Ja just see ongi kõige suuremaks probleemiks, miks Kaja ei saa enam Venemaa suunalist tegevust kritiseerida.
Välismaal teatakse väga hästi, millise käkiga Kaja on hakkama saanud. _________________ Hinnavaatlus.ee - leia parim hind! HV-s ID-kaardiga autentimine
Kas NATO's on üldse ettenähtud võimalus mõni liige välja visata? _________________ Alati teadke, et kuulujutte mõtlevad välja vihkajad, levitavad lollid, aga usuvad idioodid.
The U.S. immigration enforcement agency hired a former spokeswoman for the Palestinian Liberation Organization (PLO) and put her in a position to determine who gets to come into the country as an immigrant or “asylum seeker.” Now the Department of Homeland Security (DHS) officer is repeatedly posting pictures of Hamas terrorists parachuting in with guns and writing, “F*** Israel and any Jew who supports Israel,” a Daily Wire investigation found.
Millal me ka mitte-kristliku Talibani juurde jõuame muidu?
Around 3,500 Russian citizens in Latvia will receive letters from the migration authority this week asking them to leave the country. The government body said on September 21 that they were people who hadn't submitted documents to extend a permanent residence permit or hadn't registered for a Latvian language test by September 1. They must leave Latvia by November 30, it said. An amendment passed by parliament in 2022 tightened residency rules for Russian citizens in response to Moscow's unprovoked invasion of Ukraine. To continue living in Latvia, they must apply for permanent residence status and prove a decent knowledge of the Latvian language.
Kaja Kallas ei suuda idavedude skandaalis näha eetilist mõõdet.
Idavedude skandaal pärsib Eesti välispoliitlist mänguruumi.
Kaja Kallas kaotab kahepoolseid kohtumisi.
Peaminister Kaja Kallas kipub jääma idavedude skandaali tõttu välispoliitilisse isolatsiooni.
Esmaspäeval saatis Norra peaminister Jonas Gahr Støre erru välisminister Anniken Huitfeldti, kes oli pikalt keeldunud tagasi astumast. Välisministri abikaasa aktsiaportfellist olid läbi käinud riigile kuuluva kaitsetööstusfirma Kongsberg Gruppeni aktsiad. Kuna välisministri töö võis mõjutada firma tulemuslikkust, nähti selles huvide konflikti.
«Usaldus on midagi, mille eest peame vastutama ja hea seisma,» ütles Norra peaminister, kommenteerides valitsusremonti. «Me teeme seda täna.» Kuluaaridest oli kuulda, et välisministri vinduv skandaal hakkas juba segama Norra välissuhtlust. Niisiis, korras nagu Norras.
Aga kuidas on lood Eestis? Peaminister Kaja Kallas ei ole siiamaani aru saanud, milles seisneb idavedude skandaali probleem, ning paraku on tegemist valitsusjuhiga, keda näiteks välisminister lahti lasta ei saa. Parlamendis on suur enamus koalitsioonil, kes praegu veel samuti peaministrit maha võtta ei taha, ning kõige kõrgemal võimul ehk rahval on võimalik seda teha alles kolme ja poole aasta pärast.
Senini on aga Kaja Kallas kaevunud Stenbocki majja ning keeldub sealt alla tulemast. Ei pea olema geniaalne poliitikavaatleja mõistmaks, et selles kätkeb pretsedenditu probleem nii Eesti sise- kui ka välispoliitika jaoks. Välispoliitilise dimensiooni on muutnud eriti delikaatseks Kallase enesepositsioneering «moraalse majakana» Ukraina sõja küsimustes, kus ta ei kõhelnud aeg-ajalt vanale Euroopale etteheiteid tegemast Ukraina liiga loiu toetamise pärast.
Et samal ajal käis tema abikaasal edasi vilgas äritegevus Venemaaga, on huvide konflikt täiesti ilmne siingi ja jääb täiesti arusaamatuks, kuidas peaminister sellest aru ei saa. Avalikkus ei koosne paraku lollidest ning enamasti ei osale ka välissuhtluses just kõige tuhmimad kujud, kuna riigid soovivad olla rahvusvahelises asjaajamises edukad ja sealjuures lävida usaldusväärsete isikutega.
Toompea, meil on probleem! Ehkki Kaja Kallase lähikond üritab väita, et peaministri välissuhtlust pole idavedude skandaal pärssinud, on Postimees kuluaarivestlustes kuulnud vastupidist.
Toompea, meil on probleem! Ehkki Kaja Kallase lähikond üritab väita, et peaministri välissuhtlust pole idavedude skandaal pärssinud, on Postimees kuluaarivestlustes kuulnud vastupidist. Näiteks käis peaminister oktoobri alguses Hispaanias Granadas Euroopa poliitilise ühenduse ja Euroopa Liidu ülemkogu mitteametlikul kohtumisel.
Sellel kohtumisel osales ka Ukraina president Volodomõr Zelenskõi, kellel õnnestus peale grupipiltide tegemise pidada mitmeid kahepoolseid kohtumisi Euroopa liidritega. Pole kuulda, et Kaja Kallasel oleks õnnestunud pidada teisi kahepoolseid kohtumise peale kohtumise Kosovo presidendi Vjosa Osmaniga. See ei ole väga tavapärane olukord meie peaministrile, kellega on varasematel rahvusvahelistel tippkohtumistel soovinud kahepoolselt kohtuda isegi USA president Joe Biden.
