17.04.2025 13:59:16
Kas GPMI asendab HDMI ja Displayporti? Uus liides lubab 192 Gbit/s andmeedastuskiirust |
Hiina Shenzhen ettevõtete (sh Huawei, Skyworth ja Hisense) ühendus on välja töötanud alternatiivse GPMI liidese, mis on kordades kiirem senistest levinud HDMI ja Displayport liidestest. Lubatakse andmeedastuskiirusi kuni 192 Gbit/s ja 8K resolutsiooni tuge.
Move over HDMI and DisplayPort: China has launched GPMI, a new high-speed interface developed by the 8K UHD Video Industry Cooperation Alliance of Shenzhen, and it’s set to shake up the world of video connections. With speeds of up to 192 Gbps and support for 8K resolution, GPMI (which stands for General Purpose Media Interface) doesn’t just match existing standards, it actually blows them out of the water. And it’s not just about display tech: this newcomer also delivers up to 480 watts of power, making it a triple threat for video, data, and energy.
Behind this bold move is a coalition of over 50 Chinese tech companies determined to reduce reliance on Western standards and build a homegrown solution ready for next-gen devices. GPMI comes in two flavors: Type-B, which brings the full 192 Gbps and high power delivery, and Type-C, which trades a bit of speed (96 Gbps) for USB-C compatibility. While it’s currently focused on the domestic market, the global electronics scene may soon need to make room for China’s new cable king.
Loe edasi: https://eladelantado.com/news/china-unveils-gpmi-hdmi-alternative/
Vaata ka: https://en.wikipedia.org/wiki/GPMI
7 :: |
364 |
| Kommentaarid: 92 loe/lisa |
7 :: |
364 |
wex
20.04.2025 19:04:39
| Kasutab patenteeritud pistikut. |
Ikka on proovitud end toiduahelasse sisse süüa, et raha teenida. Ei ole lihtne troonilt tõugata midagi mis on maailmas laialt tunnustatud.
HDMI ja DP uued standardid on tagasiulatuvalt ühilduvad. Selleks, et neid välja tõrjuda peaksid vandad ühendused olema ennast ammendanud.
HDMI 2.2 ja ultra96 kaabel lubab 8k @ 240Hz, 12k @ 120Hz.
https://www.av.com/blog/hdmi-2-2-vs-2-1/
| Kommentaarid: 124 loe/lisa |
117 |
BA79
20.04.2025 19:16:16
Küsimus on selles,et milline väline seade nõuab 480W, et GPMI ennast õigustaks? OK, ma saan aru, et tehniliselt saaks ka välist videokaarti sellega toita, aga üldiselt 480W on juba selline toide, et lihtsam on kasutada toiteplokki.
Võib-olla on tegemist mingi tulevikuvisiooniga, et tulevikus saab selle ühe liidese abil toita nii telekat/monitori kui ka mängukonsooli?!? Üks toitejuhe seinapistikusse, ülejäänud seadmeid saab toita GPMI'ga?!?
1dumbpcuser
20.04.2025 20:50:36
Mõtlesin ise ka sedasama. Samas USB-c laeb telefone 100-125W, seega kaugel ka see 240W piir on...
_________________ M: MSI B660M MORTAR
O: AM5 ITX emaplaat |
97 |
BA79
21.04.2025 19:31:06
Telefonide laadimisvõimsuse piir tundub sõltuvat konkreetsetest tingimustest ja selle paneb paika telefonitootja sõltuvalt mudelist ja aku mahutavusest. Paar nädalat tagasi sai ostetud nt odavama otsa Android telefon (Realme Note 60). Sellel telefonil on ka USB-C liides (USB 2.0 spetsifikatsioonile vastav) ja tootja on telefonikarbi etiketile trükkinud et adapteri vool ei tohi ületada 10W (lubatud vahemik 2.5-10W). Andsin pereliikmele tema uue telefoni laadimiseks 5W vana Huawei telefonilaadija. Endal on iPhone SE2020 jaoks ostetud Aukey PD kiirlaadija võimsusega 20W. Telefonil olla max laadimisvõimsus 18W, see paar watti ei tee midagi, sest telefon pidavat piirama laadimisvõimsust. Võib-olla uuemad telefonid ja ennekõike tahvelarvutid nõuavad rohkem laadimisvõimsust, aga vanema generatsiooni nutiseadmete jaoks on isegi USB-C PD'st maa ja ilm ning jääb ülegi veel ( USB-C PD max väljundvõimsus on kuni 100W (5A 20V)).
viimati muutis BA79 21.04.2025 22:23:42, muudetud 1 kord |
Sahasrahla
21.04.2025 19:51:36
| Taparelvad.
wex
22.04.2025 14:08:54
| BA79 kirjutas: |
| ...(Realme Note 60). Sellel telefonil on ka USB-C liides (USB 2.0 spetsifikatsioonile vastav) ja tootja on telefonikarbi etiketile trükkinud et adapteri vool ei tohi ületada 10W ... |
Adapterist ei tule välja vool vaid pinge. Voolu mõõdetakse amprites. Vool tekib siis kui on vooluring. Telefon juhib laadimisprotsessi ja seega ka seda kui suur on vool. Adapteril peab olema piisavalt võimsust, et suudaks vajaliku voolu välja anda.
Kunagi oli asi lihtne USB, oli 5V ja 1 A ( voolu suurus võis erineda). Kuna väiksest kontaktist palju rohkem voolu läbi lasta ei saa aga rohkem võimsust oli vaja siis mõeldi selline huvitav asi välja, et tõstame hoopis pinget. P (võimsus) = U (pinge) x I (vool)
https://www.act-connectivity.com/en-us/usb-c-explained
Kui nüüd teema alguse juurde tagasi tulla siis GPMI on kirjas võimsus aga mis pinge ja vooluga see saadakse seda välja ei loe. On kuskil tehnilist infot selle GPMI kohta, või on ainult see hiinakeelne reklaam? https://www.hisilicon.com/cn/White-Paper-Technical-Guide/white-paper/gpmi-innovation
48 V pinget mida on peetud piisavalt ohutuks. Mingi hetk võib olla leitakse, et 64 V on ka piisavalt ohutu siis oleks USB-c võimsus juba 320 W-i.
viimati muutis wex 22.04.2025 17:22:04, muudetud 1 kord |
117 |
degreal
22.04.2025 17:01:45
pool kilovatti pole paha. Ööga laeb telefonilaadijaga elektriautot 25km jagu
| Kommentaarid: 29 loe/lisa |
26 |
| Kommentaarid: 758 loe/lisa |
569 |
