7 :: |
360 |
01.05.2026 08:35:07
Ee, kas mitte 99% see juba nii pole?
196 |
degrass
01.05.2026 08:35:22
Leidsin sellise nupu aastast 2024
EU kirjutas: EU common charger rules: Power all your devices with a single charger
https://commission.europa.eu/news-and-media/news/eu-common-charger-rules-power-all-your-devices-single-charger-2024-12-28_en
Are you tired of rummaging through your drawer to find the right charger for your phone? The EU has got you covered! Because the EU has standardised charging ports for mobile phones and other portable electronic devices, all new devices sold in the EU must now support USB-C charging. This will reduce the number of chargers you need to buy, help minimise electronic waste and simplify your everyday life.
Here are some benefits of the common charger:
- Increasing consumer convenience: You can charge your mobile phone and other similar electronic devices with one USB-C charger, regardless of the device brand.
- Reducing e-waste: Discarded and unused chargers account for about 11 000 tonnes of e-waste annually. The new rules encourage reusing chargers, which helps to reduce the environmental footprint.
- Saving money: You can now buy new electronic devices without a charger. This will help consumers save approximately €250 million a year on unnecessary charger purchases.
- Harmonising fast charging technology: New rules help to ensure that charging speed is the same when using any compatible charger for a device.
The EU's Common Charger Directive was approved by the Council of the EU in October 2022. Manufacturers were given a transition period to adjust their designs and ensure compliance. From 28 December 2024, the rules apply to mobile phones, tablets, digital cameras, headphones, headsets, videogame consoles, portable speakers, e-readers, keyboards, mice, portable navigation systems and earbuds sold in the EU. From 28 April 2026, they will also apply to laptops. |
Turunduse seisukohast võiksid nad sellised muudatused EU-Standardiks vms ümber nimetada.
_________________ All it took was for a lot of seemingly decent people to put the wrong person in power, and then pay for their innocent choice. |
01.05.2026 08:54:30
degrass, Ehk siis nõutakse 100W laadjaid, hoopis?
196 |
Zuumbox
01.05.2026 19:15:37
| Kuskohast Sa sellist asja välja loed? Jutt on ju konkreetselt KUNI 100W laadijatest. Üle 100W laadijatele see reegel ei kehti.
01.05.2026 23:08:19
Ma ei loe midagi välja siit teemast, mingit vastavat infot kah leida ei suutnud .
196 |
7 :: |
360 |
02.05.2026 11:06:57
Juba üsna igivana dell on usb-c laadimisega. Väga arukas lahendus
Ei ostaks täna toodet mis usb-c ei toeta.
201 |
02.05.2026 11:26:19
| Magic kirjutas: |
Ei ostaks täna toodet mis usb-c ei toeta. |
Tehakse veel üldse selliseid?
Kusjuures, ma puutusin mingi hetk kokku ühe ürgse HP’ga, mis oskas USB-C otsast kõike, välja arvatud laadimine.
Selleks vajas mingit, oma spetsiaalotsaga, klotsi.
196 |
CALEB
02.05.2026 12:39:55
Laadimine USB-C kaudu on ok, aga USB-C kui standard ise on pekki keeratud. Kui on kodus palju erinevaid laetavaid seadmeid ja igaühega neist tuleb USB-C kaabel kaasa, on ju tore? - Ei ole tore! Tulemuseks on suur hulk ühtemoodi välimusega USB-C kaableid, millest enamus on ainult laadimiseks ja mõned toetavad ka andmete edastust. Iga kord kui vaja andmeid laadida, hakka katsetama.
Kui rääkida standardist, peaksid kõik USB-C kaablid toetama nii laadimist kui ka andmesidet. Kaks peenikest juhet selles kaablis erilist hinnalisa küll ei tekita - on andmekaableid mis on odavamad kui sama "laadimisvõimsusega" ainult laadimiseks mõeldud kaablid.
Paraku siin ei aitaks enam seegi kui edaspidi ainult andmeside võimekusega USB-C kaableid tootma hakataks - turg on juba ära solgitud, kõik kodud on täis kaableid, mis on ainult laadimiseks. Aitaks ainul täiesti uus standard.
Janis
02.05.2026 12:49:37
| Miks sa igaühega katsetama hakkad? Kasuta seda kindlat mis töötab, see ju kogu selle asja point ongi et ühte kaablit saaksid kasutada.
175 |
02.05.2026 12:53:19
Ainult laadimiseks on ju puhas turvateema.
Enamik c-c teevad samas ka selle hädise 0.5 giga kui ka 10+ kaabel pole.
Aga see, et võid vale kaabli saada on muidugi tavaline
201 |
CALEB
02.05.2026 13:00:22
| Janis kirjutas: |
| Miks sa igaühega katsetama hakkad? Kasuta seda kindlat mis töötab, see ju kogu selle asja point ongi et ühte kaablit saaksid kasutada. |
Kui ikka terve perekond kasutab, siis ei tea kunagi milline kaabel kus on, võtad selle, mis kätte juhtub.
02.05.2026 13:05:52
No siis ostad LTT kaabli, vastab kõigele
201 |
02.05.2026 13:08:17
| Magic kirjutas: |
| Ainult laadimiseks on ju puhas turvateema. |
+1, Jumal hoia selle eest, et kõik kaablid, datat toetaks.
196 |
CALEB
02.05.2026 13:32:26
| Magic kirjutas: |
No siis ostad LTT kaabli, vastab kõigele  |
Küsimus pole selles, millist kaablit osta vaid selles, et kõik kohad on neid USB-C kaableid täis ja paljud ei toeta datat.
| Etz kirjutas: |
| Magic kirjutas: |
+1, Jumal hoia selle eest, et kõik kaablid, datat toetaks. |
Mis selle turvalisusega nii väga on? Igaüks võiks ise teada kuhu oma seadme järele ühendab ju.
02.05.2026 13:35:45
CALEB, ürita seda oma pereliikmetele selgeks teha.
Lihtsam on neile, reisimiseks, dataüheduseta kaablid kaasa pakkida.
196 |
