| Kuidas pooldaksid kanepi legaliseerimist Eestis? |
| Pooldaksin meditsiinilistel põhjustel kasutamist |
17% |
[ 53 ] |
| Pooldan täielikku legaliseerimist |
36% |
[ 107 ] |
| Ei poolda |
33% |
[ 99 ] |
| Olen erapooletu |
12% |
[ 36 ] |
| hääli kokku : 295 |
sukelduja
10.12.2025 18:25:19
| netcat kirjutas: |
| Nojah, ega ma tol hetkel veel ei teadnud, et mul kõhugripp oli. Kui sul lihtsalt lambist keset päeva seletamatult halb hakkab... Järeldused tulid alles hiljem. |
Mandariinide aeg oli saabunud.
| Kommentaarid: 25 loe/lisa |
25 |
netcat
10.12.2025 20:15:03
| sukelduja kirjutas: |
| netcat kirjutas: |
Mandariinide aeg oli saabunud. |
Ei olnud... tegu oli praktiliselt suvise ajaga
| Kommentaarid: 6 loe/lisa |
degrass
11.12.2025 16:03:26
FAZ kirjutab: Dangerous genetic defect in sperm donors with almost 200 children
https://www.faz.net/aktuell/gesellschaft/gesundheit/gefaehrlicher-gendefekt-bei-samenspender-mit-fast-200-kindern-accg-200346957.html
A rare mutation in the sperm of a Danish donor significantly increases the risk of cancer. Reporters reveal: The man is a biological father of at least 197 children in different countries.
With the sperm of a donor who has a rare gene mutation that promotes cancer, at least 197 children have been conceived in 14 countries across Europe. Some of them were born with the dangerous gene mutation, some have cancer, some have already died. This was the result of a research dating back to the Danish public broadcaster DR and on which more than 30 journalists from 14 public media outlets worked under the umbrella of the European Broadcasting Union’s (EBU) Network for Investigative Journalism (IJN). |
_________________ All it took was for a lot of seemingly decent people to put the wrong person in power, and then pay for their innocent choice. |
netcat
One
15.12.2025 13:14:43
| "Vanuri surnuks sõitnud teenekas perearst(mu perearst)" sai 2 aastat ja 4 kuud tingimisi ja vanur oli teenekast perearstist ~10a noorem.. head karistused ikka siin |
728 |
kyrvas
15.12.2025 15:20:03
Panen su pahameelele puid alla
tal poeg struktuurides..
netcat
16.12.2025 13:51:12
| No see seletab mõndagi. Aga mis sel meditsiiniga pistmist on? Või oli sel surnuks sõidetul mingi ravivea keiss perearsti vastu susisemas? Ma olen alati taoliste juhtumite puhul mõelnud, et huvitav, kuidas meie "struktuurid" ei kontrolli taoliste "ups juhtus" letaalsete allaajamiste puhul isikliku kättemaksu motiivi. Ammu on ju teada, et suht puhtalt pääseb kui inimese autoga surnuks sõidad. Kohaliku inimese puhul oli ilmselt suuresti ennustatav ka, millal ta seal bussipeatuses seisab ja ootab.
| Kommentaarid: 749 loe/lisa |
563 |
130 |
Plin500
HV piljardihai
28.12.2025 10:42:04
https://www.err.ee/1609895830/eestis-on-leetrite-vastu-vaktsineerimise-tase-langenud-83-protsendini
Perearsti sõnul hakkas vaktsineerituse tase aastaid tagasi vähenema toona levinud ja nüüdseks teaduslikult ümber lükatud väärinfo tõttu leetrivaktsiini ohtlikkusest.
"Pigem on rohkem minu arust viimasel ajal üleüldist umbusaldust vaktsiinide suhtes või ärevust kogu selle vaktsineerimise teemaga seoses," sõnas Rospu. |
Äratan nüüd jälle magava karu üles , aga mis küll siis aastaid ~5 tagasi levis, et selline umbusk hakkas pead tõstma.. ? Ehk peaks võtma sarnase suuna, tegema sundvaktsineerimist, jagama "tegevuseks lubavaid passe" ning sulgema ühiskonna "kõigi hüvanguks"?
