uus teema   vasta Raud »  Protsessorid »  Palju häid BIOS-e Abit NF7-S emaplaatidele! Modditud!!! märgi kõik teemad loetuks
HDTanel
Overclocker
HDTanel
sõnum 28.08.2004 21:24:26 Palju häid BIOS-e Abit NF7-S emaplaatidele! Modditud!!! vasta tsitaadiga
Tehtud ühe targa onu poolt.
Teen lihtsalt copy pasta ja parandan linkid
New ver. for Bios
D25 ver. 3.0.00
- Romsip Bios Tables
--1-21 Tables
--1-31 Tables
--4-29 , 1-31 Tables
--12-18 Tables
--Fire Tables --->>> Modded by Hell-Fire
- L12 mod built-in
- Cpu Interface Optimised 200FSB
- Bpl 3.02 Cpc Off
- Bpl 3.02 --->>> Bpl 3.19 Cpc On
- Bpl 3.02 --->>> Bpl 3.19 Cpc Off
ABIT NF7/NF7-S ver. 3.0.00 Bpl 3.02 (COMMAND PER CLOCK) Cpc On
ABIT NF7-S ver. 3.0.00 1-21 Bpl 3.02 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 1-31 Bpl 3.02 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 12-18 Bpl 3.02 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 12-31 Bpl 3.02 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 4-29 1-31 Bpl 3.02 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 4-29 Bpl 3.02 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 Fire Bpl 3.02 26.08.04 by -=Merlin=-
ABIT NF7/NF7-S ver. 3.0.00 Bpl 3.02C (COMMAND PER CLOCK) Cpc Off
ABIT NF7-S ver. 3.0.00 1-21 Bpl 3.02C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 1-31 Bpl 3.02C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 12-18 Bpl 3.02C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 12-31 Bpl 3.02C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 4-29 1-31 Bpl 3.02C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 4-29 Bpl 3.02C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 Fire Bpl 3.02C 26.08.04 by -=Merlin=-
ABIT NF7/NF7-S ver. 3.0.00 Bpl 3.19 (COMMAND PER CLOCK) Cpc On
ABIT NF7-S ver. 3.0.00 1-21 Bpl 3.19 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 1-31 Bpl 3.19 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 12-18 Bpl 3.19 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 12-31 Bpl 3.19 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 4-29 1-31 Bpl 3.19 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 4-29 Bpl 3.19 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 Fire Bpl 3.19 26.08.04 by -=Merlin=-
ABIT NF7/NF7-S ver. 3.0.00 Bpl 3.19C (COMMAND PER CLOCK) Cpc Off
ABIT NF7-S ver. 3.0.00 1-21 Bpl 3.19C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 1-31 Bpl 3.19C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 12-18 Bpl 3.19C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 12-31 Bpl 3.19C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 4-29 1-31 Bpl 3.19C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 4-29 Bpl 3.19C 26.08.04 by -=Merlin=-
ABIT NF7-S ver. 3.0.00 Fire Bpl 3.19C 26.08.04 by -=Merlin=-
I thank for together work
I thank on :
TicTac , Hell-Fire , Trats
by -=Merlin=-
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
AMD
AMD
sõnum 29.08.2004 09:49:50 vasta tsitaadiga
nf7-sl ver 2.0
From now on, the forum is owned by AMD.That means that you are NO LONGER allowed to talk about, or even mention *ntel.
Kommentaarid: 335 loe/lisa Kasutajad arvavad:  :: 145 :: 3 :: 12
volts333
volts333
sõnum 29.08.2004 11:23:22 vasta tsitaadiga
äkki keegi seletaks mulle mis vahe on cpc on/off
don't click this link...
Kommentaarid: 81 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 73
HDTanel
Overclocker
HDTanel
sõnum 29.08.2004 14:40:30 vasta tsitaadiga
CommandPerClock on pidavat suuremat FSB-d andma?
