lauri
22.01.2022 10:53:20
SD kaardilt andmete taastamine |
Üks SD kaart, mis töötas, kuid enam jutule ei võta. Nagu ikka, on seal peal pildid, mida sooviks kätte saada.
Kaamera kaarti ei tunnista.
Arvuti (Windows) otseselt ei näita.
Tenorshare 4DDiG nimeline programm näitab, et kaart on "süsteemile nähtav".
Asi on nüüd öö otsa skänninud, kuid tulemusi ei ole... veel.
Oskab keegi soovitada mingit lahendust, et pildid kätte saada?
2022-01-22 00:10:00.384 [INFO] Log sdk version: 2, 1, 0, 20-d-4a5e81c
2022-01-22 00:10:00.384 [INFO] Any Data Recovery SDK Version: 2, 2, 0, 839-8-48608e9
2022-01-22 00:10:00.390 [INFO] Mac address: C8-34-8E-60-D1-30
2022-01-22 00:10:00.525 [INFO] Success load config info!
2022-01-22 00:10:00.537 [INFO] EnumDevice enter!
2022-01-22 00:13:08.134 [INFO] [DeviceWinPhys::Read]Fail to read 0x 0, len 4096, read error 1117
2022-01-22 00:13:08.513 [INFO] 1
2022-01-22 00:13:45.806 [INFO] [DeviceWinPhys::Read]Fail to read 0x 0, len 4096, read error 1117
2022-01-22 00:14:23.191 [INFO] [DeviceWinPhys::Read]Fail to read 0x 0, len 4096, read error 1117
2022-01-22 00:14:23.191 [INFO] disk index: \\?\usbstor#disk&ven_generic&prod_storage_device&rev_0819#000000000819&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}, start offset: 4194304, total offset: 3042443264
2022-01-22 00:14:23.670 [INFO] {
"disks" :
"disk_type" : 3,
"index" : 1,
"is_external" : true,
"name" : "Generic STORAGE DEVICE ",
"partitions" :
"bitlocker_status" : 0,
"block_size" : 4096,
"can_read" : true,
"free_size" : 0,
"index" : 0,
"is_lost_partition" : false,
"is_system_partition" : false,
"mount_point" : "",
"name" : "BADTZMARU",
"system_type" : 6,
"total_size" : 15927345152
"total_size" : 15924142080
2022-01-22 00:14:23.670 [INFO] EnumDevice end!
2022-01-22 00:15:44.408 [INFO] [DeviceWinPhys::Read]Fail to read 0x 0, len 4096, read error 1117
2022-01-22 00:15:44.845 [INFO] Scan disk index 1, partition index 0, scan type 1, scan data type 3, system type 6
2022-01-22 00:15:44.845 [INFO] Scan disk Generic STORAGE DEVICE is external 1
2022-01-22 00:15:44.845 [INFO] Scan partition BADTZMARU, size 15189 MB, letter
2022-01-22 00:15:44.848 [INFO] Fat32FormatScan constructed.
2022-01-22 00:15:45.208 [INFO] Fat32FormatScan init.
2022-01-22 00:15:45.340 [INFO] Original DBR is correct(sectors_per_cluster: 64)
2022-01-22 00:15:45.340 [INFO] Backup DBR is correct(sectors_per_cluster: 64)
2022-01-22 00:15:45.528 [INFO] Fat32FormatScan start scan.
2022-01-22 00:15:45.531 [INFO] progress_sub_type(2)
2022-01-22 00:16:22.776 [INFO] [DeviceWinPhys::Read]Fail to read 0x 30a88000, len 4096, read error 1117
| Kommentaarid: 90 loe/lisa |
80 |
Mnator
22.01.2022 11:21:14
| mäletamsi kunagi toivos väitis, et on mingi eritehnika selleks soetanud
| Kommentaarid: 1157 loe/lisa |
724 |
arny
22.01.2022 19:37:33
see 4ddig on mõttetu asi kah. Proovisin hiljuti ja leiab küll mingit staffi aga taastada väga ei oska, 90% asjadest on vigased või failid mida avada ei saa. Fotode puhul ja sd kaartidega töötas viimati kõige paremini wondershare toodang, kallim kui see 4ddig aga töötab kah paremini.
| Kommentaarid: 10 loe/lisa |
9 |
lauri
22.01.2022 20:26:08
Hetkel on asi toivos'e käes. Eks näis.
80 |
otus
23.01.2022 01:48:48
Kaardil mingi nimi on kah ?
Lõhnab "ämbliku" ehitamise järgi.
lauri
23.01.2022 10:04:51
Oli mingi x+n aastat vana Sandisk. Osad pildid sai päästetud, päris suur osa on "katki". Mälukaardil oli liiga palju "bad blocke". Pidi veel edasi vaatama.
80 |
toivos
23.01.2022 21:05:56
| otus kirjutas: |
Lõhnab "ämbliku" ehitamise järgi. |
Ega "ämblik" imevahend ole. Aitab teinekor kui seade statsionaarselt ei tööta. Aga kui lugejas 70%-i ECC ei paranda, siis kardan et ei aita "ämblik" ka.
_________________ Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt. |
| Kommentaarid: 70 loe/lisa |
66 |
otus
24.01.2022 00:24:12
| Ega ei olegi. mida sa kulunud nandiga ikka teed.
toivos
26.01.2022 20:12:31
Nand tegelikult kulunud ei ole. Vaid osutub, et neljast plane-ist kahel plane-il on lakanud töötamast mõned veerud üle terve kivi. Kivi ise on TLC ja juba tehasest tulnuna on tal vigased veerud plane-del tarkvaraliselt välja lülitatud. Nüüd mingil põhjusel tekkis neid vigaseid veerge veel juurde ja ECC algoritm ei suuda enam seda kadunud infot taastada. Minul esimene flash, mis nii moodi katki läinud on.
66 |
