TonisU
22.06.2005 14:13:20
hmm..... uurides L2W foorumeid leidsin sellise asja..
| [GM]Noxie: Tecnical problem. Just wait a lil |
Snaxez
22.06.2005 16:26:27
| No_Limit kirjutas: |
Õnneks teeb L2W enneb C3 beta'si eraldi ja siis laseb alles käiku.
Kas keegi saaks kusagile selle L2 Walkeri uploadida?
EDIT: Mis värk on, L2W server 1 ja 2 saan sisse, aga 3 ei saa, kurat mis jama on, olen bännitud? |
sul paistab selle l2w foorumisse regamisega ikka jubedaid raskusi olevat...
| Deliri kirjutas: |
JONEST3 == MY GOD. He was the one who made this all happen, considering he suggested I do it. I mean, from all the horror stories about posting on websites and getting flamed, I think this one will never be included. Thanks, Jonest3.
Wooo. Thanks to Drizz, we gots a tutorial for it! Check page 3 of the posts and scroll until you find Drizz's posts. :3 Thanks again.
I'm getting tired of the posts where people ask about L2Walker, somebody answers with a vague "do a search." Look people, a search isn't going to work with the 1,000+ posts out there about it. The information is so scrambled, it took me days to figure it out. Now, for all those newbies, I'm here to help you all out. Follow the steps EXACTLY as stated, and you'll find your way to Buff/Vend botting easily.
(REMEMBER TO FOLLOW THE BUFF/VEND BOT RULES, I CANNOT BE RESPONSIBLE FOR ANYTHING YOU DO WITH THIS PROGRAM, AND PLEASE PLEASE PLEASE VIRUS SCAN IT BEFORE YOU DO ANYTHING WITH IT, WHO KNOWS WHAT SORT OF STUFF COULD'VE ATTACHED TO IT!)
((Also, anybody who wishes to host these files, it would be greatly appreciated, I don't want my bandwidth eaten up, so I had to host these on FREEWEBS, and boy, I'd guess it sucks.))
1. All right, let's get started. The first thing you need to do, obviously, is obtain a copy of eL2Walker10.2.3.zip from the mirrors at the end of this post.
2. Now, you have eL2Walker10.2.3.zip, and you have to open it. Most people at some point have download WinZIP, but if you haven't, you can obtain it from the WinZIP link at the bottom, with the mirrors and such.
3. After opening up the .zip file, you'll wanna extract it. Hit the big Extract button, and tell it where to extract to. (Make sure you create a new folder, or it'll just be a bunch of scrambled files.)
4. Extracted, and done. Wow! That was easy! (Dumbasses... XP) Nah, I included the updated settings for this server, and the maps (which when I downloaded this, it didn't have the maps, and I had to set up the server information.)
Sorry, but I am NOT going to post a huge buffer FAQ here, only the installation guide here, sorry.
And if any GM feels like reducing the posts on L2Walker, sticky this. >.>
WinZIP can be found at:
http://winzip.com
WinZIP Installation Guide:
1. Download.
2. Open.
3. Install.
4. Done.
(Basically, just hit the next button a billion times.)
Mirrors for L2Walker10.2.3:
<--closed one of these links, and set up a tracker to see how many people are downloading the other one-->
http://stateofthecomputer.com/l2/eL2Walker10.2.3-L2world.rar [unknown web, read page five.]
http://deliri.psychmind.com/
(Plllleeaeaaasse host a copy of that if you can!)
Some helpful hints for logging in via L2Walker:
In the options part of it, set it to relogin every 0 seconds, and uncheck the "delay login" checkbox.
Don't AFK bot, and read the rules.
350 hits on the web, wow. |
http://www.lineage2world.com/forum/viewtopic.php?t=5417&start=0&postdays=0&postorder=asc&highlight=el2walker10++3full+zip
viimati muutis Snaxez 22.06.2005 16:27:59, muudetud 1 kord |
| Kommentaarid: 61 loe/lisa |
54 |
Djomka
22.06.2005 16:30:40
jap, server on maas millegi pärast...täpsemalt keegi midagi ei ütle ja ka seda ei öelda, et millal uuesti üles tuleb
miks sa seda l2walkerit tahad, et keegi upib...see on ju googeldades täitsa leitav asi
lihtsalt peab olema 10.2.3 versioon...ise tõmbasin selle google'ist ja sõbrale tõmbasin ka...
kohe editin posti ja annan selle koha ka, kuidas sa l2w'sse botiga sisse saad (seda snaxi postis pole)
edit:Link
sealt tõmba set.ini ära ja siis saad l2w's mängida
| Kommentaarid: 14 loe/lisa |
12 |
No_Limit
24.06.2005 12:54:15
Ma floranis jälle, 14k karmat ja 30 pk killi. Keegi võiks aidata
_________________ Ave, Caesar, morituri te salutant |
| Kommentaarid: 46 loe/lisa |
40 |
Unholy
25.06.2005 11:42:36
Tere sain kah siis l2 c2 just endale ja kas keegi võiks mõne servu postitada sest siin viimastel lehekülgedel pole ühtegi mainitud!
