Ricki
Longero
| Kommentaarid: 59 loe/lisa |
55 |
vigurvänt
16.04.2024 13:15:03
| Ei leidnud sobivat ID-kaardi tarkvara teemat, aga see sobib vist ka siia. Igatahes viimane ID-tarkvara uuendus (ID-tarkvara versioon: 24.4, DigiDoc4 klient versioon: 4.5.0.4451, avalikustatud 15.04.2024) keeras Chrome neti korralikult kinni, isegi ruuterisse ei pääsenud, aga Edge toimis normaalselt. Mõned minutid hiljem tuli õnneks ka Chrome nett tagasi, enne kui jõudsin hakata ID-tarkvara uninstallima. Võluväel ise paranev arvuti mulle sobib, vähem jamamist. Keegi sama jamaga kokku puutunud?
27.05.2024 08:55:50
https://groups.google.com/a/ccadb.org/g/public/c/wRs-zec8w7k/m/G_9QprJ2AQAJ
The Chrome Root Program Policy states that CA certificates included in the Chrome Root Store must provide value to Chrome end users that exceeds the risk of their continued inclusion. It also describes many of the factors we consider significant when CA Owners disclose and respond to incidents. When things don’t go right, we expect CA Owners to commit to meaningful and demonstrable change resulting in evidenced continuous improvement.
On numerous instances over the last three years, e-commerce monitoring GmbH fell short of the above expectations (e.g., [1],[2],[3],[4],[5],[6],[7],[8]). In light of this, we have reached the conclusion that the GLOBALTRUST 2020 certificates suffer from a loss of integrity and action is required from the perspective of ensuring web security for Chrome users. To safeguard Chrome’s users, we are taking the following action.
Upcoming change in Chrome 124 and higher:
TLS server authentication certificates validating to GLOBALTRUST 2020 whose earliest Signed Certificate Timestamp (SCT) is dated after June 30, 2024, will no longer be trusted by default.
TLS server authentication certificates validating to GLOBALTRUST 2020 whose earliest SCT is on or before June 30, 2024, will be unaffected by this change.
This approach attempts to minimize disruption to existing e-commerce monitoring GmbH subscribers, using a new Chrome feature to remove default trust based on the SCTs in certificates.
Thank you
-Chris, on behalf of the Chrome Root Program |
571 |
571 |
16.10.2024 15:44:20
Google has started automatically disabling uBlock Origin in Chrome
https://www.xda-developers.com/google-automatically-disabling-ublock-origin-in-chrome/
Manifest V3 is Google's new extension platform update with stricter APIs for security.
uBlock Origin is being disabled in Chrome due to Manifest V3 - a new Lite version is available.
Google claims 93% of Chrome extensions comply with Manifest V3, with alternative options suggested.
313 |
ufo56
16.10.2024 19:53:54
Salvesta .reg failina ja käivita. Kuni juuni 2025 saad Manifest V2 kasutada.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Google\Chrome]
"ExtensionManifestV2Availability"=dword:00000002 |
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
571 |
ykshuntka
06.12.2024 21:07:52
Tere
1. Mis nipiga saaks ära kaotada popup küsimise "Oled kindel et soovid avada 20 järjehoidjat Yes No"
Või lükata 50 peale seda hoiatust, 14 on nagu lasteaiakasvataja piirang
2. Musta taustaga lehekülgede korral kopeerimise riba värv on ka must, kuidas seda muuta silmaga nähtavaks?
| Kommentaarid: 54 loe/lisa |
48 |
Longero
24.12.2024 17:07:43
Ma pole järjehoidjaid enam suurt salvestanud va mõned... paljud vanemad veebilehed kaovad.
Kas sellist võimalust on keegi kuskil näinud v saaks kuidagi teha, et Chrome järjehoidjatesse lisatud veebileht salvestatakse/laetakse automaatselt alla "mhtml" failina näit järjehoidjate kausta v mõnda teise minusoovitud kausta... failide asetus oleks täpselt samasugusena nagu järjrhoidjate "kaustapuu"? Sama nimega nagu järjehoidja lisati oleks ka allalaetud fail.
