pooter
02.10.2005 11:31:57
Kas see kõvaketas on vigane? |
HD Tune: SAMSUNG HD160JJ Health
ID Current Worst ThresholdData Status
(01) Raw Read Error Rate 97 26 51 9851 Failed
(03) Spin Up Time 100 100 25 6208 Ok
(04) Start/Stop Count 100 100 0 26 Ok
(05) Reallocated Sector Count 1 1 10 11111 Failed
(07) Seek Error Rate 253 253 51 0 Ok
(0icon_cool.gif Seek Time Performance 253 253 15 0 Ok
(09) Power On Hours Count 253 253 0 27 Ok
(0A) Spin Retry Count 253 253 51 0 Ok
(0B) Calibration Retry Count 253 2 0 0 Ok
(0C) Power Cycle Count 100 100 0 13 Ok
(BE) (unknown attribute) 124 118 0 38 Ok
(C2) Temperature 124 118 0 38 Ok
(C3) Hardware ECC Recovered 100 100 0 59959374 Ok
(C4) Reallocated Event Count 1 1 0 11111 Ok
(C5) Current Pending Sector 253 253 0 0 Ok
(C6) Offline Uncorrectable 253 253 0 0 Ok
(C7) Ultra DMA CRC Error Count 200 200 0 0 Ok
(Cicon_cool.gif Write Error Rate 100 100 0 0 Ok
(C9) (unknown attribute) 100 100 0 0 Ok
(CA) (unknown attribute) 253 253 0 0 Ok
Power On Time : 27
Health Status : Failed
Kettal on garantii olemas ning alles kaks päeva tagasi poest ostetud. Garantiise tagasi?
Või võib asi formatis olla? Korra juba lasin uuesti üle, siis ka jupsis.
Kõik netis alla tõmmatud failid on vigased. Kui installin midagi cd-lt siis läheb ilusti peale, kuid masin jookseb aegajalt kinni.
8
02.10.2005 12:01:57
Re: Kas see kõvaketas on vigane? |
| pooter kirjutas: |
ID Current Worst Threshold Data Status
Nende märkide järgi on asi juba päris paha.
Reallocated Sector Count:
The lower the number the worse it is. The reallocated sector count decreases as the number of bad sectors on your drive increases.
A full format will detect all the bad sectors it CURRENTLY has and will mark them as unusable, but if your disk is really starting to fail then more bad sectors will still occur afterwards.
Nii et kui veel garantiiga ketas, siis kõige mõistlikum viia kohe ümbervahetusse...
Aga kas formati (kas üldse tegid full-format?) tegemisel ka midagi torises või oli sellega raskusi?
| Kommentaarid: 37 loe/lisa |
37 |
ebuprofen
02.10.2005 12:07:09
| Proovi HDD Regenerator 1.42 (http://dontek.ru/soft/get_from_dontekHDD.Regenerator.1.42.zip), voib olla aitab
67 |
pooter
02.10.2005 12:49:12
Format oli suhteliselt aeglane (umbes 1,5 tundi), kuid mingitest probleemidest mind ei teavitatud.
Ning kui lasin selle hdd tune programmiga bad sectoreid otsima, siis ei leidnud ta ühtegi.
Proovimine võtab aega, sest pean teise masinasse alla tõmbama ning plaadile kirjutama, enne kui saan installida.
toivos
02.10.2005 16:35:50
Mis siin proovida, ega te ei taha ometigi poest ostetud UUT ketast parandama hakata. Lase talle Samsungi utiliit peale, see ütleb kindlasti, et Smart Failed ja vii poodi tagasi.
_________________ Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt. |
| Kommentaarid: 70 loe/lisa |
66 |
pooter
02.10.2005 19:04:26
| See Samsungi utility on vaja lasta käima bootivalt flopilt, mul aga flopit ei ole. Kas ma peaks siis bootivale cd-i tegema või see ei sobi?
toivos
02.10.2005 19:12:13
| pooter kirjutas: |
| See Samsungi utility on vaja lasta käima bootivalt flopilt, mul aga flopit ei ole. Kas ma peaks siis bootivale cd-i tegema või see ei sobi? |
Ise lasen kõvakettalt, võid proovida CD-lt aga kui käima ei lähe, siis tahab ini faili kirjutada. CD on aga readonly
66 |
pooter
03.10.2005 09:14:35
Samsungil on 3 diagnostika proge, kuid ühegi kirjelduses ei ole minu kõvaketast (hd160JJ). Proovisin igaks juhuks kõik utilitid läbi:
HUTIL ja SUTIL ei läinud käima ning Shdiag ei leidnud ketast ülesse.
Mul on veel üks rumal küsimus - kas ma oleks pidanud kuidagi eraldi mingid SATA driverid peale laskma. Ma vaatasin, et ketta leidis ülesse ning Windows all oli ka olemas 2 SATA ja üks PATA kontroller. Ning kõvaketas oli ka ilusti omaks võetud. Ning sestap pole mingit lisa SATA driverit sinna pannud (iseenesest oli emaplaadiga kaasas küll mingi disk, kuid seal oli kirjas NV raid midagi ning raidi ma ei kasuta).
mazdagti
01.01.2006 11:11:38
Vabanda et kasutan seda teemat oma probleemiga
| ebuprofen kirjutas: |
| Proovi HDD Regenerator 1.42 (http://dontek.ru/soft/get_from_dontekHDD.Regenerator.1.42.zip), voib olla aitab |
Kui mul tuli sellega vot selline tulemus kas see tähendab et bad sectoreid pole
Ja ärge tigetsege palun ROOKIE OLEN
_________________ No ikka täitsa kagu nukas!
FB Volvokodu, diagnostikaabi Võrumaal. |
136 |
HDvurle
HV pensionär
01.01.2006 11:24:00
pooter, see ketas on SATA 2. Lase SATA draiverid ka peale, muidu ketast tööle ei saa.
mazdagti, millise kettaga tegu? Siin ei ole hiromant Pastellisid, kes Su ketta marki ennustada oskavad.
_________________ Teie küsimused on vastatavad, kuid meie vastused on küsitavad.
IT uudissõnad. Pihuarvuti - pihkar, pihuarvuti kasutaja - pihkur. |
| Kommentaarid: 21 loe/lisa |
16 |
mazdagti
01.01.2006 11:43:13
Sorry
Kettad on C:WDC WD800JB-00FMA0 ja D:QUANTUM FIREBALL CR8.4A
136 |
v6sa
01.01.2006 12:16:52
see proge ei saagi õieti toimida windowsi 16bit emuleeringus..
_________________ Otsid kohta nokitsemiseks? Pole vajalikke tööriistu varnast võtta? Kodus lapsed ei lase rahus tööd teha? Tule kiika meie hackerspace'i k-space.ee |
91 |
mazdagti
01.01.2006 12:19:14
Seega siis minule kasutu
OT:OK mis iganes, otsin parem kellegi teadjama
136 |
v6sa
01.01.2006 12:20:01
pane win95/98/me startup flopile ja proovi sealt
91 |
mazdagti
01.01.2006 12:22:31
| mazdagti kirjutas: |
OT:OK mis iganes, otsin parem kellegi teadjama  |
MA ROOKIE SELLEL ALAL VEEL
SORRY VEELKORD ET OT
136 |
