uus teema   vasta Raud »  Protsessorid »  AMD Athlon XP2600+ Barton FSB333 & Epox 8RDA3+ FSB400 märgi kõik teemad loetuks
mine lehele 1, 2  järgmine
Taimps
Taimps
sõnum 17.12.2004 23:30:02 AMD Athlon XP2600+ Barton FSB333 & Epox 8RDA3+ FSB400 vasta tsitaadiga
Selline pisike mure ,et kuidas saaks selle masina ilusti jooksma? Pole ise muidugi suur clockaja aga...
võiks ju proovida. Natukene juba proovisin ja sain mingi sellise tulemuse aga kuidas saaks veel paremax?
Code name Barton
Specification AMD Athlon(tm) XP
Family/Model/Stepping 6A0
Extended Family/Model 7/A
Package Socket A
Technology 0.13µ
Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
Clock Speed 1543.6 MHz
Clock multiplier x11.5
Front Side Bus Frequency 134.2 MHz
Bus Speed 268.5 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1543.6 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Northbridge nVidia nForce2 Ultra 400 rev. C1
Southbridge nVidia nForce2 MCP rev. A4
Graphic Interface AGP
AGP Revision 3.0
AGP Transfert Rate 8x
AGP SBA supported, enabled
AGP Aperture 128 MBytes
Memory Type DDR
Memory Size 256 MBytes
Memory Frequency 201.3 MHz (4:6)
CAS# 3.0
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 8
General
Memory type DDR-SDRAM
Manufacturer (ID) (0000000000000000)
Size 256 MBytes
Max bandwidth PC3200 (200 MHz)
Part number
Manufacturing date Week 00/Year 00
Attributes
Number of banks 1
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 133 166 200
CAS# 2.0 2.5 3.0
RAS# to CAS# delay 2 3 3
RAS# Precharge 2 3 3
TRAS# 6 7 8
Troll
Troll
sõnum 18.12.2004 00:23:53 vasta tsitaadiga
Hakka BIOSis tasapisi FSB-d tõstma.
TXX
sõnum 18.12.2004 09:44:42 vasta tsitaadiga
Mulle tundub kirjutatust, et masin on kokku pandud ja nagu alati boodib esimest korda 100fsb peal, mida sa kohe algul ei muutnud ära ja pärast nn overcklokkisid ise 133fsb peale . Õige kiirus XP2600+ on kordaja 11,5 ja 166fsb =~1909mhz. Seega mine biosesse pane kordaja 11,5 ja siin 166 - siis on su protsessor alles normaalkiirusel nagu protsessor peabki. Kui sealt edasi tahad clokkida siis hakka pikkamööda üle 166 fsb tõstma (see juba siis omal vastutusel). Peale selle soovitaks mälu panna prosega sünkrooni (6/6 3/3 vms).
Kommentaarid: 90 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 84
armin81
sõnum 18.12.2004 10:30:34 vasta tsitaadiga
2600+ barton peaks ju fsb 400mhz ilusti kannatama, ainult kordaja maha võtta. (minu 2600+ T-bred lagi oli 440x5,5=2420mhz)
Otsid mööblit? Uuri Siit või Siit.
Soovid kolida? Vaata Siia.
Kommentaarid: 96 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 86
Taimps
Taimps
sõnum 18.12.2004 11:40:38 vasta tsitaadiga
ohh thnks kohe hakkan katsetama! igatahes suured tänud juba ette ära icon_razz.gif icon_razz.gif thumbs_up.gif
Taimps
Taimps
sõnum 18.12.2004 11:44:10 vasta tsitaadiga
aa... ja veel selline asi, et kuidas selle agp-ga on kas see töötab normilt. ma neid mhz mõtlen?
The Power of Dreams
Taimps
Taimps
sõnum 18.12.2004 12:09:06 vasta tsitaadiga
icon_biggrin.gif Nii... tegin siis järgmist... icon_rolleyes.gif see vist selle masina kohta hea ?