Edit: sain vist c3 kah installima!
Edit: C2 on yle tunni aja update teinud midagi pole muutunud...Yleval jooksevad nimed ja see bar aga all overallis pole kriipsugi...
Edit: Overall progressist peale poolteist tundi 1/5
| Kommentaarid: 47 loe/lisa |
Djomka
25.06.2005 12:07:50
serveriks võid valida siis Lineage2World'i
või siis Lineage2Isogames
ise tead kumma sealt valid....
edit:aga kui sul on varsti C3 mäng, siis praegu sa l2w's mängida ei saa....see on alles C1 ja läheb varsti C2/C3
12 |
Dominus
26.06.2005 16:50:38
sweet...sain GM'ks ISO's eile olin kah kohal kui spawniti megalt palju Lesser Giant Shootereid et doom light armor recipe spoilida saaks.Mega üritus oli igatahes
rahvast 1600 online ja enamus olid Giant Shooterite kallal krt üks GM läks vahepeal liiga elevile ja spawnis üpris palju aga serveri kõvaketas pidas vastu ja laggi polnud.
paar pilti
76 |
Unholy
26.06.2005 19:10:11
Miks ei ütle? Selline probleem keegi oskab aidata? Peale update tuli vist :S
OS: Windows XP 5.1 (Build: 2600)
CPU: GenuineIntel Unknown processor @ 1705 MHz with 511MB RAM
Video: NVIDIA GeForce4 MX 440 (7189)
General protection fault!
History: UObject::ProcessEvent <- (GameInfo Lobby.GameInfo2, Function Engine.GameInfo.L2NetPostLogin) <- ULevel::SpawnPlayActor <- MatchViewportsToActors <- (Lobby) <- ClientInit <- UGameEngine::LoadMap <- LocalMapURL <- UGameEngine::Browse <- UGameEngine::Init <- InitEngine
arvutisõber
26.06.2005 19:22:26
no seda loobib ta tavaliselt iga vea puhul
Vahel näiteks, kui mõned failid on puudu või ei sobi konkreetse serveriga
_________________ ... |
| Kommentaarid: 55 loe/lisa |
53 |
ZAndlamb
26.06.2005 20:57:43
| Nagu mina aru sain on nende general protection fault errorid seotud quake mootoriga, mis tekitab probleeme siis kui mäng arvutil "hinge kinni" tõmbab.
| Kommentaarid: 22 loe/lisa |
22 |
Djomka
26.06.2005 21:16:52
jap, siis kui mingi hullem mõll kuskil käib on kõige suurem lootus selliseid erroreid saada...
kuigi mul on mõnikord ilma suurema mõlluta välja mängust visanud, aga siege'l pole sellist asja olnud, nii et see pole alati nii, aga enamasti küll
12 |
Djomka
26.06.2005 22:09:21
siis on ainuke variant, et sul on vale versiooni mäng serverist...selline probleem on mul tulnud ainult siis, kui olen tahtnud C2 mänguga C1 serverisse saada...
muidugi võivad sul mingi failid vigased olla, aga siis peaks ta viskama, et files are corrupt sildi sulle ette...igatahes soovitan, et sa lased uuesti mängu peale ja kindlasti vaata, et siis mäng oleks C3, sest ISO server on C3
aga ma ei tea, kas sa pead tegema selle official update'i ka ära, seda küsi mafka või kellegi sellise käest, kes seal servus veel mängivad
12 |
Unholy
26.06.2005 22:22:05
| ffs ma m2ngisin seal enne ju :S....M2ng installib uuesti siis panen patchi kah peale kuidas saab nii teha et autoupdate poleks?
