uus teema   vasta Hinnavaatlus »  Vaba Mikrofon »  Ohtlike viiruste teema vol. 2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 13, 14, 15 ... 18, 19, 20  järgmine
Scart
Scart
sõnum 29.01.2024 02:32:47 vasta tsitaadiga
https://www.cureus.com/articles/203723-viral-respiratory-epidemic-modeling-of-societal-segregation-based-on-vaccination-status#!/
Given the lack of reliable empirical evaluations of needed infectious contact frequency values, the demonstrated outcome sensitivities to the infectious contact frequencies, and the intrinsic limitations of SIR models in this application, we cannot recommend that SIR modelling be used to motivate or justify segregation policies regarding viral respiratory diseases, in the present state of knowledge.
No vaata kus vigur. Järjekordne "science!", lükati kolinaga ümber. Aga eks nii juhtub, kui ravimikorpidega voodis teadlased teadust teevad.
Dr. David Fisman, a University of Toronto epidemiologist was the lead author of the April 2022 study, published in the Canadian Medical Association Journal (CMAJ), which the authors said showed that unvaccinated people posed a disproportionate risk to vaccinated people.
Fisman has worked as an adviser to vaccine makers Pfizer, Seqirus, AstraZeneca and Sanofi-Pasteur. He also advised the Canadian government on its COVID-19 policies and recently was tapped to head up the University of Toronto’s new Institute for Pandemics.
Fisman told reporters the key message of the study was that the choice to get vaccinated is not merely personal because if you choose to be unvaccinated, you are “creating risk for those around you.”
The press ran with it.
sukelduja
sukelduja
sõnum 29.01.2024 12:19:46 vasta tsitaadiga
Scart kirjutas:
Tegid kuskilt vandenõuteoreetiku lehelt otse copy-paste? Äkki sa loeks nüüd selle artikli mõttega ka läbi korraks?
Scart
Scart
sõnum 29.01.2024 12:29:08 vasta tsitaadiga
sukelduja kirjutas:
Lugesingi, sa ka? Kuna ilmselgelt mitte, siis las ma võtan ühe lausega kokku: kinnimakstud teadlased kasutasid ilma mingi reaalse maailma inputita mudeleid, mille põhjal tehti inimeste puutumatuid põhiõiguseid tühistavaid otsuseid. You know, nagu Kanada ülemkohus teatas, et Trudeau ületas kõiki ühiskonna poolt seatud piire rekkameeste konvoid rünnates.
sukelduja
sukelduja
sõnum 29.01.2024 12:37:34 vasta tsitaadiga
Scart kirjutas:
sukelduja kirjutas:
Mine võta oma rohud ära! Sa pole võimeline seda artiklit lugema ega mõistma, veel vähem järeldusi tegema ja lihtsalt korrutad kellegi teise (põhjendamatuid) järeldusi.
Scart
Scart
sõnum 29.01.2024 12:40:45 vasta tsitaadiga
sukelduja kirjutas:
Scart kirjutas:
sukelduja kirjutas:
Hea küll, ma kopeerin teadlaste poolt kirja pandud ja peer reviewed teksti veel ühe korra.
sukelduja
sukelduja
sõnum 29.01.2024 12:51:54 vasta tsitaadiga
Scart kirjutas:
sukelduja kirjutas:
Scart kirjutas:
sukelduja kirjutas:
Nad ütlevad, et SIR modeli kinnitamiseks pole praeguseks olukorras piisavalt andemeid korjatud. SIR model loodi suguhaiguste leviku jaoks ja kohandati piisknakkuste jaoks, kuid ilmselt mitte piisavalt. Ainuke järeldus on, et on vaja paremat mudelit. Kõik muud järeldused on meelevaldsed.
