raul.
22.08.2026 21:54:47
tati venitamine sai saatuslikuks.
mäng valmis on pange turgu.
üritati momentumit kasvatada ja marketingmaxxxingut teha.
arvestades seda fännide kottimist, kes igahinnaga oleks selle KOHE ära ost, võib öelda, et karma sai kätte.
| Kommentaarid: 96 loe/lisa |
22.08.2026 22:50:01
mõttetu jaanika paanika, ostavad ikka kõik.
Mõngu puhul trailer või 2min gameplayd pole mind kunagi kottinud
rastaman
22.08.2026 22:50:48
mängu üle käib siuke filosoofia
313 |
invension
23.08.2026 09:04:31
Me ei pea kumbagi tegema kuna see video ka juba väljas
| Kommentaarid: 10 loe/lisa |
9 |
Plin500
HV piljardihai
23.08.2026 09:44:43
Kogu maailma räägib mängust - geniaalne.
| Kommentaarid: 79 loe/lisa |
77 |
rocky-b
23.08.2026 10:00:20
See kontingent ilmselt ei julge päriselu stripparisse minna.
| Kommentaarid: 13 loe/lisa |
23.08.2026 11:25:52
I checked out the Cyberleek website, the hacker behind GTA 6, and it's clearly not the work of an amateur.
I'm convinced it's not just one person, but a full-fledged group of hackers.
Their contact system works in two steps:
- First, it generates a Session account (secure, anonymous, and decentralized messaging) with a unique recovery phrase. This allows anyone wanting to reach out to have a disposable, end-to-end encrypted communication channel.
- Then, it generates a Monero (XMR) donation amount, an anonymous cryptocurrency. Unlike Bitcoin, Ethereum, or Solana, its blockchain is private, and transaction amounts are completely obfuscated. So no one can see how much you've sent—except the person holding the private key (Cyberleek).
They ask for 400 XMR (165k$), but what's really fascinating are the figures AFTER the decimal point.
There are 12 decimal places generated alongside the Session account, serving as a unique identifier. When you send exactly that amount, Cyberleek detects the transaction on the blockchain, extracts the decimals, recalculates the corresponding Session ID, and reaches out to you.
According to the site, it's purely mathematical/cryptographic on the client side. The page generates a 12-digit ID mathematically linked to the Session account. Since Monero hides amounts, only Cyberleek can decrypt the received amount and retrieve your Session ID. No server-side storage of the ID is needed before payment.
They also specify that you absolutely must send the funds from a personal wallet (Cake Wallet, Feather...) and not from an exchange, or the decimals might get rounded, and they'll never be able to track you down.
I think it's a pretty elegant system, and you can see the same level of sophistication in their infrastructure.
Their site can hardly be taken down for good, because it's hosted in a decentralized way on Arweave (permanent and immutable blockchain storage), and its content is accessible via numerous gateways on the ar(dot)io network.
These gateways are access points that serve the same HTML file stored on Arweave. Taking down one gateway (or even several) changes almost nothing, since the site will still be accessible on all the others, and new mirrors can pop up in minutes.
All these elements convince me that Cyberleek is a group, not a lone individual, and given their methods, they're pros. Their knowledge of cryptography and decentralized tech suggests we're far from your average script kiddies or hackers who only break in via social engineering. There's real technical mastery here.
The somewhat childish/trolling vibe might suggest otherwise, but the technical side is beyond doubt.
Same goes for how they handle communications: everything runs through their website. They deliberately avoid any social networks that could leave logs and compromise their identity. |
https://x.com/AureaLibe/status/2091196949932261777
313 |
CnZ
23.08.2026 11:42:15
| Rockstar saatis nõuded Microsoftile ja Discordile paaril kanalil oleva kasutaja identical, onedrive jms jaoks. Väidetavalt mingid jäljed see entiteer oli jätnud
| Kommentaarid: 14 loe/lisa |
bugbrake
23.08.2026 12:33:55
Ma ise GTA sarja ei mängi ning üldiselt jätab külmaks see sari aga olgem ausad see furoor mis selle mängu kuuenda osa ümber toimub on juba omaette meelelahutusliku väärtusega
Mingi klipp avaldatakse mõned tunnid ennem Netflixis ja inimesed lähevad segaseks selle peale kes ennem näeb siis selle mängu lekkimine ja sellega seonduv hüsteeria, siis Take-Two reageering jne. See paneks i'le täpi peale kui mängu ilmudes selgub, et ei olegi midagi erilist
_________________ Alati teadke, et kuulujutte mõtlevad välja vihkajad, levitavad lollid, aga usuvad idioodid. |
| Kommentaarid: 6 loe/lisa |
23.08.2026 12:41:31
Keegi tellib endale netflixi gameplay pärast?
rocky-b
23.08.2026 13:45:31
| jeesus188 kirjutas: |
| Keegi tellib endale netflixi gameplay pärast? |
Usun, et mingi osa inimestest kindlasti. Endal mul tellimust pole ja ei kavatse seda teha ka, nagunii tuleb mõned tunnid hiljem Youtube’i ka ametlikult.
CnZ
23.08.2026 14:06:51
Seda arvatavasti Netflix ja T2 põevadki, et nüüd see mingi osa nende lekete valguses ei viitsi netflixi selle jaoks eraldi tellida, ja kui nkn tuleb paar tundi hiljem youtube ka
busta
23.08.2026 14:47:37
Peab ikka kole valu olema. Võidab see, kes saab esimena.
| Kommentaarid: 16 loe/lisa |
14 |
invension
9 |
raul.
23.08.2026 19:59:09
leekstar studio väidab, et pc "release" tuleb enne konsoole.
mis see rock* ideaalne maxxxingmarketing timeline hetkel oleks olnud ps5/xbox 2026 lõpp, ps6 2028? ja pc 2029?
päris vussi keerab selline asi ikka plaanid. sony ja pisipehmega on kindlasti ka tummised eellepingud, mida nii lihtsalt ümber ei kirjuta.
c4v6
24.08.2026 01:05:28
Kas lihtne minusugune inimene ilma mingi megahustleta näeb kusagilt ka mingeid asju? Ma seda lennukiga lendamise videot nägin aga mingi miljon on veel vist
_________________ Emotsionaalne suruja
https://hwbot.org/users/tannu013/ C'mos, Simmo... Pole hullu, ma klokin esimest korda |
| Kommentaarid: 72 loe/lisa |
68 |
invension
24.08.2026 08:26:48
| c4v6 kirjutas: |
| Kas lihtne minusugune inimene ilma mingi megahustleta näeb kusagilt ka mingeid asju? Ma seda lennukiga lendamise videot nägin aga mingi miljon on veel vist |
https://x.com/search?q=gta6%20leaked%20video&src=recent_search_click
Kui ei ole õiget liikuvat watermarki(2tk isegi) siis fake ai video. Kokku peaks nüüd 10 leaki olema.
9 |
