uus teema   vasta Ärifoorumid »  Varia ja muu tehnika (sh helitehnika ja fototehnika) ost/müük/vahetus »  6» M: Kvaliteetsed töötoolid: Vitra ja ICF, lisaks disainvalgustid FLOS :: Asukoht: Tallinn märgi kõik teemad loetuks
Lepa
Lepa
sõnum 20.10.2026 13:54:11 6» M: Kvaliteetsed töötoolid: Vitra ja ICF, lisaks disainvalgustid FLOS :: Asukoht: Tallinn vasta tsitaadiga
Pakkuda mõned toredad sisustuselemendid kvaliteeti hindavale inimesele.
1) Tippklassi töötool / juhitool ICF UNA CHAIR 718
Tootja info: https://www.icf-office.it/en/product/una-chair
ICF writes it plainly in the product sheet: Una Chair is conceived as a long-term investment, a chair that keeps its value and its appeal for the whole of its working life. The claim rests on named choices — a structure in die-cast aluminium, a material the sheet calls renowned for durability, resistant upholstery fabrics and finishes that hold their look after intense use. An executive chair is rarely replaced on a whim; this one is engineered so you will not want to.
Hind uuena ~1500eur
AH 320eur, OK 370eur
2) Tippklassi töötool Vitra Physix
https://www.vitra.com/en-us/product/details/physix?srsltid=AU7gw4Xo5ID3ypcdUKPms4q_F6hUG_nVYSQQBck6DtHUXRPaVjQK8zP4
Designed by Alberto Meda for Vitra, the Physix chair is an understated and lightweight office chair with a swivel and height-adjustable base. Its design offers exceptional comfort: a high-performance textile panel is stretched between two adjustable side bars. Its understated appearance combined with its technical performance make Physix a perfect addition to any office environment.
Hind uuena 1000+eur
AH 280eur, OK 330eur
3) põrandavalgusti FLOS Spun Light F
https://www.lumories.ee/p/flos-spun-light-f-valge-porandavalgusti-3510142.html
Flos Spun Light F is an iconic floor lamp designed by Sebastian Wrong in 2003 for Flos. Crafted entirely from high-quality aluminum, with a die-cast aluminum frame, diffuser and supports, it stands out for its fluid, dynamic silhouette — the result of a manufacturing process that transforms simplicity into a refined aesthetic statement. A contemporary classic that combines timeless elegance with modern technology.
Tegemist väga kvaliteetse ja effektse valgustiga, kõrgus 176,6cm, läbimõõt 50cm
Hind uuena ~2000eur
AH 380eur, OK 430eur
4) valgustid FLOS Miss K, paar - müügis hõbedased (pildil näha olev kollane pole hetkeseisuga müügiks).
https://www.lumories.ee/p/flos-miss-k-philippe-starck-lauavalgusti-hobedane-3510015.html
The Flos Miss K Table Lamp was designed in 2003 by Philippe Starck and is a modern classic.
Resting on a clear base, Miss K’s external diffuser appears metallic, but when the light is switched on, the outer shade takes on a transparent appearance and the subtle glow of the inner diffuser shines through.
Maheda valgusega valgustid, dimmerdatavad, sobivad hästi näiteks magamistuppa või elutuppa.
Hind uuena ~350eur tk
AH 240eur, OK 290eur (hind paarile!)
5) Laevalgusti NUD Collection (Rootsi tootja), betoonist soklitega
https://nudcollection.com/info/the-nud-story/
Tore valgusti näiteks lastetuppa - pikkade värviliste kaablite abil saab valgustid paigutada täpselt sinna kuhu valgust parasjagu vaja, sobib hästi üldvalguseks.
AH 100eur, OK 140eur
6) Laevalgusti Albri Vintage
https://www.instagram.com/Albrivintage
Eestis käsitööna vanast tehasevalgustist valminud laelamp sobib väga hästi näiteks söögilaua valgustamiseks, lingilt näha sama kupli erinevate variatsioonide kasutuskohti - sobib hästi nii suurema, kui väiksemasse laua valgustamiseks. Antud kuppel on seest valge, kuldse aktsendiga.
Tavahind 250eur
AH 160eur, OK 210eur
Asukoht Haabersti
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 109