Kuskilt jäi silma, et google on suur monopol ettevõte ja tahetakse seadusega kuidagi tükeldada, et niipalju mõjuvõimu poleks Kas ei või sellega seoses olla. Olid midagi maha sunnitud müüma... tehti vbla teine firma kuhugi vms "omad joped" värk.
_________________ Win ISO'd ja uuendused
Artiklid jagatud |
55 |
Kassmees
03.03.2025 15:13:52
| Ublock Origin enam Chromes ei tööta. Mida panna selle asemele?
46 |
Muhekas
| Kommentaarid: 20 loe/lisa |
17 |
spezwend
03.03.2025 17:39:32
| Kassmees kirjutas: |
| Ublock Origin enam Chromes ei tööta. Mida panna selle asemele? |
Ma panin Brave ja LibreWolf Chrome asemele.
| Kommentaarid: 67 loe/lisa |
63 |
Kassmees
03.03.2025 19:48:49
Ghostery kärab kah. Tõsi küll, Delfi kaebab reklaamibloki üle ja keelab lugemise ilma reklaamideta Pole hullu, Delfit kannatab Firefoxis tarbida, tolles brauseris Ublock Origin veel töötab.
Igapäevaseks netitarbimiseks on Chrome mu jaoks kõige mõnusam, seega võimalusel jään selle peale.
46 |
vigurvänt
03.03.2025 20:07:17
Paar nädalat tagasi lülitati mul samuti uBlock Origin ja TabsPlus välja, aga need sai uuesti sisse lülitada. Praegu katsetan uBlock Origin Lite versiooni, mis on Chromele vastuvõetav. Filtering mode panin optimal peale ja tundub, et sobib. uBlock Origin on samuti alles, aga välja lülitatud ja praegu proovisin, et töötab veel.
TabsPlusi lasin igaks juhuks maha, sest väidetavalt ei vasta see enam mingitele andmekaitse nõuetele vmt. Selle asemel võtsin Tabs to Front v2, mis on vist isegi parem.
time123
06.03.2025 07:02:33
Loobusin ka Chrome-st ublock origin mittetoetatavuse tõttu. Brave!
183 |
29.06.2025 22:44:54
Mis segab uBlock Origin Lite kasutamast?
| Kommentaarid: 172 loe/lisa |
161 |
Muhekas
22.07.2025 12:10:45
| Ma isegi ei mäleta mis reklaamioo blokeerijaid ma kasutasin, aga youtubega oli see jama, et kui reklaamiblokeerija oli peal siis oli video tükk aega must enne kui käima läks. Selline tunne, et reklaami asemel edastati siis musta pilti reklaamipikkuse jagu.
17 |
22.07.2025 12:13:10
| Muhekas kirjutas: |
| Ma isegi ei mäleta mis reklaamioo blokeerijaid ma kasutasin, aga youtubega oli see jama, et kui reklaamiblokeerija oli peal siis oli video tükk aega must enne kui käima läks. Selline tunne, et reklaami asemel edastati siis musta pilti reklaamipikkuse jagu. |
Seda YT teeb tänapäeval jah, et kui ei saa reklaami näidata, siis sama aja vahid musta pilti ning all on teade "Experiencing interruptions? Find out why".
147 |
Longero
12.08.2025 10:01:30
Kas see siinolev teema kehtib ka android chrome kohta?
Kas android chromel saab kuidagi uuel vahelehel olevaid veebilehtede kiirvalikute/otseteede hulka suurendada? Mul ainult üks rida kus 7 kiirvalikut. Vanal androidi chromel oli 2 rida ja 8 kiirvalikut.
Kui saaks kahelt realt ja 16 kiirvalikut oleks piisav.
