uus teema   vasta Hinnavaatlus »  Vaba Mikrofon »  Meditsiinivaatlus (vaimne ja füüsiline tervis) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 271, 272, 273 ... 313, 314, 315  järgmine
Kuidas pooldaksid kanepi legaliseerimist Eestis?
Pooldaksin meditsiinilistel põhjustel kasutamist
17%
 17%  [ 53 ]
Pooldan täielikku legaliseerimist
36%
 36%  [ 107 ]
Ei poolda
33%
 33%  [ 99 ]
Olen erapooletu
12%
 12%  [ 36 ]
hääli kokku : 295
sõnum 06.04.2022 22:17:32 vasta tsitaadiga
netcat kirjutas:
https://tervis.postimees.ee/7494554/prantsuse-uuringus-tuvastati-seni-kusimargi-all-olnud-vahi-riskitegur
Võrreldes magusainete mittetarvitajatega oli erinevaid magusaineid enam tarvitajatel suurem üldine vähirisk. Eelkõige seostus suurenenud vähiriskiga aspartaami ja atsesulfaam K kasutamine. Suuremat rinnavähi riski täheldati seoses aspartaami kasutamisega. Rasvumisega seotud vähkide risk oli seotud kunstlike magusainete üldkogusega ja eraldi aspartaamiga.
New study finds association of artificial sweeteners (AS) with cancer (PMID: 35324894)
I read the study & here are my thoughts: BIG FREAKIN WHOOP
You know what else is correlated to cancer? Eating ANYTHING at ANYTIME (PMID: 21520042) & the risk increase was twice as high (relative risk increase of 28% vs 13% in this study)
This is a correlation study which can be useful to ask questions but DOES NOT prove causality. You know what else is correlated way more tightly? The spending on science, space, & technology with suicides by hanging, strangulation, & suffocation… a near perfect correlation of 0.996 (1.0 is perfect). If you want to find something to correlate to something else, you typically can if you torture the data enough
In this study people who consumed AS were more likely to smoke, have diabetes, exercise less, eat less fiber, have a great BMI & a whole host of confounding variables. The researchers did attempt to correct for these but you can’t truly correct for all these confounders. Even so, several of the statistical correlations became non-significant when the models attempted to correct for these
Another thing that seemed odd was that while consumers of AS had higher risk of cancer than non-consumers, they also separated the consumers into high & low consumers. Oddly, in nearly every case, the risk increase of cancer was slightly greater in the LOW CONSUMERS of AS compared to the high consumers of AS. If AS are causing cancer how can you possibly explain that? Wouldn’t we expect to see at least some increase in risk in high consumers compared to low? But we actually see a slight decrease in risk despite high consumers consuming several times greater intake of AS than the low consumers
Moreover, they neglected to highlight that sucralose was NOT associated with any cancers
Finally, artificial sweeteners have been shown to help reduce body fat when used in place of sugar or even in place of water (presumably due to increased satiety) & helps prevent weight regain in HUMAN RANDOMIZED CONTROL TRIALS (PMID: 26708700). Excess body fat is far greater cancer risk (relative risk increase of upwards of 150% to 450%. Compare that to a piddly 13% that I don’t even think matters
https://fb.watch/cdDC6krklP/
Markos
sõnum 07.04.2022 13:36:22 vasta tsitaadiga
https://objektiiv.ee/seitse-tosist-argumenti-kohustusliku-vaktsineerimise-vastu/?fbclid=IwAR1BaE246dP3V3LsYxcWBXerhdCcpaLmmBtCEPuwHJAsWyJnW2vLllAEi_g
netcat
netcat
sõnum 07.04.2022 14:12:32 vasta tsitaadiga
Miks on see tõsiselt isegi üldse teema? Mingit kohustuslikku vaktsineerimist ju ei ole?
sõnum 07.04.2022 14:21:41 vasta tsitaadiga
netcat kirjutas:
raxz
sõnum 07.04.2022 14:57:17 vasta tsitaadiga
Kuidas teada, et inimene on oma eluga täiesti põhjas?
Ta jagab uueduudised ja objektiivi artikleid.
