HDTanel
Overclocker
15.10.2004 23:00:02
Milline faililaiend või OS oled sina :P |
http://bbspot.com/News/2004/10/extension_quiz.php
Ise olen
.mpg
| You live like it was a movie.Constantly in motion, you bring pleasure to many, but are often hidden away. |
Kusjuures suht täpne
EDIT: OS test
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
viimati muutis HDTanel 16.10.2004 17:46:03, muudetud 1 kord |
496 |
dvd vader
15.10.2004 23:06:12
| mulle tundub, et see asi on siit läbi käinud. tõsi küll, kui kuupäeva uskuda, siis otseslt vist see ei ole, aga peaaegu täpselt sama sisuga küll. ja kas see "naljakate lehtede" alla ära ei mahtunud?
| Kommentaarid: 83 loe/lisa |
6 :: |
7 :: |
51 |
Aq
15.10.2004 23:08:42
| Ei, see eelmine oli küsimusega: mis operatsioonisüsteem oled sina?
| Kommentaarid: 4 loe/lisa |
billtuk007
15.10.2004 23:10:30
heh mis imelikke asju ikka välja ei mõelda
ise ma olen .swf faililaiend
_________________ PSN: el_kapitanz |
| Kommentaarid: 24 loe/lisa |
23 |
test2
| Kommentaarid: 16 loe/lisa |
16 |
ZAndlamb
15.10.2004 23:12:53
Mina olen .doc
You change from year to year, just to make things tough on your competition. Only your creator really has handle on you.
viimati muutis ZAndlamb 15.10.2004 23:14:38, muudetud 1 kord |
| Kommentaarid: 22 loe/lisa |
22 |
Elof
175 |
2III7
15.10.2004 23:13:17
You are .doc You change from year to year, just to make things tough on your competition. Only your creator really has a handle on you.
| Kommentaarid: 170 loe/lisa |
152 |
Aq
15.10.2004 23:15:49
Mina olen *.rm
You are .rm You try to keep it real, but you're just a servant of the stream. Nobody really likes you all that much.
Kusjuures - mulle endale KA EI MEELDI *.rm
ZAndlamb
15.10.2004 23:17:00
| Aq kirjutas: |
Kusjuures - mulle endale KA EI MEELDI *.rm  |
Kellele meeldiks
22 |
pots4t4j4
15.10.2004 23:17:11
.inf
You are informative. When you are gone you make life very difficult for others .
401 |
HDTanel
Overclocker
15.10.2004 23:29:35
| dvd vader kirjutas: |
| mulle tundub, et see asi on siit läbi käinud. tõsi küll, kui kuupäeva uskuda, siis otseslt vist see ei ole, aga peaaegu täpselt sama sisuga küll. ja kas see "naljakate lehtede" alla ära ei mahtunud? |
Kui sa alati nii arvad siis hakka parem siin naljakate teemas kõiki teemasi sinna ümber viskama kuna suht 80% on naljakad lehed.
Minu Instagram - HDTanel |
496 |
Hõljuk
117 |
dvd vader
15.10.2004 23:40:44
| PlatoonSgtElias kirjutas: |
Kui sa alati nii arvad siis hakka parem siin naljakate teemas kõiki teemasi sinna ümber viskama kuna suht 80% on naljakad lehed. |
kui on palju läbu ja mõttetuid teemasid, siis see tähendab, et neid võiks olla veel rohkem?
6 :: |
7 :: |
51 |
Tbit
15.10.2004 23:44:53
|OSTAN|-> T43 pikk jahutus |
230 |
veiks
15.10.2004 23:50:27
| ma siis .inf kah
| Kommentaarid: 9 loe/lisa |
WerteX
306 |
Hardi
15.10.2004 23:52:05
käibki täpselt minu iseloomuga kokku
_________________ ツ
viimati muutis Hardi 15.10.2004 23:53:08, muudetud 1 kord |
| Kommentaarid: 84 loe/lisa |
sowmiles
15.10.2004 23:52:09
Sometimes you are animated, but usually you just sit there and look pretty"
viimati muutis sowmiles 15.10.2004 23:55:13, muudetud 1 kord |
HDTanel
Overclocker
15.10.2004 23:55:00
kui on palju läbu ja mõttetuid teemasid, siis see tähendab, et neid võiks olla veel rohkem? |
Kas siis ei või postitada naljakaid teemasi siia alamfoorumisse?
