parun
13.04.2005 18:34:51
Lapakas acer aspire 1362LMi probleem |
ostsin Mikromaailmast siis sellise isendi, aga tundub, et on probleem Windows näitab, et prose kiirus on 800Gh- kuigi peaks olema 1,6Gh, järgneval mälu mahuks ütleb 192 kuigi müüjal oli kirjas 256 MB- ka masina peal on 256. Minu jaoks on asi pehmelt öeldes kummaline ja kummaliseks teeb veel see, et mõnikord näitab prose kiiruseks nagau peab 1,6Gh-äkki peab nii olema????. Oleks väga tänulik kui keegi selgitaks asja. Annan ka Sandra andmed
SiSoftware Sandra
System
Host Name : ACER-684C9A655D
User : kait
Domain : WORKGROUP
Processor
Model : Mobile AMD Sempron(tm) Processor 2800+
Speed : 800MHz
Model Number : 2800 (estimated)
Performance Rating : PR1200 (estimated)
Type : Low Power
L2 On-board Cache : 256kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
Mainboard
Bus(es) : ISA AGP PCI IMB CardBus USB FireWire/1394 i2c/SMBus
MP Support : 1 CPU(s)
MP APIC : Yes
System BIOS : AT/AT COMPATIBLE
Total Memory : 191MB DDR-SDRAM
Chipset 1
Model : Acer Inc K8M400 CPU to PCI Bridge
Front Side Bus Speed : 2x 800MHz (1600MHz data rate)
Shared Memory : 1MB
Chipset 2
Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
Total Memory : 256MB DDR-SDRAM
Memory Bus Speed : 2x 160MHz (320MHz data rate)
Video System
Monitor/Panel : Default Monitor
Monitor/Panel : Digital Flat Panel (1024x768)
Monitor/Panel : Generic Television
Adapter : VIA/S3G UniChrome Pro IGP
Physical Storage Devices
Hard Disk : TOSHIBA MK4025GAS (37GB)
CD-ROM/DVD : TSSTcorp CD/DVDW TS-L532A (CD 24X Rd, 24X Wr) (DVD 3X Rd, 3X Wr)
Logical Storage Devices
Acer (C : 18GB (15GB, 83% Free Space) (FAT32)
Acerdata (D : 18GB (18GB, 100% Free Space) (FAT32)
CD-ROM/DVD (E : N/A
Peripherals
Serial/Parallel Port(s) : 1 COM / 1 LPT
USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller
USB Controller/Hub : VIA USB Enhanced Host Controller
USB Controller/Hub : USB Root Hub
FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller
PCMCIA/CardBus Controller : Generic CardBus Controller
Infrared Device : IrDA Fast Infrared Port
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : Synaptics PS/2 Port TouchPad
MultiMedia Device(s)
Device : Vinyl AC'97 Codec Combo Driver (WDM)
Communication Device(s)
Device : Agere Systems AC'97 Modem
Printers and Faxes
Model : Fax
Power Management
AC Line Status : On-Line
Battery No 1 : 100%
Operating System(s)
Windows System : Microsoft Windows XP/2002 Home (Win32 x86) 5.01.2600 (Service Pack 2)
Network Services
Adapter : VIA Rhine II Fast Ethernet Adapter
Adapter : acer IPN2220 Wireless LAN Card
Performance Tips
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
_________________ seni kuni sa pole suud lahti teinud, ei tea keegi kui loll sa oled |
Riivo
13.04.2005 18:44:36
äkki on asi selles et läpakas lülitab ilma koormuseta osa prosest välja et akut hoida igati tänuväärne tegevus ju
221 |
parun
13.04.2005 19:54:50
loll on loll olla |
no sain juba targemaks-aitäh!
Prayer
13.04.2005 20:29:43
Ja osa mälust ei näidata kuna see on videokaardi käsutuses.
Mis ühikutes muidu seda prose "asja" mõõdetakse sul - Gh = gigatund?
203 |
puna
14.04.2005 21:48:43
| Biosist saad ilmselt määrata palju video jaoks mälu kasutab.
313 |
Riivo
14.04.2005 21:55:28
| kui ei mängi siis tuleks vähem panna
221 |