KillFrenzy
KillFrenzy
sõnum 07.04.2022 15:12:11 vasta tsitaadiga
raxz kirjutas:
napoleon
Unknown virus
napoleon
sõnum 07.04.2022 15:27:26 vasta tsitaadiga
netcat kirjutas:
See on demagoogia. Sisuliselt ikka sama hala, et miks seda passi nõutakse kui inimene ennast nagunii vaktsineerida ei kavatse. Aga asja peab natuke üle võlli keerama, et oma demagoogiale kaalu anda.
sõnum 19.04.2022 00:25:13 vasta tsitaadiga
An mRNA vaccine boost may help CAR T-therapy treat solid cancers
https://www.statnews.com/2022/04/10/mrna-vaccine-boost-may-help-car-t-therapy-treat-solid-cancers/
While CAR T-therapy has cured some people with blood cancers, this form of immunotherapy has so far produced lackluster results for solid tumors like lung or kidney cancer. But a new early-phase clinical trial presented on Sunday at the American Association of Cancer Research (AACR) conference suggests that CAR T-cells may be able to shrink some solid tumors — as long as it gets a boost from an mRNA vaccine from BioNTech.
The new treatment from BioNTech requires a two-stage process. First, a patient is infused with CAR T-cells that can recognize and attack the cancer. A few days later the patient is given the mRNA vaccine, which carries the genetic code for claudin-6. The idea is that immune cells known as antigen-presenting cells will take up the vaccine, produce claudin-6, and then present the protein to the CAR T-cells circulating in the body. That will trigger the engineered T-cells to begin proliferating and producing cytotoxic compounds that can kill cancer cells.
There has been a belief that drinking small to moderate amounts of alcohol might provide a benefit to the cardiovascular system. Unfortunately for believers in that myth, new powerful scientific evidence debunks it.
https://www.skepticalraptor.com/skepticalraptorblog.php/powerful-study-shows-cardiovascular-risk-from-drinking-alcohol/
napoleon
Unknown virus
napoleon
sõnum 02.05.2022 16:21:43 vasta tsitaadiga
Võib-olla natuke vale teema, aga kas siis psühholoogiahuvilisi on?
Tekkis üks huvitav küsimus. Mille järgi me inimesi ära tunneme? AI vaatab ilmselt silmadevahelist kaugust, nina kuju, propotsioone vms. Aga kui sööta AI-le ette mingi karikatuur, siis ajaks see AI ilmselt segadusse. Inimene jälle saab aru, kellega tegemist on. Karikatuuri puhul on ilmselt muidugi mingi osa ka kontekstil. Aga võib teemat pisut laiendada ja vaadata ka näiteks multifilme. Kahel jalal kõndiv koer või kass, kellel on isegi ülajäsemed sellised, et meenutavad pigem inimese oma ja üldse kui detailselt analüüsida, siis puht objektiivselt nagu pole eriti koera/kassi sarnane. Aga ometi saame aru, mis loom see on isegi kui otsest konteksti pole ehk mingid kummalised seosed inimese aju suudab tekitada.
netcat
netcat
sõnum 02.05.2022 18:21:56 vasta tsitaadiga
Ei saand päris hästi küsimusest aru. Sa mõtled, mille järgi me aru saame, kas see on päris inimene, AHV või mingi puuslik? Või mida?
Ma olen küll näinud nii halvasti joonistatud "karikatuurseid" kasse, koeri ja muid loomi, et raske on aru saada mis elukas see peab olema.
Ja masina jaoks, mis kontekstist midagi ei tea, on asi veel raskem. Masin töötab ainult selle pealt, mis talle õpetatud on. Kui sa näitad masinale miljon korda miki-hiirt ja ütled, et see on inimene, siis järgmine kord ta liigitab miki-hiire inimeseks.
https://www.nytimes.com/2021/09/03/technology/facebook-ai-race-primates.html
https://eu.usatoday.com/story/tech/2015/07/01/google-apologizes-after-photos-identify-black-people-as-gorillas/29567465/
Kui kõik asjad, mille kohta sulle on näidatud silti "inimese näod" on olnud valged, siis, nojah, musta sihverplaadi korral peab ju otsima mingi muu vaste mis paremini sobib.