Parem toppige too naljakate lehtede teema kinni kuna keegi eriti ei raatsi uuridagi sinna ja nii jääb paljudel naljakas juhtumine nägemata
496 |
Harley
15.10.2004 23:58:33
_________________ Liikluspolitsei sponsor |
94 |
raiksman
145 |
mtv23
16.10.2004 00:38:21
You are .exe
See tulemus siis... Ma ei saa aru kas sellel küsitlusel pointi ka on
_________________ @Dj |
15 |
redenergy
16.10.2004 00:47:01
ja vahet sel on kas teema on "kunagi" siit läbi jooksnud, suht
möttetu on vinguda alati selle teemade lukustamise jne. pärast
| Kommentaarid: 30 loe/lisa |
9 |
Taavi_R
166 |
prints
16.10.2004 01:18:17
mina olen zip paki kokku ja viska minema
| Kommentaarid: 35 loe/lisa |
26 |
olc
16.10.2004 01:18:33
You're .ppt
130 |
ZAndlamb
16.10.2004 01:47:56
| olc kirjutas: |
You're .ppt  |
22 |
TechZone
16.10.2004 05:56:42
:mnajh ;O[/quote]
| Kommentaarid: 14 loe/lisa |
14 |
AMD
16.10.2004 08:55:48
krt ma ei saanud osadest küsimustest/vastustest aru
_________________ From now on, the forum is owned by AMD.That means that you are NO LONGER allowed to talk about, or even mention *ntel. |
| Kommentaarid: 335 loe/lisa |
145 :: |
12 |
Zoig
16.10.2004 09:26:58
OT:tegin siis igavusest selle OS testi ka ära, tulemus suht täpne: You are Debian Linux, peole have difficulty getting to know you. Once you finally open your shell they're apt to love you
_________________ Et oleks raskem!
viimati muutis Zoig 16.10.2004 09:42:42, muudetud 2 korda |
| Kommentaarid: 48 loe/lisa |
44 |
gamer
16.10.2004 09:36:10
ehk siis exe olen
viimati muutis gamer 16.10.2004 09:54:14, muudetud 1 kord |
| Kommentaarid: 36 loe/lisa |
36 |
birgit123
| Kommentaarid: 94 loe/lisa |
80 |
PriitL
16.10.2004 09:59:25
Ma olen... *.cgi
| Kommentaarid: 26 loe/lisa |
24 |
gamer
16.10.2004 10:00:25
pane ikka aint pilt lingina, foorumis pole ju html lubatud
<a href="http://bbspot.com/News/2004/10/extension_quiz.php"><img
src="http://www.bbspot.com/Images/News_Features/2004/10/file_extensions/cgi.jpg" width="300" height="90"
border="0" alt="You are .cgi Your life seems a bit too scripted, and sometimes you are exploited. Still a workhorse though."><br>Which File Extension are You?</a> |
36 |
Amdfan
| Kommentaarid: 362 loe/lisa |
330 |
henrit
16.10.2004 10:22:07
I'm an .exe
| Kommentaarid: 55 loe/lisa |
50 |
lawrey
16.10.2004 10:34:22
head kirjeldused muidu asjadel
_________________ -bash: chpwn: command not found |
| Kommentaarid: 38 loe/lisa |
vilemriv
16.10.2004 10:38:03
.swf siin ka
M@x
127 |
xtro
16.10.2004 10:51:14
ma siis mp3 The kids love you. You get along with just abaout everybody except the music industry. You really make yourself heard
| Kommentaarid: 453 loe/lisa |
343 |
kaspar00
102 |
ZAndlamb
16.10.2004 11:41:30
| xtro kirjutas: |
ma siis mp3 The kids love you. You get along with just abaout everybody except the music industry. You really make yourself heard  |
22 |
SUPERNIGEL
16.10.2004 11:44:24
| Ma olin HTML
karabulka
16.10.2004 11:50:16
src="http://www.bbspot.com/Images/News_Features/2004/10/file_extensions/jpg.jpg" width="300" height="90"
border="0" alt="You are .jpg You are very colorful. Sometimes you forget things, or distort the truth. You like working with pictures more than words."><br>Which File Extension are You?</a>
raven
16.10.2004 12:09:05
*.cgi
| Kommentaarid: 25 loe/lisa |
23 |
RTMS
16.10.2004 12:09:07
You are .dll You are dynamic. You are constantly in danger of bringing down the house, because you don't play well with others.
| Kommentaarid: 8 loe/lisa |
pistong
16.10.2004 12:31:45
_________________ ayo one two one two
viimati muutis pistong 16.10.2004 13:52:38, muudetud 1 kord |
| Kommentaarid: 19 loe/lisa |
16 |
Aq
16.10.2004 12:54:02
| OT:tegin siis igavusest selle OS testi ka ära, tulemus suht täpne: You are Debian Linux, peole have difficulty getting to know you. Once you finally open your shell they're apt to love you |
Mina olin kah Debian :D kuid see kirjeldus ei vasta tõele. Pigem vastupidi - olen inimene, kes esmamulje jätab hea, aga kui mind tundma öpitakse, siis :(
ronk
16.10.2004 12:58:28
| .html mina
