sõnum ![Teata moderaatorile Teata moderaatorile](./images/icon_move_w.gif) |
vanake
![vanake vanake](https://foorum.hinnavaatlus.ee/images/avatars/upload/c2f60fe06d94a979206c9601daf9df7d.jpg)
28.10.2005 21:54:16
Nüüd on asi täiesti kindel, et järgmisel nädalal saab mängu poodides näha. Iseasi muidugi kuna ta Eestise jõuab. www.egosoft.com on uudis kirjas
EDIT(28.okt) : Inglismaal said esimesed õnnelikud mängu kätte, USA - s hakkab mäng levima 5.nov, tehke omad järeldused
Kommentaarid: 47 loe/lisa |
![](./images/komment/img_10_1.gif) ![](./images/komment/img_10_0.gif) ![](./images/komment/img_10_2.gif) |
45 |
![](templates/HinnaVaatlus/imagesHV/spacer.gif) |
Vananematu
![Vananematu Vananematu](https://foorum.hinnavaatlus.ee/images/avatars/upload/a058617148ccf927406cb838135dc8b5.jpg)
01.11.2005 21:18:56
Metsa see on ainus mäng, mille järele näpud meeletult sügelevad viimasel ajal. Muu nagu suurt ei huvitagi. Space RPG-d on selline mõnus kauge teema alati olnud, kus hästi süvenedes mängu on võimalik meeletult hea elamus saada.
Kommentaarid: 31 loe/lisa |
28 |
vanake
01.11.2005 22:30:18
Loodetavasti jõuab varsi Eestisse ka, ise lähen ka juba vaikselt hulluks siin
45 |
Vananematu
02.11.2005 14:30:36
Magusamad laused mangu kohta minu silmis :
tsitaat: |
The difference between that and a simple supply-and-demand economy is that a fully dynamic economy gives you a lot more potential power and influence. In fact, so much so that it would be possible to even cripple the galactic economy if you cornered a key resource or monopolized a major industry.
So X3 will rectify this by introducing a story written by a professional scriptwriter. However, the developer wants to let you have your cake and eat it too, so the open-ended nature of the series will remain in X3, so you can veer away from the story at any time to explore and trade at your leisure.
In addition to the plot missions, there will also be optional side quests to explore.
With so many potential sides to join with, your reputation will carry a lot of weight, as you will affect pricing and availability depending on your relationship with a certain faction.
There will be more than 100 ship types, and there's supposed to be a lot more character and variety throughout the game.
28 |
Paganarh
![Paganarh Paganarh](https://foorum.hinnavaatlus.ee/images/avatars/upload/2a5846f41c4f974e3ff16051d6babb8f.jpg)
03.11.2005 13:32:07
Noh, paistab et sellest tuleb üks korralik mõnus nokitsemismäng. Eelmine sedatüüpi normaalne asi oli minujaoks Freelancer, kuigi too jäi ka nati liialt kergekoeliseks ning lühikeseks.
Tahaks juba kätte saada ning joystickult tolmu maha puhuda
Kommentaarid: 15 loe/lisa |
aise
![aise aise](https://foorum.hinnavaatlus.ee/images/avatars/upload/4f17976966300821febc28fd44c551ee.JPG)
03.11.2005 13:34:01
piltidel paistab nagu kosmoses lendamine ainult, aks ongi kogu mäng selline?
Kommentaarid: 189 loe/lisa |
172 |
maniacaic
![maniacaic maniacaic](https://foorum.hinnavaatlus.ee/images/avatars/upload/aefc2f78f0321d770988e01ad3b1efcc.gif)
03.11.2005 13:44:47
Vot see on midagi.
![](https://i.hinnavaatlus.ee/ext/e5933d00336ea9ffa5cb2dd9d1bf0201ee0a9e7d/687474703a2f2f696d672e76696c6c61676570686f746f732e636f6d2f702f323030352d322f3934333739332f3178666f6f72756d2e676966/) |
Kommentaarid: 16 loe/lisa |
Vananematu
03.11.2005 20:06:41
Nagu uued skriinid : Link
28 |
Paganarh
04.11.2005 00:00:40
nagu et ... awesome!
Vananematu
07.11.2005 15:26:57
Njah. Teate ka, et mäng on ullem ressursi õgard. Ma ei oleks uskunud, et mingi mäng tühjuses tahab nõnda palju saada. Aga elamust saab sellistelt mängudelt, kui visuaalne pool on kõik maksimum iluna näidatud. Kahjuks ei ole väga palju sättida graafilise poole pealt. Graafika on muidugi metsik. Kõik orbitaaljaamad, täheväravad, kosmoselaevad ja palju muud on metsikult ilusti tehtud, kõik on dx 9-t täis. Minu profiilis masinaga jookseb mäng enam-vähem talutavalt @high välja arvatud anistropic filter ja anti sakilisus väljas, kuigi räägivad, et kui kõik põhja panna, jookseb mäng sujuvamalt. Kusjuures jooksebki, kui AA ja af ka peale lükata, kuid ise ikka ei kasuta seda.
Ning rääkides siis tõelisusest mängus. Khm, väga vähe olen proovida saanud, kui planeedid on õigete suurustega. Väga mõnus on kuskil orbitaaljaama ümber tiirelda ja näha, et planeet on ikka seal samas. Midagi muud polegi veel proovinud. Natuke pettunud olin, et orbitaaljaamale maandudes, ei näinudki oma laeva, kuskil jaama sees ruumis. Mõtlesin, et oleks võinud olla analoogset Freelanceri või Eve Online-ga, kus kolasid ringi erinevates paikades kosmosejaamas või planeedil baaride mööda, varustajaid pidi jne. Samas ei ole midagi veel mängust avastanud. Ei võtnud new game koos story modega kah. Sättisin lihtsalt graafikat ja vaatasin kuida mäng jookseb.
