est
27.12.2004 20:55:20
| Kas tulemust ei mõjuta see,et SE-l oli vist 17testi ja PRO-l 21 testi?
One
27.12.2004 20:56:15
ei mõjuta!
punkte annavad nagunii neli esimest mängutesti - ülejäänud on niisama iluasjad
728 |
est
27.12.2004 21:01:55
| Oskad äkki öelda, miks 2001SE testis näitab,et mu PowerColor 9800 nonpro on 9800Pro?
sirtauri
27.12.2004 21:04:36
tegin ka siis ära , tulemused järgmised
vabandust et se nii pikk ,mõni mode võib seda lõikuda kui just peab
RESULTS
3DMark Score 5578
Game 1 - Car Chase - Low Detail 100.5 fps
Game 1 - Car Chase - High Detail 41.6 fps
Game 2 - Dragothic - Low Detail 93.0 fps
Game 2 - Dragothic - High Detail 43.9 fps
Game 3 - Lobby - Low Detail 98.1 fps
Game 3 - Lobby - High Detail 47.6 fps
Game 4 - Nature Not supported by hardware
Fill Rate (Single-Texturing) 440.5 MTexels/s
Fill Rate (Multi-Texturing) 839.4 MTexels/s
High Polygon Count (1 Light) 29.3 MTriangles/s
High Polygon Count (8 Lights) 6.4 MTriangles/s
Environment Bump Mapping Not supported by hardware
DOT3 Bump Mapping 66.8 fps
Vertex Shader 52.2 fps
Pixel Shader Not supported by hardware
Advanced Pixel Shader Not supported by hardware
Point Sprites 9.6 MSprites/s
SYSTEM INFO
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer AMD
Family <unknown>
Internal Clock 1.80 GHz
Internal Clock Maximum 1.80 GHz
External Clock 133 MHz
Socket Designation Socket A
Type Central
Upgrade ZIF Socket
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
Version Model 10, Stepping 0
CPUID 0x000006a0
CACHES
Level 1
Capacity 128 KB
Type <unknown>
Type Details <unknown>
Error Correction Type <unknown>
Associativity <unknown>
Level 2
Capacity 256 KB
Type <unknown>
DIRECTX INFO
DirectX Version 9.0
DIRECTDRAW INFO
DirectDraw Version 5.03.2600.2180
DISPLAY DEVICES
Description Primary Display Driver
Manufacturer NVIDIA
Name NVIDIA GeForce4 MX 440
Total Local Video Memory 64 MB
Total Local Texture Memory 64 MB
Total AGP Memory 128 MB
Display Driver nv4_disp.dll
Display Driver Version 6.14.10.5672
Driver WHQL Certified Yes
Max Texture Width 2048
Max Texture Height 2048
Max User Clipping Planes 0
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 2
Vertex Shader Version N/A
Pixel Shader Version N/A
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
Vendor ID 0x10de
Device ID 0x0171
Sub-System ID 0x00000000
Revision 0xa3
DISPLAY MODES
Resolution 320x200x16-bit RGB [565] @ 60 Hz
Resolution 320x200x16-bit RGB [565] @ 70 Hz
Resolution 320x200x16-bit RGB [565] @ 72 Hz
Resolution 320x200x16-bit RGB [565] @ 75 Hz
Resolution 320x240x16-bit RGB [565] @ 60 Hz
Resolution 320x240x16-bit RGB [565] @ 70 Hz
Resolution 320x240x16-bit RGB [565] @ 72 Hz
Resolution 320x240x16-bit RGB [565] @ 75 Hz
Resolution 400x300x16-bit RGB [565] @ 60 Hz
Resolution 400x300x16-bit RGB [565] @ 70 Hz
Resolution 400x300x16-bit RGB [565] @ 72 Hz
Resolution 400x300x16-bit RGB [565] @ 75 Hz
Resolution 480x360x16-bit RGB [565] @ 60 Hz
Resolution 480x360x16-bit RGB [565] @ 70 Hz
Resolution 480x360x16-bit RGB [565] @ 72 Hz
Resolution 480x360x16-bit RGB [565] @ 75 Hz
Resolution 512x384x16-bit RGB [565] @ 60 Hz
Resolution 512x384x16-bit RGB [565] @ 70 Hz
