raul.
22.08.2026 21:54:47
tati venitamine sai saatuslikuks.
mäng valmis on pange turgu.
üritati momentumit kasvatada ja marketingmaxxxingut teha.
arvestades seda fännide kottimist, kes igahinnaga oleks selle KOHE ära ost, võib öelda, et karma sai kätte.
| Kommentaarid: 96 loe/lisa |
22.08.2026 22:50:01
mõttetu jaanika paanika, ostavad ikka kõik.
Mõngu puhul trailer või 2min gameplayd pole mind kunagi kottinud
rastaman
22.08.2026 22:50:48
mängu üle käib siuke filosoofia
313 |
invension
23.08.2026 09:04:31
Me ei pea kumbagi tegema kuna see video ka juba väljas
| Kommentaarid: 10 loe/lisa |
9 |
Plin500
HV piljardihai
23.08.2026 09:44:43
Kogu maailma räägib mängust - geniaalne.
| Kommentaarid: 79 loe/lisa |
77 |
rocky-b
23.08.2026 10:00:20
See kontingent ilmselt ei julge päriselu stripparisse minna.
| Kommentaarid: 13 loe/lisa |
23.08.2026 11:25:52
I checked out the Cyberleek website, the hacker behind GTA 6, and it's clearly not the work of an amateur.
I'm convinced it's not just one person, but a full-fledged group of hackers.
Their contact system works in two steps:
- First, it generates a Session account (secure, anonymous, and decentralized messaging) with a unique recovery phrase. This allows anyone wanting to reach out to have a disposable, end-to-end encrypted communication channel.
- Then, it generates a Monero (XMR) donation amount, an anonymous cryptocurrency. Unlike Bitcoin, Ethereum, or Solana, its blockchain is private, and transaction amounts are completely obfuscated. So no one can see how much you've sent—except the person holding the private key (Cyberleek).
They ask for 400 XMR (165k$), but what's really fascinating are the figures AFTER the decimal point.
There are 12 decimal places generated alongside the Session account, serving as a unique identifier. When you send exactly that amount, Cyberleek detects the transaction on the blockchain, extracts the decimals, recalculates the corresponding Session ID, and reaches out to you.
According to the site, it's purely mathematical/cryptographic on the client side. The page generates a 12-digit ID mathematically linked to the Session account. Since Monero hides amounts, only Cyberleek can decrypt the received amount and retrieve your Session ID. No server-side storage of the ID is needed before payment.
They also specify that you absolutely must send the funds from a personal wallet (Cake Wallet, Feather...) and not from an exchange, or the decimals might get rounded, and they'll never be able to track you down.
I think it's a pretty elegant system, and you can see the same level of sophistication in their infrastructure.
Their site can hardly be taken down for good, because it's hosted in a decentralized way on Arweave (permanent and immutable blockchain storage), and its content is accessible via numerous gateways on the ar(dot)io network.
These gateways are access points that serve the same HTML file stored on Arweave. Taking down one gateway (or even several) changes almost nothing, since the site will still be accessible on all the others, and new mirrors can pop up in minutes.
All these elements convince me that Cyberleek is a group, not a lone individual, and given their methods, they're pros. Their knowledge of cryptography and decentralized tech suggests we're far from your average script kiddies or hackers who only break in via social engineering. There's real technical mastery here.
The somewhat childish/trolling vibe might suggest otherwise, but the technical side is beyond doubt.
Same goes for how they handle communications: everything runs through their website. They deliberately avoid any social networks that could leave logs and compromise their identity. |
https://x.com/AureaLibe/status/2091196949932261777
313 |
CnZ
23.08.2026 11:42:15
| Rockstar saatis nõuded Microsoftile ja Discordile paaril kanalil oleva kasutaja identical, onedrive jms jaoks. Väidetavalt mingid jäljed see entiteer oli jätnud
| Kommentaarid: 14 loe/lisa |
bugbrake
23.08.2026 12:33:55
Ma ise GTA sarja ei mängi ning üldiselt jätab külmaks see sari aga olgem ausad see furoor mis selle mängu kuuenda osa ümber toimub on juba omaette meelelahutusliku väärtusega
Mingi klipp avaldatakse mõned tunnid ennem Netflixis ja inimesed lähevad segaseks selle peale kes ennem näeb siis selle mängu lekkimine ja sellega seonduv hüsteeria, siis Take-Two reageering jne. See paneks i'le täpi peale kui mängu ilmudes selgub, et ei olegi midagi erilist
_________________ Alati teadke, et kuulujutte mõtlevad välja vihkajad, levitavad lollid, aga usuvad idioodid. |
| Kommentaarid: 6 loe/lisa |
23.08.2026 12:41:31
Keegi tellib endale netflixi gameplay pärast?
rocky-b
23.08.2026 13:45:31
| jeesus188 kirjutas: |
| Keegi tellib endale netflixi gameplay pärast? |
Usun, et mingi osa inimestest kindlasti. Endal mul tellimust pole ja ei kavatse seda teha ka, nagunii tuleb mõned tunnid hiljem Youtube’i ka ametlikult.