Krüpto
Plin500
HV piljardihai
Plin500
sõnum 29.08.2004 16:18:48 vasta tsitaadiga
https://foorum.hinnavaatlus.ee/viewtopic.php?t=115117&highlight=
Kommentaarid: 79 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 77
heikis
sõnum 01.07.2005 22:20:48 vasta tsitaadiga
kaevame kaevame.
kui L12 mod on biosis juba sees, siis pole kindlalt vaja füüsiliselt prose nagasid ühendada?
küsiks siis neid, kellel NF7-S 2.0 et mis biose kasutate ning mis FSB-d olete välja pigistanud.
ise kasutan Merlini D27_TaiPan_0.3_ED_Bpl_3.19_28.12.04 (CPC on)
FSB-d pole nagu juurde saanud samas mälu on kehv.
Kommentaarid: 338 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 290
sõnum 01.07.2005 22:20:52 vasta tsitaadiga
SA:VERkid, ma sain 240 katte kui kunagi see plaat oli, ABIT-i enda BIOS-iga, mis tollal uusim oli
trv
trv
sõnum 01.07.2005 22:24:54 vasta tsitaadiga
huvitav..milline neist oleks kõige optimaalsem minu konfile(profiilis) eriti just, et mul on mobile barton?
I need a break. I just tried to read 'Oxford' as a hexadecimal.
Kommentaarid: 139 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 126
heikis
sõnum 01.07.2005 22:26:29 vasta tsitaadiga
suht kasulik: http://www.ocforums.com/showthread.php?t=324662
hendu
sõnum 25.11.2005 02:45:12 vasta tsitaadiga
Vabandan, et vana teemat tõstan.
Aga küsimus nüüd selline, et kui annan prosele madalamat pinget, kas see võib proset kahjustada?
12v on 11.98v
5v on 5.05v
3.3v on 3.46v
Bios: D26 MANTA RAYS XT
prose: axp 2600+
def on 1.65 aga hetkel toidan 1.5-ga.
Kommentaarid: 116 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 102
Cooler(-10)
sõnum 25.11.2005 11:48:33 vasta tsitaadiga
Madalama pingega ei kahjusta midagi, lihtsalt ei pruugi hakata stabiilselt tööle. Kõrgema pingega võid küll prose eluiga tunduvalt vähendada.
Edit:
lihtsalt ei hakka stabiilselt tööle, kui üldse -> ei pruugi hakata stabiilselt tööle
viimati muutis Cooler(-10) 25.11.2005 20:41:39, muudetud 1 kord
Kommentaarid: 15 loe/lisa Kasutajad arvavad:  :: 2 :: 5 :: 5
heikis
sõnum 25.11.2005 16:42:40 vasta tsitaadiga
Cooler(-10) kirjutas:
Madalama pingega ei kahjusta midagi, lihtsalt ei hakka stabiilselt tööle kui üldse. Kõrgema pingega võid küll prose eluiga tunduvalt vähendada.
madalama pingega võib väga vabalt tööle hakata. ja stabiilselt icon_wink.gif sest kui enamik barton 2500+ lähevad default voldiga 3200+ peale, siis on loogiline, et 2500+ sagedus töötab default voldist ka madalamal.
keegi-Hannes
sõnum 25.11.2005 18:33:56 vasta tsitaadiga
furious_drawer kirjutas:
12v on 11.98v
5v on 5.05v
3.3v on 3.46v
prose: axp 2600+
Erinevalt eelpoolvastajatest ütlen et "äärmuslik alavolt" a'la 0,9V Bartonile võib seda ka kahjustada aga üldiselt see alates 1,35V kuni 1,75V on igati OK! Mõned prose eksemlarid käituvad alapinge puhul sellise eripäraga et temperatuuride alanemise asemel hakkab temp tõusma ja kui minna tagasi norm Voltage juurde siis temperatuur on veelgi kõrgem kui see harjumuspäraselt ja enne oli!
Kommentaarid: 42 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 38