Resolution 512x384x16-bit RGB [565] @ 72 Hz
Resolution 512x384x16-bit RGB [565] @ 75 Hz
Resolution 640x400x16-bit RGB [565] @ 60 Hz
Resolution 640x400x16-bit RGB [565] @ 70 Hz
Resolution 640x400x16-bit RGB [565] @ 72 Hz
Resolution 640x400x16-bit RGB [565] @ 75 Hz
Resolution 640x480x16-bit RGB [565] @ 60 Hz
Resolution 640x480x16-bit RGB [565] @ 70 Hz
Resolution 640x480x16-bit RGB [565] @ 72 Hz
Resolution 640x480x16-bit RGB [565] @ 75 Hz
Resolution 640x480x16-bit RGB [565] @ 85 Hz
Resolution 720x480x16-bit RGB [565] @ 60 Hz
Resolution 720x576x16-bit RGB [565] @ 60 Hz
Resolution 800x600x16-bit RGB [565] @ 60 Hz
Resolution 800x600x16-bit RGB [565] @ 70 Hz
Resolution 800x600x16-bit RGB [565] @ 72 Hz
Resolution 800x600x16-bit RGB [565] @ 75 Hz
Resolution 800x600x16-bit RGB [565] @ 85 Hz
Resolution 848x480x16-bit RGB [565] @ 60 Hz
Resolution 848x480x16-bit RGB [565] @ 70 Hz
Resolution 848x480x16-bit RGB [565] @ 72 Hz
Resolution 848x480x16-bit RGB [565] @ 75 Hz
Resolution 848x480x16-bit RGB [565] @ 85 Hz
Resolution 1024x768x16-bit RGB [565] @ 60 Hz
Resolution 1024x768x16-bit RGB [565] @ 70 Hz
Resolution 1024x768x16-bit RGB [565] @ 72 Hz
Resolution 1024x768x16-bit RGB [565] @ 75 Hz
Resolution 1024x768x16-bit RGB [565] @ 85 Hz
Resolution 1152x864x16-bit RGB [565] @ 60 Hz
Resolution 1152x864x16-bit RGB [565] @ 70 Hz
Resolution 1152x864x16-bit RGB [565] @ 72 Hz
Resolution 1152x864x16-bit RGB [565] @ 75 Hz
Resolution 1152x864x16-bit RGB [565] @ 85 Hz
Resolution 1280x720x16-bit RGB [565] @ 60 Hz
Resolution 1280x720x16-bit RGB [565] @ 70 Hz
Resolution 1280x720x16-bit RGB [565] @ 72 Hz
Resolution 1280x720x16-bit RGB [565] @ 75 Hz
Resolution 1280x720x16-bit RGB [565] @ 85 Hz
Resolution 1280x768x16-bit RGB [565] @ 60 Hz
Resolution 1280x768x16-bit RGB [565] @ 70 Hz
Resolution 1280x768x16-bit RGB [565] @ 72 Hz
Resolution 1280x768x16-bit RGB [565] @ 75 Hz
Resolution 1280x768x16-bit RGB [565] @ 85 Hz
Resolution 1280x960x16-bit RGB [565] @ 60 Hz
Resolution 1280x960x16-bit RGB [565] @ 70 Hz
Resolution 1280x960x16-bit RGB [565] @ 72 Hz
Resolution 1280x960x16-bit RGB [565] @ 75 Hz
Resolution 1280x960x16-bit RGB [565] @ 85 Hz
Resolution 1280x1024x16-bit RGB [565] @ 60 Hz
Resolution 1280x1024x16-bit RGB [565] @ 70 Hz
Resolution 1280x1024x16-bit RGB [565] @ 72 Hz
Resolution 1280x1024x16-bit RGB [565] @ 75 Hz
Resolution 320x200x32-bit RGB [888] @ 60 Hz
Resolution 320x200x32-bit RGB [888] @ 70 Hz
Resolution 320x200x32-bit RGB [888] @ 72 Hz
Resolution 320x200x32-bit RGB [888] @ 75 Hz
Resolution 320x240x32-bit RGB [888] @ 60 Hz
Resolution 320x240x32-bit RGB [888] @ 70 Hz
Resolution 320x240x32-bit RGB [888] @ 72 Hz
Resolution 320x240x32-bit RGB [888] @ 75 Hz
Resolution 400x300x32-bit RGB [888] @ 60 Hz
Resolution 400x300x32-bit RGB [888] @ 70 Hz
Resolution 400x300x32-bit RGB [888] @ 72 Hz
Resolution 400x300x32-bit RGB [888] @ 75 Hz
Resolution 480x360x32-bit RGB [888] @ 60 Hz
Resolution 480x360x32-bit RGB [888] @ 70 Hz
Resolution 480x360x32-bit RGB [888] @ 72 Hz
Resolution 480x360x32-bit RGB [888] @ 75 Hz
Resolution 512x384x32-bit RGB [888] @ 60 Hz
Resolution 512x384x32-bit RGB [888] @ 70 Hz
Resolution 512x384x32-bit RGB [888] @ 72 Hz