Scart
Scart
sõnum 29.01.2024 13:05:48 vasta tsitaadiga
sukelduja kirjutas:
Seda mudelit kasutati, et teha põhjapanevaid järeldusi, millega võeti inimestelt nende põhiõigused ja neid otsuseid teinud ja õiguseid tühistanud tegelased teadsid seda. Kas sa nagu meelega oled hetkel dense või mängid lihtsalt kuni arvamusliider tagasi jõuab ja kõik oma pasanteeriaga üle laseb?
sukelduja
sukelduja
sõnum 29.01.2024 14:06:05 vasta tsitaadiga
Scart kirjutas:
sukelduja kirjutas:
Sa võiks vähemalt Abstract osa mõttega läbi lugeda enne kui tuimalt oma joru edasi paned. Pigem on sellest välja lugeda, et probleem oli vaktsineeritute leebem kohtlemine, mis võimaldas ka selles grupis levikut. COVID kui ülinakkava ja kergesti muteeruva olemuse järgi võib kohe öelda, et SIR mudel COVIDi puhul ei tööta. Sest ei vaktsineerimine ega läbipõdemine ei kaitse uue nakatumise eest. PEalegi on kohe töös konkreetselt öelud, et mudel oli suht must-valge:
Our model assumes only two risk populations (vaccinated and unvaccinated), considers only the attack rates on epidemic completion (Av, Au, and At), and takes the degree of segregation η to be time-independent, without variation due to public holidays and such. It does not consider other outcomes such as death or hospitalization, and does not include different age groups with different characteristics such as contact frequencies or recovery times
napoleon
Unknown virus
napoleon
sõnum 11.02.2024 14:52:08 vasta tsitaadiga
Mis COVID-19'st saanud on? Mingeid piiranguid pole, huvi vaktsineerimise vastu on ka leige, aga ma ei tahaks nagu uskuda, et see COVID-19 niisama lihtsalt oma urgu tagasi puges ja inimesi enam ei kimbuta.
Kommentaarid: 76 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 59
somnambuul
sõnum 11.02.2024 14:56:38 vasta tsitaadiga
Tavaline "külmetushaigus" on.
sõnum 11.02.2024 15:17:54 vasta tsitaadiga
Raskusaste sõltub nüüdseks peamiselt nakatunust - on kuulda olnud nii paaripäevaseid kurguvalusid kui nädalast palavikuga pikaliolekut.
Kommentaarid: 162 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 151
One
sõnum 11.02.2024 17:38:24 vasta tsitaadiga
Eks tuleb oodata kuni hiina selle 100% tapva lahti laseb.. enne vaja natuke vähem tapvaks tuunida, muidu surevad kandjad enne ära kui levitada jõuavad.
Kommentaarid: 1007 loe/lisa Kasutajad arvavad:  :: 3 :: 1 :: 727
sõnum 11.02.2024 20:07:15 vasta tsitaadiga
Miks te enam kovidi vastu ei vaktsineeri?
Kommentaarid: 689 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 532
One
sõnum 11.02.2024 20:09:05 vasta tsitaadiga
Riigil raha pole, iga vaktsineerimine tähendab suurt miinust või uut maksu icon_cry.gif
sõnum 11.02.2024 20:10:41 vasta tsitaadiga
Just läksid vaktsiinid prükki ju.
sõnum 11.02.2024 22:36:40 vasta tsitaadiga
Mikros soojaks ajades tapaks bakterid..
HV valuutakalkulaator
Kommentaarid: 461 loe/lisa Kasutajad arvavad:  :: 12 :: 7 :: 356
napoleon
Unknown virus
napoleon
sõnum 11.02.2024 22:58:29 vasta tsitaadiga
Tanel kirjutas:
Valimatult sh. ka kasulikke. Aga seda ei tea, kas mikro viiruse ka tapab. Need elukad on ju nii pisikesed.... või siis polegi elukad nagu öeldakse
sukelduja
sukelduja
sõnum 11.02.2024 23:55:13 vasta tsitaadiga
napoleon kirjutas:
Pea kõigil on suurem või väiksem kokkupuude olnud, st mingid antikehad on olemas. Aga põetakse ikka korralikult. Mõned surevad ära ka. Ajakirjandusel puudub huvi teemat käsitleda. Riiklikul kampaanial ka eriti mõtet pole. Antivaksikud lõugavad oma kajakambrites nagu enne ja vahel üritavad mõne laiema ringiga meedias sellel teemal "saagi" käima tõmmata, niikuinii on tegemist suuremas osas vaimuhaigetega.
