uus teema   vasta Tarkvara »  Arvutimängude foorum »  Half-Life 2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 135, 136, 137 ... 241, 242, 243  järgmine
Scart
Scart
sõnum 02.03.2005 17:28:40 vasta tsitaadiga
5 veebruari pressiteade
""Over the next month or so there will be a couple of interesting releases via Steam, in addition to the upcoming Counter-Strike map de_compound.
First, we'll be releasing an update to Half-Life 2: Deathmatch that will include the Slam, Stunstick, and the Crowbar. We're not ready to release the contest winning maps just yet, but we will be releasing a new map we've built at Valve to tide people over while we sort out the contest winners. There will also be a release to Counter-Strike: Source around the same time that will address a few minor issues.
One feature that we'll be adding to the Source engine in the coming months is high dynamic range lighting. To showcase this we've taken a part of the Highway 17 chapter of Half-Life 2 and worked it into a single level that incorporates HDR along with some new gameplay. We're calling this short level "The Lost Coast," and it will be made available free of charge to Half-Life 2 customers that meet a specific set of high end hardware requirements. We'll be publishing those requirements soon."
486
sõnum 02.03.2005 18:44:47 vasta tsitaadiga
Kas HL2-e saab kustutada ilma et ConterStrike Source ei kustuks?
zero
corvette
sõnum 02.03.2005 18:47:05 vasta tsitaadiga
486 kirjutas:
peaks saama
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 48
486
sõnum 02.03.2005 19:08:00 vasta tsitaadiga
Ma unisin HL2 ära ja mõlemad ikoonid kadusid ära. Igaks juhuks proovisin kas Steamist lähevad käima ja ikka läksid icon_eek.gif see kustutand ju midagi icon_mad.gif
zero
carl232917
sõnum 03.03.2005 20:43:54 vasta tsitaadiga
Half life 2 on ülimalt hea mäng esiteks on ta täiesti reaalne mida ei saa doomiga võrrelda (doomIII) teiseks ei saa doomis asju liigutada nagu half life 2-s et võtad tünni ja viskad kellegi surnuks...............ühesõnaga doomIII sakib ja HAF LIFE 2 on lihtsalt parem, parem, ja veel kord parem ......soovitan kõigile thumbs_up.gif
Kommentaarid: 8 loe/lisa Kasutajad arvavad:  :: 3 :: 1 :: 1
carl232917
sõnum 03.03.2005 20:46:45 vasta tsitaadiga
pane steamist tööle siis vaata hl2 ikoonile (steami sees) ja vajuta paremat hiire klõpsu siis kõige all properties ja seal see on .uniinstall...
siLc
sõnum 03.03.2005 20:48:35 vasta tsitaadiga
On olemas nupp et oma eelmisesse posti vahepeal pähe karand teemakohased asjad kirjutada icon_rolleyes.gif
Kommentaarid: 196 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 185
Scart
Scart
sõnum 07.03.2005 11:11:34 vasta tsitaadiga
link :: kae siit
pidavat paljulubav mod olema
Ho Ho
Ho Ho
sõnum 07.03.2005 11:21:35 vasta tsitaadiga
pelatnäha huvitav kuid loodetavasti tuleb see ikka ingliskeelsena välja
Auron
Auron
sõnum 07.03.2005 13:19:26 vasta tsitaadiga
Kusjuures olen ise juba esimesest vilmist alates jurassic park'i ikka suht fännand ja mingi hea selleteemaline mod oleks väga teretulnud icon_smile.gif
Kommentaarid: 152 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 129
corvette
sõnum 07.03.2005 14:40:01 vasta tsitaadiga
päris kõva jah, suuri dinosauruseid peaks hl2 mootor lubama küll icon_razz1.gif
Loodan ka seda ingliskeelsena näha
Scart
Scart
sõnum 31.03.2005 08:58:53 vasta tsitaadiga
link :: kae siit
telekast võetud pildid Source mootori HDRist
predator
predator
sõnum 31.03.2005 10:51:00 vasta tsitaadiga
Kusagilt lugesin, et meie põhjanaabrid valmistavad HL2 mod`i Talvesõjast või jätkusõjast, täpselt ei mäletagi enam, see võib küll päris huvitav tulla.
Kommentaarid: 177 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 154
rene p
sõnum 31.03.2005 11:54:12 vasta tsitaadiga
predator kirjutas:
otsi link ülesse, päris huvitav tõesti...
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 67
486
sõnum 31.03.2005 12:51:02 vasta tsitaadiga
predator kirjutas:
KAs siis gravity gunniga lumepalle saab visata?
zero
circles
circles
sõnum 31.03.2005 19:34:34 vasta tsitaadiga
486 kirjutas:
predator kirjutas:
käsitsi kindlasti ma arvan. muide, HL2 deathmatch on siiamaani buge täis, millal valve need ükskord ära parandab. icon_rolleyes.gif
Võtke õuna!
EvilKatarn
diivanilill
EvilKatarn
sõnum 31.03.2005 19:39:07 vasta tsitaadiga
486 kirjutas:
predator kirjutas:
Talvesõjas ju pold mingit graviti guni(kui ventiil tahab miskit reaalsemat teha)
Kommentaarid: 109 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 80
siLc
sõnum 31.03.2005 19:43:49 vasta tsitaadiga
Samas ma kahtlen et sommid hakkavad 1930-1940aastate relvastust nagu Mosin-Naganti vintpüssid (rahvakeeli lihtsalt Vene vintpüss) nullist modelleerima icon_neutral.gif
predator
predator
sõnum 31.03.2005 19:47:02 vasta tsitaadiga
darkplayr kirjutas:
Ma ei leia seda kohta enam üles aga kui ma paar-kolm kuud tagasi leidin juhuslikult infi selle mod kohta, siis mõned selle ajastu relvade mudelid olid näituseks juba valmis pandud.
Riivo
Riivo
sõnum 31.03.2005 20:03:06 vasta tsitaadiga
darkplayr kirjutas:
aga mine sa tea icon_razz.gif täitsa huvitav võiks olla kui see neil hästi välja kukub
HDTanel
Overclocker
HDTanel
sõnum 02.04.2005 20:50:46 vasta tsitaadiga
http://www.zone.ee/platoonsgtelias/1/HL2_lol_2.jpg?2
http://www.zone.ee/platoonsgtelias/1/HL2_lol_3.jpg?2
http://www.zone.ee/platoonsgtelias/1/HL2_lol_4.jpg?2
http://www.zone.ee/platoonsgtelias/1/HL2_lol_5.jpg?2
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
EvilKatarn
diivanilill
EvilKatarn
sõnum 02.04.2005 21:00:00 vasta tsitaadiga
Auron
Auron
sõnum 02.04.2005 21:01:26 vasta tsitaadiga
Kaks neist piltidest olid ka selle kuu PCG gamersnap'i s. icon_lol.gif Igastahes head on icon_lol.gif
HDTanel
Overclocker
HDTanel
sõnum 02.04.2005 21:03:29 vasta tsitaadiga
Ma tean icon_biggrin.gif ma iga kuu ostan... sealt just sain icon_razz1.gif thumbs_up.gif icon_lol.gif
PC Gameris ikka jõhkrad ajuvabad pildid icon_biggrin.gif thumbs_up.gif mega
Krüpto
RustyZ
RustyZ
sõnum 02.04.2005 21:07:32 vasta tsitaadiga
mismoodi need tehtud on ei tea?
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Half-Life 2 mine lehele eelmine  1, 2, 3 ... 135, 136, 137 ... 241, 242, 243  järgmine