Siin on kuidas õpetada masinat kassidel ja koertel vahet tegema.
https://machinelearningmastery.com/how-to-develop-a-convolutional-neural-network-to-classify-photos-of-dogs-and-cats/
Aga tagasi inimese juurde. Ma arvan, et inimest aitab inimeseks liigitada see, kui ta on inimese suurune, inimese kujuline ja liigub nagu inimene. Näiteks kui üldse ei liiguta, võib tegu olla kuju või laibaga. Kui liigub kummaliselt, võib tegu olla zombi või robotiga. Kui on liiga väike, siis on päkapikk või härjapõlvlane, aga kui liiga suur, siis on hiiglane. Ja mis kujusse puutub, siis see muidugi varieerub kõige rohkem, aga mõned puuduolevad jupid ilmselt ei sega, samas kui neid on harjumuspärasest rohkem, nt 2 pead või 6 jalga siis vist inimeste sekka asja ei ole.
napoleon
Unknown virus
napoleon
sõnum 02.05.2022 18:28:29 vasta tsitaadiga
netcat, ma mõtlesin pigem, et kuidas konkreetse inimese ära tunneme mitte lihtsalt tuvastamist, et tegemist on inimesega. See loomade teema oli lihtsalt llustreerimiseks.
Markos
sõnum 02.05.2022 19:42:13 vasta tsitaadiga
napoleon kirjutas:
Nägemismälu, mõnel on see paremini arenenud, suisa fotograafiline, teine jätab meelde mingisugused võtmedetailid ja siis tuletab. AI jaoks ei oe niipalju informatsiooni vaja, seal talletatakse ja hiljem võrreldakse vaid olulisi parameetrid, et andmehulka ja töötluskiirust kontrolli all hoida. Lisaks näeb masin mõningaid asju ka paremini, kui inimsilm.
sõnum 06.05.2022 23:02:00 vasta tsitaadiga
SKG kirjutas:
SKG kirjutas:
In a First, Man Receives a Heart From a Genetically Altered Pig
The breakthrough may lead one day to new supplies of animal organs for transplant into human patients.
link
Update (March 9): Transplant recipient David Bennett died yesterday, two months after his surgery, the University of Maryland Medical Center has announced. According to the university’s statement, the transplanted pig heart performed well for several weeks after the surgery with no signs of rejection, but Bennett's condition began deteriorating several days ago. “We remain optimistic and plan on continuing our work in future clinical trials,” surgeon Muhammad Mohiuddin says in the statement.
https://www.the-scientist.com/news-opinion/man-receives-transplanted-heart-from-genetically-modified-pig-69600
Vot siis...
Update (May 5): MIT Technology Review reports that the heart David Bennett received was infected with porcine cytomegalovirus, a factor that may have contributed to his death.
napoleon
Unknown virus
napoleon
sõnum 07.05.2022 16:49:37 vasta tsitaadiga
Lugesin ilukirjandust kus teema keerles selle ümber, et inimesel oli mälukaotus nii, et ei mäletanud isegi oma nime ega mitte midagi oma varasemast elust. Aga huvitaval kombel oskas rääkida, arvutada, autot juhtida jms. Eks sarnast stsenaariumi ole ka filmides erievate nurkade all vahel kohanud.
Aga kas selline valikuline mälukaotus on reaalselt ka võimalik et ei mäleta isegi kõige lähedasemaid inimesi, aga samas koolis õpitu on ilusti meeles?
sõnum 07.05.2022 17:05:02 vasta tsitaadiga
Jah, eri tuupi malestused. On voimalik, on olnud juhtumeid.
Unsolved Mysteries on mitut juhtumist kasitlenud, mul ei ole tapseid episoode hetkel anda.
https://www.imdb.com/title/tt0094574/
https://en.wikipedia.org/wiki/Unsolved_Mysteries
napoleon
Unknown virus
napoleon
sõnum 07.05.2022 17:15:42 vasta tsitaadiga
mkay, peab millalgi natuke aja maha võtma ja vaatama, paistab päris põnev vaatamine
sõnum 07.05.2022 17:35:34 vasta tsitaadiga
ot:
Seal on omajagu jura ka.. "vaimud", ufod jms, need ma olen skippinud.
5. hooaeg kasil hetkel.
sõnum 07.05.2022 21:08:30 vasta tsitaadiga
Ufod on väga huvitav teema beer_yum.gif peab tsekkama
sõnum 07.05.2022 22:30:40 vasta tsitaadiga
Porcine Virus May Have Led to the Death of First-Ever Pig Heart Transplant Patient
Doctors say this infection will likely be preventable in future pig heart transplants
https://www.smithsonianmag.com/smart-news/porcine-virus-may-have-led-to-the-death-of-first-ever-pig-heart-transplant-patient-180980042/
“We are beginning to learn why he passed on,” Dr. Griffith reportedly said in the webinar, “[the virus] maybe was the actor, or could be the actor, that set this whole thing off…If this was an infection, we can likely prevent it in the future.”
