praegune kellaaeg 15.07.2026 09:56:46
eestim33s
28.05.2022 12:01:58
app.adnetmedia.ee ja Bitdefender |
kellelgi kogemusi? Bitdefender püüab selle https://www.hinnavaatlus.ee/ külastades kinni.
False positive Bitdefenderi poolt või on cert valesti konfitud?
Suspicious connection blocked
one minute ago
Feature:
Online Threat Prevention
chrome.exe attempted to establish a connection relying on an unmatching security certificate to app.adnetmedia.ee. We blocked the connection to keep your data safe since the used certificate was issued for a different web address than the targeted on
| Kommentaarid: 8 loe/lisa |
7 :: |
362 |
A.S.
28.05.2022 13:22:20
| Mul igivana FF (51.0.1) all https://app.adnetmedia.ee/js/rp.js (see on mul blokitud) ütleb samuti, et "app.adnetmedia.ee uses an invalid security certificate. The certificate is only valid for the following names: *.readpeak.com, readpeak.com. Error code: SSL_ERROR_BAD_CERT_DOMAIN". Aga kuna on blokitud (tean-tean, olen paha), probleemi pole.
| Kommentaarid: 34 loe/lisa |
34 |
eestim33s
01.06.2022 19:38:37
| Peale HinnaVaatluse veebilehe uuenemist Bitdefender seda enam ei tuvasta.
A.S.
01.06.2022 19:44:54
| Ei tuvasta, sest seda pole enam seal. Ju siis keegi torkis/eemaldas veidikene, probleemne sait ise on aga endiselt "not secure".
34 |
