Proovisin 30 fps-i peal mängu. Dodgemine on täpselt sama. Koletiste kiirus võib esialgu tunduda aeglasem, aga lõpptulemusena ütleksin, et siiski on sama kiired.
Räägitakse veel, et durability langeb laipu lüües 2x kiiremini @ 60fps. Võib-olla vastab tõele, aga see ei ole küllalt põhjus, miks peaks loobuma ilusast sujuvast 60-st fpsist.
DARK SOULS II IS BESTOWED ADDITIONAL CHAPTERS WITH THE LOST CROWNS DLC TRILOGY
Three new DLC chapters known as The Lost Crowns trilogy will take you through entirely original areas to face a slew of unknown enemies, overcome diabolic challenges, and take-on fearsome bosses.
DLC of Crown of the Sunken King will be available in Europe and Australasia on July, 22, 2014 for PC and Xbox / July 23 for PlayStation 3
DLC of Crown of the Old Iron King is scheduled for August 26, 2014 for PC and Xbox / August 27 for PlayStation 3
DLC of Crown of the Ivory King will conclude the trilogy on September 23, 2014 for PC and Xbox / September 24 for PlayStation 3
A Season Pass program is also available for the entire The Lost Crowns trilogy via Steam for PC and PlayStation Network for PS3 from today.
Crown of the Sunken King, the first chapter in the trilogy, sends you on a journey to reclaim the crowns that Drangleic’s King Vendrick once owned.
Crown of the Sunken King features an entirely different world within the DARK SOULS II universe, where stepped pyramids span a vast underground cavern. It is said that one of the ancient crowns lay buried deep within these dark caverns; but surely such a valued item cannot sit unguarded.
Players that seek adversity and glory will be rewarded with a crown that holds the strength of lords from times long past.
Suht pettunud FROM-s sellise käigu pärast. Alguses öeldi, et DLC-d ei tule, lastakse välja complete mäng. Siis öeldi, et DLC võib-olla ikkagi tuleb. Ja nüüd season pass...
Kas asi nüüd uues emafirmas või jaapanlased tutvuvad lääne müügimudeliga ma ei tea, aga jätab halva maitse suhu võrreldes Artoriase DLC-ga DS1-le.
Vähemalt nüüd teada, mille taha bugide parandamine jääb.
eks ta vaikselt alla mäge veereb... pärast tuleb kindlasti vingumine, et asi ei müüa ja kõik teised selles süüdi _________________ |--{o,o}-----(\__/)-----------------|
Producer Takeshi Miyazoe said earlier this year that the game had potential for DLC, but it would depend on fan feedback.
On keegi DLCsid mänginud ka? Kuulduste järgi on nende content parem isegi kui põhimängus. Krt, ei meeldi eriti DLC'de ostmine aga tuleb vist ikka ära võtta
kas ps4 'jale mingi aeg "täis" versioon kah välja lastakse, või ei ole selle kohta veel midagi kuulda?
s.t täis graafikaga, mida algselt lubati, + need tulevad 3 lisa osa. _________________ |--{o,o}-----(\__/)-----------------|
madness, olen mõlemad dlc´d läbi mänginud ja meeldisid väga.
angel, kuskil intervjuus jäi silma, et nextgen reliisi ei tule. Tegelevad parem uue projektiga(Bloodborne), mida tol ajal veel välja polnud kuulutatud.
ei tahaks seda eriti uskuda, mis sai sellest "heast grafaga" buildist siis. Pigem usuks, et kui DLC hooaeg on läbi tuleb PS4/Xbox One'i peale täis graafika ja dlc'dega mäng välja _________________ |--{o,o}-----(\__/)-----------------|
Sai seda SOTFS mängitud ja see veelgi sittem kui vanilla. Relvad lagunevad kiiremini, sest rohkem vaenlasi ja isegi maagi pulk läks katki, sest see ka laguneb iga spelliga WTF. Maagia üldiselt tegid nõrgemaks. Mul mängu parim pulk maxitud ja parimad spellid. Ja kohati on däm ikka väga nõrk. Eriti hiljemad alad. Mäletan et vanillas pidin pea terve mängu läbi tegema, et parim relv maagile saada. Ja ikkagi polnud dämmiga selliseid probleeme. Aga selles SOFTis sain parima relva suht varakult ja maxituna on däm ikka väga lahja.
Levelid nüüd ka veelgi sittemad. Panid igalepoole vibumehi ja muid ranged mofusid. Vaenlased kelle liikumis animatsioon on liiga aeglane võrreldes kiirusega millega ringi liigub. Siuke hiigel TROLL mäng. Seda sitta ei tohi tõsiselt võtta. Üritasid vist nalja teha. Ja god modis seda paska läbides, ajab vahest naerma küll. Et milline ilge pask see ikka on. _________________ Gdesainer