The donor pig was raised by the biotech company Revivicor, reports the New York Times’ Roni Caryn Rabin. It had been genetically altered to minimize the chance of rejection from Bennett’s body and had been screened several times for pathogens.
“It was surprising. That pig is supposed to be clean of all pig pathogens, and this is a significant one,” Mike Curtis, CEO of eGenesis, a competing company also breeding pigs for transplant organs, tells MIT. “Without the virus, would Mr. Bennett have lived? We don’t know, but the infection didn’t help. It likely contributed to the failure.”
The tests conducted on the pig were done in its snout, and only could detect active infections, per the Times. The virus was later found lurking in the pig’s spleen.
“It’s a latent virus and hard to detect,” Joachim Denner of the Institute of Virology at the Free University of Berlin, who led a study on pig hearts transplanted into baboons, tells MIT. “But if you test the animal better, it will not happen. The virus can be detected and easily removed from pig populations, but unfortunately they didn’t use a good assay and didn’t detect the virus, and this was the reason. The donor pig was infected, and the virus was transmitted by the transplant.”
Denner says the patient was sick before the transplant, which also played a role in his death.
“This patient was very, very, very ill. Do not forget that,” he tells the publication. “Maybe the virus contributed, but it was not the sole reason.”
Transmission of viruses from animals to humans is a concern for such transplants, reports the Times. If a virus adapts inside a patient and spreads to doctors and nurses, some fear it could trigger another pandemic, per MIT. But experts believe the type of virus found in Bennett’s donor is incapable of infecting human cells, the publication reports.
Despite Bennett’s death, the transplant was largely considered a success, and researchers plan to continue studying how to use animal organs to save lives.
“This doesn’t really scare us about the future of the field, unless for some reason this one incident is interpreted as a complete failure,” Dr. Griffith tells the Times. “It is just a learning point. Knowing it was there, we’ll probably be able to avoid it in future.”
Markos
sõnum 10.05.2022 19:44:15 vasta tsitaadiga
Kindlasti p6hjustab koroonaviirus ainult nohu, kuid ärge pärast tulge rääkima, et füüsiline v6imekus on langenud ja kaks trepiastet v6tavad v6hma vms.
Aga noh, mida mina ka tean.
No ei ole, inimesed on erinevad, vastasel juhul oleksid kõik ühtemoodi haiged või siis ühtemoodi terved, aga ei ole. Nii nagu intellektuaalsed ja füüsilised võimed varieeruvad, teeb seda ka tervis üleüldisemalt. Mõni saab radiatsioonist vähi, teine samades tingumustes olnu elab kõrge vanaduseni, probleemideta, kuigi viibisid samas keskkonnas, ning said ka parameetritelt võrreldava doosi kiiritust. Ma sain viiruse, haigeks ei jäänud, sümptomeid polnud, test oli punane. Trepist käimine hingeldama ei võtnud ei enne, ega ka pärast. Potentsiaalse "põdemise" ajal viskasin hoovis mitu tundi lund.
degrass
degrass
sõnum 10.05.2022 20:03:28 vasta tsitaadiga
Kas HV ka erilistele kasutajatele darwini vms auhindu jagab?
All it took was for a lot of seemingly decent people to put the wrong person in power, and then pay for their innocent choice.
Markos
sõnum 10.05.2022 21:52:36 vasta tsitaadiga
degrass kirjutas:
Siin on neid "erilisi" veelgi, kes pole isegi nakatunud, tihedast kokkupuutest hoolimata, lihtsalt vedamine ? Oma lähenemises vaatad kogu asja vaid ühte tahku, jättes kõrvale kõik muu, peamise aspektina selle, et me ei tule ühelt ja samalt koosteliinilt.
degrass
degrass
sõnum 10.05.2022 22:09:34 vasta tsitaadiga
Markos, oled sa sellele kunagi mõelnud, et maailm ei ole selline, nagu me arvame selle olevat? See mida me tajume on ainult illusioon, meie meelepete? Oled sa kunagi mõelnud sellele, et äkki sa eksid ja saad asjadest valesti aru?