Name AMD Athlon XP
Code Name Barton
Specification AMD Athlon(tm) XP 2600+
Family / Model / Stepping 6 A 0
Extended Family / Model 7 A
Package Socket A
Technology 0.13 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
CPU Clock Speed 1923.8 MHz
Clock multiplier x 11.5
Front Side Bus Frequency 167.3 MHz
Bus Speed 334.6 MHz
L2 Speed 1923.8 MHz (Full)
L2 Location On Chip
Memory
DRAM Type DDR-SDRAM
DRAM Size 256 MBytes
DRAM Frequency 200.7 MHz
FSB:DRAM 5:6
CAS# Latency 3.0 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
# of memory modules 1
Module 0 DDR-SDRAM PC3200 - 256 MBytes
aga temp. kui palju võib olla hetkel siin vähe mässasin ja on mingi 48C
OK igatahes suured tänud ex nüüd näis kui stab. see töötama hakkab thumbs_up.gif
The Power of Dreams
TXX
sõnum 18.12.2004 12:11:58 vasta tsitaadiga
Uuematel XP 2600+ on kordaja lukus ja kehvapoolse jahutusega ei ole mõtet 2300mhz peal jooksutada (11,5*200=2300) ning siis tuleb juba ka cpu volti tõsta. Pane agp lukku 66 peale nforce mobodel on siuke võimalus täitsa olemas. Pane mälu sünkrooni prosega pidavat kasulikum olema. Nüüd on su barton õigel kiirusel jälgi ka prose temperatuuri.
Taimps
Taimps
sõnum 18.12.2004 13:02:55 vasta tsitaadiga
selline kiire küsimus ,et kuidas seda mälu prosega sünkrooni panna? icon_redface.gif
ja et kas siis hakkab kohe korralikult toimima ka see dual ddr värk?
Suured tänud!
The Power of Dreams
armin81
sõnum 18.12.2004 15:16:55 vasta tsitaadiga
fsb - ram clock ratio vms peaks olema see mida sul vaja. vähemalt minu plate sellist asja ei omanud ja ram läks automaatselt fsb-ga kaasa.
tempi jälgin ise täiskoormusel (seti jookseb ja cpu usage 100% koguaeg) mul veel manuaalne rpm valik jahutusel - keerad tibake juurde vajadusel.
üle 65 eriti ei ole lasnud, aga isegi 70 ei ole väga hullu.
Troll
Troll
sõnum 18.12.2004 15:41:19 vasta tsitaadiga
Praegu on sul protsessor alles nominaalkiirusel tööl, sa pole veel sugugi teda klokkinud! Mälu töötab praegu 200MHz peal, ehk 5:6 ratioga. Kui sa protsessorit lisaks ei kloki, siis pole sul mõtet mälu kiirust alla tõmmata, et teda sünkroonis tööle panna.
Taimps
Taimps
sõnum 18.12.2004 17:29:45 vasta tsitaadiga
no vot siis icon_neutral.gif Aga kas tasub siis veel midagi muuta?
The Power of Dreams
Troll
Troll
sõnum 18.12.2004 18:06:45 vasta tsitaadiga
Taimps kirjutas:
RAM töötabki sul 200MHz ehk DDR mäluna 2x200=400MHz peal! icon_biggrin.gif Prosel võid FSB-d veelgi tõsta BIOSis.
Taimps
Taimps
sõnum 19.12.2004 11:59:53 vasta tsitaadiga
Niii.......!!
Mure järgmine kõik muidu ilus ja hea aga nüüd hakkab ise resti tegema mingi aja möödudes ütleme siis
,et iga paari kolme tunni tagant?? icon_cry.gif Mingi jama on sees. temp. muidu 46/41 C
The Power of Dreams
Troll
Troll
sõnum 19.12.2004 13:10:53 vasta tsitaadiga
Taimps kirjutas:
Niii.......!!
Tõsta BIOSist CPU pinget kuigivõrd.
armin81
sõnum 19.12.2004 18:41:27 vasta tsitaadiga
Jõulutroll kirjutas:
Taimps kirjutas:
Niii.......!!
Taimps, paned pinget juurde proovi mõnda testi. näiteks Sisoft Sandra mingi prose test, või Burn in test. kui ei ole stabiilne siis veel volte vaja.
P.S. voldid ajavad ka tempi natuke juurde.