No_Limit
26.06.2005 23:37:50
Lineage 2\system\L2.exe
40 |
rem4605
27.06.2005 09:43:41
damn xD
Clann laguneb (ISO)-s
mingi 3 liiget on veel okku, ja need kh ei ole aktiivsed! xD
btw. mafka hea uudis ! xD
| Kommentaarid: 21 loe/lisa |
17 |
Djomka
27.06.2005 12:58:48
kui SoE'd kaasas pole, siis on natuke nadi see kinnijäämine jah...
ja kui sa mystic oled, siis on suht pohh see rõivastuse kandmine, et kas sul on enne 20 D grade seljas või mitte
kui enne LVL 20't peale paned D grade asjad, siis mp'd tuleb juurde, aga defence, speed ja sellised asjad lähevad suht maha...peaasi, et sa ei peaks kuskile jooskma või et mingi mob sulle löögiulatusse ei jõuaks
12 |
Djomka
27.06.2005 20:37:26
ma olen l2w serveris, sina oled ISO's
ja ISO's on kergem materjale/raha kokku ajada...
hmm, 5 milli ei lähe kohe mitte, et endale top D selga ajada, selleks läheb kuskil 2,5 milli (sisse arvestatud ka bspsd'd)
ja kõige kergem on ikka raha ise teenida ja esimesel võimalusel osta endale kena staff, siis alles armor...muidugi on lootust, et sul tuleb armor ka dropina
praegu sa oled wizard jah, aga kelleks sa kavatsed edasi minna, kas spellsinger või elemental summoner...selles suhtes, et kui lähed ss'ks siis pole erilist mõtet sul ju neid servitori asju õppida, kuna neid sul vaja edaspidi ei lähe
12 |
rem4605
28.06.2005 00:29:35
| huntermagic kirjutas: |
ei tea veel mõtlen....lvl 25 olen hetkel leidsin sitaks hea tapmis koha siis sain surma ja ei leidnud enam ylesse  |
lol
Oleks pidanud kaarti j2lgima! xD
Krt mu clann on ikka nii in-active, et ikka kohe on xD
krt aint 2 memberit(in-active)-id.... :S:S:S
Ja olen oma dual spirit swordist kh 2ra tydinenud....
Krt linnas kh teised charrid myyvad imaasju IME-hindadega........
üks tahtis myya mulle oma SLS-i......... 150kk......
lol mul aint 60kk ja krt arvasin, et saab 50kk k2tte...
äkki mafka saa saad eestlasi natuke aidata GM-ina xD
Teised GM-id aitavad küll 2das s9pru xD
(mingitel uustulnukatel, keda ple elusees m2ngus n2inud on mingid TOP B ja S grade asjad seljas )
Igaljul mul on praeguseks m2ngutuju l2inud, ja kavatesed clanni h2vitada yldse!v
17 |
ZAndlamb
28.06.2005 01:02:14
| Ma aeg ajalt mängin aga suht kopp ees peale chari kaotamist matse oli ikka räigelt kogutud jne. Praegu teen bishopit või prophetit, pole veel valinud.
22 |
wazaa
28.06.2005 09:29:05
Ma ei tea aga kas te ei võiks seda juttu mis kilbike kellelgi või relv on kuskil mujal arutada? see nagu suht mõttetu postide kogumine teil
| Kommentaarid: 53 loe/lisa |
40 |
Cyberlord
28.06.2005 09:33:10
Irw GM`idel on reeglite vastane üldiselt teisi playereid "sponsoreerida"...iga mees pelab ise ikka ja teenib omad asjad välja. Mis mõte sellel mängul siis üldse on kui kõik kätte antakse
| Kommentaarid: 546 loe/lisa |
449 |
rem4605
28.06.2005 09:58:12
| Cyberlord kirjutas: |
Irw GM`idel on reeglite vastane üldiselt teisi playereid "sponsoreerida"...iga mees pelab ise ikka ja teenib omad asjad välja. Mis mõte sellel mängul siis üldse on kui kõik kätte antakse  |
Dunno
17 |
ZAndlamb
28.06.2005 10:02:49
Ausalt ma võtaks vastu kui pakutaks, võibolla olen lihtsalt vihane kuna kaotasin chari, võibolla lihtsalt tüdinenud mängust kes teab...
EDIT:
| wazaa kirjutas: |
Ma ei tea aga kas te ei võiks seda juttu mis kilbike kellelgi või relv on kuskil mujal arutada? see nagu suht mõttetu postide kogumine teil  |
Sama võiks öelda SETI, k saluuni jne teemade kohta.
22 |
Dominus
28.06.2005 11:44:37
| (mingitel uustulnukatel, keda ple elusees m2ngus n2inud on mingid TOP B ja S grade asjad seljas) |
Bgrade on kerge...kogud matse või ostad ning lased mõnel päkal teha..ja Sgrade pole kellelgi...välja arvata see kilp mis leiti kuskil karupersest.