SSD
SSD
sõnum 11.05.2022 01:59:59 vasta tsitaadiga
degrass, Ei. Ei ole nii mõelnud ja ei usu seda jama.
Pomeransts on odav. Eks see Isamaa on ennegi müügiks olnud. Elamisload jne. Kahju.
Kommentaarid: 314 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 267
Markos
sõnum 11.05.2022 15:17:38 vasta tsitaadiga
degrass kirjutas:
Olen mõelnud, samas poevad millegipärast kivi alt välja alati tegelased, kes teavad täpselt, kuidas asjad käivad. Kõik inimesed eksivad, aga, miks sina arvad, et sina ei eksi ? Empiirilised vaatlused kinnitavad, et sinu õpikuteooria on õige vaid osaliselt, sest reaalses elus on kuhjaga variantsioone, mis sellele ei allu. IT insenerina kohtan ma tihti paberi peal tehtud asju, mis peaksid töötama, kuid reaalsus on see, et asjad lähevad p*rse ja keegi ei tea miks.
napoleon
Unknown virus
napoleon
sõnum 11.05.2022 15:25:00 vasta tsitaadiga
Eksimine on inimlik. Aga insener peaks ka seda teadma, et kui on oht viga teha tasub see teha kindlamale poolele
Markos
sõnum 11.05.2022 15:35:32 vasta tsitaadiga
napoleon kirjutas:
Ei ole päris 1:1 võrreldav, kuid ilmestamiseks, miks teooriad ja praktika teinekord tublisti lahknevad. Mõne inimese kindlast kõneviisist võiks järeldada, et inimorganismi toimimine on 101% selge ja läbi uuritud, aga ei ole ju, vastasel korral ei peaks me vaktsiine ega ravimeid testima, piisaks, kui algandmed arvutisse sisestada ja väljund oleks, kas toimib või ei toimi. Mul on siin covidi osas seinast seina tulemused, mis võiks öelda, et õigeid, ega valesi vastuseid ei ole.
sõnum 18.05.2022 21:49:32 vasta tsitaadiga
Vana, kuid juhtusin eile lugema. Võinuks arvata, et tippsport koos dopingu ja steroididega mõjub vastupideselt, kuid...
Tour de France cyclists live six years longer
Going by the amount of reports on doping use during the Tour de France, you'd expect that the competitors are more likely to have a shorter life than us ordinary mortals. But according to researchers at Paris Descartes University, the opposite is the case. Their epidemiological study, published in European Heart Journal, suggests that cyclists who take part in the Tour de France live at least 6.3 years longer than the average French male.
https://www.ergo-log.net/tour-de-france-cyclists-live-six-years-longer.html
It would seem that genetics and training factors together outweigh the negative effects of doping.
Meta-analüüs liha ja südamehaiguste kohta.
Multiple previous studies have linked red meat consumption to cardiovascular disease risk in the general population. However, newer research has found most of those associations seem to be the result of other unhealthy behaviors of meat eaters compared to people that eat less red meat, such as smoking, a higher bodyweight and an overall poorer diet.
This new meta-analysis of cohort studies adds to the evidence that red meat consumption is not as clearly associated with cardiovascular disease as previously thought. Red meat consumption had variable associations with specific cardiovascular disease risks but no significant relation with total cardiovascular disease mortality risk.
The researchers had no reported conflicts of interests.
These results align with randomized controlled trial data: controlled experiments generally find few or no negative effects of eating unprocessed red meats.
Reasonable intakes of unprocessed red meats, such as pan fried beef or grilled steak, in the context of an overall healthy diet are unlikely to constitute a major health risk, but I would still avoid processed red meats, as they offer no benefits and greater theoretical risks compared to unprocessed red meats.
Associations of the consumption of unprocessed red meat and processed meat with the incidence of cardiovascular disease and mortality, and the dose-response relationship: A systematic review and meta-analysis of cohort studies
https://pubmed.ncbi.nlm.nih.gov/35491892/
napoleon
Unknown virus
napoleon
sõnum 22.05.2022 17:16:35 vasta tsitaadiga
Kas keegi teab, palju on vererõhku mõõtes erinevus kas mõõta täpselt nii nagu aparaadi juhendis kirjas ehk istudes ja käsi lauale toetades või mõõta siis kui inimene on voodis pikali? Eeldame, et tegelik vererõhk on sama kuigi ilmselt on tegelik ka voodis pikali olles pisut madalam.
sõnum 22.05.2022 18:40:29 vasta tsitaadiga
napoleon kirjutas:
Ühel juhul saad reaalse vererõhu, teisel juhul lihtsalt numbri millega pole sul midagi peale hakata.
