Reixx
06.05.2005 08:36:30
| mnjah, aga äkki keegi põhjendaks nii väikest klokkumist... äkki kuskil mingi piirang peal biosis:P
| Kommentaarid: 62 loe/lisa |
54 |
diisel2.0
06.05.2005 09:25:24
| emaplaat on paras pidur,see piirabki
33 |
Sponge
06.05.2005 11:31:33
| huvitav millal s939 sempron amtelikult välja tuleb? seda võiks ju isegi 24/7 hoida 2,7ghz, xtremes oli kellelgi see ja oc OLI KUI LOOMAL
| Kommentaarid: 398 loe/lisa |
323 |
razor
06.05.2005 12:29:34
| Bh6 üle 220mhz ei lähegi vaja oleks 3.3V vhemalt mälule anda.
120 |
One
06.05.2005 13:06:53
A 20 Pin PSU Can Kill Your RAM on DFI NF4. Seriously, READ THIS Now!
An OCZ customer contacted me last week with a dead kit of PC3500 EB memory. After testing , we found 1 stick was bad. I set him up with an RMA. This week he contacted me with a set of PC3500 EL that has the same issue.
He was running an 430w Antec 20 pin PSU (no knock on Antec PSU's inteneded, they are fine). He also had the 5v memory option enabled on the board, but was running 3.1v. As we all know by now THIS IS NOT OK. DFI is telling us not to run 24 pin PSU and not to use a 20 Pin model, even with an adapter, no exuses and no discussion. Use a 20 pin and you could end up with dead memory!
I have heard of others with dead memory and am just now understanding why. DFI keeps telling us not to use a 20 pin PSU. I am 100% sure that this is the cause of damaged and dead memory and possibly even CPU's in this board. It' not DFI's fault, the board is shipped with documentation that states to use only a 24 pin PSU. It's not the memory's fault either, but it gets blamed and RMA'ed costing you and the manufacturer money.
Any of you that will say"my system works just fine with my 300w Maxiflower Himalayan Powerjacker PSU and it's a 20 pin!", at best are having bad performance and don't know it, and at worst are heading for some damaged components.
My personal recommendation for the DFI NF4 is for at least a 480w GOOD QUALITY 24 Pin PSU (nothing from bad OEM's will do, see the official list in the stickies). I prefer 500w or greater to insure that your system will perform well for you and that you have no damaged components. Using less might be limiting your overclocks anyway. You wanted the fastest board available, get a PSU to match!
Thanks for reading.
veel juttu: http://www.dfi-street.com/forum/showthread.php?t=10785
jõudu teile ja teie mäludele
minu tccd on surnud juba 8)
728 |
serz47
06.05.2005 13:07:40
Jah sellep2rast ma ostisn kah endale 24pin PSU enne oli 20pin
| Kommentaarid: 45 loe/lisa |
40 |
Evil
Hull
06.05.2005 13:13:04
Krdi raisk, alles panin 2K kõige parema toite peale magama, mis hetkel turul oli ja nüüd jälle uus vaja võtta, isegi üleminek ei aita.
202 |
HDTanel
Overclocker
06.05.2005 13:16:43
Lugege ennem ostu siis veidike asjast ka
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
Evil
Hull
06.05.2005 13:28:50
| PlatoonSgtElias kirjutas: |
Lugege enne ostu siis veidike asjast ka  |
Njaa sa oled alati kõige targem.
202 |
ragface
06.05.2005 13:53:06
et siis kumbagi ei või kasutada?
kasutan 20-pinist üleminekuta ning kõik voldid on normis samuti ei ole muid anomaaliaid esinenud. kuid eks kõik plaadid liiguvad oma vältimatu surma poole, nii et mingi osa vastab seal ka tõele...
mind muidu huvitab, kuidas teha kindlaks voltide ja amprite mõõtmisel, kas kasutatakse originaal 20- või 24-pin toitekat... võtame näiteks jsp, mida mul on 2 tükki: samad näitajad, erinev pinide arv. ja siis panen anteci 550w toitekale ülemineku otsa ning see on sitem kui 24-pin jsp 480w? power correctioniga toiteka puhul ei ole ju vahet mitu pini seal otsas on ja paljuks jagatakse... (antud 20-,24-pin küsimuses siis)
_________________ -
\R |
| Kommentaarid: 18 loe/lisa |
16 |
HDTanel
Overclocker
06.05.2005 14:02:42
Kui sa kasutad üleminekut siis kaks raili vms on topitud ühte liini... tekitab ülepinge lõdvalt ja sulab ära ilusti... hoolduses olen näinud kahte sellist juhtumit.
