uus teema   vasta Ärifoorumid »  Arvutitehnika ja tarkvara müük/vahetus »  M: MikroTik Cloud Router Switch CRS328-24P-4S+ (24xRJ45, 4xSFP+, PoE+) :: Asukoht: Tln märgi kõik teemad loetuks
jotjot
sõnum 28.10.2025 11:36:56 M: MikroTik Cloud Router Switch CRS328-24P-4S+ (24xRJ45, 4xSFP+, PoE+) :: Asukoht: Tln vasta tsitaadiga
Müüa
MikroTik Cloud Router Switch CRS328-24P-4S+RM
24 x 1Gbps RJ45
4 x 10Gbps SFP+
PoE ja PoE+ tugi.
AH: 175
OK: 225
https://mikrotik.com/product/crs328_24p_4s_rm
CRS328-24P-4S+RM is a 28 independent port switch.
It has 24 Gigabit Ethernet ports, which offer different power output options: Passive PoE, low voltage PoE, 802.3af/at (Type 1 “PoE” / Type 2 “PoE+”) with auto-sensing.
PoE-Out is passed over mode B pins (4,5+)(7,8-).
The four SFP+ ports provide up to 10 Gbps connectivity options via either optical fiber or Ethernet modules (not included).
CRS328-24P-4S+RM comes in a 1U rackmount case with 100-240 V AC 500 W power supply built-in.
The device consumes up to 44 W leaving guaranteed 450 W (3x150 W per every 8 Ethernet ports) to power your PoE devices.
Each port can provide up to 30 W of power with any power output option you choose.
The device has a “Dual boot” feature that allows you to choose between two operating systems - RouterOS or SwOS.
If you prefer to have a simplified operating system with only switch specific features, use SwOS.
If you would like the ability to use routing and other Layer 3 features in your CRS, use RouterOS.
You can select the desired operating system from RouterOS, from SwOS or from the RouterBOOT loader settings.
All the feature set comes with disruptive price, providing best price/performance on the market.
Specifications
Product code: CRS328-24P-4S+RM
Switch chip model: 98DX3236
10/100/1000 Ethernet ports: 24
SFP+ ports: 4
Serial console port: RJ45
Dimensions: 443 x 300 x 44 mm
Operating System: RouterOS / SwitchOS
Size of RAM: 512 MB
Storage size: 16 MB
Storage type FLASH
Max power consumption without attachments: 44 W
Max power consumption: 494 W
Cooling type: 2 fans
PoE-out
PoE-out ports: Ether1-Ether24
PoE out: 802.3af/at
Low voltage PoE-Out current limit: 1000 mA
High voltage PoE-Out current limit: 450 mA
Max total out (A): 20 A
Kommentaarid: 401 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 339
avax
avax
sõnum 28.10.2025 17:56:08 vasta tsitaadiga
Kõrvad on racki jaoks?
Kommentaarid: 269 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 212
jotjot
sõnum 01.11.2025 17:50:40 vasta tsitaadiga
avax kirjutas:
jah, on ikka olemas.
avax
avax
sõnum 02.11.2025 19:16:55 vasta tsitaadiga
Poe või edasimüüja garantii?
jotjot
sõnum 03.11.2025 13:39:30 vasta tsitaadiga