Reaalne kogemus lähedase peal olemas…erinevus võib olla 2-3x, absoluutnumbrites siis.
degrass
degrass
sõnum 22.05.2022 19:42:22 vasta tsitaadiga
napoleon kirjutas:
Ma ei oska täpselt vastata, kuid r6hk s6ltub k6rguse erinevusest v6rreldes südamega. Südame k6rgusel on sul üks tulemus, 30cm allpool teine.
netcat
netcat
sõnum 22.05.2022 22:30:36 vasta tsitaadiga
Aga kuidas siis lamavatel haigetel vererõhku mõõdetakse?
degrass
degrass
sõnum 22.05.2022 22:44:01 vasta tsitaadiga
netcat kirjutas:
Kui sa istud, siis mansett asetatakse südame k6rgusele, lamades samuti?
SSD
SSD
sõnum 22.05.2022 22:48:13 vasta tsitaadiga
Kolmapäeval saab naine 24h aparaadi külge 150-100 oli vererõhk. icon_neutral.gif
sõnum 23.05.2022 22:32:05 vasta tsitaadiga
Mis arvate, päris julge otsus Uus Meremaalt.
Many countries will monitor the results of New Zealand's plan to ban sales of tobacco to anyone born after 2009. Chris McCall reports.
This year, New Zealand will launch a bold plan to eliminate smoking and eventually render sales of tobacco completely illegal. The key element of the plan is the introduction of a so-called Smokefree Generation, meaning anyone born on or after Jan 1, 2009, will be banned from ever buying tobacco products. Proponents say it is achievable and realistic. Critics say it could badly backfire, make banned smoking glamorous and tempting, or fuel an already burgeoning black market, reminiscent of the one in alcohol that started in the USA a century ago under prohibition.
https://www.thelancet.com/journals/lancet/article/PIIS0140-6736(22)00925-4/fulltext
lexo
lexo
sõnum 23.05.2022 22:39:38 vasta tsitaadiga
Üldiselt arvan, et sellised lauskeelud on harva edukad. Eriti siis, kui toode on lähiümbruses (s.h. lihtsalt ühe vanema inimese kaugusel) endiselt kättesaadav.
sõnum 23.05.2022 23:18:53 vasta tsitaadiga
Seal kirjas, et kättesaadavust piiratakse ka.
Taani ja Malaisia samuti plaanivad:
The Danish health ministry said its proposal would mean that no one born in 2010 or later would ever be able to buy tobacco products. However, the proposal still requires negotiation with parties in parliament and with the EU, the ministry said. Malaysia has announced plans for a new law this year to anyone born after 2005 smoking cigarettes, in what it has called a Generation End Game.
This case report describes a patient in Sweden who had an out-of-hospital cardiac arrest and received defibrillation with an automated external defibrillator delivered by a drone
ykshuntka
ykshuntka
sõnum 25.05.2022 00:19:00 vasta tsitaadiga
Eesti noored juba kasutavad moodsaid ja minu jaoks rõvedaid eauruteid tubaka asemel.
Kommentaarid: 53 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 47
ahoioi
sõnum 25.05.2022 12:54:02 vasta tsitaadiga
On kunagi ükski kuiv seadus pidanud?
napoleon
Unknown virus
napoleon
sõnum 25.05.2022 17:42:13 vasta tsitaadiga
ahoioi kirjutas:
Kui konkreetselt tubakast rääkida, siis selle valmistamine on mõnevõrra keerulisem kui vägijoogi puhul.
Jah, pole raketiteadus ja sellega on tegeletud juba sajandeid, aga peab olema koht kus seda kasvatada ja koht kus seda hiljem töödelda.
SSD
SSD
sõnum 25.05.2022 21:06:18 vasta tsitaadiga
Mu vanaemal kasvas tubakas. Ei teagi miks. Aga ma võtsin lehed ja hakkasin kuivatama. Kui nii enam-vähem kuivanud olid, siis proovisin neid suitsetada. Kehv oli. Ei põlenud hästi ja suits oli ka nagu supiaur. Ühesõnaga pask!
