24.03.2023 23:30:13
16/3/23
Sony klienditugi vastas:
Hi,
Thank you for contacting PlayStation Support. I'm sorry to hear you've had issues adding a payment card to your account.
Before we go any further, please check if your card is a payment method accepted on the PlayStation Store. You can confirm this on our website at https://www.playstation.com/support/store/payment-methods-accepted-on-ps-store/.
To troubleshoot your issue, I also recommend that you confirm the following:
• Make sure credit/debit card is registered to the same country as the account for PlayStation Network.
• Make sure you're entering the card holder's name exactly as it appears on the card and that the billing address is exactly correct
If you've confirmed that this is all correct, please wait 24 hours without making any attempts to add the card to your account. After this time, please try to add the card again.
Should you continue to experience issues adding the card, please contact your payment provider for further assistance. In the meantime, if you would like to make a purchase from the PlayStation Store we would recommend that you purchase PSN money vouchers as a temporary workaround.
I hope this helps, but if you have any other questions, please contact PlayStation Support, and one of our team will be happy to help.
Thanks,
The PlayStation Support Team
Proovisin täna veel, ei õnnestunud, kuni blokeeriti jälle 24h tunniks.
| There have been too many failed connection attempts. Give it some time and try connecting later. |
Minu panka kahtlustada on muidugi kummaline kui seesama kaart absoluutselt kõigis teistes teenustes töötab
Saatsin vastuse neile, eks näeb siis.
17/3/23
Minu vastus:
Hi,
I have confirmed that my card is accepted payment method on PlayStation Network as it is a VISA card.
My VISA debit card is registered in Ireland, so is my PlayStation Network account. Both in the same country.
I tried to enter my full name as “...”, also “MR ...” as it is on my bank statements.
I did the same with my address. Still no luck.
There is no issue with my payment provider, as the same card works perfectly fine with Amazon, Microsoft Store, Nintendo eShop, eBay etc. With ALL OTHER SERVICES.
Can you please advise.
Thank you
Kind regards
20/3/23
Sony vastus:
Hi,
Thank you for your recent contact with PlayStation support.
I'm sorry to hear that you are experiencing problems registering your credit or debit card on your account. To successfully register card to an account on the PlayStation Network there are a few things you would need to check first.
1 - Make sure the credit/debit card is registered to the same country as the account for PlayStation Network.
2 - Make sure that you are entering the card holders name exactly as it appears on the card.
3 - Make sure that you are entering the billing address exactly as it is on file with the card provider. You may need to double check this with them as there can sometimes be discrepancies in the way addresses are recorded on different databases.
If you are still unable to add the card please contact the card provider directly to check with them if there is any block on their end. This is important even if you are able to register the card on other websites, as a block may be service specific.
If the issue persists and you need to get back in touch please provide the following:
1 - A screen shot of the error message you receive when trying to register your card.
2 - The type of card you are attempting to register.
3 - The platform you are using to register the card (i.e., PS4, PS5, website)
4 - A time stamp for your last attempt to register it (date and exact time).
5 - Confirmation of what the card provider advised when you contacted them.
Once we have this we can investigate further. In the meantime you can continue to use an alternative payment method or wallet top up vouchers on your account. Your case reference number is ... .
Thanks,
Tundub, et nad ei loe üldse, mida klient kirjutab ja korrutavad sama asja, et tülikast kliendist lahti saada
21/3/23
Minu vastus:
Hi,
Thank you for your reply.
1 – My VISA debit was issued in Ireland by Allied Irish Banks. My PSN account is registered to Ireland.
2 – I entered my name correctly as it is on the card.
3 – I entered my billing address correctly as it is on my bank statements.
The issue is still there..
1 – See the attached screenshots
2 – VISA debit
3 – PS5 and PlayStation website
4 – Around 20:35 (on the PlayStation website) and 21:15 (on my PS5 console) Dublin time @ 20/3/2023
5 – I called my bank (AIB) and described my issue. They advised there are no blocks or limitations on my card.
Please advise how to proceed next.
Thank you
Kind regards
24/3/23
Sony vastus:
Hi,
Unfortunately we are unable to see this attempt on our end. Can you please try to add your card again, only from your console this time and then tell us the exact time and date of your attempt?
Thanks,
24/3/23
Minu vastus:
Hi,
I tried to add my card again around 20:03 (Dublin, Ireland time) 24/3/2023
See the attached photo with error message on top.
