pppd
07.06.2023 10:15:44
Telia müüb online.ee e-posti keskkonna |
Telia müüb online.ee keskkonna ning augustis hakkab seal e-posti teenust pakkuma uus omanik Fjordmail Technologies. Muudatus puudutab näiteks hot.ee ja neti.ee lõpuga meiliaadresse ning nende omanikel soovitatakse juuni-juuli jooksul sinna korra sisse logida.
Muudatus puudutab kõiki @online.ee, @hot.ee, @suhtlus.ee, @neti.ee, @estpak.ee, @solo.ee, @estnet.ee ja @vnet.ee lõpuga e-posti teenuse kontosid.
https://www.err.ee/1609000391/telia-muub-online-ee-e-posti-keskkonna
mi
07.06.2023 10:44:49
https://www.fjordmail.no/online-ee-english/
On the early morning of 8 August 2023, Online.ee will be switching from the old servers to Fjordmail’s servers. As an Online.ee user, this means that the webmail will look a bit different, but your email will continue to work as normal.
You do not have to do anything in relation to this change.
As long as you know your email address and password, you will be able to sign in to the new webmail on 8 August. All your emails will be kept and you can continue using your email as normal.
Please note that by 5 September, you will need to have an active subscription to keep using your Online.ee email. The price for this subscription is €4.99 per month including VAT, and the subscription must be activated between 8 August and 5 September.
More information about the changes will be posted on Online.ee on 8 August. |
"Ei pea" tõesti midagi tegema ... kui just juhuslikult ei taha teenust edasi kasutada...
| Kommentaarid: 23 loe/lisa |
23 |
07.06.2023 10:48:01
Eks siis tuleb oma @estpak.ee aadress hingusele saata.
Olid toredad mitukümmend aastat.
196 |
kevku
07.06.2023 10:52:22
| nüüd pole siis enam ühtegi kodumaist "tasuta" e-maili teenuse pakkujat.
| Kommentaarid: 7 loe/lisa |
Dreamlover
07.06.2023 10:59:38
5€ kuus selle eesr, et meiliaadressi kasutada? Või mis see subscription veel annab?
_________________ ARVUTID
3G1,5/3G2,5/5G1,5/5G2,5 KAABEL
HDD kettad |
| Kommentaarid: 1900 loe/lisa |
1325 |
dx626
07.06.2023 11:01:39
| 22 aastat käigus olnud neti.ee e-maili saab siis maha kanda.
| Kommentaarid: 191 loe/lisa |
155 |
napoleon
Unknown virus
07.06.2023 11:15:23
Ilmselt need keskkonnad vaikselt hääbuvad kui tasuliseks tehakse.
Raha eest peaks mingi lisaväärtuse saama, tasuta e-posti pakkujaid on piisavalt.
| Kommentaarid: 78 loe/lisa |
60 |
Oompa
pppd
07.06.2023 11:49:05
tegelikult on asi ikka suht pekkis, pole jõudnud veel kõiki oma @eesti.ee aadressiga tehtud kontosidki ümber teha, nüüd on vaja ka vanemad @neti.ee ja @hot.ee peale tehtud asjad vaja üle vaadata Viieka eest on võimalik palju mõistlikumat asja teha kui tundmatut norra IT-d toetada.
pois11
07.06.2023 12:54:51
| Jumal tänatud, et 20+ aastat tagasi valinud google.. Pidevalt on mingid sulgemised ja muutused aga google tuli, et jääda.
109 |
napoleon
Unknown virus
07.06.2023 12:59:30
| Kindel on siin elus vaid surm ja maksud. Ma olen rahul, et pole gmaili ega hotmaili kunagi aktiivselt suhtlemiseks kasutanud. Neil on kohati liiga agressiivne spämmifilter mida eriti juhtida ei saa. Võid mõne kirja ju märkida not spam, aga kui järgmine kord samalt saatjalt kiri tuleb, lendab ikka spämmi või ei jõua üldse kohale.
60 |
Dreamlover
07.06.2023 13:03:37
5€ kuus on 60€ aastas.
Selle eest saab enda domeeni regada ja veebimajutuse tellida. Ja tee meiliaadresse, palju süda lustib
HDD kettad |
1325 |
pois11
07.06.2023 13:08:53
| napoleon kirjutas: |
| Kindel on siin elus vaid surm ja maksud. Ma olen rahul, et pole gmaili ega hotmaili kunagi aktiivselt suhtlemiseks kasutanud. Neil on kohati liiga agressiivne spämmifilter mida eriti juhtida ei saa. Võid mõne kirja ju märkida not spam, aga kui järgmine kord samalt saatjalt kiri tuleb, lendab ikka spämmi või ei jõua üldse kohale. |
Aga loo siis filter, et ei teisaldata kunagi mitte ühtegi kirja rämpsposti ja rämpsposti kaust on alati puhas. Või siis filtreeri domeeni järgi. Ühesõnaga ainuke filter mis toimib ongi üldse google oma.
109 |
Forss
07.06.2023 13:09:30
Oma domeen on kõige õigem variant.
Viimasel ajal olen näinud väga palju probleeme Gmaili kontode kinni panemisega ja teha ei ole enam midagi.
Googlega tasuta konto puhul pole väga varianti ka midagi vaidlustada.
