praegune kellaaeg 30.09.2025 09:59:23
arvutisõber
22.07.2004 17:17:50
Imelik e-mail |
tsitaat: |
Mail Delivery Subsystem <MAILER-DAEMON@aol.com>
Blokeeri Saatja
Lisa Kontaktidesse
Kellele: ................
Lisa Kontaktidesse
Kuupäev: 09:32 22-07-2004
Saada Kalendrisse Ülesandeks
Pealkiri: Returned mail: User unknown
Manused:
nimetu.dat (1KB)
nimetu.dat (1KB)
Lisa Valitud Manused Dokumentidesse
The original message was received at Thu, 22 Jul 2004 02:32:26 -0400 (EDT)
from tartu-cl.partners.ee [194.126.117.194]
*** ATTENTION ***
Your e-mail is being returned to you because there was a problem with its
delivery. The address which was undeliverable is listed in the section
labeled: "----- The following addresses had permanent fatal errors
The reason your mail is being returned to you is listed in the section
labeled: "----- Transcript of Session Follows -----".
The line beginning with "<<<" describes the specific reason
your e-mail could
not be delivered. The next line contains a second error message which is a
general translation for other e-mail servers.
Please direct further questions regarding this message to your e-mail
administrator.
--AOL Postmaster
----- The following addresses had permanent fatal errors -----
<1tcswain50@netscape.net>
----- Transcript of session follows -----
... while talking to air-nc04.mail.aol.com.:
>>> RCPT To:<1tcswain50@netscape.net>
<<< 550 MAILBOX NOT FOUND
550 <1tcswain50@netscape.net>... User unknown
See ka mingi viiruse saadetud e-mail või on see päris veateade ?
_________________ ... |
Kommentaarid: 55 loe/lisa |
53 |
ridariass
22.07.2004 17:38:29
Paistab ikka viirusepoisi kätetöö, kui sa just sinna 1tcswain50@netscape.net ise midagi kirjutand ei ole.
_________________ There is no patch for human stupidity... |
Kommentaarid: 232 loe/lisa |
206 |
arvutisõber
22.07.2004 18:58:20
vaatasin ise ka, et pole ühtegi tuttavat aadressi selles e-mailis
no eks ta viirus vist ole jah, igaks juhuks mõtlesin ka teistelt küsida, kuna saatsin juba päris ammu ühe kättesaamise kinnitusega e-maili, aga siiani pole kinnitust ega e-maili
53 |
Ülo
23.07.2004 16:03:07
Lihtsalt
saadab viirusega nakatatud kirju.
Olen ise postmaster@partners.ee peale mitu hoiatuskirja saatnud, aga mõningatel firmadel on ju kama!
_________________ Errare humanum est. Perseverare diabolicum. |
Kommentaarid: 6 loe/lisa |
obu90210
27.07.2004 10:10:11
Kõige hullem viiruste juures on see, et raiped võltsivad from aadressi. Olen kah paar korda sõimata saanud, et mehed, mis saadate viirusi laiali. Ei ole saatnud! Meiliserveri logis ei ole probleemse kirja kohta märkigi. Tihti on viirused lalai lennanud ka mitte-töö ajal, kui meie tööjaamad kinni.
Ja siis sõimatakse, et mehed, teil on mingi lollakas müügijuht, kes saadab viirusi. From aadress on sales@greif.ee < iseeneses mõista, sellist meilboxi meil polegi.
On ka juhtumeid, kus from aadress on täiesti eksisteeriv aadress. Olenevalt, kas genereerib aadressi domeeni alusel ise, või otsib from aafressireale miskit aadressbookist. Oleneb viirusest.
Tihti saadab firma viirusi reaalselt laiali.
Tihti pannakse nende meiliaadressid from reale.
Väga pahandada ei maksa, enda viirusekontroll ja muu turva asjakohaseks ja ongi muret vähem
Kommentaarid: 4 loe/lisa |
Ülo
27.07.2004 15:25:31
tsitaat: |
See ei ole kõige hullem. Hullem on see, kui korduvatele logidega tõestatud hoiatustele vaatamata ei võeta viirusesaatja masinaga midaki ette. Masina reaalse IP aadressi on alati võimalik kirja päisest kätte saada.
tsitaat: |
Need viirused ei pruugi sinu SMTP serverit üldse kasutada. Piisab et NAT oleks lubatud. Kui veel sõimajaid leidub, nõua väite tõestamist kirja päisete kaudu. Ja kui IP on Sinu masina oma, siis otsi parem see nakatunud masin sisevõrgust ülesse!
Statistikat: Momendil aktiivseid eri tüüpi viiruseid 10. Kõige aktiivsem neist Worm.Bagle.Gen-zippwd (http://www.rainingfrogs.co.uk/index.php?search=num&vid=16455)
lisa lemmikuks |