Taimps
Taimps
sõnum 19.12.2004 19:26:52 vasta tsitaadiga
OK Thnks!!! panen pinget veits juurde ja proovin neid progesi ka icon_wink.gif
Aga tahtsin veel küsida ,et kas prose jahutuse pinget ka võib tõsta ja kas üldse saab. hetkel pole neid
muutnud on siis vistt järelikult Default
The Power of Dreams
armin81
sõnum 19.12.2004 19:38:52 vasta tsitaadiga
jahutusel poe pinget ... on aint pöörded. mida rohkem puhub seda rohkem jahutab ja rohkem häälitseb.
kui temp üle 60 ei kisu pole paanikaks vähimatki põhjust.
Taimps
Taimps
sõnum 22.12.2004 21:21:05 vasta tsitaadiga
nii.... vahepeal siin nii kiire olnud ,et pole aega olnud teid külastadagi beer_yum.gif
aga sai nüüd, prosel pinget ühe ühiku võrra tõstetud ja tegin ka jahutse tervele
süsteemile. Nüüd mobo 25-35C ja prose 30-45C mis arvate kas ok?
suunasin seda jahutust väheke rammile ja kõvakale ka, ja ohh imet
masin töötab, no minu arvates PERFECT thumbs_up.gif .
Ahh jaa selle unustasin öelda, et ühe 256 rammi panin ka veel juurde ja
mulle tundub, et toimib see dual ddr süsteem.
The Power of Dreams
Taimps
Taimps
sõnum 12.01.2005 21:24:01 vasta tsitaadiga
nüüd siis ikka kippus sees kripeldama, et thaks seda masinat ikka veel natukenegi paremini-kiiremini
Name AMD Athlon XP
Code Name Barton
Package Socket A
Technology 0.13 µ
Bus Speed 334.6 MHz
L2 Location On Chip
Mainboard and chipset
Motherboard manufacturer
Motherboard model nVidia-nForce,
BIOS vendor Phoenix Technologies, LTD
BIOS revision 6.00 PG
BIOS release date 10/17/2003
Chipset nVidia nForce2 Ultra 400 rev. C1
Sensor chip Winbond W83627HF
AGP Status enabled, rev. 3.0
AGP Data Transfert Rate 8x
AGP Max Rate 8x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 128 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 512 MBytes
FSB:DRAM 5:6
CAS# Latency 2.5 clocks
# of memory modules 2
Module 1 DDR-SDRAM PC3200 - 256 MBytes
The Power of Dreams
Taimps
Taimps
sõnum 12.01.2005 22:00:18 vasta tsitaadiga
kas on ehk veel mingeid andmeid vaja? et saaksite paremini
CPU Core 1.63V
+5V 5.08V
+12V 11.86V
-5V -5.05V
+5V Standby 4.82V
VBAT Battery 3.07V
VDD 1.58V
DIMM 2.72V
AGP 1.50V
Zandriel
sõnum 12.01.2005 23:54:42 vasta tsitaadiga
nu pane m@lu 1:1 ja vikska kiirust juurde t6stes oma 166 kusagile 200 juurde ning proovi stabiilsust. Kui ei ole stabiilne siis hakka vaikselt volte juurde lisama ja proovima. Arvatavasti peaks asi töötama ilma mingi jamata 11.5x 200 = 2300mhz
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 16
Taimps
Taimps
sõnum 13.01.2005 18:12:14 vasta tsitaadiga
aga kuidas ma panen selle mälu 1:1 ?
aaga kas see 11,5 kas seda pole mõtet muuta või ei saa seda muuta?
praegu näitas mälu vist
aga kuidas olema peaks või võiks olla?
The Power of Dreams
Rasmus
sõnum 13.01.2005 18:48:41 vasta tsitaadiga
Mälu sageduseks pane samuti 166MHz.
Protessoril võid fsb-d tõsta küll. aja iga kord mingi paar MHz juurde ja testi, kas arvuti peab vastu. Kui tuleb piir, on aeg volte tõstma hakata. Ja niimoodi samm-sammult lähedki aina ülespoole, kuni lagi käes. Vaata, et maha ei põleta icon_smile.gif
Rakvere parasiit
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 47
Taimps
Taimps
sõnum 15.01.2005 14:33:31 vasta tsitaadiga
uus teema   vasta Raud »  Protsessorid »  AMD Athlon XP2600+ Barton FSB333 & Epox 8RDA3+ FSB400 mine lehele 1, 2  järgmine
