sõnum |
17.03.2023 23:35:40
Reolinkil on neile nõuetele vastavaid kaameraid küll. Mul on RLC-510WA.
Teistel tootjatel samuti olemas.
tsitaat: |
New Reolink Client v.8.8.5 - Auto Upgrade Client Feature!🥳
Hi guys!
The Client (PC software) v.8.8.5 is now available! You can download the Client v.8.8.5 now via the Reolink download center: http://bit.ly/3ZSVl5z
What's more! We have turned on the auto upgrade feature for your Reolink Client. We use the grayscale release strategy so that the update time will differ in different regions. Just like the Reolink App, it takes some time to arrive in your Client software.
What's New:
Added update notes on the "About Reolink" page.
Added information security notices.
Added Night Mode Focus Enhancement for RLC-823A 16X.
Added the Image Layout Settings for fisheye cameras.
Added a switch for the doorbell button sound.
Supports Reolink TrackMix LTE Plus + Reolink Solar Panel Plus.
What's Improved:
Improved the logic of switching stream types in live view and playback.
Improved the options in the doorbell status LED setting.
Improved the interfaces of the "Date & Time" page.
Improved filters for recordings: separating smart detection events ("Others") from "Any Motion" events.
Improved display of device status: when the NVR goes offline, its channel name in the device list will go dark.
Linked the pre-alarm function to the switch of the siren: when the siren is off, the pre-alarm function will be automatically off; when the siren is on, the pre-alarm function will be automatically on.
Improved the device initialization process and the WiFi configuration process.
Improved the image display of fisheye cameras FE-P/FE-W: the images of their playback and live view, the thumbnail image of playback, and the image for time-lapse will keep the original ratio.
Improved download function:
When the channel names are the same, the channels will not be merged into one option in the download window.
Even when the channel names are the same, the channels will be shown separately in the download window.
Allows you to select and download recordings by different channels of the camera.
Fixed Other bugs
Thanks😊 |
https://www.facebook.com/groups/reolink/posts/1238294807071060/
_________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..." |
28.03.2023 07:47:29
Lapsetuppa kaamerat vaja. Kallist pole vaja ajutiseks, aga pilt võiks öösel enamähem olla.
Pildi kvaliteet tundub enamusel kole olemat, nii et millist võtta?
Xiaomi c400 tuli välja, kallim kui c200 ja 300, aga äkki natuke parem pilt....60€ võiks selline max hind olla
Mingeid alternatiive sama raha eest?
Aeg maha 1p
28.03.2023 08:20:32
Mul on mingi suvaline ali 15 eurone keeratav ja kallutatav, wifiga. Näitab pimedas rahuldavat pilti
€ 11,49 53%OFF | Original ycc365 1080P Cloud HD IP Camera WiFi Auto Tracking Camera Baby Monitor Night Vision Security Home Surveillance Camera
https://a.aliexpress.com/_mtNTLmQ
_________________ People have been calling for a month and we've been sold out for a week or so.
Janis
28.03.2023 08:21:59
Mul oli 30 eurone c1c selleks
28.03.2023 10:04:36
Janis kirjutas: |
Mul oli 30 eurone c1c selleks |
sinutorust vaadata videot sellest, siis pilt tundub küll väga kehvake....
Võtsin selle c400 ära, eks vaatab mis pilti see näitab.
Asjaga kiire, ali ei sobi tellimiseks
von Wu
04.04.2023 12:23:02
Sai juhtmega IP-kaamerate (DaHua) süsteemi lisatud 3 uut kaamerat jagajaid kasutades. PoE switchist läheb 2 kaablijuppi jagajasse, sealt 1 pikk kaabel teise jagajasse, millest väljub 2 kaablijuppi. Kummagi otsas üks kaamera.
Täna avastasin, et eile oli paljudel kaameratel mingiks ajaks kadunud ühendus salvestiga. Ja mitte ainult jagatud kaabli otsas, vaid ka mitmel teisel. Veateade IPC Offline. Eile lõunast kuni praeguseni on jälle korralikult töötanud.
Kas asi on jagajates või milleski muus? Miks need kaamerad ära kadusid, mis pole jagatud kaabli otsas?
_________________ Müüa 3D-printer
Haruldane Mazda oksjonil: link |
04.04.2023 12:36:34
jeesus188 kirjutas: |
Mingeid alternatiive sama raha eest? |
https://reolink.com/product/e1-zoom/
https://reolink.com/product/e1-pro/
04.04.2023 12:56:27
läks xiaomi juba loosi, sai alustuseks vajalikud asjad tehtud
von Wu
06.04.2023 19:58:52
EZVIZ Wifiga kaamerad. Kes see **** arvas, et on hea mõte, kui kaamera pilti saab vaadata ainult sel juhul, kui wifivõrk on ühendatud internetiga?
