erick
08.10.2005 10:34:46
THG sai kätte 65nm Cedar Mill P4 prosed |
Põhimõtteliselt kiiruseerinevusi pole, aga TDP on langenud umbes 20% - 3.0GHz - 3.6GHz 2MB prosede puhul on see nüüd näiteks 86W.
Lähemalt saab lugeda siit:
http://www.tomshardware.com/cpu/20051007/index.html
96 |
Ho Ho
08.10.2005 10:55:02
"Those of you who may be disappointed by the lack of performance gains should keep in mind that Intel might easily be able to finally add faster Pentium 4 processors at 4+ GHz if there is market demand. At the end of the day, the TDP of 86 Watts is still pretty far away from the 130 W that today's performance FMB would allow for. "
võibolla siis nüüd on lootust saada mõni 4.5G p4
Huvitav kuidas selle kellatavusega olla võib? Tore igatahes teada et Intelil 65nm peale üleminek suht hästi läheb.
86 |
08.10.2005 20:42:05
| Ho Ho kirjutas: |
| "Those of you who may be disappointed by the lack of performance gains should keep in mind that Intel might easily be able to finally add faster Pentium 4 processors at 4+ GHz if there is market demand. |
eks Intelil ole natuke vesi ahju, sest AMD on jõudnud jõudluse kasvatamisega juba põlistele inteli edualadele ja seal aitaks Inteli kerge vaevaga välja vaid P4 suur MHz...
201 |
One
08.10.2005 20:52:08
| Magic kirjutas: |
| ...seal aitaks Inteli kerge vaevaga välja vaid P4 suur MHz... |
sealt aitab välja Conroe, 2k6 sügis
728 |
RKsilver
08.10.2005 21:01:32
klge natuke hiilgav küsimus ka minu poolt.
mis oranz pesa selle plate prose socketi ja I/0 vahel on
| Kommentaarid: 172 loe/lisa |
140 |
Ho Ho
08.10.2005 21:22:02
manualist lugesin et sinna pessa käib selline vidinas:
1-7 Installation of U-Plus DPS (Universal Plus Dual Power System)
The U-Plus Dual Power System (U-Plus D.P.S.) is a revolutionary eight-phase power circuit built for
ultimate system protection. Designed to withstand varying current levels and changes, the U-Plus DPS
provides an immensely durable and stable power circuit to the CPU for solid system stability. These
characteristics make it the ideal companion with the latest LGA775 Intel® Pentium® 4 Processor as well
as future Intel® processors. As well, 4 blue LED's are mounted on the U-Plus D.P.S. for intelligent
indication of system loading.
86 |