sõnum 11.02.2024 23:58:17 vasta tsitaadiga
https://www.delfi.ee/artikkel/120269349/sakslane-kohis-mitu-liitrit-verd-ja-suri-lennukis
Kommentaarid: 223 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 192
Scart
Scart
sõnum 19.02.2024 01:04:24 vasta tsitaadiga
https://twitter.com/canindependent/status/1758485570446143653
Mulle eriti meeldib see ehe Kanada tänapäev - "soovite end äkki ära tappa?" korda kaks thumbs_up.gif
Oisu.
sõnum 25.02.2024 14:27:52 vasta tsitaadiga
Igal aastal saab 10 000 inimest Norras raske veremürgituse.
Umbes 20 protsenti nakatunutest sureb sellesse.
Algselt koroonatestimiseks soetatud masin tähendab, et Helgelandi haigla ei pea vereproove saatma mikrobioloogia laborisse. Helgelandi jaoks on lähim seda tüüpi labor Nordlandssykehusetis Bodøs. Vastuse saamine võttis päevi.
Helgelandi haigla, Nordlandi haigla ja Tromsø ülikooli uuringud näitavad, et masina täpsus veremürgitust põhjustavate bakterite tuvastamisel on 97,8 protsenti. See tähendab, et veremürgitust saab ravida varem.
https://www.nrk.no/nordland/denne-maskinen-kan-revolusjonere-behandling-av-alvorlig-syke-i-distriktene-1.16770549
sukelduja
sukelduja
sõnum 26.02.2024 01:26:37 vasta tsitaadiga
Oisu. kirjutas:
Sepsist saab ravida ka siis, kui ei teata, mis bakteriga tegu on. Lihtsalt pumbatakse inimene erinevaid antibiootikume täis ja ravitakse kõike, mis võimalik on.
degrass
degrass
sõnum 26.02.2024 11:22:48 vasta tsitaadiga
sukelduja kirjutas:
Oisu. kirjutas:
Eeldusel, et patogeen ei ole resistentne kasutatava antibiootikumi suhtes.
˄28 The term "troll" refers to internet users–in this context, paid operatives–who post inflammatory or otherwise disruptive content on social media or other websites.
Nie wieder ist jetzt
Draqula
sõnum 26.02.2024 15:46:09 vasta tsitaadiga
degrass kirjutas:
sukelduja kirjutas:
Oisu. kirjutas:
Ja küll me seda resistentsust mõnuga kasvatame kui "lihtsalt pumpame suvaliselt antibiootikume". Ma saan aru küll, et selliselt talitamine on teatud asjaoludel põhjendatud, kuid resistentsus antibiootikumide suhtes on järjest tõsisem probleem.
sukelduja
sukelduja
sõnum 26.02.2024 17:36:44 vasta tsitaadiga
Draqula kirjutas:
degrass kirjutas:
sukelduja kirjutas:
Oisu. kirjutas:
Seda protseduuri tehakse haiglas ja veenisiseselt. Eesmärk on haigustekitaja 100% hävitamine. Kui seda korralikult teha, siis ei teki mitte mingit resistentsust. On jäänud üksikud tõhusad antibiootikumid, mida üldse tavainimese kätte ei antagi.
uus teema   vasta Hinnavaatlus »  Vaba Mikrofon »  Ohtlike viiruste teema vol. 2 mine lehele eelmine  1, 2, 3 ... 13, 14, 15 ... 18, 19, 20  järgmine