Internetita Wifisse ühendada üritades teatab lihtsalt, et ebaõnnestus. Ei sõnagi sellest, miks. Kui pärast ühendamist internet ära võtta, siis õnneks salvestab sisemällu edasi, aga vaadata saab ainult siis kui internet tagasi panna.
Kas Reolink laseb internetita ka vaadata?
07.04.2023 00:36:43
Sisevõrgu IP-ga kaamerale ligi ei lase kui Interneti pole?
elukaz
07.04.2023 01:16:09
Ma vaatan ka välise ip kaudu, ei viitsi kahte aadressi kasutada. Tekib küll ajuvaba ring aga noh, sest saab
von Wu
07.04.2023 21:28:20
SKG kirjutas: |
Sisevõrgu IP-ga kaamerale ligi ei lase kui Interneti pole? |
Nii jah.
new1
22.04.2023 11:10:17
Neid vanu telefone 4tk juba tekkinud, millel ekraanid ämblikud, kuular ei toimi või muud sellised hädad ja vedelevad tühja. Mõtlesin et paneks parklas auto peale vaatama ning leiaks veel mingi rakenduse ühele ja lõpuks viitsisin selle alfred äpiga proovida et kuidas toimiks. Tasuta versioonil see video kvaliteet nii saast, et ei kõlba kuhugile. Tavalise telefoni kaameraga filmides versus see mida läbi selle alfredi võimaldab ei kannata võrrelda. Otseselt mul seda vaja pole sinna ja kuutasu ma küll maksta ei näe pointi. On mõni vabavaraline väpp, mis liikumise peale salvestab normaalselt ja sellise kvaliteediga, nagu telefoni kaamera maksimaalselt võimaldab või tasuta versioonide puhul võib sellest ainult unistada? Ühekordse max paarikümne eurise makse võiksin teha ka äpi eest, need vist seotakse kontoga ja saan hiljem järgmisele telefonile uuesti tasuta alla laadida nagu aru saanud olen, näiteks leafspy pro, ainuke äpp mille eest maksnud olen, see vähemalt on õnnestunud hiljem järgmistesse telefonidesse sedasi alla laadida.
Hiid
06.06.2023 18:47:53
On Reolinki kaamera RLC-510WA
Seni katsetasin WIFI võrgus, salvestas kõvakettale miskiseid faile ja osa SD kaardile. Mis suva järgi, pole veel aru saanud.
Panin siis SD kaardi sisse, tahaks teise metsa viia, aga kuidas ma siis neid faile näen, mis sinna on salvestatud?
WIFIt metsas ju ei ole
Tassin koju iga kord? Või saab teloga kuidagi ka ligi? SKG, tead?
06.06.2023 19:10:40
Teoorias peaks toimima nii, et teed uhe telefoniga wifi hotspoti, kuhu kaamera ja teine telefon uhenduvad, siis saad teise telefoni abil katte.
Teiseks, see kaamera pole sellise asja jaoks moeldud, kus wifi puudub, vaid Go seeria omad, kuhu SIM kaart sisse kaib.
rex
07.06.2023 18:31:52
Või viskad mingi 4G ruuteri kõrvale. Kui Reolink oma nina pilve suudab pista, et sealt kinni hakata, pole fix IP-d vaja.
14.06.2023 20:25:01
Mingi uus mudel, mil vaidetavalt varviline night vision.
https://reolink.com/product/cx410/
elukaz
Janis
16.06.2023 09:41:35
Värviline on siis kui küljes olev lamp põleb. Mul selline paar aastat seinal olnud
18.06.2023 16:31:29
https://fb.watch/leM9ngyBvD/
Hiid
18.06.2023 17:13:54
soovitage jahikaamerat
üks FBs ütles, et VIKERI pidi hea olema
link
pois11
18.06.2023 17:29:58
Hiid kirjutas: |
link |
Mõtle nüüd hästi järgi, 4K 32MB ja 60€... midagi ei klapi. Olen sellist kaamerat seadistanud. Pildi sensor on ehk 1,3MB või siis 3MB eraldusvõimega aga mitte rohkem.
Hiid
18.06.2023 17:59:41
FBs jahikaamerate grupis oli kaamera kraavis, kus kevadepoole Ilves, nüüd karu , kult ja kits.
Kõigil pilt briljantne. See sama tüüp soovitaski.
link
pois11
18.06.2023 18:13:27
Eks see ajab muidugi asja ära aga ise ilma GSM funktsioonita kaamerat küll ei ostaks. Hea ju kaugteel seadistada ja näha mis kaamera juures toimub.
Hiid
18.06.2023 19:21:11
kuhu see GSM oma infi pritsib? Migisse servusse või arvutisse? Või kuda see käib?