Markos
sõnum 27.05.2022 13:52:43 vasta tsitaadiga
Sisuliselt ütles Eesti kohus, et tõenduslik teaduspõhine lähenemine tuleb prügikasti visata ja sellele tuginedes ei saa otsuseid vastu võtta. Loeb vaid juriidika.
Ma oleks väga üllatunud olnud, kui kohus oleks midagi muud otsustanud. Kohtu seisukoht, et kõik koroonaga seonduv on pidevas muutuses, on ka aluseks sellele, miks mingi "tõenduslik teaduspõhine" lähenemine antud juhul ei päde. Kui kohus oleks otsustanud, et "tõenduslik teaduspõhine" on ainuõige alus, siis luuakse sellega tuleviku tarbeks pretsedent, mis muudab igasuguse hetkel kehtiva teadusliku põhjenduse dogmaks, sõltumata sellest, kas see mingil hilisemal perioodil ümber lükatakse, või mitte. Selle alusel kedagi süüdi mõista on väga ohtlik. Kui kuriteopaigalt leitakse sinu dna'd, mis on tõenduslik teaduspõhine lähenemine, kas see siis on automaatselt aluseks sinu süüdimõistmiseks, või kaalutakse siiski ka teisi tõendeid, mis võiksid sind sündmuspaigale asetada ?
ykshuntka
ykshuntka
sõnum 29.05.2022 12:06:49 vasta tsitaadiga
Tere
Kas Borrelioosi testile on õige aeg minna 2nädalat peale puugi hammustust?
6päeva möödudes on vara?
ahoioi
sõnum 29.05.2022 13:42:09 vasta tsitaadiga
Numbrilt 1220 peaksid vist kõige paremini selle kohta vastuse saama.
sõnum 29.05.2022 13:44:54 vasta tsitaadiga
Oota kaks nädalat, kui enne seda mingeid visuaalseid ja/või füüsilisi sümptomeid pole tekkinud. Vähemalt nii soovitati meditsiinitöötaja poolt viimasel korral.
M: Intel i5 4590 protsessorid
M: HP Elitedesk 800 G3 SFF
Kommentaarid: 750 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 563
ykshuntka
ykshuntka
sõnum 29.05.2022 15:11:57 vasta tsitaadiga
Tänan.
Pean ikka perearstiga vestlema jah.
Synlab 65€ on natuke palju ise välja köhida.
sõnum 30.05.2022 09:42:26 vasta tsitaadiga
Cancer and a high fat diet: What's the link?
https://www.medicalnewstoday.com/articles/cancer-and-a-high-fat-diet-whats-the-link
netcat
netcat
sõnum 30.05.2022 10:44:02 vasta tsitaadiga
ykshuntka kirjutas:
Tänan.
Apteegis müüakse ka tee-see-ise borrellioositesti mis natuke vähem maksab kui perearst ei taha jutule võtta võid sellest alustada.
Tasub muuseas meeles pidada, et sümptomaatiline ringikujuline punetus, mida mõni arst lausa religioosselt borrellioosi tuvastamise aluseks peab esineb ainult kuni 50% juhtudest. Omas peres on mitu laksu olnud täiesti ilma selleta, üks arenes kuni närvikahjustuseni enne kui jälile saime. Ei maksa sellist viga teha
KillFrenzy
KillFrenzy
sõnum 30.05.2022 10:53:15 vasta tsitaadiga
netcat, mismoodi see töötab?
Arsti juures võeti selle veeniverd.
netcat
netcat
sõnum 30.05.2022 11:24:07 vasta tsitaadiga
KillFrenzy kirjutas:
Pakend sisaldab: 1 fooliumpakend, 1 testkassett, 1 pipett ja kuivatusaine; 1 pudel 1 ml lahusega, 1 steriilne lantsett vereproovi võtmiseks, 1 kasutusjuhend eesti ja vene keeles.
uus teema   vasta Hinnavaatlus »  Vaba Mikrofon »  Meditsiinivaatlus (vaimne ja füüsiline tervis) mine lehele eelmine  1, 2, 3 ... 271, 272, 273 ... 313, 314, 315  järgmine