Kui kinni juba pandud on, siis kinni ta ka jääb.
Zones ka seletav postitus:
https://www.zone.ee/blogi/2023/06/07/mehed-teie-postkastid-polevad/
pppd
07.06.2023 13:14:45
| pois11 kirjutas: |
| Jumal tänatud, et 20+ aastat tagasi valinud google.. Pidevalt on mingid sulgemised ja muutused aga google tuli, et jääda. |
gmail on poisike, @estpak.ee aadress tuli mul millalgi 90ndatel, kui Larry Page veel ülikoolis käis.
pois11
07.06.2023 13:18:39
| Ma alustasin mail.ee `ga.. siis kolisin ...@starman.ee peale mis kinni pandi. Sellest alates ainult gmail.com. Ma muidugi maksan 25€ aastas ja tarbin ka muid tasulisi teenuseid. Kalkuleerin kuidas tahan, on see siiski kõige odavam ja mugavam lahendus kui hakata zone.ee blogi juttu tõsiselt võtma.
109 |
napoleon
Unknown virus
07.06.2023 13:37:08
| pois11 kirjutas: |
Aga loo siis filter, et ei teisaldata kunagi mitte ühtegi kirja rämpsposti ja rämpsposti kaust on alati puhas. Või siis filtreeri domeeni järgi. Ühesõnaga ainuke filter mis toimib ongi üldse google oma. |
See pole ka hea.
Mul DNSRBL on üsna hea filter mul oma domeenil. Greylist on ka üldiselt tõhus, aga selle kasutamisest loobusin kuna ei viitsinud igasuguseid erandeid konfida.
Aga see eeldab muidugi juba VPSi mitte lihtsalt veebimajutust.
60 |
ummiq
07.06.2023 13:48:10
Ja nüüd avastab keegi äri, et broneerib kiiruga nende vaeste nimeste domeene ja hakkab neid müüma.
Suht p***s teema ikka.. Telia võiks pigem ise raha küsida, mitte anda kellegi lambi meelevaldusesse eestlaste maist virtuaalset vara. Või siis anda tähtaja ja lihtsalt teenuse kinni panna.
Olen suht kindel, et siit tuleb väga palju õnnetuid olukordi välja.
Loodetavasti ei muutu emailid "vabaks", kui neid enam ei kasutata.
_________________ --
Urmas
| Kommentaarid: 214 loe/lisa |
183 |
napoleon
Unknown virus
07.06.2023 13:58:15
| ummiq, oletame et oled see vaene inimene ja broneerin endale sinu domeeni kuna sa ise ei jõua selle eest maksta. Mis minu motiiv selle tegevuse juures oleks? Suure vaheltkasuga seda sulle tagasi müüa ei saa kui sa isegi tavahinda maksta ei jõua. Vaese inimese domeen kedagi teist ka väga ei huvita kuna ilmselt pole tuntud kaubamärk või muidu mingi väga atraktiivne nimi. Mõned isiklikud kirjad saaksin nii endale õngitseda, aga vaevalt needki mingit kolmanda osapoole jaoks põnevat infot sisaldaks.
60 |
Nipi1000
07.06.2023 14:17:30
endal ootab ees suur töö nüüd, vaja hakata emaili muutma erinevates keskkondades(10+). Ei kujuta isegi ette kuidas seda kõike teha, kui nt. kasutajanimi on emaili aadress.
...igaljuhul väga nõme teema
| Kommentaarid: 21 loe/lisa |
20 |
Braien
07.06.2023 14:22:00
Äärmiselt nõme lugu, endal ka konto seal keskkonnas ~20 aastat olnud.
90 |
Prillpapa
Kremli troll
07.06.2023 14:22:08
Ennem kerkib küsimus, mis on selle uue omaniku Fjordmail Technologies motiiv raha eest osta x riigi x teenusepakkuja e-kirja teenuse riismed, et hakata tasuta e-maili teenust edasi pakkuma..
Kas google eeskujul asuda postkasti omanike kirjade sisu analüüsima ja selle pinnalt reklaamifirmadele tulemust müüa või on Fjordmail Technologies-il muid teenuseid mida tasuta e-post peaks tarbima meelitama.
Ei hammusta seda bisnisplaani läbi..
_________________ --- |
| Kommentaarid: 20 loe/lisa |
20 |
Oompa
07.06.2023 14:23:03
Nad ei hakkagi tasuta pakkuma? Nende kogu teenusmudel on kohalikud e-posti pakkujad ära osta ja hakata kuutasu nõudma.
napoleon
Unknown virus
07.06.2023 14:30:14
| Oompa kirjutas: |
| Nad ei hakkagi tasuta pakkuma? Nende kogu teenusmudel on kohalikud e-posti pakkujad ära osta ja hakata kuutasu nõudma. |
Teab kas see ennast tasa ka teenib. Mõni võib-olla nutab ja maksab mõned kuud, aga ilmselt hakkab suurem osa oma asju sealt ära kolima.
60 |
darud
07.06.2023 14:45:21
| Keegi teab võimalust "hot/online" keskkonnast korraga meilide saatmist/tõstmist teisele kontole nt gmailile? Suht palju vajalikke kirjasid tekkinud aastatega.
| Kommentaarid: 51 loe/lisa |
47 |
