sõnum |
Kännuämblik
Kommentaarid: 12 loe/lisa |
12 |
27.02.2021 14:04:00
Tuli äsja kiri.
tsitaat: |
You can now place a deposit for Starlink which will hold your place in line for future service.
Starlink users currently see data speeds vary from 50Mb/s to 150Mb/s and latency from 20ms to 40ms in most locations. As we launch more satellites, install more ground stations and improve our networking software, data speed, latency and uptime will improve dramatically.
The Starlink team will provide periodic updates on availability as we launch more satellites and expand our coverage. Depending on your location, it may take a year or longer for Starlink to be available in your area.
To check availability for your location, visit Starlink.com and re-enter your service address. Thank you for your interest in Starlink and your continued support!
PLACE DEPOSIT |
_________________ HV valuutakalkulaator |
Kommentaarid: 461 loe/lisa |
12 :: |
7 :: |
356 |
mega
27.02.2021 16:20:05
Tuli jah, küsivad $99. Kodulehel aadressipäringule andis 2022 ühendamise võimaluseks. Ei teagi kohe, kas raatsin praegu raha alla panna. Samas reklaamivad seda, nagu saavad vaid kiiremad! Krt, nagu mõni petukiri juba...
_________________ - censored - |
Kommentaarid: 268 loe/lisa |
235 |
kala1
27.02.2021 16:29:43
mega, see deposit värk vist juba viimaste seeria tesla autode ajast
_________________ The German soldier has impressed the world, however the Italian Bersagliere soldier has impressed the German soldier. |
Kommentaarid: 48 loe/lisa |
44 |
27.02.2021 17:17:59
Hoiab arengutel silma peal. Viimane kogemus satiinternetiga oli paarkümmend aastat tagasi dialup üleslaadimine, sat allalaadimine.
Kommentaarid: 255 loe/lisa |
223 |
lurr
27.02.2021 19:30:14
deposiidi saad tagasi kui keeldud teenusest. Ei kaota sa seda raha.
Iseenesest näitab deposiit potentsiaalsete liitujate hulka, ses mõttes igati mõistlik firma poolt vaadatuna.
panin isegi selle soti sisse, näis.
Kommentaarid: 123 loe/lisa |
111 |
maty
27.02.2021 19:36:50
panin ka 99usd sisse
Kommentaarid: 73 loe/lisa |
63 |
napoleon
Unknown virus
27.02.2021 19:40:48
Kuidas see üldse tehniliselt töötab? Nagu aru saan, siis need satelliidid lendavad suht madalal mitte geostatsionaarsel orbiidil ehk Maa pealt vaadatuna ei püsi üldse paigal. Toimub siis pidev "roaming" satelliitide vahel?
Kommentaarid: 76 loe/lisa |
59 |
maty
27.02.2021 19:47:54
viimati muutis maty 27.02.2021 21:16:25, muudetud 1 kord |
63 |
12 :: |
7 :: |
356 |
napoleon
Unknown virus
27.02.2021 20:09:36
Tanel kirjutas: |
Kasutage youtube tage palun |
ot: |
HV foorumis tundub, et media tag toimib paremini kui youtube. Youtube tag-ga näiteks ei saa määrata, et kindlast kohast mängima hakkaks
59 |
KillFrenzy
27.02.2021 20:34:38
Jep, võiks eemaldada youtube tagid ja meda tagi ümber nimetada kasvõi.
_________________ M: SFP Telia GPON võrgu jaoks - 40€ |
Kommentaarid: 151 loe/lisa |
133 |
kenkauksi
03.06.2021 15:34:22
mega kirjutas: |
Tuli jah, küsivad $99. Kodulehel aadressipäringule andis 2022 ühendamise võimaluseks. Ei teagi kohe, kas raatsin praegu raha alla panna. Samas reklaamivad seda, nagu saavad vaid kiiremad! Krt, nagu mõni petukiri juba... |
Ilmselt nõudlus suurem kui tootmisvõimsus ja deposiidiga saab kiiremini kätte. Lisaks saavad infot kus suurem nõudlus on ja kiiremini asjatada vaja.
Ise veel oma deposiiti sisse pannud ei ole, aga kindlasti lähiajal teen ära.
