“It’s the first time we’ve publicly stated this,” said associate director for HPC (High Performance Computing) at LLNL, Terri Quinn. In a world-first disclosure in a presentation delivered today to the 79th HPC User Forum at Oak Ridge National Laboratory (ORNL), he added that the information came straight from the source: “I cut these words out of [AMD’s] investors document, and that’s what it says: it’s a 3D chiplet design with AMD CDNA3 GPUs, Zen 4 CPUs, cache memory and HBM chiplets.”
AMD’s MI300 APUs will feature CPU and GPU chiplets in the same 3D-enabled packaging with a coherent, HBM3 memory architecture, powered by the company’s 4th generation Infinity Fabric and next generation Infinity Cache. Leveraging both Zen 4 and the CDNA 3 graphics acceleration architecture, MI300 APUs will leverage TSMC’s 5nm process technology (likely N5 or N5P). However, the balance of CPU and GPU cores per APU is still a wild guess.
The following motherboards have already received the new BIOS which is available from their respective product page:
MOTHERBOARD BIOS VERSION*
MEG X570 GODLIKE E7C34AMS.1I1
MEG X570 ACE E7C35AMS.1J1
MEG X570 Unify E7C35AMS.AE1
MEG X570S ACE MAX A7D50AMS.151
MEG X570S Unify-X MAX A7D51AMS.141
MEG B550 Unify E7D13AMS.171
MEG B550 Unify-X E7D13AMS.A71
MEG B550 Mortar WiFi E7C94AMS.1D1
MEG B550M Mortar E7C94AMS.1D1
Ryzen 5 5600X3D ja/või Ryzen 9 5900X3D tulemas ? Esimene on palju tõenäolisem.
https://www.techpowerup.com/296392/amd-readies-more-ryzen-5000x3d-processors
Samas artiklis ka veel huvitavaid spekualtsioone: AMD could develop certain "Zen 4" SKUs on the AM4 package, which sees a "Zen 4" CCD paired with a current-gen cIOD that has DDR4 and PCIe Gen 4 connectivity
Ausaltöelda oleks 5950X3D ka AM4 jaoks päris huvitav.
5950X tuumad on juba niigi all core loadi ajal tõsises voolunäljas AM4 peal. Kui nüüd suur kärakas cache sealt mõnikümend vatti veel ära sööb, siis enamus rakendustes kukub all core perf madala takti pärast pepupli.
Arvestades kuidas 5950x curve optimizeriga saab voolutarvet maha võtta ja 1T/nT jõudlust kasvatada siis ma arvan, et AMD suudaks praegusel hetkel neid kive piisavalt binnida.
Mul on 5950x suht algusest peale olnud ja kannatab korralikult, ühetuuma koormusel käib 5,05-5,15Ghz. NH-D15 jahutab.
AMD Ryzen Threadripper PRO 5995WX SEP is $6,499
AMD Ryzen Threadripper PRO 5975WX SEP is $3,299
AMD Ryzen Threadripper PRO 5965WX SEP is $2,399
Milking Mode=On
Mis pole ka üllatav konkurentsi puudumise tõttu. Kahjuks see tähendab, et HEDT on pmst serveri hindadega. Nii võib endale jalga tulistada, sest kui TR ja Epyc hinnad nii sarnased on, siis miks peaks keegi nuditud TR valima kus ainus eelis on OC tugi?
Mingid Extreme OC tüübid ainult ostaksid siis. Kahju. TR oli hea toode aga AMD on selle oma ahnusega pmst tapnud.
Juba varem olid TR müüginumbrid ~1% koguhulgast (mindfactory.de andmed). Nüüd kukub see ilmselt 0,01% peale.
Pmst kui sa 3D artist pole kes kasutab Studio Draivereid või lausa Quadro või muud spetsiifilist riistvara mis sertifitseeritud ja fine tuned töötama tarkvaraga siis vist oleks Epic isegi mõistlikum kui lihtsalt jõudlust vaja on. On tunda, et AMD ei tunneta konkurentsi, sest Intel polegi siiamaani oma analoogi uuendanud... _________________ IsAiUseful.com - tee oma esimesed sammud kohaliku AI suunas
Jah. Aga threadripperid on ikka väga spetsiifilises sektoris väga nõutud asjad. Nad on nõus maksma ja AMD on nõus neile tarnima toote.
