Jah, Delfil on juba mitu nädalat piss püksis ja veresaun.
Paras aeg pikaajalisi juurde võtta. See low võiks kesta jvähemalt aasta, siis saab end rahuliku tempoga täis süüa. _________________ Liitu Binance'ga Liitu Honey'ga
netcat, miks nad nutavad? Et oleks saanud veidi madalamalt osta? See liikumine, mis praegu toimub on 10-15-20-25 aasta lõikes täiesti köömes. Pole nagu mõtet nutta kui nende pensirahadega just lühiajalisi ei tee.
Mündibüroo on võrreldes meie Delfiga veel üsna optimistlik.
Rug pulls and other scams in the decentralized finance (DeFi) space over the past year have helped the revenue generated by cryptocurrency scams surge 81% in 2021 to hit $7.7 billion.
According to Chainalysis’ 2022 Crypto Crime Report, DeFi rug pulls accounted for 37% of all crypto scam revenue, up from 1% in 2020. In these scams, developers create seemingly legitimate crypto projects to then abscond with investors’ funds.
The firm highlighted that code audits, which could be used to find vulnerabilities allowing scammers to target unsuspecting investors, are not a requirement for a project to list its token on decentralized exchanges (DEXs).
While cryptocurrency scam revenues went up in 2021, they’re still down from the highs seen in 2019, when scammers made nearly $10 billion. The number of deposits to investment scam addresses dropped from 10.7 million in 2020 to 4.1 million in 2021, suggesting there were fewer individual victims.
Uhke värk, et ka krüpto suhtes vastuvõtlikuid ja teadlike poliitikuid on olemas.
Hoiame pöialt, et ka Eestis sellise leiame. _________________ Liitu Binance'ga Liitu Honey'ga
Ethereum’s Hashrate Hits Record High of 1 Petahash
Earlier this month, Ethereum network participants upgraded and implemented the Arrow Glacier upgrade, which delayed the network’s transition to a Proof-of-Stake consensus algorithm. The network’s hashrate has since grown to a record high of 1 petahash.
The figure is equivalent to around 1,000 TH/s, and shows the network’s hashrate has increased 66,125% since March 2016, when hashrate started being recorded on the network. Ethereum’s biggest miner is ethermine.org with 2826 TH/s of hashrate. It’s followed by F2Pool’s 134.8 TH/s and Poolin’s 103.5 TH/s.
There are around 61 mining pools working on the Ethereum network. Once the network moves to a Proof-of-Stake consensus algorithm, what’s known as the Ethereum Ice Age will occur, as mining difficulty will grow exponentially, to the point miners won’t be able to remain profitable.
Jah viimesed ja viimane rida, teie ei saanud sellest aru. miners won’t be able to remain profitable. Ehk aasta, kahe pärast ei saa enam midagi ilmselt. Difficulty lendab pärs lakke _________________ Punktkeevitus patareidele/akudele. Akutrelli/laptopi/e-bike. PM
Ega see diff siis niisama lambist ei tõuse ja võrdlus 2016-ga täitsa mõttetu. Kui lähemalt vaatad siis diff käib sammu hinnaga.
Siin on näha varasemad jääaja tulekud, praegu ei paista sealt veel midagi kätte jõudnud: https://etherscan.io/chart/blocktime _________________ Ma ei saa sellest aru, järelikult on see vale.
Eks see puudutab ikka eraisikuid ka. Aga kurb kui me riik suure hooga endale vett peale tõmbab. Nüüd siis päris suure mõjuvõimuga uudistes ja sajad tweedid uudist linkimas.
Selle asemel võiks aega ja raha panustada desetraliseerituse integreerimiseks praegusesse finantssüsteemi. Piitsa-meetodid vajuvad ajalikku. Tuleb hakata teisiti mõtlema, präänikutega motiveerima. _________________ Liitu Binance'ga Liitu Honey'ga
viimati muutis Kristoferr 02.01.2022 13:27:30, muudetud 1 kord
Kosovo serblased neljas põhjapoolses regioonis ei ole maksnud oma elektri eest alates 1998.-1999. aasta sõja lõpust albaania võitlejate ja serbia relvajõudude vahel.
Nad ei tunnista Priština autoriteeti ning on lojaalsed Belgradile, kirjutas AFP.
Huvitav, palju neid kaevandajaid seal tegelikult on? Tasuta elekter ju.
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