Thank you
Eks näeb... tahaks jälile jõuda, kus on probleem, tundub, et paljudel see jama (foorumite ja reddit põhjal).
Saaga jätkub...
3/4/23
Minu vastus, kuna Sony ei vastanud eelmisele kirjale:
Hi,
Is there any updates on this case?
Kind regards
4/4/23
Sony vastus:
Hi,
Thank you for contacting PlayStation Support with regards to the payment method.
I have taken a look into your account, and I can confirm that I am not seeing any attempts to add a payment method on our side since the 17th of March. This would indicate that either you are logged into a different account, or you are entering the incorrect details which is why it isn't reaching our systems.
With this in mind, I would advise you to get back in touch with the payment provider to confirm every detail about the card and then attempt to add the payment method again and if you are still having trouble, please provide us a brand new timestamp.
Thanks,
4/4/23
Minu vastus:
Hi,
I’m logged in as ... into PlayStation Store. I tried to add my VISA card again, twice. Timestamps: 4/4/2023 @ 14:26 & 14:29 Dublin, Ireland.
See the error message below from the PlayStation Store website:
I have contacted my bank already and they have confirmed me there are no limitations or blocks at their side.
The same VISA card works fine with my Amazon, eBay, Nintendo and Xbox services.
Kind regards
5/4/23
Sony vastus:
Hi,
Thank you for contacting PlayStation support about your payment issues and I'm sorry about the delay in getting back to you.
I’ve now passed your query on to our specialist team for further investigation.
Just so you know, these types of queries can take a few days to investigate, but we'll email you again with more information as soon as we can.
If you need any help in the meantime, just give one of our team a call and give them your reference number 12913151 on 0203 5382665 (01 691 7379 for ROI) between 10:00 - 18:30 Monday to Friday and one of our team will be happy to assist.
Thanks,
6/4/23
Sony vastus:
Hi,
I've been looking into your case for you - thanks for your patience whilst we did so.
This card has been rejected by your bank/card issuer.
Unfortunately we are never given the reason for the bank's refusal. Common reasons include incorrect expiry date, address incorrect etc. however you will need to contact their bank for further information.
As you have already made several failed attempts we recommend that you wait at least 24 hours before trying again to ensure that you don't trigger also any block from our automated security checks.
If you wish to add funds to your account as soon as possible we recommend that you purchase PSN money vouchers which are available through many major game retailers.
Thanks,
12/4/23
Minu vastus:
Hi,
I tried to add my VISA debit card again today at 16:16 Dublin time. Still no luck.
Also tried to add my Mastercard at 16:34 (issued by N26 bank) and no luck with that either. See the attached screenshots with the error message.
I called my bank today who issued my VISA card and they were able to do a bit of investigating. They told me that Sony PlayStation Store is not using the secure SCA method for online payments, that's why it's getting rejected.
Can you please look further into this if you can use SCA security for card payments as this is a requirement in Europe:
https://www.visa.ie/partner-with-us/payment-technology/strong-customer-authentication.html
Kind regards
20/4/23
Minu vastus:
Hi,
Haven’t heard back from you over a week now.
Would you have any updates in relation to supporting the SCA card payments?
See my previous email below.
Thank you
Kind regards
20/4/23
Sony vastus:
Hi,
Thanks,
22/4/23
Minu vastus:
Hi,
Please see my previous email to you.
My bank has advised me that they are rejecting it because Sony is not using the Strong Customer Authentication (SCA) for card payments in the PlayStation Store, which is mandatory in European Economic Area (EEA).
Will you be updating your card payment system to accommodate European customers?
Kind regards
viimati muutis SKG 22.04.2023 20:02:02, muudetud 5 korda |
313 |
Vael
| Kommentaarid: 17 loe/lisa |
16 |
31.03.2023 16:01:34
| “Even PS2 and PS4 at their peaks never sold in February as much as PS5 just did” |
Kuna eelenavalt polnud sarnaseid saadavusprobleeme, mis hiljem tehisliku rekordi tekitaks?
See rekord on selle arvelt, et eelenavatel aastatel oli halb saadavus ja soovi korral polnud voimalus kohe poest osta.