CnZ
23.08.2026 14:06:51
Seda arvatavasti Netflix ja T2 põevadki, et nüüd see mingi osa nende lekete valguses ei viitsi netflixi selle jaoks eraldi tellida, ja kui nkn tuleb paar tundi hiljem youtube ka
busta
23.08.2026 14:47:37
Peab ikka kole valu olema. Võidab see, kes saab esimena.
| Kommentaarid: 16 loe/lisa |
14 |
invension
9 |
raul.
23.08.2026 19:59:09
leekstar studio väidab, et pc "release" tuleb enne konsoole.
mis see rock* ideaalne maxxxingmarketing timeline hetkel oleks olnud ps5/xbox 2026 lõpp, ps6 2028? ja pc 2029?
päris vussi keerab selline asi ikka plaanid. sony ja pisipehmega on kindlasti ka tummised eellepingud, mida nii lihtsalt ümber ei kirjuta.
c4v6
24.08.2026 01:05:28
Kas lihtne minusugune inimene ilma mingi megahustleta näeb kusagilt ka mingeid asju? Ma seda lennukiga lendamise videot nägin aga mingi miljon on veel vist
_________________ Emotsionaalne suruja
https://hwbot.org/users/tannu013/ C'mos, Simmo... Pole hullu, ma klokin esimest korda |
| Kommentaarid: 72 loe/lisa |
68 |
invension
24.08.2026 08:26:48
| c4v6 kirjutas: |
| Kas lihtne minusugune inimene ilma mingi megahustleta näeb kusagilt ka mingeid asju? Ma seda lennukiga lendamise videot nägin aga mingi miljon on veel vist |
https://x.com/search?q=gta6%20leaked%20video&src=recent_search_click
Kui ei ole õiget liikuvat watermarki(2tk isegi) siis fake ai video. Kokku peaks nüüd 10 leaki olema.
9 |
IceUul
Sinu Ema
25.08.2026 08:00:12
Huvitav kas GTA6 tõesti sisaldab sellist 18+ contenti nüüd? järgmine leek...
Hetkel juba nii palju erinevaid videosid, et raske aru saada enam, mis AI ja mis reaalne
| Kommentaarid: 219 loe/lisa |
188 |
Slinky
25.08.2026 08:33:33
Eks GTA V oli ka M-rated, ehk 17+ ja suht alguses kohe Trevor lehvitas palja noksiga Ja need "küberporrulaugu" lekked on autentsed
c4v6
25.08.2026 08:48:12
Kae õudu, valimatult saab rahvast killida aga tisstuss on tabu?
68 |
Janis
25.08.2026 08:54:37
| Neutraalset vaadet soovitakse, aasta on siiski 2026
| Kommentaarid: 210 loe/lisa |
176 |
IceUul
Sinu Ema
25.08.2026 09:15:46
| c4v6 kirjutas: |
Kae õudu, valimatult saab rahvast killida aga tisstuss on tabu?  |
No selle stripi klubi video järgi oli asi veel päris viisakas...
188 |
ptbl
25.08.2026 10:59:40
| c4v6 kirjutas: |
Snowflake mentality
| Kommentaarid: 81 loe/lisa |
79 |
25.08.2026 11:53:44
| IceUul kirjutas: |
Hetkel juba nii palju erinevaid videosid, et raske aru saada enam, mis AI ja mis reaalne  |
Eelmised gta-d samuti pegi 18.
313 |
invension
25.08.2026 18:20:42
Tänased 3 videot rannas, ööklubis ja arvutipoes näitab kenasti miks nii kaua seda voolitud on.
Tahaks PC peal 4Ks juba seda kõike näha.
9 |
313 |
invension
26.08.2026 18:49:39
CyberLeek droppis just 4 minutilise Lucia proloogi sellise sõnumiga.
9 |
Kevvare
26.08.2026 19:59:15
Loodan, et keegi ei suppordi teda enam. Jätab väga meeleheitel mulje juba ja puhaku jalga veits.
Tea kas homme kajastavad kuidas ps5 vs ps5 pro'l jookseks ka?
29 |
invension
27.08.2026 09:51:31
Ei poolda ka selle tondi tegevust ja selgelt tal täiesti savi ka:
Eesti aja järgi 22:00 täna extended trailer. Selle pikkust ka on öeldud kuskil?
9 |
S.I.L.L.U
27.08.2026 22:41:40
| Netflix treila vaadatud - ei midagi erilist. RDR ja Max Paynei pealt võetud elemente.
90 |
Kevvare
27.08.2026 22:47:33
Mulle jättis hea mulje, ega mis muud ikka oodata. Tegevust tundub ka jaguvat.
Ühest asjast ma ei saa aru, recorditud oli praegu tavalise ps5 peal, sellel fps droppe jagus.
Kuidas peaks see asi üldse jooksma xbox S peal nagu nad reklaamivad, et sellele ka välja läheb?
