heretic666
| Kommentaarid: 73 loe/lisa |
486
23.08.2024 13:03:42
65w ja 35w on huvitavad. Ehk kiirus ka nii halb pole. Kui vaid uued videokaardid ka säärase energia dieedi teeksid oleks uus gen päris hea.
Sest praegune gen on ikka totaalne saast, sitt performance ja ögivad nagu sead!
_________________ zero |
| Kommentaarid: 46 loe/lisa |
39 |
1dumbpcuser
01.09.2024 19:55:17
| 486 kirjutas: |
Sest praegune gen on ikka totaalne saast, sitt performance ja ögivad nagu sead! |
Inteli on T-mudelid ehk madala tdp-ga cpu-d tootmises olnud vähemalt Sandy Bridge aegadest peale ehk Core i#-2000-seeriast alates
Ka 14-nda põlve omadel on olemas 35w-sed T-mudelid
Edit:
China's largest Core i9-14900K gaming cafe has suffered from instability issues since 2023 — the flagship store has 171 gaming PCs with Core i9-14900K chips
TomsHW
"Intel investigates product problems thoroughly, provides support for technical issues, and is reliable in warranty and after-sales service. This responsibility gives me the confidence to make money steadily and at ease and also makes me more determined to continue to equip all new stores with the latest Core i9 processors," said Xie to Fast Technology.
China's largest Core i9-14900K internet cafe is part of a chain of internet cafes owned by Dongyu E-Sports in Yueyang, Hunan. The company has set up six gaming cafes around different parts of the city for a total of 689 PCs where 68% of the gaming rigs utilize and Intel Core i9 CPU. The flagship store has the most Core i9-14900K CPUs, comprised of 171 machines. Each rig has an RTX 4090D GPU and a 540 Hz refresh rate gaming monitor. Mainstream rigs are purportedly equipped with RTX 4070 Super GPUs.
The rigs are about as high-end as it gets. Each Core i9-14900K is manually overclocked to 5.9 GHz, and the system RAM is overclocked to a blisteringly quick 8,533 MHz. The RTX 4090Ds are also overclocked, with speeds of 3.1 GHz on the GPU core and 13 GHz on the memory, respectively. 360mm AIO liquid cooling is employed to keep the CPUs cool.
Edit2:
Pole läbi see 13/14-gen ebastabiilsuse saaga veel, septembri lõpus tuleb veel uudiseid, ilmselt ka siis uus bios update vms?
Intel Core 13/14th Gen Instability Update - Future Products Unaffected + Current Gen Product Updates
Intel Community
_________________ M: |
97 |
1dumbpcuser
97 |
04.09.2024 21:19:58
arvatavasti algmaterjalideks lõhkumine ei tasu ära.
arvata võib, et need, mis pole surnud, lähevad uuele ringile
_________________ - londiste
216 |
1dumbpcuser
97 |
486
05.09.2024 12:50:37
Mis selle Inteli probleem praegu, vigased 13. ja 14. genni prosed ei müü piisavalt hästi? Kuidas siis 15. gen välja kukub sellises raskes olustikus, veelgi vigasem?
39 |
1dumbpcuser
05.09.2024 13:04:02
| 486 kirjutas: |
| Mis selle Inteli probleem praegu, vigased 13. ja 14. genni prosed ei müü piisavalt hästi? Kuidas siis 15. gen välja kukub sellises raskes olustikus, veelgi vigasem? |
Ei tule 15-ndat põlvkonda, vaid Core Ultra 200-seeria (Arrow Lake, LGA 1851)
Täiesti erinev arhitektuur (näiteks loobutakse Hyper-Threadingust) ja väidetavalt pingeprobleemidest vaba:
Intel "Arrow Lake" and "Lunar Lake" Are Safe from Voltage Stability Issues, Company Reports
https://www.techpowerup.com/326198/intel-arrow-lake-and-lunar-lake-are-safe-from-voltage-stability-issues-company-reports
97 |
Vael
05.09.2024 13:04:05
Pigem on kõin hästi kaubaks läind, nüüd pole garantiikorras vastu anda.
Teine võimalus on, et Intel lihtsalt leidis veel ühe võimaluse garantiist mööda põiklemiseks.
"Nüüd meil RMA protsess läheb kohe läbi, mingeid lisa protseduure läbi pole vaja viia, nagu vahepeal mõtlesime. Aga näed, sorry, pole millegi vastu vahetada. Oodake paar kuud"
Ja selleks ajaks on loodetavasti enamikul rahval ees ja loobutakse.
