Mis ime seda Ukrainat NATO-sse veaks - euroopas ilma USA-ta ei veaks end sedasi iial otse sõtta.
Ennem lakkab ilma USA-t NATO sisuliselt olemast, isegi ida-euroopa nt Poola kes on samuti slaavina ülimalt sõjakas Venemaa vastu olnud ja Ukrainat võidule õhutanud, on pärast USA tagasitõmbumist euroopast mitu kraadi jahedamaks võtnud, lausa otse välja öelnud, et Poola "rahuvalveväed" Ukrainasse ei lähe.
Mis veel siis saab kui euroopa päriselt Venemaaga mõõgad peaks ristama _________________ ---
The Russians would have been in Kyiv in 4 hours if they went down the highway. But a Russian general decided to go through the farmland.
I don't know who that general is but knowing Vladimir, he is probably not around any longer.
Trump on Zelenskyy:
“I was a little bothered by the fact that Zelenskyy was saying I have to get constitutional approval. He has approval to go to war and kill everybody but he needs approval to do a land swap because there will be some land swapping going on. I know that through Russia and through conversations with everybody. To the good, for the good of Ukraine.
Good stuff, not bad stuff. Also, some bad stuff. For both.
So there's good and there's bad. But it's very complex because you have lines that are very uneven. And there'll be some swapping.
There'll be some changes in land. And the word that they will use is, you know, they make changes. We're going to change the lines, the battle lines.
Trump: I get along with Zelenslyy but, you know, I disagree with what he has done. Very very severely disagree. This is a war that shouldn’t have happened.
Ega USA keela Euroopa riikidel sõjaliselt sekkuda ukrainas. Ukraina on hea populismi häälte püüdja. Narkarite koalitsiooni tegusid oodatakse siiani ukrainas.
Reports from many Ukrainian sources of a potentially catastrophic Russian breakthrough toward Dobropilla in Donetsk region, with advance Russian troops cutting off the Dobropilla-Kramatorsk road.
Russian breakthrough has been confirmed, ukrainian "New Donbass Line" bypassed in the most vulnerable point.
Russian assault platoons are rushing behind ukrainian lines. They can now turn west and threathen Dobropilla or continue North and Kramatorsk will be in danger.
Päris "huvitav" sõnakasutus USA diplomaadil, nagu tiblad oleks midagi ära teeninud.
https://x.com/McFaul/status/1954645148421493136 _________________ "a rental car, three cheeseburgers and a head start."
Kui varem toetas suurem osa Ukraina rahvast võitluse jätkamist kuni võiduni sõjas, siis nüüd on pöördutud variandi poole, et sõda võimalikult kiiresti läbirääkimistega lõpetada.
Hiljutine Gallupi küsitlus näitas, et üle kolme aasta kestnud vastupanuvõitluse jooksul on nende inimeste arv, kes usuvad, et Ukraina ei peaks peatuma enne, kui võit käes on, kahanenud 73 protsendilt 24 protsendini. Samal ajal on läbirääkimiste teel lahenduse pooldajate osakaal kolmekordistunud – 22 protsendilt 69 protsendini. Küsitluse läbiviijad lisavad, et trend on ühtlane kõigis piirkondades ja rahvastikurühmades.
Jube kehvasti tehtud küsitlus..... Osa infot nagu ära jäetud küsitlusest
Maade loovutamine, laste röövimine jne _________________ This message was sent from space using stargate
Arvestades, et vabariiklased selle kingituse tibladele tegid, siis liigub ju vähe ja varasemalt lubatud tarned ei liigu ju jätkuvalt mahus nagu peaks. Sealt nopitakse ju asju välja mida EL peaks nüüd ostma hakkama.
Lisaks hiinast ei saa Ukraina enam kõike droonidele mida varem sai...tibla seevastu saab tehaste sisseseade ehk faktiliselt ostab vähem, aga praktikas see tööstuse ahel aina suureneb.
viimati muutis Magic 12.08.2025 09:19:31, muudetud 1 kord
do your own research _________________ Every version of the garment appears to be sold out online, with prospective shoppers given the opportunity to join a waitlist.
