No_Limit
13.07.2005 12:21:54
L2W on nüüd C2
Some things we know right off.
1.) /loc & /time and /unstuck commands crash the client.
2.) Dwarf private workshop and crafting buttons crash the client.
3.) Recommend button crashes the client.
4.) Innacurate quest pieces crash the client.
Example: You have 40 wolf claws for a quest, but somehow got an extra 3
When you talk to the NPC to get your reward, it crashes you. To fix this, you must delete the extra number of items from your inventory.
5.) Clan functions such as the privilage button in the menu crash the client.
6.) Skills Bleed, Posion, Decay and a few others do not show the effect.
Not something that will effect game play tho so nothing to worry about.
How to play now:
1.) Downloaded C2 Client.
2.) Install
3.) Download C3 Textures.
4.) Install C3 Textures.
5.) Download our patch
6.) Install our patch
Unrar the patch where you want as a temp.
Then open it up and select the 3 folders in there and copy or cut them out.
Then open up your Lineage2 C2 Folder
IE: c:\program files\lineage2\
There you will see all your folder like: Animations, System, SysTextures.
These are the folders you need to over right with out patch
To make sure you can do these couple steps if you know whats going on.
Step One: Delete your system folder
Step Two: Put our system folder
a.) If you dont feel like deleting it you can past ours over it.
("Better to delete it and just use ours tho.")
This is where it would be on a default install: system folder in c:\lineage2\system
b.) Then you can just paste the others 2 folder over the old ones.
7.) Last couple things to check, depending on which way you did it.
a.) Delete your Game Guard Folder out of C2 System Folder.
b.) Delete your Obsene-e.txt file out of C2 System Folder
6.) Then join the server as normal...
_________________ Ave, Caesar, morituri te salutant |
Kommentaarid: 46 loe/lisa |
40 |
ZAndlamb
13.07.2005 12:57:01
huntermagic kirjutas: |
Zandlamb räägiti et mõned lännud kasjutajad pidid tagasi olema tulnud...Sul pidi ju mingi lvl 80 kadunud olema? Tuli tagasi? |
lvl 53 ikka
EDIT: Proovisin, pole tagasi tulnud.
Kommentaarid: 22 loe/lisa |
22 |
Lordlesta
13.07.2005 17:14:09
keegi võiks öelda, miks ma l2w-is koguaeg disconnekti saan kui ma serverit hakkan valima?
Kommentaarid: 31 loe/lisa |
No_Limit
13.07.2005 17:28:00
server 1 on hetkel üleval ainult ja login server lendab pidevalt maha.
40 |
arty
13.07.2005 22:51:36
l2w vennad on tõsiselt ajast maas, serverid #3 ja #2 pole siiamaani updatetud, kohe 2 päeva ajast maas, kui lubavad võiks ikka ära teha õigel ajal . Aga vht ple peaasi et korralikult tööle saavad
No_Limit
13.07.2005 23:10:42
Nad lükkais vaid server 1 üles, siis sealt saavad nad teada vead ja parandavad need juba enne 2 ja 3 serveri ülestulekut ära, peaksid õnnelik olema, hea suveõhtu ilm on ka, mine õue.
40 |
LightsabeR
14.07.2005 04:38:06
No_Limit kirjutas: |
peaksid õnnelik olema, hea suveõhtu ilm on ka, mine õue. |
täpselt
ma jõudsin alles koju
tra rahvas nautige seda aega, kui l2w maas on.. saate ehk sõltuvusest vabaks
Kommentaarid: 14 loe/lisa |
14 |
arty
14.07.2005 11:14:09
LightsabeR kirjutas: |
täpselt
tra rahvas nautige seda aega, kui l2w maas on.. saate ehk sõltuvusest vabaks  |
Ega ma sõltuvuses pole 8) Iga päev käin ujumas ja staffi. Sellepärast veits vihane, pidin seda C2'te maru kaua tõmbama arvuti ööseks käima jätma, siis ei saanud magada ja nüüd polnudki vaja , oleks võinud järgmine päev jätkata mitte öösel tirida . OK ega vht ple.
No_Limit
14.07.2005 16:54:30
Kas kellelgi on mulle Tsurugi Blade ja Recipet anda? L2W
40 |
LightsabeR
14.07.2005 19:33:14
Tsurugi x SLS dualid teed jah? kaval
btw.. ega kellelgi server #1 mõnda chari pole? ma täna tegin endale seal lv 14 chari .
14 |
Lordlesta
14.07.2005 19:39:51
mul selline küssa, et kui ma ära suren, kas mõnda teisse linna ei saa tekkida? sest nii närvi ajab kui käin ilge pikka maa maha, saan surma ja siis hakka uuesti mingi tund käima...
