praegune kellaaeg 30.07.2026 00:35:58
tonuonu
29.07.2026 22:23:48
» M: Samsung QVO 8TB 2.5" SATA :: Asukoht: Tallinn |
Kolm ühesugust Samsung QVO 8TB SSD-d müüa. Ühtegi defekti neil olema ei tea ning on kasutatud enda pildiarhiivi koopia hoidmisel. Asuvad Tallinnas keskturu juures ja liigun autoga ringi.
AH: 1000. Käibemaksuga paberi saab, kui KM hinnale otsa lisada. Kui ära ei lähe, võib ju muid summasid ja asju pakkuda.
% cat sda.txt sdb.txt sdh.txt | grep -i hours
9 Power_On_Hours -O--CK 096 096 000 - 15292
0x01 0x010 4 15292 --- Power-on Hours
9 Power_On_Hours -O--CK 096 096 000 - 15322
0x01 0x010 4 15322 --- Power-on Hours
% cat sda.txt sdb.txt sdh.txt | grep -i "START OF INFO" -A 24
=== START OF INFORMATION SECTION ===
Model Family: Samsung based SSDs
Device Model: Samsung SSD 870 QVO 8TB
Serial Number: S5SSNF0W522153E
LU WWN Device Id: 5 002538 f4354a9aa
Firmware Version: SVQ02B6Q
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available, deterministic, zeroed
Device is: In smartctl database 7.3/5319
ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun May 17 18:21:50 2026 EEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
Serial Number: S5SSNF0W512612J
LU WWN Device Id: 5 002538 f4352e1f8
Local Time is: Sun May 17 18:21:53 2026 EEST
Serial Number: S5SSNF0W522137X
LU WWN Device Id: 5 002538 f4354a99a
Local Time is: Sun May 17 18:22:16 2026 EEST
% cat sda.txt sdb.txt sdh.txt | grep -i written
241 Total_LBAs_Written -O--CK 099 099 000 - 38735437844
0x01 0x018 6 38735437844 --- Logical Sectors Written
241 Total_LBAs_Written -O--CK 099 099 000 - 38935974892
0x01 0x018 6 38935974892 --- Logical Sectors Written
241 Total_LBAs_Written -O--CK 099 099 000 - 38959859772
0x01 0x018 6 38959859772 --- Logical Sectors Written
% cat sda.txt sdb.txt sdh.txt | grep -i WORST -A20
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
12 Power_Cycle_Count -O--CK 099 099 000 - 72
177 Wear_Leveling_Count PO--C- 099 099 000 - 7
179 Used_Rsvd_Blk_Cnt_Tot PO--C- 100 100 010 - 0
181 Program_Fail_Cnt_Total -O--CK 100 100 010 - 0
182 Erase_Fail_Count_Total -O--CK 100 100 010 - 0
183 Runtime_Bad_Block PO--C- 100 100 010 - 0
187 Uncorrectable_Error_Cnt -O--CK 100 100 000 - 0
190 Airflow_Temperature_Cel -O--CK 075 040 000 - 25
195 ECC_Error_Rate -O-RC- 200 200 000 - 0
199 CRC_Error_Count -OSRCK 100 100 000 - 0
235 POR_Recovery_Count -O--C- 099 099 000 - 21
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
12 Power_Cycle_Count -O--CK 099 099 000 - 76
190 Airflow_Temperature_Cel -O--CK 074 038 000 - 26
235 POR_Recovery_Count -O--C- 099 099 000 - 16
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
190 Airflow_Temperature_Cel -O--CK 067 040 000 - 33
235 POR_Recovery_Count -O--C- 099 099 000 - 11
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
| Kommentaarid: 13 loe/lisa |
Dreamlover
29.07.2026 22:27:10
Kuidas neil garantiiga lood on?
_________________ ARVUTID
3G1,5/3G2,5/5G1,5/5G2,5 KAABEL
HDD kettad |
| Kommentaarid: 1910 loe/lisa |
1331 |
tonuonu
29.07.2026 22:34:37
| Dreamlover kirjutas: |
| Kuidas neil garantiiga lood on? |
Vabandust, ma ei tea. Ma olen unustanud, kust ja millal nad ostetud on. Aga asjakohane küsimus. https://semiconductor.samsung.com/consumer-storage/support/warranty/ lehel oleva info järgi "3 years or 2,880 TB TBW". Esmapilgul ei leidnud kohta, kust seerianumbri järgi kontrollida saaks. Kahtlustan, et kolm aastat on juba täis.
Kui küsimus on selle kohta, mis garantii ma annan, siis ma pole kindel, mis see HV viisakas müüjapoolne garantii oleks? Üks kuu?
tonuonu
29.07.2026 22:49:22
Küsisin Claude käest:
How many terabytes is written and what percentage of SSD lifetime resource is used?
Written per drive (Total_LBAs_Written × 512 B):
Drive Serial Sectors written TB written TiB
sda S5SSNF0W522153E 38,735,437,844 19.83 TB 18.04 TiB
sdb S5SSNF0W512612J 38,935,974,892 19.94 TB 18.13 TiB
sdh S5SSNF0W522137X 38,959,859,772 19.95 TB 18.14 TiB
Total ≈ 59.7 TB across the three.
Lifetime used: the Samsung 870 QVO 8TB is rated 2,880 TBW. At ~19.9 TB each that is ≈0.69 % of rated endurance — roughly 1/145th.
The drives' own counters agree it is negligible:
Wear_Leveling_Count normalized 99 (raw 7 = average P/E cycles used) → ~1 % consumed
Percentage Used Endurance Indicator = 0 %
Reallocated sectors, program/erase failures, bad blocks, uncorrectable and CRC errors: all 0
At the current rate (~19.9 TB over 15,300 power-on hours ≈ 1.3 TB/month) the TBW rating would take well over a century to reach — these will age out or hit a controller/retention limit long before wear matters.
Turvamees
29.07.2026 23:34:40
HV miinimum on 1 nädal käimagarantiid
_________________ Nuudlid ja hapupiim.
Egas tola loll pole |
| Kommentaarid: 23 loe/lisa |
22 |
tonuonu
29.07.2026 23:46:12
No saab 1 kuu . See ei muuda üldpilti.