Resolution 512x384x32-bit RGB [888] @ 75 Hz
Resolution 640x400x32-bit RGB [888] @ 60 Hz
Resolution 640x400x32-bit RGB [888] @ 70 Hz
Resolution 640x400x32-bit RGB [888] @ 72 Hz
Resolution 640x400x32-bit RGB [888] @ 75 Hz
Resolution 640x480x32-bit RGB [888] @ 60 Hz
Resolution 640x480x32-bit RGB [888] @ 70 Hz
Resolution 640x480x32-bit RGB [888] @ 72 Hz
Resolution 640x480x32-bit RGB [888] @ 75 Hz
Resolution 640x480x32-bit RGB [888] @ 85 Hz
Resolution 720x480x32-bit RGB [888] @ 60 Hz
Resolution 720x576x32-bit RGB [888] @ 60 Hz
Resolution 800x600x32-bit RGB [888] @ 60 Hz
Resolution 800x600x32-bit RGB [888] @ 70 Hz
Resolution 800x600x32-bit RGB [888] @ 72 Hz
Resolution 800x600x32-bit RGB [888] @ 75 Hz
Resolution 800x600x32-bit RGB [888] @ 85 Hz
Resolution 848x480x32-bit RGB [888] @ 60 Hz
Resolution 848x480x32-bit RGB [888] @ 70 Hz
Resolution 848x480x32-bit RGB [888] @ 72 Hz
Resolution 848x480x32-bit RGB [888] @ 75 Hz
Resolution 848x480x32-bit RGB [888] @ 85 Hz
Resolution 1024x768x32-bit RGB [888] @ 60 Hz
Resolution 1024x768x32-bit RGB [888] @ 70 Hz
Resolution 1024x768x32-bit RGB [888] @ 72 Hz
Resolution 1024x768x32-bit RGB [888] @ 75 Hz
Resolution 1024x768x32-bit RGB [888] @ 85 Hz
Resolution 1152x864x32-bit RGB [888] @ 60 Hz
Resolution 1152x864x32-bit RGB [888] @ 70 Hz
Resolution 1152x864x32-bit RGB [888] @ 72 Hz
Resolution 1152x864x32-bit RGB [888] @ 75 Hz
Resolution 1152x864x32-bit RGB [888] @ 85 Hz
Resolution 1280x720x32-bit RGB [888] @ 60 Hz
Resolution 1280x720x32-bit RGB [888] @ 70 Hz
Resolution 1280x720x32-bit RGB [888] @ 72 Hz
Resolution 1280x720x32-bit RGB [888] @ 75 Hz
Resolution 1280x720x32-bit RGB [888] @ 85 Hz
Resolution 1280x768x32-bit RGB [888] @ 60 Hz
Resolution 1280x768x32-bit RGB [888] @ 70 Hz
Resolution 1280x768x32-bit RGB [888] @ 72 Hz
Resolution 1280x768x32-bit RGB [888] @ 75 Hz
Resolution 1280x768x32-bit RGB [888] @ 85 Hz
Resolution 1280x960x32-bit RGB [888] @ 60 Hz
Resolution 1280x960x32-bit RGB [888] @ 70 Hz
Resolution 1280x960x32-bit RGB [888] @ 72 Hz
Resolution 1280x960x32-bit RGB [888] @ 75 Hz
Resolution 1280x960x32-bit RGB [888] @ 85 Hz
Resolution 1280x1024x32-bit RGB [888] @ 60 Hz
Resolution 1280x1024x32-bit RGB [888] @ 70 Hz
Resolution 1280x1024x32-bit RGB [888] @ 72 Hz
Resolution 1280x1024x32-bit RGB [888] @ 75 Hz
TEXTURE FORMATS
Pixel Format 32-bit ARGB [8888]
Pixel Format 32-bit RGB [888]
Pixel Format 16-bit RGB [565]
Pixel Format 16-bit RGB [555]
Pixel Format 16-bit ARGB [1555]
Pixel Format 16-bit ARGB [4444]
Pixel Format 8-bit Indexed()
Pixel Format FourCC [DXT1]
Pixel Format FourCC [DXT2]
Pixel Format FourCC [DXT3]
Pixel Format FourCC [DXT4]
Pixel Format FourCC [DXT5]
3D Capabilities AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Rendering to a Window, Mipmap LOD Bias Adjustment, Projected Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures
DIRECTSHOW INFO
DirectShow Version 6.05.2600.2180
REGISTERED DIRECTSHOW FILTERS
Filter .RAM file Parser
Filter 3ivx D4 Audio Decoder
Filter 3ivx D4 Media Splitter
Filter 3ivx D4 Video Decoder
Filter AAC Decoder
Filter AC3 Parser Filter
Filter AC3 from AVI XForm
Filter ACELP.net Sipro Lab Audio Decoder
Filter ACM Wrapper