Ma mingi hetk entusiastina mõtlesin ka, et ehitan TR aga siis tuli 3950x ja 5950x ning ausalt, rohkem ei ole vaja. See 5950x on ikka jõhker püss, jätkuvalt.
Overclocking the AMD Ryzen Threadripper 5990X 64-core processor up to 4825 MHz with the ASUS ROG Zenith II Extreme Alpha motherboard and EK-Quantum custom loop water cooling. Shatters 100,000 Points In Cinebench R23 & Achieves 80% Performance Uplift Versus Stock Chip.
Paistab, et 5600x jääb 6800xtle jalgu.
BF42Hz kunub FPS 160lt 100 peale.
Hullem on olukord NFS HEATs, kus FPS teeb sama triki, aga tunnetus on hullem, kakub tuntavamalt. Samuti on 70% peal CPU kasutus. Lükkasin küll graafikat high-Ultra pealt, ainult Ultra peale, aga poleks oodanud, et selline prose pudelikael ikka ees...1440p peal.
https://www.techpowerup.com/296863/alleged-6-core-ryzen-7000-series-tested-in-basemarks-gpu-rendering-tests The first test is an OpenGL test where the 6-core CPU beats the 16-core CPU by a not insignificant 9.5 percent overall, but by more than 11 percent when it comes to the minimum frame rate in the benchmark.
Engineering samplid jooksevad tavaliselt madalal taktil ja mitte kõige optimaalsema firmware peal. ES ja 6 tuuma kohta hea tulemus.
Edit
https://www.tomshardware.com/news/amd-ryzen-5-7600x-single-core-benchmarks
ES kohta pole paha, sealt peaks veel takti juurde tulema
The Ryzen 5 7600X delivered up to 22% higher single-core performance than the Core i9-12900K. Compared with the Core i5-12600K, the unannounced Ryzen 5 7600X outpaced the Intel chip by 27%. Furthermore, if we look at a generation-over-generation comparison, the Ryzen 5 7600X posted 56% higher single-core performance than the Ryzen 5 5600X.
SKG, Kõige täpsem muudatuste logi on sinu emaplaadi tootja kodukal BIOS sektsioonis.
AMD ise minuteada AGESA changelogi ei väljasta, kuna tavakasutaja ei saa nullist omale mingi AGESA versiooni pealt BIOS-t kokku lasta. Kuna see on mõeldud emaplaaditootjatele, siis nad ilmselt ei pea vajalikuks seda avalikustada lõpptarbijatele.
1.2.0.3 ja 1.2.0.7 vahel on palju muudatusi olnud.
Enda emaplaadi põhjal midagi sellist:
Update AMD AGESA V2 1.2.0.7
Update AMD AGESA V2 1.2.0.6 B for Ryzen 7 5800X3D support
Reappear the option of Max CPU Boost Clock Override for Vermeer
Major vulnerabilities updates, customers are strongly encouraged to update to this release at the earliest.
Credits to "Assaf Carlsbad and Itai Liba from SentinelOne"
Introduce capsule BIOS support starting this version.
Update AGESA ComboV2 1.2.0.5
Change default status of AMD PSP fTPM to Enabled for addressing basic Windows 11 requirements https://support.microsoft.com/windows/1fd5a332-360d-4f46-a1e7-ae6b0c90645c
Update AMD AGESA ComboV2 1.2.0.3 B for Ryzen 5000 G-Series processors support
Minul näiteks on 03 ja 07 vahel lisatud 5000G ja 5800X3D tugi. fTPM on vaikimisi sisse lülitatud. Parandatud fTPM stutter probleem ja parandatud turvaprobleeme.
Samas emaplaaditootjad ei väljasta kõiki AGESA versioone. Üsna tavaline on mingid versioonid vahele jätta ja uuema peale hüpata vms. _________________ Win11 upgrade skriptid neile kelle masin ise ei taha 23H2, 24H2 või 25H2 pealt ennast uuendada: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738
Pakutakse, et vähemalt 299 peale peaks kukkuma kui 7700X tuleb välja 299 peal sama tuumade arvu aga parema IPC-ga (küll väiksema L3 puhvriga).
See oleks päris suur hinnalangus 450 pealt 300 peale. Lisaks saavad AM4 omanikud mingi raha tagasi ka oma eelneva prose müügist seega see pole päris nii, et kogu see summa tuleb kuludesse kanda. _________________ Win11 upgrade skriptid neile kelle masin ise ei taha 23H2, 24H2 või 25H2 pealt ennast uuendada: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738
Üsna tõenäoline on, et võtan 7950x launchipäeval või saadavuse tekkimisel MSRP lähedase hinnaga.
