praegune kellaaeg 07.08.2025 08:52:52
Kristoferr
23.05.2025 09:20:45
M: ORICO-TB3-S4 :: Asukoht: Keila |
ORICO-TB3-S4. Koos toiteadapteriga. Windowsiga töötas kenasti plug&play.
https://www.orico.cc/us/product/detail/7772.html
tsitaat: |
TB3-S4
Category: Adapter/Expansion
ORICO Technologies Co., LTD
Operating System: MacOS
Windows
Self or Bus Powered: Self Powered
Thunderbolt Version: Thunderbolt 3
1 x USB3.0 Type A supports 10Gbps .
2 x USB3.0 Type A supports 5Gbps .
2 x USB2.0 Type A supports 480Mbps .
1 x RJ45 LAN port supports 10/100/1000M.
1 x SD2.0/microSD2.0 Card Reader supports SDXC cards up to 2 TB, SDR25 data transfer rate 25MB/Sec. (single-LUN)
1 x 3.5mm stereo combo jack (microphone input/audio output) x 1
2 x USB-C (Type C Host) 10Gbps.
1 x USB-C PD port, Mac output 60W for charging. (Thunjderbolt 3)
1 x USB-C PD port, Mac output 15W for chargin |
AH: 40-
OK: 70-
Vajadusel pakiautomaat +4€.
_________________ Liitu Binance'ga
Liitu Honey'ga |
Kommentaarid: 258 loe/lisa |
209 |
xtr
22.06.2025 11:57:08
_________________ M: Magic Mouse + Keyboard
M: Ryzen 2600/B450M/16GB/1TB/GTX1080/650W
M: 2020 MacBook Pro 13 M1/16/500 ja 2020 MacBook Pro 13 i5/16/500 |
Kommentaarid: 317 loe/lisa |
262 |
Kristoferr
209 |
indiviid
06.08.2025 21:58:34
35
Kommentaarid: 1 loe/lisa |
Kristoferr
06.08.2025 22:25:22
Kui reedeks üle ei pakuta, siis reede hommikul võin posti pista või võib ka käest kätte.
Liitu Honey'ga |
209 |
lisa lemmikuks |