_________________ Cheap rotating residential proxies
Multichain cryopto payments made easy |
Kommentaarid: 178 loe/lisa |
158 |
Kännuämblik
12 |
lurr
01.07.2021 09:02:45
Kuskilt jooksis läbi uudisnupp, et ta peab enne teenuse pakkumist saama load riikide vastavatelt ministeeriumidelt/ametitelt - see saab olema parajalt mahukas töötükk.
111 |
kaabakas
01.07.2021 09:24:41
Bürokraatia üldiselt on ajamahukas, aga mitte töömahukas. Iseasi, kas ja kui palju neid lube ikkagi vaja ongi.
Aga Eloni lubaduste peale pole mõtet tähelepanu kulutada. Jah, asjad tal kogu aeg arenevad ja mõnikord uskumatu jõu ja kiirusega, aga sellest, millal tal midagi valmis saab, pole tal õrna aimugi.
https://www.smbc-comics.com/comic/fsd
Kommentaarid: 103 loe/lisa |
93 |
Kännuämblik
12 |
Maldur
03.07.2021 13:40:40
Oleks katusele kinnitanud, poleks midagi uudist, aga kui oma näo ette panna siis muidugi ...
Kommentaarid: 4 loe/lisa |
15.07.2021 14:58:36
Paistab et pole veel postitatud Starlinki kasutajate foorumi aadressi:
https://starlinkforum.net
Sealt leiab üht-teist lugemist-vaatamist.
Ja siin on huvitav kaardirakendus kõigi Starlinki satelliitide asukohtadega reaalajas ja teadaolevate maa-jaamadega: https://satellitemap.space/
Kommentaarid: 33 loe/lisa |
12 :: |
7 :: |
356 |
12 :: |
7 :: |
356 |
opusdeus
27.09.2021 08:45:43
mega kirjutas: |
Ilmselt latentsus on ainuke puudus, aga mitte nii suur kui tänasel SAT internetil. Panin ka kirja. Justnimelt "viimast miili" silmas pidades. Enne jõuab see Starlink kohale kui EV "viimane miil" realiseerub... |
Viitega aitab neid Syntropy - web 3.0 ettevõte, mis viis edukalt ka testi läbi. Mediumis artikkel selle kohta -https://medium.com/syntropynet/syntropy-starlink-testing-results-9263fd3f22f7
12 :: |
7 :: |
356 |
avrn
01.11.2021 19:41:17
Eestis ka mõni ühendus on?
Kommentaarid: 5 loe/lisa |
01.11.2021 22:59:30
avrn kirjutas: |
Eestis ka mõni ühendus on? |
Kui oleks, siis võrdluses fixed internet, mille alla kuuluvad kõik eesti kaabli internetid ja ka fixed koduinternetid 4G baasil.
Võibolla keskmise kiirusetesti alusel olekski üks 100M Starlink kasutaja edetabeli ees.
Keskmiselt tellitakse eestis koju 50M nett, kes saab vähem, saab vähem, kes saaks rohkem, ka üle 100 alati ei lähe, isegi kui kuni Gbit võimalik.
Ja kuna Eestis algavad paketid hetkel vist 5Mbit/s kiirustest, standard ühe kodukasutaja netiks on 10Mbit/s kus on tv ja arvuti, siis kiiremad ühendused kus perekond, võetakse ca 50-100Mbit/s
Arvestagem ka hajaasustust ja aeglaseid 4G ühendusi ning ADSL ühendusi.
Paistab igati loogiline number.
Küsimus on pigem, kas see Starlinki kiirus ongi nö max downlink IGALE kasutajale või on tegemist jagatud resursiga nagu mobiilsidevõrgus? Paar kiirt eesti suunas, 1x kasutaja max see kiirus, teine kasutaja oma täiskoormusega :2 kiirus jne?
Siis saaks selgeks ka nende teiste sateliidipakkujate kiiruse max näitajad.
Ma oleks ilmselgelt antud paketi klient kui ma kitsedega kasahstani mäestikus peaks kükitama. Antud hetkel arvestades hinda ja tehnikat ning ka kõike äärmuslikemaid olusid, veel mitte.
Ehk tegemist on speedtestide ja kasutajate tulemiga, mitte tehnilise võimekusega.
223 |