29 |
addres999
27.08.2026 22:50:28
Njah, isiklikult jäi ka kaalukauss natuke pettumuse poole, hinge oli nagu vähe. Samas kogu see ülevaade oli kokkupandud üsna suvaliselt. Mõni kiirem lühitrailer suudaks kindlasti hoopis teise mulje luua. Combati pool oli küll natuke liiga tuttav. Kohati oli näitlemine/voice ka kuidagi puine, aga mônes teises kaadris jällegi väga veenev.
Graafiliselt tundus pigem süngema poolsem ja sügavam, mis pole paha asi - ootuspärane.
Raske ikkagi nii vähese põhjal midagi otsusavalt arvata. Huvi pole siiski kadunud, ootan veel sisu ning olen ka kindlasti novembris ostmas. Eks ise mängides saab kindlasti head emotsiooni tagasi ka, avastamist väärt üllatusi ja detaile jagub pikemaks ajaks.
viimati muutis addres999 27.08.2026 22:53:34, muudetud 1 kord |
| Kommentaarid: 30 loe/lisa |
30 |
invension
27.08.2026 22:53:21
Ülikõva, täpselt sellisst GTA-d olengi oodanud
Ainuke miinus oli selle esitluse kvaliteet oma 30fpsi, madala reso ja karvase raytracinguga.
9 |
27.08.2026 22:55:41
Kevvare, dünaamiline resolutsioon, mis seal ikka.
26min video tundus täitsa OK
313 |
IceUul
Sinu Ema
28.08.2026 08:46:59
Vaatasin ka selle täies pikkuses ära netflixist, 4k resoga. Kuna ootused polnud väga kõrgeks aetud, siis ei pidanud ka pettuma. Samas nii vaimustatud küll ei olnud, et kohe poodi PS5 Pro-d ostma jooksen.
Gameplay osas suht sama, mis GTA 5, saab teha lisa tegevusi, uued mängu mehhaanikad, story pool tundus tugev ja visuaalis ei pidanud ka pettuma.
Täna vaatasin hommiku kohvi kõrvale sai youtube versiooni vaadatud ja pidin pettuma. Ma ei tea, kas video kvaliteet on kehvem või on asi selles, et vaatasin eile Netflixi versiooni OLED LG G5 telerist, kus
oli pildi paranduse värgid peale lülitatud vs arvuti ekraan, kus need asjad väljas. Pilt tundus kehvem ja 30fpsi oli selgelt näha.
Kokkuvõttes: ootame parandatud/täiendatud PC versiooni ära, mida saab 120fps+ mängida.
188 |
rocky-b
28.08.2026 09:07:24
| IceUul kirjutas: |
Ma arvan, et siin mängib juba vanus rolli, et mängud ei suuda sellist vaimustust enam tekitada Aga olen nõus, mulle väga meeldis kõik mida video näitas, soundtrackis ka ilmselt taaskord pettuma ei pea; Depeche Mode - People are people montaaž oli suht cool.
IceUul
Sinu Ema
28.08.2026 09:42:02
| YT ja FB kommente selle kohta vaadates tundub, et väga suur enamus on positiivselt meelestatud selles videos nähtu põhjal.
188 |
IceUul
Sinu Ema
28.08.2026 10:08:45
| IceUul kirjutas: |
Huvitav palju netflix maksis selle eest, et nad omale 6h varem selle kätte saavad? Ainuke variant on üheks kuuks netflix tellida, loota, et keegi illegaalselt seda jagab/striimib või siis ootad hommikuni.
Mul millegipärast netflix näitab, et meie regioonis pole saadaval, loodetavasti võetakse maha  |
| phobic kirjutas: |
| Mul lasi kenasti meeldetuletuse lisada. Mingit "This title currently isn’t available to watch in your country" teksti ka kusagil ei lehvitanud |
See sai ise korda, kummaline, miks selline veateade enne oli. Aga õnnestus lisada listi ja ära vaadata.
188 |
rastaman
28.08.2026 10:20:35
| peamine pluss on ikka mängumaailma välimus, aga kuidagi liiga tume on, päevasel ajal varjud kottpimeduses. see vast konsoolide puudus, PC peal raytracingu valguspõrked parandaks selle
invension
9 |
rocky-b
28.08.2026 10:57:23
Kaalub sama palju kui 3,5 GTA San Andreast .
28.08.2026 11:40:11
Huvitav teooria, tasub soolaga võtta nagu ikka selliseid asju.
Sony’s Disc Erasure Was Motivated By The Reluctance To Print Millions Of GTA 6 Discs, Claims Insider
https://tech4gamers.com/sonys-disc-erasure-gta-6/
Moore’s Law is Dead claims that Sony shifted to a digital-only strategy as it didn’t want to print millions of GTA 6 discs.
The company only decided on this move recently, and the Rockstar title was an underlying reason.
Sony also didn’t want to upgrade its Austria plant for PS6 disc production. |
313 |
1dumbpcuser
97 |
Meshboy28
28.08.2026 13:02:43
| rocky-b kirjutas: |
| soundtrackis ka ilmselt taaskord pettuma ei pea; Depeche Mode - People are people montaaž oli suht cool. |
Ojaa, see tegi südame soojaks
| Kommentaarid: 44 loe/lisa |
40 |