Filter ASF ACM Handler
Filter ASF DIB Handler
Filter ASF DJPEG Handler
Filter ASF ICM Handler
Filter ASF JPEG Handler
Filter ASF URL Handler
Filter ASF embedded stuff Handler
Filter ASX file Parser
Filter ASX v.2 file Parser
Filter AVI Decompressor
Filter AVI Draw
Filter AVI Splitter
Filter AVI/WAV File Source
Filter BDA MPEG2 Transport Information Filter
Filter BDA Slip De-Framer
Filter Bicubic Video Resizer
Filter Color Space Converter
Filter CyberLink Audio Decoder
Filter CyberLink DVD Navigator
Filter DV Muxer
Filter DV Splitter
Filter DV Video Decoder
Filter Decrypt/Tag
Filter Default DirectSound Device
Filter Default MidiOut Device
Filter DirectVobSub (auto-loading version)
Filter DivX Decoder Filter
Filter DivX MPEG-4 DVD Video Decompressor
Filter DivXAntiFreeze
Filter DivXG400
Filter DivXG400Force
Filter Elecard MPEG2 Demultiplexer
Filter Elecard MPEG2 Video Decoder
Filter Elecard PIM2 Null
Filter Elecard PVA Demultiplexer
Filter File Source (Async.)
Filter File Source (Netshow URL)
Filter File Source (URL)
Filter File stream renderer
Filter Fraunhofer Video Decoder
Filter IVF source filter
Filter Indeo® audio software
Filter Indeo® video 4.4 Decompression Filter
Filter InterVideo Audio Decoder
Filter Internal Script Command Renderer
Filter Leadtek Audio Decoder
Filter Leadtek File Source Filter
Filter Leadtek Video/SP Decoder
Filter Ligos MPEG Audio Decoder
Filter Ligos MPEG Splitter
Filter Ligos MPEG Video Decoder
Filter Line 21 Decoder
Filter Line 21 Decoder 2
Filter Lyric Parser
Filter MIDI Parser
Filter MJPEG Decompressor
Filter MPEG Layer-3 Decoder
Filter MPEG-2 Demultiplexer
Filter MPEG-2 Sections and Tables
Filter MPEG-2 Splitter
Filter MPEG-I Stream Splitter
Filter Microcrap MPEG-4 Video Decompressor
Filter Microsoft MPEG-4 Video Decompressor
Filter Microsoft Screen Video Decompressor
Filter Moonlight Odio Dekoda
Filter Moonlight Sync2Async
Filter Morgan MJPEG Decompressor
Filter Morgan Stream Switcher
Filter Multi-file Parser
Filter NSC file Parser
Filter Ogg Multiplexer
Filter Ogg Splitter
Filter Overlay Mixer2
Filter QT Decompressor
Filter QuickTime Movie Parser
Filter SAMI (CC) Parser
Filter Subtitle Mixer
Filter Subtitle Parser
Filter VBI Surface Allocator
Filter VGA 16 Color Ditherer
Filter Video Port Manager
Filter Video Renderer
Filter Vorbis Decoder
Filter WM ASF Reader
Filter WM ASF Writer
Filter WST Decoder
Filter Wave Parser
Filter WinFast Data Transform filter
Filter Windows Media Audio Decoder
Filter Windows Media Multiplexer
Filter Windows Media Pad VU Data Grabber
Filter Windows Media Update Filter
Filter Windows Media Video Decoder
Filter Windows Media source filter
Filter XML Playlist
Filter XviD MPEG-4 Video Decoder
MEMORY INFO
Total Physical Memory 256 MB
Free Physical Memory 62.71 MB
Total Pagefile Memory 617.84 MB
Free Pagefile Memory 393.93 MB
MEMORY ARRAYS
Max Module Capacity 768 MB
Location <unknown>
Use <unknown>
Supported Error D&C <unknown>
Supported Speeds <unknown>
Supported Types <unknown>
Supported Voltages <unknown>
MEMORY SLOTS
Installed & Enabled Size 256 MB
Form Factor DIMM
Frequency 0 Hz
Slot A2
Manufacturer <unknown>
Type <unknown>
Enabled Size 256 MB
