tavikas
16.10.2005 18:09:11
RAW formaat? |
siis probleem järgmine:
proovisin bootida flopilt ning ütles mingi I/O errori. teise masina(ja ka teise fdd draiviga) vaatasin winXP alt ketast ja näitas suurust 0 ja formaati RAW. Ometigi alles eelmine nädal ta buutis ja formaat oli FAT. Kuidas see siis niimoodi muutub?
Mida see RAW endast üldse kujutab? Proovisin ka teist flopit, mis ei olnud boot disk vaid lihtsalt andmekandja - selllega sama lugu. Samas mõne flopy kohta ütleb ka ilusti FAT ja 1,44. Milles asi?
| Kommentaarid: 17 loe/lisa |
15 |
taifunk
16.10.2005 18:15:56
Flopi siis formaatimata. Lükka aga sisse ja paremklõpsuga "Format" ja pane ta FAT formaat peale.
_________________ Remember this day, men, for it will be yours for all time. |
| Kommentaarid: 45 loe/lisa |
36 |
marti252
16.10.2005 18:20:31
Heh, sul ütleb floppy, et raw, aga mul 80gb ketas mis on vajalikku stuffy täis
The format of my hard drive is shown as Raw in Disk Managment under Windows 2000, XP, or 2003.
Question
Why is my drive shown with a Raw format in Disk Management under Windows 2000, XP, or 2003?
Answer
Problem:
The hard drive is inaccessible and is shown with a "Raw" format in Disk Management under Windows 2000, XP, or 2003.
Cause:
This issue indicates that the partition table on the hard drive has become corrupt or damaged. While the data may still remain on the physical hard drive, it will not be accessible through normal operating system access methods. This issue can be caused by the following reasons:
* Viruses or spyware on the computer.
* If the computer does not support the hard drive capacity correctly.
* If the BIOS is not configured correctly for the hard drive
* If the hard drive is physically failing or there are media errors on the drive.
Resolution:
To ensure that the hard drive is working correctly and free from physical defects, please test the drive following the directions in Article ID 59. If no errors are detected by our diagnostics, the hard drive is physically working correctly. You will need to use a data recovery program or data recovery company to access and recover the data from the hard drive. Once data recovery has been performed, we recommend low-level formatting the hard drive with our diagnostics from the directions in Article ID 1211 before repartitioning and reformatting the drive for usage again.
Aga kuidagi peaks olema võimalik koduste meedotidega ka stuffi seal kätte saada
Kas kellelgi on soovitusi
| Kommentaarid: 9 loe/lisa |
9 |
16.10.2005 18:25:22
marti252: Aga mismoodi Su HDD-d näitab selline asi nagu programm NTFS for DOS. Selle paned flopile või cd-le ja siis üritad kettale ligi saada.
Teine asi - igasugused taastamisprogrammid, kas nendega oled üritanud infot kätte saada
211 |
kraff
16.10.2005 18:29:13
Oli ka ühe masina HDD-ga sama RAW probleem. Prooviks sai see teise masinasse tõstetud ja seal töötas kenasti. Edasi rändas ketas vanasse masinasse tagasi ja oh imet polnud RAW-st enam jälgegi. Vaata esimese asjana kaabeldus üle.
_________________ Let`s go, let`s go, I`m bored, let`s go! |
| Kommentaarid: 290 loe/lisa |
236 |
marti252
16.10.2005 18:46:10
| tahanteada kirjutas: |
Teine asi - igasugused taastamisprogrammid, kas nendega oled üritanud infot kätte saada  |
Proovisin proget search and rescue ja see ütles, et seal kettal ei ole kustutatud faile.
Dosis minu arust sata kettast ei näe
Siin täpsemalt mu probleemist
https://foorum.hinnavaatlus.ee/viewtopic.php?t=209102
9 |
HacaX
16.10.2005 19:27:48
Kui Winnis ei näita siis DOSis vaevalt näitab. Pigem soovitaks kustunud failide asemel mõnda kustunud partide taastamise proge proovida (mõni undeleter võimaldab mõlemat, aga selle peale ei tasuks loota). DOSi all on üks selline vidin olemas nagu TestDisk mille üks funktsioon ongi partitsioonide taastamine. Kuidas SATA toega on seda ei oska kahjuks öelda...
| Kommentaarid: 24 loe/lisa |
22 |
jannyy
04.12.2005 15:29:33
Aga kas kuidagi äkki andmeid taastada pole võimalik, kui disket, muutus üks päev lambist raw-ks.
Mis võib aidata, oleks hädasti vaja andmed sealt kätte saada.
| Kommentaarid: 8 loe/lisa |
