin WW, kuidas on mõnes MP rahvarohkemas serveris kui reso on 1024x768 ja graff low- med? |
kuidas mp-s freim limiteri maha saab?
ja kurat ma ei saa servudesse... teadagi mille pärast
728 |
One
11.12.2005 01:57:50
see viimane servu:
1024x768 medium
keskmine fps jääb sinna 250-300 kanti
vahest tõuseb üle 500
edit:
1024x768
kõik max, 4x AA
min fps seal 120 kandis, keskmine 150-200
728 |
RvN
11.12.2005 15:04:57
keegi mängib mingites noobservudes:D
anyway, alates 70st fps'ist vahet pole, laagi pole tundagi
ja 250-300 sa küll oma 800gt'ga ei saa... mingi väga miinustes settingutega ka mitte
42 |
Smoking
11.12.2005 15:09:32
RvN, Tead ka mida räägid? Tal on X800GT2 mille bios on flashitud X850XT PE-ks ja kellad on üsna lähedale selle def-ile. X850XT PE on kiireim X seeria kaart välja arvatud X1800, nii et pole mingit probleemi saada tema prose ja mäludega sellist tulemust.
298 |
