130 |
Froggy
23.07.2020 23:57:52
| Kus oleks mõistlik /võimalik akut vahetada? Originaal akut vist niisama müügis kuskil ei leidu, kui ise vahetada tahan?
| Kommentaarid: 29 loe/lisa |
Raetsep
24.07.2020 09:22:19
| Froggy kirjutas: |
| Kus oleks mõistlik /võimalik akut vahetada? Originaal akut vist niisama müügis kuskil ei leidu, kui ise vahetada tahan? |
Viru Fonum vahetas mul kokku ca. 40€ eest ära. Uut akut tuli ca. kuu oodata, sest need tulevad ma ei tea kust, aga muidu tip-top.
| Kommentaarid: 26 loe/lisa |
25 |
Froggy
05.08.2020 19:43:45
Tartus selline koht täitsa olemas. Lähen uurin
E: Läksin seda teed et saatsin läbi oneplusi kodulehe akuvahetusse. Kui ups'i uimerdamine väljajätta siis väga kiire asi. Pluss läks garantii alla.
newarvuti
09.07.2021 09:27:11
Android 11 Open Beta on saadaval: https://forums.oneplus.com/threads/oxygenos-android-11-open-beta-1-for-oneplus-6-6t.1464997/
Muudatuste nimekiri:
System
- Updated to OxygenOS 11 version
- Fresh new UI visual design brings you a more comfortable experience with various optimizations of details
- Since this is a big Android update with multiple new features, the upgrade process might be a little longer, please be more patient.
Game Space
- Newly added gaming tools box for convenient switches of Fnatic mode. You can now choose three ways of notifications: text-only, heads up, and block, just for your immersive gaming experience
- Newly added quick reply feature in a small window for Instagram, WhatsApp, and Telegram (Enable it by swiping down from upper right/left corners of the screen in gaming mode)
- Newly added mistouch prevention feature. Enable it, swipe down from the top of the screen, click and the notification bar will pop out
Camera
- Updated the camera UI and optimized some of the function paths to offer a more convenient operation
Ambient Display
- Newly added Insight clock style, a joint creation with Parsons School of Design. It will change according to the phone usage data (To set: Settings > Customization > Clock on ambient display)
- Newly added Canvas feature that can automatically draw a wireframe picture based on a lock screen photo on your phone(Path: Settings - Customization - Wallpaper - Canvas - Choose photo preview and it can be generated automatically)
Dark Mode
- Added a shortcut for Dark Mode, you can pull down the Quick Settings panel and find it
- Supported automatically enable by time range (path: Settings - Display - Dark Mode - Turn on automatically - Automatically enable from sunset to sunrise / Custom time range)
Shelf
- Newly shelf interface design, the interface is clearer
- Added weather widget, animation effect smarter
| Kommentaarid: 94 loe/lisa |
kjaups
MeesKesTuliMetsast
28.08.2021 14:10:46
OOS11 üle nädala nüüd peal ja vähe toores too elukas.
Garmini kellaga suhtlus pidevalt katki, kella pealt teadete kustutamine ei taha töötada.
Androidauto laeb autoga ühendades kuni minuti üles, ennem seda uuendust sisuliselt kohe kaabliga ühendades.
Split screen ei käivitu või ei lase ekraani jaotamist muuta või jääbki pärast pool ekraani nö katkiseks, et seal ainult taustapilt ja äppi ennast ei mana.
_________________ M: korter Mustamäel
YAGA müügiputka |
142 |
newarvuti
30.08.2021 08:54:35
| kjaups kirjutas: |
| Garmini kellaga suhtlus pidevalt katki, kella pealt teadete kustutamine ei taha töötada.. |
Mul OP6 peal oli Garmini kellaga ühendusmured (aeg-ajalt kadus ära), aga OP6T-l ei ole veel olnud.
Network reset sai proovitud 6-l, ei aidanud. Samas 6T-l sai Android 11 pandud clean installina peale, ehk see tekitas erinevuse.
kjaups
MeesKesTuliMetsast
04.10.2021 16:10:34
Viimane bugfix 11.1.1.1 on ikka täielik ikaldus. Mahukamad asjad hanguvad. Mängida midagi, siis käib korralik lääg läbi ja jõnkab. Isegi Duolingo laeb vahepeal lehte
Ennem sai mängule teha ekraani poolitus ja samal ajal netist otsida midagi - nüüd kooma palat.
YAGA müügiputka |
142 |
fgth
15.10.2021 13:40:05
See Oxygen 11 muutis 3a vana Oneplus 6 aku kestvust mitmeid tunde lühemaks, nüüd tuleb vist rollbackiga tegelema hakkama
| Kommentaarid: 69 loe/lisa |
67 |
Froggy
15.10.2021 18:11:40
| fgth, Enda sama vanal OP6'l ei ole küll midagi märganud.
masmre
16.10.2021 20:27:40
| Mul läks pigem paremaks hoopis. Ennem mõtlesin juba aku vahetamise peale ja sai äragi ostetud, aga nüüd vaatan, et kestab vanaga ka veel.
| Kommentaarid: 82 loe/lisa |
76 |