Total Bit Width 0
Data Bit Width 0
Installed & Enabled Size 0 bytes
Form Factor <unknown>
Frequency 0 Hz
Slot
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
Frequency 0 Hz
Slot
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
MOTHERBOARD INFO
Manufacturer
Model KT400A-8235
Version N/A
BIOS Vendor Phoenix Technologies, LTD
BIOS Version KT400A - 42302e31
BIOS Release Date 12/05/03
BIOS Properties Plug and Play, Flash, AGP
CARD SLOTS
Number 1
Designation PCI-1
Type PCI
Characteristics <unknown>
Data Bus Width 32
Details Available, Long
Device Class <unknown>
Device Name
Device Manufacturer
Device Driver Date
Device Vendor ID 0x0000
Device ID 0x0000
Device Sub-System ID 0x00000000
Device Revision 0x00
IRQ 0
Number 2
Designation PCI-2
Type PCI
Data Bus Width 32
Details In Use, Long
Device Class Sound, Video or Game Controller
Device Name Creative AudioPCI (ES1371,ES1373) (WDM)
Device Manufacturer Creative Technology Ltd.
Device Driver Date
Device Vendor ID 0x1274
Device ID 0x5880
Device Sub-System ID 0x20001274
Device Revision 0x02
IRQ 11
Number 3
Designation PCI-3
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 4
Designation PCI-4
Type PCI
Data Bus Width 32
Device Name WinFast TV2000 XP WDM Video Capture
Device Manufacturer Leadtek Research Inc.
Device Driver Date
Device Vendor ID 0x109e
Device ID 0x036e
Device Sub-System ID 0x6606107d
Device Revision 0x11
IRQ 10
Number 5
Designation PCI-5
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 0
Designation AGP
Type AGP
Data Bus Width 32
Device Class Display Adapter
Device Name NVIDIA GeForce4 MX 440
Device Manufacturer NVIDIA
Device Driver Date
Device Vendor ID 0x10de
Device ID 0x0171
Device Revision 0xa3
IRQ 11
SYSTEM DEVICES
Description VIA Standard PCI to ISA Bridge
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x3177
Subsystem ID 0x00000000
Revision 0x00
Description VIA Standard CPU to PCI Bridge
Manufacturer VIA
Vendor ID 0x1106
Device ID 0x3189
Revision 0x80
Description VIA CPU to AGP2.0/AGP3.0 Controller
Manufacturer VIA
Vendor ID 0x1106
Device ID 0xb198
Revision 0x00
Revision 3.5
Rate 1x, 2x, 4x (4x enabled)
Aperture Size 0 bytes
Sideband Addressing supported (disabled)
Fast Write supported (enabled)
MONITOR INFO
MONITORS
Name Default Monitor
Manufacturer (Standard monitor types)
Max Width 0
Max Height 0
Max Width 0
Max Height 0
Name Plug and Play Monitor
Max Width 0
Max Height 0
POWER SUPPLY INFO
BATTERIES
OPERATING SYSTEM INFO
Operating System Microsoft Windows XP
Version 5.1.2600
Service Pack Service Pack 2
Locale EE
Desktop Width 1024
Desktop Height 768
Desktop BPP 32
HARD DISK INFO
HARD DISKS
Name ST380011A
Manufacturer (Standard disk drives)
Capacity 74.53 GB
Model ST380011A
Interface Type IDE
| Kommentaarid: 52 loe/lisa |
8 :: |
18 |
wa666ou
27.12.2004 21:07:59
irw, kena kena
oleks piisanud vast lingist
95 |
arm2004
27.12.2004 21:08:38
no käi jala, annan ORB'i link mitte ära topi miskit piiblit siia mida keegi ei loe ikka ja kust polegi midagi asjalikku lugeda
_________________ nooope! |
97 |
sirtauri
27.12.2004 21:10:41
| lähtun asjaolust ,et kõik mis ma siin kirjutan või copy pasten peab olema põhjalik.