Teemast ju räägitud juba kuid tagasi, nüüd selle USA relvastuse peatamise mõjudest veelkord. Ehk keegi kes arvab, et ei räägita on mingites luuludes.
Lühidalt edasi on lagedad alad kus võiks oluliselt rohkem saavutada rasketehnikaga.
Trumpi äraandmist nõutavate piirideni on veel kõvasti minna.
Annab ta jee. See on ju maavarasid täis, naftat, maagaasi, kulda, vaske, tsinki, sütt, kriitilisi mineraale ja haruldasi muldmetalle (grafiit, neodüüm, niobium, skandium jne).
ps. See nüüd naljaga öeldud aga kui Trump hakkab venkudega diile tegema ukrainlaste seljataga Ukraina alasid neile loovutama, siis võiks Ukraina ju ka diili teha ja pakkuda venelastele Alaskat
Sellest on korduvalt kirjutatud, et tiblastani majandus on kokkukukkumise äärel. Teab palju see nüüd tõele vastab, sõja alguses kirjutati ka, et kohe on neil moon otsas.
Aga sellest polegi lugenud, et kuidas Ukrainal läheb? Lääne abi neil muidugi abiks on, aga ega nende majandusele see sõda ka ju positiivselt ei mõju. See mõju on vast marginaalne, et mõnes muus riigis keegi Ukraina tooteid eelistab.
Ja samad inimesed räägivad, et kohe võetakse balti riigid ette.
Kui balti riigid ei saada kõike oma raha ja relvu Ukrainasse, siis võetakse ette balti riigid. _________________ Has anyone really been far even as decided to use even go want to do look more like?
Ukraine could agree to stop fighting and cede territory already held by Russia as part of a European-backed plan for peace.
Volodymyr Zelensky told European leaders that they must reject any settlement proposed by Donald Trump in which Ukraine gives up further territory – but that Russia could be allowed to retain some of the land it has taken.
This would mean freezing the front line where it is and handing Russia de facto control of the territory it occupies in Luhansk, Donetsk, Zaporizhzhia, Kherson and Crimea.
The softening of the negotiating position comes ahead of talks between Mr Trump and Vladimir Putin in Alaska on Friday.
Juba kolm aastat on Venemaa mõne kuu kaugusel kollapsist.
See justkui viitab sellele, et venemaa ei kuku kunagi kokku aga kukkus kokku nii Tsaari-Venemaa kui ka Nõukogude Liit.
Mõned arvavad, et vastava kursi on Venemaa ka praegu juba võtnud. Ukrana sõda on inimkaotuste poolest Nõukogude-Afganistani sõjaga võrreldes kümnekordne. Aga Afganistani sõda kestis 10. aastat.
Tehnikaga on umbes samamoodi.
Ja Nõukogude liit oli 2x suurema elanike arvuga kui tänane venemaa.
Seda kõike perspektiivi pannes võiks ju eeldada, et jätkusuutlik see asi venemaal ei ole.
Võim kukkus kokku, mentaliteet jäi _________________ All it took was for a lot of seemingly decent people to put the wrong person in power, and then pay for their innocent choice.
Autokraatiates toimub kokkukukkumine äkitselt. Viimane näide oli Süüria. Paar nädalat enne ei viidanud miski sellele, et Assad võik venemaale pageda.
Ükski analüütik ei osanud seda ette näha. Ometi see juhtus. Samas on režiimid nagu Põhja-Korea ja Iraan palju pikemalt püsinud. Iraanis ehk kunagi asjad muutunuvad, aga Põhja-Koreas on seda raske ette näha, sest peamees on võrdlemisi noor (kui ülekaalulisus ei tapa) ja seal antakse võim peresiseselt edasi.
