uus teema   vasta Ärifoorumid »  Arvutitehnika ja tarkvara müük/vahetus »   M: MikroTik Cloud Smart Switch 326-24G-2S+RM :: Asukoht: Mustamäe märgi kõik teemad loetuks
tomes
sõnum 26.04.2026 21:55:59  M: MikroTik Cloud Smart Switch 326-24G-2S+RM :: Asukoht: Mustamäe vasta tsitaadiga
Cloud Smart Switch 326-24G-2S+RM is SwOS powered 24 port Gigabit Ethernet switch with two SFP+ ports in 1U rackmount case that provides wire speed connectivity with several new switching features.
It gives you all the basic functionality for a managed switch, plus more: allows to manage port-to-port forwarding, apply MAC filter, configure VLANs, mirror traffic, apply bandwidth limitation and even adjust some MAC and IP header fields. SFP cage supports both 1.25 Gb SFP and 10 Gb SFP+ modules.
Tootja infoleht
Täiskomplektne: kommutaator, toiteadapter, racki kõrvad ja karp. Postiga saadan ettemaksu korral ja ostja kulul.
AH 60€
OK 75€
Kommentaarid: 65 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 59