8 :: |
18 |
L7
27.12.2004 21:36:59
| sirtauri kirjutas: |
| lähtun asjaolust ,et kõik mis ma siin kirjutan või copy pasten peab olema põhjalik. |
Sa lähtu parem sellest, et prügi pole siia mõtet postitada, või noh - SPAMMida
| Kommentaarid: 14 loe/lisa |
12 |
Synergy
27.12.2004 23:01:18
| Viimati oli midagi 16500 kanti. Testiks siis 3dmark20001 SE
| Kommentaarid: 51 loe/lisa |
49 |
arm2004
27.12.2004 23:04:49
| Synergy kirjutas: |
| Viimati oli midagi 16500 kanti. Testiks siis 3dmark20001 SE |
kuda nii vähe, sul ju parem raal kui mul, aga mul üle 18k
97 |
incognito
27.12.2004 23:23:13
väga põhjalik on, kui kirjutad CPU MHZ ja tüübi, videokaardi tüübi ja klockid millel benchisid ning driveri ver. ....
ära unusta ka skoori kirjutamast
| Kommentaarid: 62 loe/lisa |
56 |
hmekk
28.12.2004 01:15:47
sai siis täna uuesti tehtud , kõik resursse nõudvad asjad ära , jne
grafa oma valikutest siis pandud ei mäletagi kas nüüd high performance või
high qualiti aga igatahes 189xx oli neid punne .... print skriini nupp pani näkku ja pilti ei saanud
_________________ Fotoblogi / Flickr |
8 :: |
68 |
arm2004
28.12.2004 01:19:15
| hmekk kirjutas: |
mismoodi see välja nägi?
97 |
hmekk
28.12.2004 01:42:34
klõpsasin seda , panin aknad kinni , aga vaata pilti ei teinud....
8 :: |
68 |
Synergy
28.12.2004 01:46:30
Ei tea jah. Video sai eraldi 2003'es 5500p miski 450/750 kelladel aga vähe kuidagi jah. Driveriks omega 4.9 Samas pole ammu formatit ka teind kuigi spyware jms pole on ikka aeglaseks jäänd. Video eelmine omanik oli saanud 5500 kätte default kelladel, aga minu masinas sai defaultina 4800p.
49 |
hmekk
28.12.2004 02:28:49
väike ot : keegi aitaks mul futuremarki konto teha ?
ma millegipärast ei saaa teha
8 :: |
68 |
sentinel
| Kommentaarid: 10 loe/lisa |
9 |
zoybone
28.12.2004 20:03:45
3dmark2001se: 305/600 15125
_________________ Räägi tõtt ja sul pole tarvis midagi meeles pidada. Mark Twain |
| Kommentaarid: 22 loe/lisa |
21 |
commer
28.12.2004 20:08:01
duron2.2Ghz+FX5700U 12767
edit: 12987 punni
_________________ Arvutite hooldus ja komplekteerimine Tartumaal
viimati muutis commer 29.12.2004 00:21:37, muudetud 1 kord |
| Kommentaarid: 925 loe/lisa |
712 |
incognito
56 |
commer
712 |
High-Q
28.12.2004 21:15:15
"graafikakiirendi", mis midagi ei kiirenda sama hea staatilist pilti või slaidshowd vaadata
97 |
killr0y
28.12.2004 22:38:06
| enda profiilis oleva arvutiga 5100 punni...
| Kommentaarid: 95 loe/lisa |
84 |
A2100
28.12.2004 22:48:04
Mille kuradiga te testite? Tahaks ka oma pilli skoori vaadata
| Kommentaarid: 8 loe/lisa |
margusser
167 |
