MatchMaker
01.06.2025 14:33:35
link :: Venemaa raudteel Ukraina piiri lähedal varises kokku kaks silda, mitu inimest hukkus
tsitaat: |
Venemaal Ukrainaga piirnevatel aladel varises kokku kaks raudteesilda, esimene õnnetus juhtus laupäeva hilisõhtul Brjanski oblastis ja teine Kurski oblastis pühapäeva varahommikul.
Brjanskis varises raudtee kohal olev sild rööbastele kohas, kus möödus reisirong. Kurskis aga varises kaubarongi ülesõidu ajal kokku raudteesild. |
https://kyivindependent.com/enemy-bombers-are-burning-en-masse-ukraines-sbu-drones-hit-more-than-40-russian-aircraft/
Video of FPV drone strikes at Tu-95MS bombers
https://x.com/Liveuamap/status/1929131059632857149
https://x.com/Liveuamap/status/1929132029951484255
https://x.com/Liveuamap/status/1929127774662316522
tsitaat: |
This morning, a truck stopped at a gas station at the entrance to the city. After a while, drones began flying out of the back, which then attacked various objects. The driver has been detained.
The driver of the truck filled with drones that attacked Olenegorsk may not have known about the cargo — Baza
Local Russian residents claim that a truck arrived in Olenegorsk, with the driver running around in panic as FPV drones repeatedly launched from the trailer.
According to them, traffic police have detained the driver, who reportedly said, "I was told to come here, someone would meet me."
Kommentaarid: 2 loe/lisa |
-Kaivo-
01.06.2025 14:51:48
Kas näeme sel aastal taktiklise tuumalöögi ära. Putinil lõppevad vastused.
Kommentaarid: 16 loe/lisa |
15 |
pwn13
01.06.2025 15:53:18
Pommitajate ründamine on viisakas, Venemaa ei saa neid asendada.
_________________ pWn |
Kommentaarid: 72 loe/lisa |
67 |
MatchMaker
01.06.2025 15:58:54
tsitaat: |
SBU quoted by Ukrinform:
"The special operation "Pavutyna", as a result of which the SBU hit 41 Russian strategic aviation aircraft, was prepared for more than a year and a half.
The President of Ukraine, Supreme Commander-in-Chief Volodymyr Zelensky, personally supervised the operation. And the plan was implemented by Vasyl Malyuk and the staff of the Service. According to our sources, this operation was extremely complex from a logistical point of view.
The SBU first transported FPV drones to Russia, and later - mobile wooden houses. Later, on the territory of the Russian Federation, the drones were hidden under the roofs of houses, already placed on trucks. At the right moment, the roofs of the houses were remotely opened, and the drones flew to hit the Russian bombers
https://x.com/michaelh992/status/1929159877768679614
bugbrake
Kommentaarid: 6 loe/lisa |
01.06.2025 16:30:44
Sai loodetavasti rabanduse, kui kuulis et 1/3 tema strateegilisest lennuväest tuleb maha kanda.
Kokku peaks neid lennuked kuskil 130 kanti olema, mis veel lennuvõimelised ja nüüd on neid 40 tuuris vähem.
Kommentaarid: 228 loe/lisa |
194 |
pwn13
01.06.2025 16:33:23
Huvitav millega vatid vastavad. Raudselt lastakse mingit tsiviil sihtmärki
67 |
somnambuul
Kommentaarid: 60 loe/lisa |
54 |
bugbrake
01.06.2025 16:45:26
Võib öelda, et ukrainlased on taas sõjanduses ajalugu teinud ja sõjanduse reegleid üle kirjutatud
_________________ Alati teadke, et kuulujutte mõtlevad välja vihkajad, levitavad lollid, aga usuvad idioodid. |
napoleon
Unknown virus
01.06.2025 16:48:12
Mingit kiunu tiblade poolt veel polegi kuidas Ukraina neile liiga teeb
Kommentaarid: 77 loe/lisa |
60 |
Oisu.
01.06.2025 16:58:39
Noh see "педик" tuli ju korduvalt ära
Irkutski oblast
Kommentaarid: 3 loe/lisa |
pwn13
67 |
01.06.2025 17:58:43
Paras venelastele. Enda süü, et kasutavad strateegilisi pommitajaid sellise lokaalse sõja jaoks. Nüüd on tulemus käes. Oleks neid kunagi mitte kasutanud, siis Ukrainlased oleks seda austanud ja neid mitte sihtinud.
Eriti irooniline on see, et venelased arvasid, et nende pommitajad on ohutus kohas 3000-4000km kaugusel. Ukrainlased korraldasid väikse tulevärgi juba varem see nädal ja see oli 7000km+ kaugusel.