28 |
vanake
07.11.2005 16:22:16
Kus sa proovida said? Ostsid? Tellisid? Kui ostsid siis sooviks ka teada saada kus müügis on
45 |
Vananematu
28 |
vanake
07.11.2005 20:55:47
Kas on ka mõni firma mis Eestisse toob asja kohale? Egosoft tooks, aga hind on maru kirves, äkki keegi viitsib otsida mingi netimüügi koha kust Eestimaale ka saaks tellida (esimesest lingist ei leidnud, et saaks).
Tänan!
EDIT : http://shop.game.net/ tellisin mina, lubati 2 päevaga kohale tuua, vaatame kas nii läheb ka
viimati muutis vanake 09.11.2005 20:10:56, muudetud 1 kord |
45 |
Wilts
09.11.2005 18:19:13
graafika ilus... lootsin, et meelitab mind evest eemale aga kõik on kuidagi puntras... nagu EVE's pos'i ümbrus. miks naad erinevate planeetide juures laiali pole?
kogu elu toimub kahe stargate vahelisel alal
Eves on kuidagi puhtam ja vabam tunne...
_________________ L.A.M.P/ LAMP "Loose Association of Mercenaries & Privateers" |
30 |
Vananematu
14.11.2005 18:33:26
http://www.fileshack.com/file.x?fid=7902
Uus patch saadaval, mis parandab igast vigu ja peaks parema esitluse tagama. Ver 1.3ega, mis peaks novembri keskel saabuma, lubatakse aga väga suurt performance kasvu. Esimesel proovimisel jäigi see silma, et kohe väga koledasti asi jooksis. Ja polegi rohkem teda proovinud. Kui patch 1.4 välja tuleb, siis proovin ja süvenen mängu ka, hetkel ei ole ühtegi arukat kommentaari näinud mängu kohta, mis põhjendaks miks ta hea või halb on... peab ikka ise käpa külge panema ja 10 lk teksti kirjutama
28 |
Scart
![Scart Scart](https://foorum.hinnavaatlus.ee/images/avatars/upload/9f7d8851462bbff0728a4818f6aaefb0.jpg)
15.11.2005 16:43:30
esmamulje on kindel.... mäng on lummavalt ilus ja x2'ga võrreldes kobe edasiminek
Kommentaarid: 119 loe/lisa |
101 |
HDTanel
Overclocker
![HDTanel HDTanel](https://foorum.hinnavaatlus.ee/images/avatars/upload/0b7b4d3a49712655df6441315a2a977f.png)
21.11.2005 14:13:54
Kus krt seda saada on??? ja palju maksab... tahan osta aga kuskil ple
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
Kommentaarid: 634 loe/lisa |
495 |
Scart
21.11.2005 14:17:29
PlatoonSgtElias kirjutas: |
Kus krt seda saada on??? ja palju maksab... tahan osta aga kuskil ple |
täiesti võimalik, et seda eestisse ei toodagi retail kaubana letile müügiks, pead ilmselt egosoftilt endalt ostma
101 |
vanake
21.11.2005 18:48:27
Mina tellisin siit http://shop.game.net/ aga juba 2 nädalat tuleb
45 |
HDTanel
Overclocker
22.11.2005 11:44:26
Palju kokku läheb koos tolliga?
495 |
vanake
04.12.2005 14:01:51
DELIVERY: 2.95 GBP
TOTAL: 29.94 GBP
ehk siis 685.-
E: KÄTTE SAIN!!!
Pärast 3 nädalast ootamist jõudis pakk lõpuks kohale, ja olen nüüd juba veidi mänginud. Peaks mainima, et mäng on ikka vapustavalt ilus ja erineb täielikult oma eelkäijast. Mul jookseb max reso ja detailidega ilusti. Meeldis esimene missioon, kus tuli näiteks planeedi pinnal lennates piraate kõmmutada Ärisüsteem on päris keeruline, aga kui asja käppa saad siis on küll lõbu laialt, olen juba paar päeva spacefueli (illegaalne viin) ärinud, saadud kasumist ostsin kaubalaeva ja varsti ostan ka oma esimese jaama!
Jaamade ehitamisel on juurde tulnud palju uusi jaamu ja 200 000 maksev vidin, mis lubab jaamu omavahel liita Niisiis kui liidad mingid tehased kokku on transpordikulu väiksem, sest energija mõlemale jaamale saab tuua kohale ainult ühe laevaga.
Kokkuvõttes on mäng ja mängitavus väga hea ja igati oma hinda väärt (andestan isegi 3 nädalase transpordi, kuna mäng on lihtsalt super)!
45 |
abstainer
![abstainer abstainer](https://foorum.hinnavaatlus.ee/images/avatars/upload/fc860c3bfb50b9711fba0da0e8537877.gif)
08.12.2005 01:30:48
vanake kirjutas: |
Mul jookseb max reso ja detailidega ilusti. |
Hmm... mul sama CPU ja video mis sul, kuid ilusti eriti ei taha joosta default settingutel, ning see loading kestab ca 5 min (võtsin aega )
Kaua sul see loading võtab aega?
_________________ nobody's perfect |
15 |
vanake
08.12.2005 08:34:46
Aega pole just võtnud, aga üle 2min see küll ei ole
45 |
Scart
23.12.2005 11:41:09
link :: kae siit
1.3 on väljas
101 |
Vananematu
24.12.2005 00:31:02
Lõpuks god damn ometi. Panen nüüd mängu uuesti peale ja loodan, et asi jookseb seekord.
28 |