76 |
Djomka
28.06.2005 16:08:41
| mine giranisse, seal on kõige paremad D grade asjad müügil...kõige paremad NG asjad ka
12 |
virko
28.06.2005 16:25:46
| Mafka kirjutas: |
Bgrade on kerge...kogud matse või ostad ning lased mõnel päkal teha..ja Sgrade pole kellelgi...välja arvata see kilp mis leiti kuskil karupersest. |
sina kui GM peaks paremini asja teadma kui mina
sa ytled et ainult yks kilp? miks siis inimesed S grade saapaid ja mytse myyvad
Djomka
28.06.2005 18:10:39
said D grade asjade jaoks raha kätte, siis saad C grade'i jaoks ka...pole ju eriline probleem või mis ?
ja miks peaks Gm seda paremini teadma ? Kas ta tõesti kõnnib igast inimesest mõõda ja vaatab, mis tal inventorys/wh's/seljas on ?
pole teadlik, et kas mingi käsklusega saab vaadata, palju S grade asju on droppinud või paljud kasutavad S grade asju
12 |
Unholy
28.06.2005 18:24:27
| kus c grade asju saab osta?
CpCC
28.06.2005 18:46:19
| luxurist, kristallide eest saad ainult osta seal poes.
| Kommentaarid: 8 loe/lisa |
ZAndlamb
28.06.2005 19:13:47
| kus c grade asju saab osta? |
Dion weapon and armor shopist
22 |
Unholy
29.06.2005 09:08:55
| ZAndlamb kirjutas: |
Dion weapon and armor shopist |
Sain teada juba playerite käest! Nüüd oleks parima relva jaoks raha vaja..Ilgelt hea oleks kui keegi kasvõi 2 milli saaks anda...
rem4605
29.06.2005 11:25:31
Sain teada juba playerite käest! Nüüd oleks parima relva jaoks raha vaja..Ilgelt hea oleks kui keegi kasvõi 2 milli saaks anda... |
V9id PM-ida mulle m2ngus.
V9in sulle paar milli anda.
17 |
Unholy
29.06.2005 13:50:53
| Mis clani tasub minna?
virko
30.06.2005 10:23:22
ISO server-hea hea hea
mu lvl 63 sorc avadon set, deadmans +5 lihtsalt kustutati 2ra
nüüd ei v6ta klann mind kh tagasi
rem4605
30.06.2005 12:29:30
| virko kirjutas: |
nüüd ei v6ta klann mind kh tagasi  |
Chat-is räägitaxe, et tuleb vist Wipe out xD
Lol, ma ple p2ris kindel...
Loodan, et tuleb xD
tglt mul on jumala savi xD
17 |
Unholy
30.06.2005 15:20:25
Kui wipe tuleb siis ma lahkun sellest servust pakun teistele HV-lastele kah, et l2heks m2ngiks parem
http://www.l2extreme.com/
Miks?=
1.Peetakse parimaks free serveriks
2.playereid on kõvasti rohkem
3.ei ole nii palju maas kui iso
4.Playerite kadumis jama ei ole
arvutisõber
30.06.2005 15:31:12
ma ka seal L2X, üli tegija server minu arvates. Ise olin seal vist LvL 69 Human Sorc
53 |
Dominus
30.06.2005 15:47:43
irw @ rem4605 nojah...juhtub...Enamus ISO adminne puhkusel kah,Jamaica ftw!
mingi paar nädalat siis saavad nad fully fixed c3'e...äkki sellepärast ei viitsi keegi ennast liigutada
76 |
ZAndlamb
30.06.2005 17:09:38
| huntermagic, ma olen ise ka juba l2x's, läksin sinna üle kui isos ss lag talumatuks muutus.
22 |
No_Limit
30.06.2005 17:16:21
Miks te L2W ei tule?
40 |
arvutisõber
30.06.2005 18:47:30
| Miks te L2W ei tule? |
Seal ju suht madal exp. Igal pool servudes juhtub alati mingi jama ja charid kaovad või tehakse wipe. Parem mängida high rate servus
Ja muide, ega selle 35x expiga sa naljalt level 80 -nt ka ei saa, ikka aega võtab peaks mainima, aga mängijad raatsivad vähemalt PvP -d teha ja vägev on
53 |
Negative
30.06.2005 19:10:54
| Selline küsimus, et kui ma tahan L2x-i tulla, kas ma saan siis official lehelt tiritud C3 clientiga ka connectida?
| Kommentaarid: 49 loe/lisa |
42 |
rem4605
30.06.2005 19:19:35
lol
l2hen nüüd 2-hex n2dalaks laagrisse.