Vaatasin täpsemaid seadistusi chrome://flags/
Jäid silma ainult need pikast nimekirjast, proovisin korra kuid tulutult (tegin chromele restardi peale seadete muutmist).
”Customize the new tab page: If enabled, allows users to customize the new tab page – Android” chrome://flags/#new-tab-page-customization
”New tab page customization toolbar button: Add the new tab page customization button on the toolbar (mobile only). – Android” chrome://flags/#new-tab-page-customization-toolbar-button
Edit: Leidsin üles.
Saab uue kiirvaliku lisada
”Customize Most Visiteid Tiles: Adds long-click menu to fix the title and URL of a Most Visited Tile; enables MVT reordering. – Android” chrome://flags/#most-visited-tiles-customization
Edit 12.08.2025.
Kas keegi oskab aidata. Mis värk selle Chrome veebilehe MHTML faili allalaadimisega on. Veebileht laetakse alla ilma MHTML faililaiendita .
Android tahvel Galaxy S9+ (Android 14, One Ui 6.1): Chrome 138.0.7204.168 leht laetakse alla ilma faililaiendita.
Android tahvel Galaxy S9+ (Android 14, One Ui 6.1): Brave 1.77.97, Chromium 135.0.7049.84 leht laetakse alla ilma faililaiendita.
Telefon Galaxy Note 10+ (Android 9, One UI 1.5 pole firmware uuendanud ei tea mis ajast): Chrome 138.0.7204.174 leht laetakse alla koos faililaiendiga.
Android tahvel Galaxy Tab S4 (Android 8.1.0 pole firmware uuendanud ei tea mis ajast): Chrome 109.0.5414.118 leht laetakse alla koos faililaiendiga.
Tundub, et seesama probla on ka arvutisse installitud Chromel. Mul omal Win 7 koos vana Chromega seal laeb ilusti alla koos faililaiendiga, aga see hiiglama vana värk ka.
Midagi head gooogle’st ei leidnud. See häda tundus inimestel hakkama ca 2022a pihta.
Mõned lingid:
Saving website behaviour has changed in Android browser https://community.brave.com/t/saving-website-behaviour-has-changed-in-android-browser/203000
Android Chrome not saving pages as mhtml https://support.google.com/chrome/thread/166079709/android-chrome-not-saving-pages-as-mhtml?hl=en
why chrome 75.0.3770.80 not have mhtml chrome://flags ??? https://support.google.com/chrome/thread/7696455/why-chrome-75-0-3770-80-not-have-mhtml-chrome-flags?hl=en
Saving in mhtml format https://community.brave.com/t/saving-in-mhtml-format/98914
Android Chrome saving web page without MHTML extension https://android.stackexchange.com/questions/247025/android-chrome-saving-web-page-without-mhtml-extension
Asi selles, et peab käsitsi laiendi järgi panema igakord. Mul neid MHTML faile terve ports, hea mugav salvestada ühe arhiivilehena. Pealegi androidis ei saa brauseri laiendusi kasutada ja ega need muud laiendused pole suurem asi asenduseks.
Artiklid jagatud |
55 |
Muhekas
20.04.2026 15:57:32
| Mingisugust head adblocki sooviks, kui vaatan Youtube siis need reklaamid viskavad üle, mingisugust kunagi kasutasin, aga siis oli tükk aega must pilt enne kui video käima läks, ju siis reklaami asemel kuvati musta pilti reklaamipikkuse jagu.
17 |
20.04.2026 17:00:06
| Muhekas kirjutas: |
| Mingisugust head adblocki sooviks, kui vaatan Youtube siis need reklaamid viskavad üle, mingisugust kunagi kasutasin, aga siis oli tükk aega must pilt enne kui video käima läks, ju siis reklaami asemel kuvati musta pilti reklaamipikkuse jagu. |
Youtube Premium on parim. Aga muidu uBlock Origin, Pi-Hole mingil määral.
147 |
trebla
22.04.2026 05:48:11
| Muhekas kirjutas: |
Reklaam Youtubes?