313 |
Aeron
| Kommentaarid: 72 loe/lisa |
65 |
12.04.2023 19:37:00
Eelmiste mudelite muuginumbriteni on palju maad:
Võttis aega, aga tundub, et sain täna teada, miks Sony PlayStation Store ühtegi pangakaarti ei aktsepteeri. Proovisin täna PS Stores oma Visa ja Mastercardi uuesti lisada - kumbki ei tööta. Helistasin siis juba kolmandat korda panka ja palusin neil väheke rohkem uurida. Pika uurimise peale öeldi, et Sony ei kasuta oma online poes turvalist SCA autentimismeetodit, mida Euroopas nõutakse ja sellepärast ei saa ka kaarte maksevahendina kasutada. Vot siis! Saatsin Sony-le vastuse, et ehk viivad oma maksesüsteemi EEA-ga vastavusse.
| The requirement for SCA for e-commerce will be enforced across most of the EEA from January 1st 2021, and in the UK from September 15th 2021. It is already being enforced for other electronic transactions. |
Kirjavahetus seal: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11251798#11251798
313 |
karlutikas
20.04.2023 10:26:00
| Kuidas uue playstation plus süsteemiga on, kas niiöelda gift card variandina saab ka seda osta? Vaatasin mingites e-poodides ringi, aga aastaseid pakette pakub Essentialile, aga Extra ja Premium varianti nagu ei leidnudki. Essentialiga mingit mängude kollektsiooni kaasa ei saa, kui õigesti aru saan?
| Kommentaarid: 13 loe/lisa |
20.04.2023 11:02:08
Apply gift card funds toward a PlayStation Plus membership.
Step 1: Sign into your account for PlayStation Network (PSN) or create an account at PlayStation.com.
Step 2: Find the 12-digit code on your gift card.
Step 3: Go to Redeem Code on PlayStation Store on your console or at PlayStation.com and enter the code.
Step 4: To purchase a PlayStation Plus membership using the funds from this code, select the membership plan of your choice and complete the purchase. |
Mangude kataloogi ei saa jah, kuid mingid igakuised mangud vist on.
viimati muutis SKG 20.04.2023 11:15:38, muudetud 1 kord |
313 |
renx09
20.04.2023 11:14:46
ma just ostsin aastase Essentiali, mingi väike hittide/klassikute kollektsioon on ikka kaasas, näiteks God of War, Bloodborne, Detroit: Become Human jms, mingi paarkümmend tiitlit vähemalt
_________________ !! |
| Kommentaarid: 315 loe/lisa |
252 |
rixk
| Kommentaarid: 35 loe/lisa |
20.04.2023 11:59:15
| renx09 kirjutas: |
| ma just ostsin aastase Essentiali, mingi väike hittide/klassikute kollektsioon on ikka kaasas, näiteks God of War, Bloodborne, Detroit: Become Human jms, mingi paarkümmend tiitlit vähemalt |
Palju maksis, kas 60 eur voi said soodsamalt?
313 |
renx09
20.04.2023 12:02:56
| SKG kirjutas: |
| renx09 kirjutas: |
Palju maksis, kas 60 eur voi said soodsamalt? |
ei viitsinud mingeid imeasju taga ajada, ostsin 60ga otse ps store-st, Soome regioonis
252 |
26.04.2023 23:00:20
Saaga, mis on juba üle kuu aja kestnud, käib edasi.
Sony näitab näpuga minu panga poole, tegelikult nüüd mõlemi, kuna PlayStation Store ei aktsepteeri ei Iirimaa kohalikku AIB panka ega ka N26 panka. Sony arvates on mõlemad pangad süüdi (blokeerivad PlayStation Store), kuigi nende samade deebetkaartidega töötavad mul absoluutselt kõik muud teenused (Google, Xbox, Nintendo, Amazon, Paypal, eBay etc). Pangad näitavad näpuga Sony suunas, viidates sellele, et vaadates nende error logisid, siis PlayStation Store ei kasuta SCA-ga ühilduvat maksesüsteemi, mis on Euroopas kohustuslik.
26/4/23
Sony vastus:
Hi,
We've been looking into your case for you. Thanks for your patience whilst we did so.
I can advise that our payments system does use SCA, in the form of 3D Secure 2 (3DS2).
We are not receiving widespread reports of similar issues from other users, which we would expect if there was indeed a problem with our payment system and can only reiterate to you that your attempts to add the card are being blocked by your card provider.
You can add funds to your account via PlayStation Network money voucher, or an alternative payment method available in your region.
Thanks,
| We are not receiving widespread reports of similar issues from other users |
Minut Google otsingut näitab, et see vastus on jama. Reddit jm foorumid on selle erroriga teemasi täis.
313 |
beastbeats
18.05.2023 13:10:28
PlayStation strives to create a gaming experience without barriers that fits the needs of players of all abilities.