496 |
One
06.05.2005 14:09:47
| Kui sa kasutad üleminekut siis kaks raili vms on topitud ühte liini... tekitab ülepinge lõdvalt ja sulab ära ilusti... hoolduses olen näinud kahte sellist juhtumit. |
oled? ma pole siin eraldi railidega toitekaidki näinud
seda sulanud 12v lisamolexi juhtumit tuleb ikka ette
aga neil plaatidel/toidetel pole pcie-st ega dual 12v railist haisugi
728 |
Arvo Cobrietti
06.05.2005 14:11:05
| nu enamusel toitekatel ju niikuinii üks 12v rail?
| Kommentaarid: 39 loe/lisa |
37 |
ragface
06.05.2005 14:46:00
kas 20 -> 24 üleminekul pannaks 2 raili üheks kokku?
2x12 railid on ju 24-pin toitekates (4 vaba auku ühe 12 raili jaoks) ehk 20->24 üleminek jagab su +12 raili 2-ks, normaalse pc-ga toitekatel ei juhtu ju midagi, kui sa selle 2ks lahutad...
pealegi kui sa ostad jsp v colorsiti 24-pin 400w toiteka, siis sul ei ole 2 +12 raili vaid ikka labaselt combined 1 rail... 620W 24-pin ocz siis... andke, andke, adnke!
uurisin veel pisut seda asja:
need põlemised toimusid selle pärast, et kasutati lihtsalt piiripealset toiteplokki ja videokaarti(v 2te sli-s) mis tahtis 200+w ... ma ei tea mitu watti saab pcx siinist kaart, kuid moleksist nõudis 140+ watti tundub loogilisem põhjus olevat ning need läbipõletajad on ikka nö piiripealsed toitekad, mis selle peale põlvili sadasid.
2 moleksit kaartidele, üks molex veel plaadile sli toiteks ning muu riistvara + rasvane prescott ja 400w paneb pillid kotti
PS prescoti v6tan tagas! kuid ikkagi
_________________ -
\R
viimati muutis ragface 06.05.2005 15:01:54, muudetud 4 korda |
16 |
One
06.05.2005 14:48:15
peab miskise Fortroni kuskilt hankima ikka
728 |
tnz
06.05.2005 16:00:35
| Üritasin natukene clockida masinat, aga takerdub raisk 215fsb juures (10 kordajaga), Prose on amd64 3200+ ning mälu on Adata pc 3200 256mb (kokku neid 4 tükki masinas). Volt on deafult.
rene p
06.05.2005 16:08:16
| tnz kirjutas: |
| Üritasin natukene clockida masinat, aga takerdub raisk 215fsb juures (10 kordajaga), Prose on amd64 3200+ ning mälu on Adata pc 3200 256mb (kokku neid 4 tükki masinas). Volt on deafult. |
see mälu ei pruugigi sul rohkem minna, seda enam et sul on neid seal 4tk .)
aga jah pigem ongi süüdi selles madalas FSB-s 4 mälu korraga masinas ja kindlasti töötab sul see 1:1 FSb-ga?
68 |
Evil
Hull
06.05.2005 16:10:04
| tnz kirjutas: |
Kõik mäluslotid täis siis võta klokkimise ajaks 2 välja ja anna prosele volti juurde. Poleks paha teada mis emaplaat on.
202 |
tnz
06.05.2005 16:13:36
| Evil1923 kirjutas: |
| tnz kirjutas: |
Kõik mäluslotid täis siis võta klokkimise ajaks 2 välja ja anna prosele volti juurde. Poleks paha teada mis emaplaat on. |
A8N-sli, pole ka teab mis loom clockimise poolest :I
razor
06.05.2005 16:40:48
4 pulka 1T peal?
120 |
tnz
06.05.2005 19:45:46
| Toppisin 2T peale ja hetkel fsb 225. Mis vahe neil üldse on 1T ja 2T, ma suht algaja selle koha pealt
One
06.05.2005 20:52:14
need on 24/7 kellad/timingud
töötas samadega ka 270mhz @ dual
pinge 24/7 3,3v ja 270mhz peal 3.5v
see viimane 16 on vale, tegelt on asi 11
728 |
vambola
06.05.2005 21:10:52
| Aga jõudlus? On ikka kiirem ka kui enne?
120 |
One
06.05.2005 21:46:25
| vambola kirjutas: |
| Aga jõudlus? On ikka kiirem ka kui enne? |
millega võrreldes?
3200mb/sec oli memtest86 mälu läbilase
ennem pole kordagi sääraseid numbreid näinud
728 |
Evil
Hull
06.05.2005 22:42:17
| Winterwind, kas kasutasid oma Antec True 550W sel hetkel kui TCCD-d surid?
202 |