3. võimalus, tootmisprotsess on nii kehv, et i9 tuleb vähe peale. Ja järgmiseks seeriaks pole ka siis suurt lootust. Pidid juba TMSC peale üle vist kolima...
| Kommentaarid: 17 loe/lisa |
16 |
1dumbpcuser
05.09.2024 13:08:29
Vael, nad ju pikendasid garantiiaega 2-aasta võrra või miskity, nii et kummi venitada neil pole, mida rutem saavad rma-dega tegeletud, seda väiksem oht on ka selle tõttu kohtukeissi kaela saada
97 |
05.09.2024 13:16:28
486, Intelil hetkel kamaluga probleeme, seega valikut on: kasumi vähenemine, madalamad marginaalid, 13/14 gen probleemid, foundry probleemid jne.
Keegi ei tea hetkel kuidas 15th gen välja kukub, võibolla isegi Intel ise ei tea.
Lunar Lake on seni olnud oodatust parem aga Inteli probleemid on viimasel ajal ilmnenud ikka mingi aeg pärast launchi (turvaprobleemid, yield, toomisdefektid jne), seega vara veel hõisata.
Muidugi AMD jättis kehvapoolse Zen 5 launchiga (vähemalt desktop/consumer segmendis) Intelile tee valla. Läpakates paistab Lunar Lake kah asjalik olevat aga iseasi kui kallis see tuleb, sest see kasutab TSMC uusimat ja kallimat node ja palju seda toota suudetakse üldse?
Serverites on Inteli seis kõige kehvem, sest Zen 5 on väga tugev selles osas ja Inteli kehvemad majandusnäitajad on paljuski just madalama serveri turuosa tagajärg.
| Kommentaarid: 92 loe/lisa |
Zonerman
05.09.2024 13:21:37
Ei tea kas Inteli dedicated GPU projekt ka cancel tuleb. Sinna on ka meeletult raha sisse pandud ja seni suurt miskit pole. Battlemage on tulemas aga ei tundu mingi ulme, mis GPU turgu raputaks, pigem AMD rDNA4'ga mid segmendis. Lisaks suured võlad Intelil kaelas.
_________________ Sõim ja räuskamine läheb SIIA |
| Kommentaarid: 68 loe/lisa |
67 |
1dumbpcuser
97 |
12.09.2024 09:07:34
Klientidele kindlasti meeldib, saad kopika aga töötavat masinat sul endiselt pole...
196 |
Vael
12.09.2024 14:56:43
| Wu Kongi kohta ka kurdetakse, et pätsid peal aga ikka jookseb kokku, eriti shader cache arvutamise ajal.
16 |
1dumbpcuser
97 |
Optimist
| Kommentaarid: 10 loe/lisa |
23.09.2024 10:52:32
mitte-f vaadates siis 331, 433 ja 600 raha.
täpselt samad hinnad, mis eelmisel/eelmistel põlvkondadel.
216 |
1dumbpcuser
97 |
Auron
24.09.2024 06:14:16
Ega Intelil polegi midagi refreshida, sest selle arhidektuuriga ei purjeta enam kuhugi ja lihtsalt pinget peale surades saada heal juhul 100Mhz juure kui kiirused on juba seal 6000Mhz kandis on täielik paigaltammumine ja halvemal juhul hoopis halvem. Kui arvestada, et asjalikumad uuendused on käinud nii umbes 8 aasta tagant ja üle umbes 3 socketi siis eeldades, et trend nö. jätkub ei ole erilist põhjust enne 2030 midagi oodata. Samas nagu olen varem öelnud siis nähes kuidas intel liigub üha rohkem suunas kus P-cored on ebaolulised ja suratakse juure aint E-coresi siis kodusel kasutajal kelle kõige nõudlikum asi ongi pmst mängud ei ole midagi roosilist.
Samalaadset asja näeme ka ideena AMD puhul kus Zen'il saab 8 aastat täis ja läheb paigaltammumiseks.
133 |
24.09.2024 07:10:45
Auron, arhitektuur ju uueneb. selles osas ei ole probleemi näha.
inteli konks on kuskil mujal, tõenäoliselt tootmises.
216 |
1dumbpcuser
26.09.2024 14:19:20
Nagu 13->14 gen tehti?
----------------------------------------------------_
Edit: tohoh, LGA 1851 saab ainult ühe põlvkonna cpu-sid?
Intel’s Beast Lake monster gaming CPUs were canceled, could rumored Razer Lake chips fill that void?
Techradar
Intel to release another microcode update addressing Raptor Lake instability
https://videocardz.com/newz/intel-to-release-another-microcode-update-addressing-raptor-lake-instability
97 |
heretic666
