weyx13
01.02.2005 04:21:53
New.Net |
New.Net: Type library (Registry key, nothing done)
HKEY_CLASSES_ROOT\TypeLib\{B7620AF8-B460-455a-946F-16F8BF52A9AD}
--- Spybot - Search && Destroy version: 1.3 ---
2004-11-29 Includes\Cookies.sbi
2005-01-27 Includes\Dialer.sbi
2005-01-27 Includes\Hijackers.sbi
2005-01-11 Includes\Keyloggers.sbi
2004-05-12 Includes\LSP.sbi
2005-01-27 Includes\Malware.sbi
2004-11-29 Includes\Revision.sbi
2004-11-29 Includes\Security.sbi
2005-01-27 Includes\Spybots.sbi
2004-11-29 Includes\Tracks.uti
2005-01-27 Includes\Trojans.sbi
Spybot leab piiratud õigustega kasutajal sellise värgi.
Eemaldada ei lase, kuskil add/remove's ega program filedes seda pole.
HJT ei leia midagi.
Ad-Aware ega Microsofti enda antispy ka mitte. Viga ainult sellel kasutajal, teised puhtad.
Mis teha saab?
Max Powers
01.02.2005 08:15:31
tsitaat: |
HJT ei leia midagi.
tsitaat: |
New.Net can be easily removed following these instructions:
1) From the Windows Start button select Settings and then Control Panel.
2) When the Control Panel window opens, double-click on the Add/Remove Programs icon.
3) When the Add/Remove Programs Properties window opens, locate New.Net in the list of installed programs. Select it and then click on the Add/Remove button.
4) Follow the on screen instructions.
See peaks tegelikult olema küll add/remove all.
Ja kui ei ole siis selle õpetuse järgi saad ehk lahti - http://www.geocities.com/merijn_bellekom/new/nonewdotnet.html
Kommentaarid: 215 loe/lisa |
182 |
UMMI9999
01.02.2005 17:17:29
Enne New.Net eemaldamist soovitan tõmmata LSPFix, kuna New.Net eemaldamine võib ka neti kaasa viia.
Lühike õpetus, kui niisama lahti ei saa:
Next, load regedit and open HKEY_CLASSES_ROOT\CLSID . Delete the keys 4A2AACF3-ADF6-11D5-98A9-00E018981B9E and DD521A1D-1F98-11D4-9676-00E018981B9E . For older variants the key will be DD770A75-CE18-11D5-98D8-00E018981B9E instead.
Open HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run . Delete the new.net value. Open HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects and remove the 4A2AACF3-ADF6-11D5-98A9-00E018981B9E key. You can also delete the new.net entry in HKLM\Software and the tldctl2 classes in HKCR to clean up if you wish.
Reset the computer and you should be able to delete the NewDotNet folder (new variant) or the newdotnet DLL in the Windows directory (old variant).
_________________ Quid est veritas?
Kes teab vastust? |
Kommentaarid: 9 loe/lisa |
9 |
weyx13
01.02.2005 23:03:38
add/remove all teda ikka ei ole, otsinguga ta newdot*dll ega sellele sarnaseid faile ei leia, regeditis puuduvad UMMI toodud key'd. Probleemi nagu polekski, ainult spybot leiab
HacaX
01.02.2005 23:21:21
Ja miks mitte kustutada seda võtit mille SB leiab?
Isiklik arvamus: tegu mittefunktsionaalse jäänukiga, SB vast just selle pärast ei julgegi kallale minna, et midagi rohkemat ei leia.
Soovitaks tegelikult SB sätetes beetade näitamine sisse lülitada ja nõnda ka proge viimase versiooninumbrini värskendada (peaks olema 1.4b2 IIRC). Äkki mingi signatuuride ühildumatusest tingitud kala.
Kommentaarid: 24 loe/lisa |
22 |
weyx13
02.02.2005 00:58:38
Võtit kustutada ei lasknud, aga beeta vist aitas. Igal juhul praegu puhas
Minu poolt teema lukku, thanks
HacaX
02.02.2005 15:59:16
Lisan veel ühe märkuse: sai mõeldud *käsitsi* kustutamist. RegEdiga otsisid teisi võtmeid, aga mitte seda mille SB välja tuhnis. Või eksin?
22 |
lisa lemmikuks |