Sai sama tehtud 3950x ja 5950x launchil ning mõlemad on olnud korralikud tööloomad, 5950x samas kuskil jalgu ei jää veel niiet ehk kannatab seekord oodata.
Lihtsalt huvi pärast millega tegelete mis pidevalt sellist arvutivõimsust vajab.
Foorumist jääb mulje, et valdav enamus upitab oma riistvara meelelahutuslikel eesmärkidel, a'la mängurid, kuigi vanakooli mehed teadvat rääkida, kus ka 90-ndatel, misaja riistvara-mängud tänapäevasega ei kannata võrdlust, olevat toonastest mängudest mitte vähem emotsiooni-naudingut saadud.
Vahetasin sügisel oma 5 aastat vana tööarvuti uuema vastu - tööjõudluses vahet ei märganud. Ainuke suurem märgatav vahe on, kui andmeid varundan ja neid kokku zip-in.
Samamoodi üks tuttav arhitekt, kes oma töid aegajalt 3D renderdab nö kunde jaoks ja arendajale reklaamiks ilupilte teeb, tunnistas kus alati uus arvuti teeb küll märgatavalt kiiremini neid renderdusi aga töökorraldus olevat ikkagi endine, kus tema arvuti kõrval neid renderdusi ei oota, las masin rassib kui endal uneaeg ja ei olevat vahet kas vana renderdas 6 tundi ja uus 2 tundi - hommikuks on ikka valmis. Ometi mingi x aastate tagant tulevat riistvara välja vahetada. _________________ ---
Eeldan, et suht sarnased hinnad tulevad. Loodetavasti Inteli poolne surve hoiab vähemalt ära suure hinnatõusu.
Mis surve, Alder Lake'st - 5% kiirem Raptor Lake ve?
Intel alustas hinnasõda ja kukkus omadega viimane kvartal kahjumisse. Samas on nad lubanud (üllatus üllatus eks) prose hindasi ca 20% tõsta. IMHO 7000 seeria launchi hinnad tunduvad igati mõistlikud vaadates lekkinud benche. AM5 emmed + DDR5 on pigem kohad kus raha tuleb rohkem välja käia.
AM5 emaplaatide hinnad sõltuvad pigem ikka tootjatest endist. X670E on odavam kiibistik kui X570. Samas inflatsiooni tõttu võivad olla kallinenud teised komponendid mis emaplaadile lähevad. DDR5 pikemas plaanis ikka langeb. Kui panna sinna juurde AMD prosede parem efektiivsus (väiksem voolukulu) siis ei saa välistada, et AM5 platvorm on nii odavam kui ka energiasäästlikum. Kindlasti räägib AM5 kasuks see, et erinevalt Inteli 700 seeria plaatidest mis peale Raptor Lake enam midagi ei toeta saab AM5 miinimum veel Zen4, Zen 4 X3D, Zen5 ja Zen5 X3D uuendused. Kuna AMD on olnud kahtlaselt vaikne selles osas, siis Zen6 enam ei loodaks AM5 peale aga see on ka 2025+ aasta toode alles seega sinna on kolm aastat aega. _________________ Win11 upgrade skriptid neile kelle masin ise ei taha 23H2, 24H2 või 25H2 pealt ennast uuendada: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738
anubis, Pigem jah on AM5 pikaealisus seotud DDR5-ga. Kui DDR6 tuleb, siis tuleb ka ilmselt uus socket.
Hetkeinfo on, et see on arenduses aga standard saab 1.0 versiooni alles 2024 mis tähendab, et tooteid ei näe enne 2025-2026. 13000-17000 kiirused ja 4x 16bit kanalit per pulk (vs 2x 32bit DDR5 peal ja 1x 64bit DDR4 peal).
Seega Zen6 võibolla napilt veel mahub AM5 peale.
