EvilMick007
20.09.2005 22:59:51
| [Dev]Reaper kirjutas: |
| It doesn't seem to be Arch and them DDoSing us, so its only one likely suspect and the l2extreme, pussies have been caught several times DDoSing everyone in the top 10, why no one has done a goddamn thing to them is beyond me. |
_________________ Pentestimise ja küberturbe konsultatsiooni soovi korral võib kirjutada.. |
| Kommentaarid: 46 loe/lisa |
41 |
maarjuzz
21.09.2005 12:50:56
| EvilMick007 kirjutas: |
Tra on ikka lohhe olemas rsk...
Ma kujutan ette neid friike kellel pole muud teha kui teisi nussida!
Mingid prillidega seanäoga vinnilised väiksed m.unnid, sebivad ringi ja keervad kõigile taha
Sigade invasioon!!
| Kommentaarid: 4 loe/lisa |
EvilMick007
21.09.2005 12:59:03
Well mina serverit vahetama ei hakka... ei viitsi nullist uuesti alustada... selle servu C3 oli piisavalt korralik, et oodata kunas uuesti jalad alla saavad, st uue ISP omale leiavad
41 |
Alandril
21.09.2005 18:32:32
| maarjuzz kirjutas: |
Sigade invasioon!! |
HAHAHAH lol hästi öeldud endel
| Kommentaarid: 6 loe/lisa |
Dominus
22.09.2005 02:10:03
nii...Aeon jõudis kah korraks netti Enraged serveri info siis :
<[HGM]Aeon> I still don't have everything, but I have enough to tell you what I am going to do
<[HGM]Aeon> I JUST.. moved into a new apartment.. didn't even unpack
<[HGM]Aeon> and now today I had to move some stuff back out to higher ground from the impending hurricane
<[HGM]Aeon> As far as the server...
<[HGM]Aeon> I am sorry to say.. but nothing is going to happen until after I see if there is a "Houston" left after this weekend
<[HGM]Aeon> The server since our current supposed host... decided to drop us
<[HGM]Aeon> will be shipped to me and I will place it in a new co-location in Houston
<[HGM]Aeon> since... there is a Hurricane hitting Houston in 2 days... it's going to be touch and go
<[HGM]Aeon> for those who think the server is going down
<[HGM]Aeon> It is NOT...
<[HGM]Aeon> we will go up, and we will be up, we just need to find the correct home for everything
<[HGM]Aeon> our current host dropping us because of a DDoS was... to say the least
<[HGM]Aeon> suprising
<[HGM]Aeon> but it just tells you how scared other people are
<[HGM]Aeon> Sooooo... right now my main concern is to make sure i still have a home
<[HGM]Aeon> to ship the server to...
<[HGM]Aeon> then if it is still standing, make sure its not standing under water
<[HGM]Aeon> if A & B are ok
<[HGM]Aeon> then C would be if there is still power
<[HGM]Aeon> then I will be able put in the new co-location
<[HGM]Aeon> IF we manage to get by this hurricane with minimal damage....
<[HGM]Aeon> it could be as soon as next week
<[HGM]Aeon> it will be a local co-location in Houston where people will actually defend against DDoS |
76 |
biomehanik
22.09.2005 06:37:34
| Mafka kirjutas: |
krt mõned laused on head koomilised... then if it is still standing, make sure its not standing under water
aga jah ....küll see server ...(kunagi) jälle üles tuleb
| Kommentaarid: 260 loe/lisa |
227 |
Snaxez
| Kommentaarid: 59 loe/lisa |
53 |
Demonium
22.09.2005 14:15:59
Kurat....kahju hakkab neist lausa
Kujud näevad sitaks vaeva....ddos.....mingi vend satub isegi mingisse auto õnnetusesse....ja siis veel mingi host n.ussib ka veel näkku....
Aga jah....see kuju suudab ikka asja küll naljaga võtta et kui mul veel on kodu peale seda orkaani jne....
Igatahes.....loodan, et peale tormi saavad nad servu üles panna ilma, et mingi piider dosserdama ei hakka.....