M: Uus/pakendis Fjern Fjork Titanium Forked Spoon - 10€ |
| Kommentaarid: 366 loe/lisa |
282 |
21.05.2023 17:43:48
| Keegi teab, kas Sony aktsepteerib Revolut kaarti või on samasugune ikaldus nagu kõigi teiste pankadega?
313 |
siven
21.05.2023 18:43:43
| SKG kirjutas: |
| Keegi teab, kas Sony aktsepteerib Revolut kaarti või on samasugune ikaldus nagu kõigi teiste pankadega? |
ei tea millest räägid?
uk PSN ja juba aastaid toimib tavaline SEB kaart paypal Samuti alati toiminud.
149 |
313 |
beastbeats
25.05.2023 14:41:39
PlayStation Showcase 2023 - Accessories Sneak Peek
282 |
S.I.L.L.U
25.05.2023 20:03:59
Mõttetu hardware
Spiderman 2 ja Alan Wake 2 olid ainukesed huvipakkuvad teemad.
| Kommentaarid: 96 loe/lisa |
90 |
heretic666
25.05.2023 20:22:37
Pipart keele peale, Metal Gear Solid 3 remake ka announceti
HW wise ei tundu jah see handheld stream device eriline hitt hakkaks olema
| Kommentaarid: 73 loe/lisa |
d3t
25.05.2023 23:43:31
| heretic666 kirjutas: |
HW wise ei tundu jah see handheld stream device eriline hitt hakkaks olema |
Arvestades, et Sony Remote Play pole Eestis saadaval iOS platformil ja ilma jamamisetta Androidil, siis võib müük üllatada paljudes riikides mis jagavad saatust Eestiga.
_________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
| Kommentaarid: 85 loe/lisa |
72 |
29.05.2023 15:23:02
Kas PSN-is mingi spam filter ka on voi peab Messages seadistuse "Friends Only" peale panema?
313 |
euforia
29.05.2023 16:07:44
| SKG kirjutas: |
| Kas PSN-is mingi spam filter ka on voi peab Messages seadistuse "Friends Only" peale panema? |
Mul vist PSNi algusest peale "Friends Only" peal olnud. Kes väga on tahtnud kontakti saada on sõbraks lisanud. Mingitel suvakatel tavaliselt midagi head öelda ei ole.
Ainuke trikk, kuidas suvalised saavad sõnumi saata, on see kui loovad grupi ja lisavad su, enne grupi kutse vastu võtmist siis juba ilmuvad nende sõnumid, kunagi vihastasin ühe tegelease nii välja, et ta võttis selle vaeva ette, et sõimama hakata. See oli PS4ja peale, võimalik, et nüüdseks muudetud.
| Kommentaarid: 29 loe/lisa |
Laifstaile
29.05.2023 16:54:42
| Report ja blokk
| Kommentaarid: 25 loe/lisa |
24 |
Dj-E
Aeg Maha 2a
29.05.2023 20:43:08
| SKG kirjutas: |
Minut Google otsingut näitab, et see vastus on jama. Reddit jm foorumid on selle erroriga teemasi täis. |
Selles asi ongi, et inimesed lähevad pigem Redditisse kiunuma. Selle asemel, et Sony supportiga ühendust võtta. Niimodi ei jõuagi sama murega inimeste kaebused Sony-ni.
| Kommentaarid: 22 loe/lisa |
21 |
30.05.2023 11:42:18
| Dj-E kirjutas: |
| SKG kirjutas: |
Selles asi ongi, et inimesed lähevad pigem Redditisse kiunuma. Selle asemel, et Sony supportiga ühendust võtta. Niimodi ei jõuagi sama murega inimeste kaebused Sony-ni. |
Ma olen Sony-ga ule 2 kuu kirjavahetuses ja telefonivestlustes olnud, saatsin neile isegi telefonikone salvestused pankadega, korrutavad sama asja - pangad "kiusavad" neid ja blokeerivad Sony tehinguid, mis on naeruvaarne. Molemad pangad on oelnud, et see on levinud probleem Sony-ga, kuna nad ei kasuta piisavat turvalisust (SCA compliant). Nende support on taiesti kasutu selles osas. Seda on mitmed ka Redditis maininud. Eks inimestel ole usk kadunud, minnakse mujale kaebama.
Tegin spetsiaalselt Sony parast nuud omale krediitkaardi ka. Nagu arvata vois - see ei toimi, PS Store ei aktsepteeri.
Mujal tootab probleemideta.
313 |