Pigem AMD ei ole hetkel konkreetselt öelnud mis aastani nad AM5 toetavad. Võibolla tahavad lihtsalt jätta endale taganemistee juhul kui enne DDR6 tulekut mingil põhjusel ühilduvus siiski murtakse.
ot:
Muide Zen6 koodnimi on Venice. Toob mälestusi: https://en.wikipedia.org/wiki/Athlon_64#Venice_(90_nm_SOI)
Kuigi minu esimene prose üldse oli hoopis OEM kastis Sempron 64 3000+ (Palermo) ja siis Athlon 64 X2 (Manchester). Tollal kahetuumalist omada oli kõva sõna. Mäletan, et kooli kõrvalt tööd tehes ja vanematelt taskurahaks saaduna käisin välja 18000 EEK Athlon X2 3800+, 2GB RAM (OCZ DDR-400) ja 7900GTX eest. Vist oli ka WD Raptor boot kettaks. Hinnad on muidugi kõvasti tõusnud. Tänasel päeval teeks see 1150€ mille eest ei saa tipp proset, OC RAM ja tippkaarti. Pigem kas emaplaadi, prose ja RAM või siis ainult tippkaardi.
Terv.
Kui on int graafikaga G seeria prose (mul 5650G "Cezanne"), kas seljuhul läheb PCIe slotist osa raisku/maha arvamisele? Ma ei saa soovi korral kaht x8 PCIe kaarti panna?
Mida peetakse silmas siin tsitaadi viimases reas "Flexible PCIe"... mingi jagatud PCIe värk ve?
Vaatasin plate andmeid mille foorumist soetasin, aga pole veel ksutusse võtnud ja prose ka juba olemas.
ASRock X470 Taichi https://www.asrock.com/mb/AMD/X470%20Taichi/index.asp#Specification
AMD Ryzen series CPUs (Vermeer, Cezanne, Renoir, Matisse, Summit Ridge and Pinnacle Ridge)
- 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE1); dual at x8 (PCIE1) / x8 (PCIE3))*
AMD Ryzen series CPUs (Picasso, Raven Ridge)
- 1 x PCI Express 3.0 x16 Slot (single at x8 (PCIE1))*
AMD Athlon series CPUs
- 1 x PCI Express 3.0 x16 Slot (single at x4 (PCIE1))*
Longero, Ma peast hetkel ei mäleta aga Cezanne vist ikka lubab 16 rida esimesse slotti. Muidugi piiratud 3.0 kiirusele.
Seda kas emaplaat teeb 2x8 bifuricationit sõltib juba platest endast. See eeldab, et on olemas kaks x16 füüsilist slotti mille saab bifuricatoniga jaotada 2x8 elektriliseks. Muidu jooksevad x16 elektriline ja x4 elektriline kiibistikust vms.
Kirjelduse järgi peaks see plate toetama jaotamist 2x 8 peale, et SLOT_1 ja SLOT_3 jookseksid Gen3 x8 kiirusel. Lihtsalt ma ei tea kas selle jaoks on BIOS säte või lülitub see automaatselt ümber kui mõlemasse slotti panna x8 seade. _________________ Win11 upgrade skriptid neile kelle masin ise ei taha 23H2, 24H2 või 25H2 pealt ennast uuendada: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738
Ma lihtsalt jäin mõtlema, et kusagilt peab ju graafika tugi tulema ja äkki piiratakse PCIe slotte. Plaan mingiaeg kokku panna esimene TrueNas ja sobivusel ning hilisemal täiendamisel jääks x8 võrgukaardile ning x8 ketaste HBA kaardile.
Kui ei NAS ei sobi siis läheb lihtsalt win peale.
Longero, Cezanne (APU) osas piiratakse hetkel PCIe kiirust. kõik APU'd on 3.0 kiirusega.
Teine suurem erinevus on see, et APU omab poole vähem L3 puhvrit mis mõjutab peamiselt mängude jõudlust.
Njah ET ehk Easter Time peaks olema GMT-4 ja meil suveaeg GMT+3, seega alles effin 2 öösel. AMD võinuks mingi counteri tuubi või kusagile tiksuma panna ikka.
