uus teema   vasta Tarkvara »  Turvalisus »  probleem mircuga märgi kõik teemad loetuks
mesilased
sõnum 16.12.2004 21:07:45 probleem mircuga vasta tsitaadiga
Ma kasutan mircu suht palju ja ükspäev hakkas ta andma sellist errorit connectimisel serveriga. No siis ma hakkasin oma masinat kontrollima igasuguste spyware tõrjete ja viirusetõjetega.
Muidu on peal NOD32 viirusetõrje ja sygate personal firewall. Ja siin nimekiri programmidest millega ma oma masinat kontrollisin, aga need ei leidnud midagi:
Spysweeper
Spybot-search and destroy
Ad-aware SE
Antivir for XP.
Hijackthis logi on järgmine:
Logfile of HijackThis v1.98.2
Scan saved at 20:06:14, on 16.12.2004
Platform: Windows XP (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2600.0000)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\System32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Executive Software\DiskeeperLite\DKService.exe
C:\Program Files\NOD32\nod32krn.exe
C:\Program Files\Analog Devices\SoundMAX\SMAgent.exe
C:\WINDOWS\System32\wdfmgr.exe
C:\Program Files\Intel\Intel(R) Active Monitor\imonnt.exe
C:\Program Files\Intel\Intel(R) Active Monitor\imontray.exe
C:\Program Files\Analog Devices\SoundMAX\SMax4PNP.exe
C:\Program Files\Analog Devices\SoundMAX\Smax4.exe
C:\PROGRA~1\A4Tech\Keyboard\Ikeymain.exe
C:\Program Files\Java\j2re1.4.2_04\bin\jusched.exe
C:\PROGRAM FILES\ATI TECHNOLOGIES\ATI CONTROL PANEL\ATIPTAXX.EXE
C:\Program Files\NOD32\nod32kui.exe
C:\WINDOWS\System32\ctfmon.exe
C:\Program Files\AVPersonal\AVWUPSRV.EXE
F:\Program Files\eMule\emule.exe
C:\WINDOWS\System32\wuauclt.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Documents and Settings\Mihkel\Desktop\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.neti.ee/
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
F2 - REG:system.ini: UserInit=C:\WINDOWS\System32\userinit.exe
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O4 - HKLM\..\Run: [IMONTRAY] C:\Program Files\Intel\Intel(R) Active Monitor\imontray.exe
O4 - HKLM\..\Run: [SonicFocus] "C:\Program Files\Sonic Focus\SFIGUI\SFIGUI.EXE" BOOT
O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\SoundMAX\SMax4PNP.exe
O4 - HKLM\..\Run: [SoundMAX] "C:\Program Files\Analog Devices\SoundMAX\Smax4.exe" /tray
O4 - HKLM\..\Run: [iKeyWorks] C:\PROGRA~1\A4Tech\Keyboard\Ikeymain.exe
O4 - HKLM\..\Run: [ATIPTA] C:\PROGRAM FILES\ATI TECHNOLOGIES\ATI CONTROL PANEL\ATIPTAXX.EXE
O4 - HKLM\..\Run: [NeroCheck] C:\WINDOWS\System32\\NeroCheck.exe
O4 - HKLM\..\Run: [nod32kui] "C:\Program Files\NOD32\nod32kui.exe" /WAITSERVICE
O4 - HKLM\..\Run: [SmcService] C:\PROGRA~1\Sygate\SPF\smc.exe -startgui
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\ctfmon.exe
O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O15 - Trusted Zone: messenger.hotmail.com
O15 - Trusted Zone: loginnet.passport.com
O15 - Trusted Zone: login.passport.net
O15 - Trusted Zone: memberservicesnet.passport.net
Oleksin väga tänulik kui keegi aitaks sellele probleemile lahenduse leida.
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 8
Max Powers
sõnum 16.12.2004 21:23:59 vasta tsitaadiga
http://www.google.com/search?q=ping+pong+error+in+mirc&ie=UTF-8&hl=et
Neid muidu uurisid?
Pole kindel kas seal midagi ka on, aga ei hakkaks ise uurima, kui juba läbivaadatud
mesilased
sõnum 16.12.2004 23:56:19 vasta tsitaadiga
no ma vaatasin need läbi ja targemaks sain küll aga lahendust ikka ei leidnud
TzigaLind
sõnum 17.12.2004 01:32:02 vasta tsitaadiga
Kas ainult see irc server kiusab või teised ka?
Tee housecall.trendmicro.com läbi
Võimalik on ka, et irc server peksab segast
või on miski @ sind kiusupärast g-lined
ehk siis per user global bänn
Piix!
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 14
lamp
lamp
sõnum 17.12.2004 04:47:31 vasta tsitaadiga
see lõhnab küll kvaakneti global buni järgi.
mircu kahtlaseid skripte pole lõuditud?
kataloog on puhas?
jne
jne
uuri kvaakneti faq kuidas ipbanni maha saab sellistel juhtudel
eriti julm
Kommentaarid: 191 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 168
mesilased
sõnum 17.12.2004 20:03:40 vasta tsitaadiga
suured tänud aitajatele, sain tööle