Valgevene on kah küsimärk. Hetkel tundub, et luka poeg võtab juhtimise üle ja kõik jätkub samamoodi. Tšetšeenias samamoodi.
Kole raske on kokku kukkuda, kui oled juba kaelani pasas. Igasugused näitajad on Venemaal juba ammu punases, aga sealne elu ei allu tavalistele reeglitele. Samas lõputult ei saa see pull neil seal käia, moel või teisel see lõppeb. Ka N-Liidu kokku kukkumist ei peetud omal ajal võimalikuks ja kardeti lausa katastroofiliseks oleva, kui peaks juhtuma.
Kahjuks ükski ajakirjanik ei taha või pole piisavalt terav, et talle jooksu pealt faktikontrolli teha. Nagu varem näha olnud, kritiseerijad saavad pressikonverentsidelt bänni. _________________ "a rental car, three cheeseburgers and a head start."
Ma isegi ei teadnud, et 2012 toimus Donbassis jalgpalli EM vms.
Piltidelt paistab nagu igati tavaline lääne linn.
Nüüd on "vene maailm" muutnud selle porimülkaks mida juhivad kriminaalid ja kus kraanist ei tule isegi puhast joogivett.
FC Shakhtar Donetsk oli omal ajal ikka suht norm tiim.. Mitte päris tippklass aga vahel suutsid korralikult üllatada. Ega seal rahaga ka väga kokku ei hoitud.
Enne Russkii Mir-i tulekut, käisid seal teiste staaride hulgas Beyonce ja Rihanna esinemas. _________________ "a rental car, three cheeseburgers and a head start."
Hungarian Prime Minister Viktor Orbán has said that "Russia has won" the war in Ukraine, ahead of a possible meeting between US President Donald Trump and Kremlin leader Vladimir Putin in Alaska on Friday 15 August.
He also said Europe had lost the opportunity to negotiate with Putin under former US president Joe Biden’s administration and now risks having its future decided without its involvement.
"If you are not at the negotiating table, you are on the menu," Orbán said, adding that he was partly opposed to the EU’s joint statement on Ukraine because it made Europe "ridiculous and pathetic".
Orbán has become the only EU leader who did not sign a statement in support of Ukraine.
The heads of 26 EU member states signed a joint declaration on the eve of the Trump–Putin meeting in Alaska, reaffirming support for Ukraine. The statement stressed that international borders must not be changed by force, Ukrainians must be free to decide their own future, and the path to peace in Ukraine cannot be determined without Ukraine’s participation.
The only one who refused to sign was Hungarian Prime Minister Viktor Orbán. “The only reasonable action for EU leaders is to initiate an EU–Russia summit similar to the US–Russia meeting,” he said.
Meanwhile, a scandal is brewing in Hungary over Orbán’s luxurious palace near Budapest, officially owned by his father.
The prime minister insists it is “just a modest farm,” yet it has no signs of agriculture — instead, it boasts a swimming pool, a zoo, and an underground parking garage.
The main question: where did the money for such luxury come from — and is it connected to Orbán’s consistent pro-Russian stance?
Trump: If the first meeting goes okay, I would like to have a second meeting almost immediately between Putin, Zelensky and myself if they want me there.
If I don't get the answers I want, there will be no second meeting.
Reporter: There is a new report that the Russians have hacked into the computer system that manage US federal court documents. Will you bring this up with Putin?
Trump: I guess I could, they hack in, that is what they do. They are good at it.
Donald Trump is preparing to offer Vladimir Putin access to rare earth minerals to incentivise him to end the war in Ukraine.
The US president will arrive at the much-anticipated meeting with his Russian counterpart on Friday armed with a number of money-making opportunities for Putin.
They will include opening up Alaska’s natural resources to Moscow and lifting some of the American sanctions on Russia’s aviation industry, The Telegraph can reveal.
Proposals include giving Putin access to the rare earth minerals in the Ukrainian territories currently occupied by Russia.