https://greenwichmeantime.com/time/to/eastern-local/
AMD Ryzen 9 7950X - $699 US
AMD Ryzen 9 7900X - $549 US
AMD Ryzen 7 7700X - $399 US
AMD Ryzen 5 7600X - $299 US
15.09: CPU preorder
27.09: X670 & X670E emaplaadid ja CPU shipping
10.10: B650 & B650E emaplaadid
AMD Ryzen 'Zen 4' Desktop CPU Features:
Up To 16 Zen 4 Cores and 32 Threads
+29% Performance Uplift In Single-Threaded Apps
Brand New Zen 4 CPU Cores (IPC / Architectural Improvements)
Brand New TSMC 5nm process node with 6nm IOD
25% Performance Per Watt Improvement Vs Zen 3
>35% Overall Performance Improvement Vs Zen 3
~13% Instructions Per Clock (IPC) Improvement Vs Zen 3
Support on AM5 Platform With LGA1718 Socket
New X670E, X670, B650E, B650 Motherboards
Dual-Channel DDR5 Memory Support
Up To DDR5-5600 Native (JEDEC) Speeds
28 PCIe Lanes (CPU Exclusive)
105-120W TDPs (Upper Bound Range ~170W)
+62% perf aga +47% efficiency vs 12900k tunduski kahtlane. aga 170w ja ilmselt siis 230w power limit seletaks seda päris hästi. hilisem slaid ütleb up to 230w socket power delivery, nii et jah.
7600x/7700x 105w tdp
7900x/7950x 170w tdp
5000-seeriaga sama kõrgema hinnataseme kinnistamine on päh.
avx-512 oli mõttetu räni raiskamine nagu ma mäletan. _________________ - londiste
AM5 on toetatud kuni 2025+
See kinnitab, et Zen4 ja Zen5 on AM5. Tõenäoliselt ka Zen6.
Pakun, et uus socket tuleb koos DDR6-ga 2026 kõige varasemalt.
Muidugi kiibistikud tulevad iga Zen väljalaskega uued ja seal võib esineda ühilduvusprobleeme. Kas Oktoobris kuu launchitav B650 toetab 2025-2026 launchitavat Zen 6? Kahtlane.
Samas erinevalt AM4 ja B350-st on emaplaadid seekord algusest peale paremini ehitatud. Peaasi, et mõni tootja ei koonerda ja ei kasuta 16MB BIOS kivi kuhu uute prosede tugi ära ei mahu.
Kui suudetakse isegi B650 peal toetada PCI 5.0, siis ei tohiks probleem olla ka 32MB BIOS kivi.
Erinevalt Intelist kus Raptor Lake jääb praeguse socketi viimaseks ja Meteor Lake nõuab jälle uut socketit.
7600X value pole mudugi eriti hea. 300 prose + miinimnum 125 B650 plate ja 100+ DDR5.
7700X tundub suht mõttetu 399 juures. Mõistlikum siis juba 7800X3D ära oodata kui see tuleb eeldatavasti 450 hinnaga (Q1 2023) või panna 150 juurde ja võtta 7900X.
7950X @ 699 on tegelikult odavam kui 3950X ja 5950X olid. Siin on kindlasti Inteli poolne surve abiks.
Samamoodi on ka Inteli 13-s põlvkond kohe-kohe tulemas, 2 aastat tagasi polnud Intelil millegi erilisega hiilata, hetke leakide järgi paistab Intel oma veast õppinud olema. Kasutajatele see hea, AMD on näidanud, et kui konkurentsi pole, siis pannakse hind tuimalt väga kõrge. Soodsamaid protsessoreid, kui 2a tagasi ei pruugi siiski tulla, sest dollar on vahepeal tunduvalt tugevamaks läinud. Kuna uus socket nagunii tuleb, siis veel passin ja mõtlen kas minna inteli leeri üle või jääda AMD peale. Eks reviewd näitavad palju üldse 4K peal vahet on uued prosed vs 5900x.
Ühele kliendile paigaldatud ja suht vähest kasutust saanud Auros Master X570 v1.2 emaplaat andis saba. Vilgutas ainult CMOS tulukest, netist googeldades polnud ma sugugi ainus, kes neid tulukesi näinud. Eks näis kaua nüüd garantiis on emaplaat. _________________ Laptopid.ee Suur sülearvutite salong, kohapeal 200+ sülearvutit, HV kasutajale 5-10% läpparilt alla!
Võiks mingi küsitluse teha nagu tavaliselt on olnud, kes plaanib uuendada, mis CPU vms.
Minul sellist kihelust ei ole nagu eelmisel korral (X3D mudeliteni on ka veel aega) ja, kus lõpuks jäin üldse oma esialgsest ostust ilma (müüdi rohkem, kui reaalselt tarnida suudeti) ning pidin üle poole aasta uut CPU-d ootama, ent sain 5900X juba enam-vähem normaalse hinnaga. Pigem ootan ja vaatan, mida Intel AMD-le vastuseks toob (ühe kindla brändi kummardaja ma ei ole).