Mõistagi venelastel polnud nii kaugel mingit õhutõrjet kah. Ühes vidos üks pealtvaataja jahub mingist Pantsir'st mida kuskil näha pole ja kuulda on ainult käsirelvadest tulistamist. FPV drooniode vastu on enamus relvi pikalt distantlist praktiliselt kasutud, sest FPV on nii väike ja manööverdav.
Huvitavam on see kuidas need droonid ründasid. Ma eeldan, et need kasutasid AI'd, et rünnata eelnevalt sisse programmeeritud sihtmärke, sest vaevalt kuskil autos istusid droonioperaatorid ja distants on liiga suur, et neid reaalajas Ukrainast kontrollida.
Igal juhul suur kaotus venelastele. 41 pommitajat rivist väljas ühe päevaga
Kommentaarid: 92 loe/lisa |
heretic666
01.06.2025 18:13:12
tsitaat: |
Eks siin ka vahe kas kasutavad sõjaliste sihtmärkide vastu või lasevad kaubanduskeskusi/lastehaiglaid/kortermaju õhku
tsitaat: |
Mingi tweet ka väitis just sedasama et AI trainingut kasutati eelnevalt.
Küll külajutud aga üks tuumaallveelaev olla ka õhku lennanud Severomorskis.
1. Juuni 2025 kirjutati ajalooõpikutesse.
Eks mingi orešniku keskmaarakett siis "vastuseks" pannakse ehk teele nagu 1x juba tehtud sest alati peavad vastama millegagi.
Kommentaarid: 73 loe/lisa |
One
01.06.2025 18:16:32
Putler ei tahtnud rahu, head seletamist siis lollidele miks see hea oli
Kommentaarid: 1009 loe/lisa |
728 |
MatchMaker
01.06.2025 21:25:34
tsitaat: |
US officials are warning it's European allies that Russia plans to conduct a "disproportionate retaliation" against Ukraine following today's attack.
An official warning could be released by the US Embassy in Ukraine shortly
01.06.2025 21:28:48
Ukrainal pole midagi kaotada. Mida venelane nüüd siis teeb?
Ründab järjekordset lastehaiglat? Laseb mingi suure tammi õhku? Laseb kobarmoona kaela rindelähedase linna tsiviilidele? Laseb teele IRCM?
Oh wait. Nad on kõike seda juba teinud. Neil pole enam kaarte.
01.06.2025 21:30:51
Tomorrow kirjutas: |
Oh wait. Nad on kõike seda juba teinud. Neil pole enam kaarte. |
Tactical Nuke, Kiievisse?
Neil pole enam kah suurt kaotada.
194 |
MatchMaker
01.06.2025 21:39:34
tsitaat: |
President Zelensky: in total 117 drones were used in "Spider web" operation. The office of the operation was next to FSB HQ in one of the Russian regions |
01.06.2025 21:59:23
Etz kirjutas: |
Neil pole enam kah suurt kaotada. |
Siis on head-aega Hiina tugi. Kui putin ei kasutanud tuumarelvi siis kui Ukraina võttis tagasi suuri alasi Harkivi ja Luhanski oblastites 2022 aastal, siis miks ta peaks seda kasutama nüüd kui ta arvab, et ta on võitmas?
Pealegi üks taktikaline tuumarelv on väikse raadiusega Ukraina suurust silmas pidades. Psühholoogiline mõju oleks sellel kindlasti, aga isegi venemaa liitlastel oleks raske taluda tuumarelvade kasutamise normaliseerimist konventsionaalses sõjas.
CnZ
01.06.2025 22:08:46
Tubli töö ukrid
Zelenski ja Kiievi juhtkond väidetavalt viidud peitu ära, pidi tulema korralik kättemaks
Kommentaarid: 14 loe/lisa |
Oisu.
01.06.2025 22:51:28
Selles tanklas pargitud KAMAZ veokist startisid droonid Vysokii sõjaväelennuvälja suunas
link
ufo56
Kommentaarid: 78 loe/lisa |
67 |
Kommentaarid: 1142 loe/lisa |
722 |
Auron
02.06.2025 07:57:15
Selle edasi tagasi tõksutamise ümber võib ju jaurata aga suur küsimus on ikkagi selles kuidas asi lõpu leiaks? Kõige suurem probleem sõja lõpetamise puhul on ju ikkagi selles, et tibla ei saa ju lihtsalt asju kokku pakkida kui verejanulisele rahvamassile kõlbab ainult "kõik eesmärgid saavutati" lahendus. Ehk siis igasugune diplomaatiline sõja lõpp oleks ka puutini lõpp ja selles probleem ongi. Ühes küljest võib küll mõelda, et kui tibla piisavalt vastu nina saab siis on ukrainlastel läbirääkimiste lauataga jõuõlg suurem aga samas ise kipun arvama, et tibla on sedalaadi loom kes mida rohkem nurka aetakse seda ohtlikumaks muutub - just kui silmas pidada mingisuguseid meeleheitlikke käike
Kommentaarid: 154 loe/lisa |
131 |