Koroonaajastu otsused "kinkisid" meile nüüdse olukorra, kus päriselt vajalike vaktsiine paljud enam ei ole nõus tegema. Seda polnud raske ennustada, olen seda korduvalt ise ka siia kirjutanud. Üks-kriis- korraga kahjuks ei päde ning meie võimetus ette mõelda oma otsuste mõju on tekitanud olukorra, kus jälle hakatakse rääkima inimestest, kes millegipärast ei usalda vaktsiine.
| Kommentaarid: 79 loe/lisa |
77 |
Oisu.
28.12.2025 10:45:24
Kas artiklis kirjutab ka, et meile on tulnud "vaktsineerimata riikidest" rahvast juurde?
Kas kuskil on ka "map", kust näha leetrite levikut Eestis?
One
28.12.2025 16:17:10
Kuulge targad milles asi võib olla.. Labajalad tundetud/surisevad, eriti varbad.. Veresuhkur on natuke kõrge kuigi ei tarvita üldse magusat(varem tarvitasin ja siis polnud seda probleemi).
Pere(loe looma)arst ütles et jah, veresuhkur on liiga kõrge aga tema raviskeemi muutma ei hakka.. Kuskile tasulisele vastuvõtule?
Viitab nagu magneesiumi puudusele aga võtan nii multivitamiini kus seda on ja lisaks eraldi magneesiumit ja neid olen võtnud vähemalt viimased 5a. See jama tekkis mingi 3 nädalat tagasi.
728 |
28.12.2025 16:47:56
Vitamiinipuudus tuvastatakse vereprooviga, mitte ei sööda neid lihtsalt niisama peoga sisse igaks juhuks.
Mu perearst ütles otse et see puhas skämm...
Liigud ikka piisavalt või istud end niisama vaikselt surnuks nagu enamus eestlasi kipub nüüdsel ajal tegema?
158 |
One
28.12.2025 17:04:29
Libedaga väga ei liigu aga aastate lõikes enamvähem samapalju nagu tavaliselt.. Alati võiks rohkem liikuda ja eks üritan ka, äkki ongi selles asi.
Tean, et vitamiide värk tuvastatakse vereprooviga, lihtsalt arst pole mitte kunagi mulle vitamiinidest peale vereproove rääkinud.
728 |
130 |
sukelduja
12.01.2026 18:19:25
| Winterwind kirjutas: |
Viitab nagu magneesiumi puudusele aga võtan nii multivitamiini kus seda on ja lisaks eraldi magneesiumit ja neid olen võtnud vähemalt viimased 5a. See jama tekkis mingi 3 nädalat tagasi. |
Kahtlaselt neuropaatia moodi tundub. Lähed diabeediarsti/endokrinoloogi vastuvõtule. Perearst teeb saatekirja. Siis paned ennast näiteks "Diabeedikeskusesse" vastuvõtule kirja. Edasi sõltub sellest kui kõrge see "kõrge" on. Diabeedil on vastik komme täiesti iseseisvalt hullemaks minna. Raviskeemi perearst ei muudagi, see on endokrinoloogi rida. Aga kõik kellel diabeedi diagnoos üleval on, peaksid vähemalt paar korda aastas diabeediõe või arsti vastuvõtul käima.
25 |
netcat
14.01.2026 16:21:36
Magneesium oli vist lihaskrampidele, rohkem. Närvikahjustused võivad tulla B12 puudusest. Too viimane võib omakorda tulla mingitest omastamise häiretest, niiet suu kaudu multivitamiini lahmimine ei pruugi üldse toimida. Mu mamma saab näiteks teist aastakümmet regulaarseid süste juba, enne oli äärepealt jäsemete halvatus tulemas - diagnoositi haiglas pärast korralikku uuringut.
Samas võivad ka mingid vereringe häired olla jalgades. Igatahes vii oma jalad arstile, enne kui gangreen tuleb ja küljest ära kukuvad, mitte ära pugi purgivitamiine.