No_Limit
14.07.2005 19:49:57
Tuli idee, et võiks klanni kokku kutsuda või siis kõik L2 fännid kes isegi kunagi meie klannis olnud.
Tore oleks teid nolifereid näost näkku ka tunda
Välja on pakkuda Tallinna lanparty eSports 2005, mis toimub 26-28 august.
Ja ma ei taha mingit pipardamist kuulda, et: "ma ei saa, mul kaka arvuti." Kui kodus saad mängitud, siis saad ka lanpartyl
Iga mees (insert girl, if you wish) otsustab ise, kas tuleb või mitte, mina olen igatahes kohal
Mis arvate?
40 |
LightsabeR
14.07.2005 21:45:08
ei julge teha nii kaugele ette mingeid plaane
muidu mõte iseenesest hea
14 |
Lordlesta
14.07.2005 21:55:06
ää kas seal mängus friendlist ka on? ja kuskil clan members list?
ZAndlamb
14.07.2005 22:19:27
/friendlist , clani liikmeid saad vaadata chari infi alt(seal kus skillid, pooleli olevad questid jne on)
22 |
Lordlesta
14.07.2005 23:53:05
ZAndlamb kirjutas: |
/friendlist , clani liikmeid saad vaadata chari infi alt(seal kus skillid, pooleli olevad questid jne on) |
aga nii saab ju aint friendlisti vaadata, nagu ma seal aru sain. Kuidas neid sinna siis listi saab panna? või äkki kuskil lehel on õpetused olemas mängu kohta?
virko
14.07.2005 23:56:41
/friendinvite nimi
kas BD'l on v2ga halb def we?
Kommentaarid: 1 loe/lisa |
Djomka
15.07.2005 00:05:16
BD'l on suht normaalne defence...aga peale LVL 40 tal ei tohiks tulla ühtegi armor mastery't
samas tal on head tantsud, mis teevad temast rohkem DD kui defence chari
Lordlesta, sa saad siis mingisse teise linna ennast transportida, kui sinu clanil on guildhouse ja/või castle...siis tulevad sinna valikusse asjad juurde
12 |
wazaa
15.07.2005 16:39:35
Tegin kõik nii nagu kirjas, kuid miskipärast peale seda kui selle l2w updeidi peale lasin ei ole mäng enam fullscreenis, ja see ka veel et kas hetkel ongi serverid maas?
Kommentaarid: 53 loe/lisa |
40 |
No_Limit
15.07.2005 17:45:03
Maas jah, tehakse rollback'i hetkel vist!
[5:43pm] -tookey(#l2world)- we do not know how long the server will be down, they are however rolling it back to pre c2,....that is all we know...please stfu...kthx bye
40 |
Lordlesta
15.07.2005 17:56:28
wazaa kirjutas: |
Tegin kõik nii nagu kirjas, kuid miskipärast peale seda kui selle l2w updeidi peale lasin ei ole mäng enam fullscreenis, ja see ka veel et kas hetkel ongi serverid maas? |
fullscreeni saad siis kui paned mängu optionis enda reso suuruse...
LightsabeR
15.07.2005 20:25:51
Lordlesta kirjutas: |
wazaa kirjutas: |
fullscreeni saad siis kui paned mängu optionis enda reso suuruse... |
Ei. Fullscreen ja window mode sõltuvad l2.ini filest. Uploadisin siia -> http://www.hot.ee/priit87/l2.ini.
Soovitatavalt tee vanast ini filest backup juhuks, kui kunagi vaja läheb. Ah jaa.. ini file asub l2 directory system folderis.
ja serverid on maas. Server #1 tuleb vahel üles, kuid #2 ja #3 peab veel ootama.
[5:43pm] -tookey(#l2world)- we do not know how long the server will be down, they are however rolling it back to pre c2,....that is all we know...please stfu...kthx bye |
see rollback on tingitud sellest, et mingid low lvl mobid dropisid 30k + adenat. Ja mingid muud exploitid olid ka veel...
14 |
No_Limit
15.07.2005 20:29:11
Jah, nad oleks nagunii rollbacki teinud, mõni jooksis juba A grade settidega ka ringi.
40 |
virko
15.07.2005 20:31:29
Palun r22kige nati BD'st ja SK'st (head ja halvad kyljed)
No_Limit
16.07.2005 03:06:59
BD, Head buffid ja head debuffid. Kuni level 60 gladist tugevam staside poolest.
BD'l ei ole Armor Masterit. Head spellid, mis teevad korralikult ikka dämmi kui õieti kasutada
EDIT: Kuulsin, et ISOgames läks CS'i serveritega miinustesse ja tegi L2 serverid ja nüüd loodab annetustega tagasi teenida. Kui teenib oma rahad tasa, läheb nende server maha. Nii vähemalt mulle räägiti.
40 |