On põhjust märgata, et ka Eestis resideerivat diplomaatilist korpust on vallanud Kallase suhtes mõningane spliin. Kui on juba tekkinud tunne, et peaminister lahkub varem või hiljem Euroopasse või teisele tööle, ei rutta välissuhtlus enam oma aega suhetesse temaga investeerima.
Huvitav on seegi, et Läti uus peaminister pole senini Eestisse jõudnud, ehkki tema valimisest on möödas juba kuu aega.
Tanel, kõik on korras, lihtsalt ülejäänud riikide ladvik pole vele aru saanud, et Kaja pole milleski süüdi ja toimis tegevuse lõpetamine venemaal.
Enne sulgemist tuleb ju rekatega sealt, see hea Eesti õhk tagasi tuua, mis purkides sinna sai viidud.
Ilma purkidetta on seda lihtsam ka vedada, mahub tendi alla rohkem. _________________ ...life is random...so am I...
30 miljonit eurot, mis see ära ei ole.
Ja teiseks, mis isegi tähtsaim, ühest 5-st Venemaa vedude eriloast sai Kallase kaasa, kes sellest abikaasale ei rääkinud sõnagi.
Korruptsiooni pole. _________________ Hinnavaatlus.ee - leia parim hind! HV-s ID-kaardiga autentimine
Postimehes kirjutatakse mingi ajupeeretus millele saab rõõmsalt kaasa plaksutada. Loomulikult tuleb.
Aga tegelikult, mis kahepoolseid kohtumisi Kallas kaotab? Kes kajastab seda teemat peale ühe erakonna ajalehe mis hirmsasti püüab kuid midagi välja ei tule?
https://www.facebook.com/kallaskaja
Kui palju võtab aega, et avada üks lehekülg ja sealt piltidelt saab kogu selle s*ta ümber lükata?
Ok, Ungari tiblad ja idatiblad kiunuvad, kuid see on normaalne. Peavadki.
Miks see pastakast väljaimetud Kaja Kallase teema jätkuvalt päevakorras on?
Kaubavahetus venemaaga ei ole kunagi kedagi väga huvitanud. Miks see teema just praegu aktuaalseks muutus. Milles seisneb täpselt PM süü?
Saan aru, et avaldad Postimehes kirjutatut.
Aga palun vihjet.
Mina ei suutnud leida norra keelset vihjet
Agressorriikidesse saadetakse sanktsioonidealust kaupa ka legaalselt, kasutades üleminekuperioodi või küsides strateegilise kauba vedamiseks eriluba. Erilubasid saab väga harva. Näiteks on sel aastal transiidiks ning importiks ja ekspordiks väljastatud vaid viis eriluba. Pärast täiemahulise sõja algust on üleminekuperioodi õigust kasutanud ka peaministri skandaali kiskunud Stark Logistics.
https://www.washingtonpost.com/business/2023/10/20/forbes-sale-musaev-russia/
Mingi tibladega seotud Musajev ostis Forbesi ära. Eks sealt hakkab varsti mingit kahtlast kraami tulema _________________ M: Intel i5 4590 protsessorid: 10€/tk M: HP Elitedesk 800 G3 SFF: 90€/tk M: HP Elitedesk 800 G2 Mini 35W: 90€/tk
On näha, et koerjumal soovib iga hinna eest vaigistada ja naeruvääristada Kallase kriitikuid, aga võib öelda, et see ei õnnestu tal, klähvigu vihast palju tahab.
Sa ütlesid, et Kallase mees sai.
Ma ei loe seda välja kuskilt.
Kallase mehel on Metaprindis osalus? See muudab ju kõike!! /s
Mõttetu. Tuleb kohe whataboutism, et teised tegid/teevad kaaa... _________________ M: Intel i5 4590 protsessorid: 10€/tk M: HP Elitedesk 800 G3 SFF: 90€/tk M: HP Elitedesk 800 G2 Mini 35W: 90€/tk
Kas Arvo Hallik oli Stark Logisticsi Venemaa-suunalise äriga kursis?
Arvo Halliku strateegiline tugevus on finantsarvestus, M&A (ühinemise ja omandamise) tehingud, mistõttu tema väärtuspakkumine veotegevuse korraldamisel on tagasihoidlik. Selle väljakutse raskus lasus Kristjan Kraagi õlgadel. Loomulikult omaniku ja nõukogu liikmena talle raporteeriti üldiseid mõõdikuid.
Ole hea, loe.
Aga jätkuvalt, kuidas on Kallase mees seotud 30 miljoniga? Kuidas sai Kallase mees mingi eriloa?
ot:
Eks ta ehitab taas mingi õlemehikese, mida siis taguda.
Ise lükkasin ta ignore listi, algul oli isegi natuke naljakas aga lõputult ei jaksa seda sousti lugeda.
Anubise täiskasvanud Pennsylvania avenüül andsid teada, et peale kaltsupeade rünnakut juutide vastu seitsmendal oktoobril pole mingit antisemitismi olnud