Pole üheski enda masinas elu sees ühtki YT reklaami näinud. Nädalas tunni-paar ikka asju vaatan. AB, ABP ja UBO seni platsi puhtana hoidnud. FF / Chrome.
Võõrastes arvutites ja telekates olen teada saanud küll, et YT reklaame näitab.
_________________ Having a smoking section in a restaurant is like having a peeing section in a swimming pool.
velo.clubbers.ee |
| Kommentaarid: 68 loe/lisa |
60 |
22.04.2026 06:44:06
| Ma ei viitsinud nende lisanditega jamada. Panin Brave'i.
571 |
raul141
26.04.2026 17:17:05
Betamax, endal ka sama asi, ainuke miinus on see, et kontot ei ole brauseril nagu chromel või FF- il. Hea mugav , tirib kõik järjehoidjad ja paroolid kaasa vanast seadmest. Huvitav on ka see, et chome teeb ikka kogu aeg uuendusi, brave samal baasil ju, ise seal küll sellist tantsimist pole täheldanud
_________________ dell somm ding mi poi |
| Kommentaarid: 22 loe/lisa |
22 |
26.04.2026 17:36:24
| Tulevad ka seal. Sõltub ka sellest, millised uuendused Chrome'ile tulevad. Kui lihtsalt mingid välimusega seoses või nipet-näpet Chrome'i spetsiifilist, siis need loomulikult Brave'ile ei tule. Kui tulevad turvauuendused Chromiumile ja muud kapotialused värgid, siis saavad kogemuse põhjal enam-vähem samaaegselt.
571 |
313 |
mina634
07.05.2026 02:55:04
Selles ongi linuxi võlu. distribuutorid pakendavad chromiumi ja sinna ei panda seda.
google chrome pakendab seda ise ja võib teha mida tahab..
09.05.2026 13:41:43
mina634, Chrome vs Chromium. Chromiumi võid ka Windowsis kasutada ja Chrome'i Linuxis. Seejuures tulevad Chrome'iga kaasa kõik selle "rõõmud" sõltumata OS-ist.
Ma ei ole Chrome'i ammu käima pannud ja ei leidnud seda AI mudelit enda Windowsist, kuigi Chrome on paigaldatud.
"%LOCALAPPDATA%\Google\Chrome\User Data\OptGuideOnDeviceModel" kaust puudub.
vigurvänt
09.05.2026 17:29:48
| User Data kaust on 1 GB, mingit 4 GB sodi pole sinna topitud. Järelikult mu arvuti ei ole "eligible device".
09.05.2026 20:06:03
| Minu oma oli.
571 |
Longero
11.05.2026 18:05:24
Google Chrome Is Silently Downloading a 4GB Gemini Nano AI Model to User Devices Without Consent https://www.ghacks.net/2026/05/06/google-chrome-is-silently-downloading-a-4gb-gemini-nano-ai-model-to-user-devices-without-consent/
How to Check for and Remove Chrome’s AI Model
Deleting the OptGuideOnDeviceModel folder doesn’t stop Chrome from redownloading it. The most reliable way to remove it is to uninstall Chrome completely.
If you want to disable the download without removing Chrome, you can try the following:
1. Type chrome://flags into the address bar.
2. Search for "Enables optimization guide on device on Android."
3. Set the dropdown to Disabled.
This flag also shows whether a device is eligible for the feature. Older hardware might not qualify, and the download seems to be limited to newer machines. |
Artiklid jagatud |
55 |
Karlsson
11.05.2026 23:24:43
| Kas Androididel ka sama jama?
| Kommentaarid: 90 loe/lisa |
81 |
ricom2ger
13.05.2026 07:44:44
Mis teeb ühe masina üldse sobivaks, et see "Seadmes olev AI" tekiks seadete alla. Mitmes masinas kontrollisin ja ainult ühes on see valik olemas süsteemi all.
_________________ Kamehameha in your face! |
111 |
| Kommentaarid: 92 loe/lisa |