PS koduseks abiks soovitaks määrida mingi tsirkulatsiooni ergutava salviga ja süüa ingverit, kui vastunäidustatud pole, ajab vere paremini ringi käima, ikka abiks sel külmal ajal.
21.01.2026 15:22:43
https://tervis.postimees.ee/8400642/perearsti-valus-appikarje-olukord-on-karm-ja-mul-ei-ole-voimu-seda-lahendada
Ta toob välja karmi reaalsuse: «Isegi juhul, kui meil oleks kõiki spetsialiste piisavalt, siis saadame lapsed ikkagi tagasi samasse keskkonda, mis nad haigeks on teinud.»
Pind märgib, et arst ei saa ravimitega parandada koolikiusamist, vaesust ega üksildust. «Praegu medikaliseerime me sotsiaalsüsteemi puudujääke ja ootame, et arstid näsiksid läbi tagajärgedest. Enamik lapsi ei ole katkised inimesed ideaalses maailmas, vaid haavatavad inimesed puudulikus maailmas.»
Tema pöördumine on üleskutse mõista, et tervishoid üksi ei suuda kanda vastutust ühiskondliku ebastabiilsuse eest. «See siin on ühe perearsti kogemus – mitte süüdistus, vaid appikarje. Olukord on karm ja mul ei ole võimu seda lahendada.»
130 |
netcat
21.01.2026 15:35:21
| See oli juba väga palju aastaid tagasi, kui ma lugesin kuskilt ühe arsti arvamust, et 50% depressioonijuhtumitest saaks kõige paremini ravida raha välja kirjutades.
napoleon
Unknown virus
21.01.2026 15:43:53
Aga siis oleks pool Eestit "depressioonis"
Ja siis oleks lõpuks teine pool ka kui peavad esimese poole "depressiooni" ravi kinni maksma
| Kommentaarid: 78 loe/lisa |
60 |
netcat
21.01.2026 15:49:02
Eks ta ole.
Inimesed olid kiusatud, vaesed ja üksildased ka eelmisel sajandil. Aga siis millegipärast keegi ei arvanud, et selle vastu arsti käest abi leiab, seega neid ei tülitatud selle murega.
Kassmees
20.02.2026 04:12:57
| netcat kirjutas: |
| See oli juba väga palju aastaid tagasi, kui ma lugesin kuskilt ühe arsti arvamust, et 50% depressioonijuhtumitest saaks kõige paremini ravida raha välja kirjutades. |
Vastab tõele küll. Tänapäeval saaks rahaga mõnegi jama kaotada. Mõnele piisab, kui saab arved makstud, riided selga ja iga päev endale maitsvalt süüa. Mõni tahaks välises säras teistega võistelda ja tegelikult elu ainus kaif tulekski tal sellest, miski muu temal naudingut ei tekita - aga vot, ei ole ressursse.
Aga muuseas, kui hiljuti põetud viirus on häälepaelad tuksi keeranud, siis kui kaua võib aega võtta taastumine? Nädal tagasi tulin mingist viirusest välja. Võibolla covid, lõpuosas maitses võileib nagu papp. Hääl on kutu. Pingutusega mingi jorin tuleb, aga kui üle minuti kõneleda, siis seegi katkeb ja edasi vaid sosistan. Perearst ütles: tema ei oska aidata. Tuleb lihtsalt kurgule puhkust anda, rääkimist piirata ja loota, et taastub.
| Kommentaarid: 59 loe/lisa |
46 |
20.02.2026 11:09:59
Kui perearst ise aidata ei oska, siis peaks ta suunama sind erialaarsti juurde. Mitte et ootad-loodad-palvetad.
158 |
greaper
20.02.2026 14:48:19
Kas see mitte vandenõu teooria teemas ei peaks olema?