_________________ The future will be a vast black memory on your grave! |
No_Limit
22.09.2005 14:48:46
Meie serveri poole läheneb 5 astme orkaan
_________________ Ave, Caesar, morituri te salutant |
40 |
biomehanik
22.09.2005 15:13:49
| No_Limit kirjutas: |
Meie serveri poole läheneb 5 astme orkaan  |
just hommikul raadiost kuulasin ... pidi vist olema seni suurim mis sinna kanti sattunud
227 |
LightsabeR
22.09.2005 15:26:09
| biomehanik kirjutas: |
just hommikul raadiost kuulasin ... pidi vist olema seni suurim mis sinna kanti sattunud |
Vähemalt seekord evakueeritakse inimesed õigel ajal (või vähemalt üritatakse). Muidugi varaline kahju on vältimatu ja see tuleb ikka päris suur.
| Kommentaarid: 14 loe/lisa |
14 |
biomehanik
22.09.2005 17:44:54
| LightsabeR kirjutas: |
Vähemalt seekord evakueeritakse inimesed õigel ajal (või vähemalt üritatakse). Muidugi varaline kahju on vältimatu ja see tuleb ikka päris suur.  |
njah...saab mõned head kaadrid katastroofidest jälle ja näha kuidas üks linn on maatasa tehtud ...loodusjõud on ikka karmid
227 |
Snaxez
53 |
biomehanik
22.09.2005 22:44:24
Enraged post Aeonilt:
Hurricane Rita
#1 most important thing at this point. Aeon is in Houston, and Rita is coming for him. That is the most important thing on my mind.
#2 most important thing, getting the server back online. Unfortunately because of important item #1, that will delay us. The colocation I will be putting the server in will be based here in Houston. We need to ride the hurricane out and then we can work on getting the server up.
As I stated many times, this server is NOT going to shut down, so all those people who are trying to keep us offline will be unsuccessful. We will eventually find a host capable of handling DDoS attacks.
227 |
Dominus
76 |
maarjuzz
23.09.2005 08:28:00
Tundub et on aeg teha pikem paus sellest mängust..
Praegune L2 ei pakkunud enam pinget ja viskas vaikselt juba siibrisse...
Loodetavasti kui kunagi mängutuju tuleb siis on kõik see C4 stuff juba pira servudesse jõudnud
I just went outside one day and...CAN U BELIEVE IT!! theres life outside
Special thanks to all Abyssus clan..ei hakka kedagi eraldi välja tooma...olete kõik lahedad sägad..
Ah.. ega ma täitsa ära ei kao..eks ma käin ja kummitan teid vendis vm
Have fun and give it hard!
LightsabeR
23.09.2005 10:56:52
Have fun and give it hard! |
Yeah.. peaks ka jälle "quitima" . Aga noh.. don't be a stranger . Grindi siis kõvasti irl .
14 |
Alandril
23.09.2005 14:08:27
Asshooooole ei noh krt lõpuk avalikustas kah siis
1 nolifer vähem jälle was fun endel
biomehanik
23.09.2005 14:37:09
heh ega jah...ma praegu muud ei viitsi teha kui et l2w vahel pk spree noob geariga või pvp...lvldamisest ei tule juttugi
227 |
Djomka
23.09.2005 15:00:06
igatahes, was fun MJ ja ma tahaks näha, kui sa mõnikord meid ka vaatama ei tule venti või mängu
12 |
biomehanik
24.09.2005 22:07:25
imelik et L2w näitab 1 ja 3 server Full nüüd.... varem olen koguaeg sisse saanud
227 |
Djomka
24.09.2005 22:12:53
l2w's pidavat olema mingid jamad...juba enne oli nii, et 3's server on pidevalt täis ja keegi sisse ei saa
arvatakse, et see on seotud #4 lahtitegemisega
soovitan lugeda l2w foorumit, seal on oma 5 teemat kindlasti, kus kõigest sellest juttu on
12 |
Lordlesta
25.09.2005 17:14:37
nii, mul väike probleem. Olen praegu elven knight ja kas ma siis enam ei saagi plainswalkeriks? sest kui hakkan vahetama, näitab ainult temple knight ja swordsinger
| Kommentaarid: 31 loe/lisa |
Dominus
25.09.2005 17:18:09
uhh...tekib küsimus miks sa siis knight'iks läksid mitte scoutiks? kui juba knight oled siis jah plainswalkeriks ei saa...kui ainult Temple Knight'iks või Swordsingeriks Sws oleks suht vajalik klass muidu,head buffid n stuff :]
76 |
Lordlesta
25.09.2005 17:26:13
ah krt kust ma teadsin,
mis sa siis soovitad swordsingeriks minna?