Kui tulen tagasi loodan, et c3 on yleni fixitud ja Wipe out tehtud..
Cya all
17 |
ZAndlamb
30.06.2005 20:01:07
Seal oli mul ka ss lag, isos on mingi haige värk et 30 seci ss töötab... 30 seci ei tööta jne jne ning see on absoluutselt kõikidel.
JanisK, praegu ple mõtet tulla l2x'i oota paar päeva siis lähevad kõik servud c3 peale, praegusel hetkel on vaid kaks c2 servut üleval ning üks server on natukeseks ajaks maas, selle tõttu ma ka veel ei mängi seal kuigi kõik patchid/värgid on valmis pandud.
22 |
Djomka
30.06.2005 21:20:26
ise mängisin ka kunagi high rate kohtades...edasine jutt puhtalt minu arvamus
high rate servu on bs, sest seal ei pea mingit vaeva nägema, et kuskile jõuda...kõik on poes olemas ja kui kunagi mängida kuskil low rate servus, siis on mök-mök, nagu mul oli...kuidas seda teha ja kas seda polega poes müüa jne...
eks te kõik ise teate, enda asi kus ja kuidas L2'te mängida, aga pole siis pärast mõtet tulla ütlema, et ohh, nii igavaks muutus, et viitsi enam mängida vms.
endal on l2w's mingi 5 chari 40+ tehtud (DA kõige kõrgem), millega ma kavatsen edasi mängida...spoileriga kenasti c.leatherit spoilima ja retsepte, et raha teenida ja endale doom set lõpuks kokku ajada, mitte, et sa lähed ostad kõik poes ja ongi lõbus...siis tuled siia näitama kui kõva mees oled, et sul on sellised ja sellised asjad (kuigi nende asjade jaoks pole mitte mingisugust vaeva nähtud)...Huntermagic, sul ma eriti soovitan l2w's mängida...harjutad natuke low rate servus, saad targemaks pvp's ja kõiges muus, siis minna high rate servusse tagasi ja tead kohe, mida teha, mis on hea jne...
nagu enne juba ütlesin, see on minu arvamus, kui keegi ennast puudutatuna tunneb, siis shit happens
ja l2x's oli ss lag ja item lag ja kõik lagid veel mis nimetamata on....rõhk on sõnal oli (enam ei tea, kuna pole sinna oma jalga suht ammu juba tõstnud)
12 |
Unholy
30.06.2005 21:30:28
põmst ma ei viitsi eriti arvuti taga istuda suvel niikaua, et high rate servu nagu kerab rohkem hetkel olen maal ja siin ei ole midagi vahepeal teha siis 2 p2eva j2rjest yle 12 tunni l2 pelada on suht julm ...
scarface
02.07.2005 13:14:31
Küsimus kuidas teha seda [pilti/logo] clanni nime ette .. kui suur ja mitme värvine ja mis formaat ta peab olema ja kuhu ta peab siis panema? Mingi väike õpetus võiks olla .
tänud.
POLE vaja enam ..sain teada
viimati muutis scarface 02.07.2005 20:06:32, muudetud 1 kord |
| Kommentaarid: 45 loe/lisa |
43 |
mythic
02.07.2005 18:08:34
põmst ma ei viitsi eriti arvuti taga istuda suvel niikaua, et high rate servu nagu kerab rohkem hetkel olen maal ja siin ei ole midagi vahepeal teha siis 2 p2eva j2rjest yle 12 tunni l2 pelada on suht julm ... |
Nõrk...
Omal ajal panin kella 1ni öösel
Hellspawn Clan > all
(Olin lvl 68 Spellsinger )
Nüüd on see muidugi ajalugu
Unholy
02.07.2005 19:37:26
| mythic kirjutas: |
Nõrk...
Nüüd on see muidugi ajalugu  |
Ei suuda nii kaua, enam kah ei ole niigi kaua...Priit tegi sul osa leveleid sellega nii, et 2ra uhkusta midagi :/
EDIT: Koma...
viimati muutis Unholy 03.07.2005 09:19:41, muudetud 1 kord |
mythic
02.07.2005 23:12:03
IRW, noob rsk Priit aitas vahel jah, vb terve mu chari peale tegi 5 lvlit kokku, enamuses ta raisaks cbsps, leveleid ja raha