Miks pean uskuma härar Pellat, mitte teadlasi, uuringuid jms? Soomes viidi 2020 läbi uuring, kus võeti need "tuuliku tundlikud" inimesed ja paluti teada anda, millal on infraheli sees (mis hirmsasti kohe neile mõjub) ja millal väljas, mis arvad, mis tulemused olid, kas kohe said kannatajad aru, etheli sees? https://novaator.err.ee/1106196/soome-uuring-tuulegeneraatorite-helid-ei-ole-inimese-tervisele-kahjulikud
Samuti, mis veel tekitab infra heli?, Liiklus, kliimaseadmed, lennukid, tuul, äike, merelained
Pigev võiks nende "infrahaigete" vaimset tervist uurida ja ma kardan, et seal ei ole põhjus mitte tuulikus, vaid mõnes muus "poliitilises" mõjutuses. Kas pole mitte huvitav kokkulangemine, et pea kõik need, kes hirmus haigeks tuulikute juures jäävad on ekre valijad? Üks neist ju lausa väitis, et kui merel laev 50km kauguselt mööda sõidab, siis tal majas aknaklaasid värisevad, mis sa veel tuulikust räägid
_________________ Psychologists usually attribute belief in conspiracy theories to a number of psychopathological conditions such as paranoia, schizotypy, narcissism, and insecure attachment, or to a form of cognitive bias called "illusory pattern perception". |
24 |
Kassmees
20.02.2026 21:32:16
| Kui perearst ise aidata ei oska, siis peaks ta suunama sind erialaarsti juurde. Mitte et ootad-loodad-palvetad. |
Mis arsti juurde minna? Saan saatekirja küsida.
Miks pean uskuma härar Pellat, mitte teadlasi, uuringuid jms? Soomes viidi 2020 läbi uuring, kus võeti need "tuuliku tundlikud" inimesed ja paluti teada anda, millal on infraheli sees (mis hirmsasti kohe neile mõjub) ja millal väljas, mis arvad, mis tulemused olid, kas kohe said kannatajad aru, etheli sees? icon_lol.gif icon_lol.gif https://novaator.err.ee/1106196/soome-uuring-tuulegeneraatorite-helid-ei-ole-inimese-tervisele-kahjulikud
Samuti, mis veel tekitab infra heli?, Liiklus, kliimaseadmed, lennukid, tuul, äike, merelained icon_lol.gif icon_lol.gif icon_lol.gif
Pigev võiks nende "infrahaigete" vaimset tervist uurida ja ma kardan, et seal ei ole põhjus mitte tuulikus, vaid mõnes muus "poliitilises" mõjutuses. Kas pole mitte huvitav kokkulangemine, et pea kõik need, kes hirmus haigeks tuulikute juures jäävad on ekre valijad? Üks neist ju lausa väitis, et kui merel laev 50km kauguselt mööda sõidab, siis tal majas aknaklaasid värisevad, mis sa veel tuulikust räägid icon_lol.gif |
Eks iga suurem uuendus on põhjustanud vastumeelsust vastavalt inimeste lollusele. Esimese aurulaeva ehitajat peeti ju lausa vanakuradi käsilaseks, laeva hõõguvad katlad hirmutasid usklikke. Infraheli pelgajad on ilmselt sama klass.
Aga siiski. Mingid helid võivad tekkida ja väga huvitavalt levida. Aastaid tagasi elasin Tähtvere linnaosas. Kui seal lihtsalt käia, ei pruugi miskit kõrva hakata. Aga seal elades hakkas kõrva üle raudtee asuv Vitamiini alajaam. Selle urin levis mõnes suunas imelikult hästi. Oli kuulda mu toas Kreutzwaldi tänaval. Oli kuulda Laulupeo puiesteel. Ja huvitav, levis isegi Jakobi mäe alla viie tee ristile. Päevasaginas ei pannud ma seda tähele, öösiti kippus kohati häirima.
EPA ühika kõrval asuva õppehoone katusel on tuulegenekas. Mõnikord teeb see üsna valju vuhinat. Mis paneb täitsa mõtlema, kas tahaks elada kohe seal kõrval. Huvitav, kas tornühika rahvas seda vuhinat enda tubades kuuleb?
46 |
